Challenger Tractor MT955E MT965E MT975E Parts Catalog 573951D1
Brand: Challenger
Model: Challenger MT955E, MT965E, MT975E Tractor
Serial Number: FXXX1001 - LXXX9999
Part Number: 573951D1
Number of Pages: 2778 Pages
Mt900e
2016
Engine Serial Number Range Z37990-B62918
Engine Serial Number Range A73943-B68579
Engine Serial Number Range A65958-C73092
Coolant Piping
Coolant Pump And Thermostat
Electronic Engine Management
Intake Manifold
Exhaust Manifold
High Pressure Turbocharger
Low Pressure Turbocharger And Icac
Starting From Engine Serial Number B62509
Exhaust Aftertreatment
Oil Cooler And Filter
Oil Pump And Sump
Ccv And Intake Group
Fuel Injection System
Fuel Filters
Engine Assemblies
Hydraulic Lash Adjustment
Starting From Engine Serial Number B67070
Valve Rocker Cover
Up To Engine Serial Number B67050
Timing Gears And Housing
Flywheel And Housing
Crankshaft And Pistons
Control Units
Engine Overhaul Parts
Alternator Mounting Group, 220 Amp
Belt Tensioner
Accessory Drive Group
Cooling Group
Cooler Assembly
Fuel Lines Group
Fuel Water Separator Filter Assembly
Engine Oil Service Group
Oil Drain Valve Group
Exhaust Group
Tier 4, Final Compliant
Less Regulated Countries
16.8 L Engine
Def
Diesel Exhaust Fluid Tank Group
2017
Emissions Arrangement
Water Jacket Heater Group, 120 Volt
Water Jacket Heater Group, 240 Volt
Coupling Group, Engine Drive Coupler
Front Axle Assembly, High Capacity Differential
Differential Assembly, Front, High Capacity
Shim Pack Kit, Bz
Shim Pack Kit, Am
Axle Assembly, Final Drive
Housing Assembly, Differential
Park Brake Assembly
Rear Axle Assembly, High Capacity Differential
Differential Assembly, Rear, High Capacity
Parking Brake Assembly
Axle Lube Lines Group
Axle Lube Filter Assembly
Block Assembly, Axle Lube
Differential Lock
Plug Group
Plug Installation Without Creeper-Differential Lock
Special Application
Frame And Suspension
Frame Group, Front
Frame Group, Center
Articulation Link Assembly
Engine Mounting Group
Cab Mounting Group, Basic
Transmission Mounting Group
Steering Column Assembly
Steering Control Group With Mounting
Hydraulic Steering Group
Steering Pilot-Electric Assembly
Steering, Priority Valve Assembly
Hydraulic Steering Valve Lines
Steering Group
Electric Steering, Priority Valve Assembly
Steering Pilot Assembly
Hydraulic Steering Cylinder
Steering
Housing Assembly, Front
Housing Assembly, Rear
Case Assembly
Powertrain Bolt List
Transmission Filler Group
Lock
Axle Lube Standpipe Group
Driveshaft, Pto Articulated
Driveshaft, Pto Rear
Needle Bearing Carbonitride Half Differential Service Kit
Intermediate Drive Shaft Support
Solenoid Valve Assembly, 3 Way
3 Way Solenoid Valve
Clutch Group
Transfer Gear Group
Pump Drive Group
Cover Group, Transmission
Yoke Group, Input
Yoke Group, Output
Valve Group, Mdl-C, 2011
Relief Valve Group-C
Case Assembly, Rear
Spool Assembly
Sight Gauge
Front
Rear
Service Kit
Input Shaft
Planetary
Transmission Filter
Hydraulic Filter Pressure Switch Assembly
Front Case
Without Power Take Off
Axle Lube Lines Group, Without Pto
Hydraulic Pump, Triple
Hydraulic Control
Service Brake Control Assembly
Brake
Valve-Brake Charge
Park Brake Valve Group
Park Brake Valve Assembly
Accumulator Assembly, Service Parts
Brake Lines Group
Brake Group, Hydraulic Trailer Brake, With Drawbar
Hydraulic Trailer Brake Valve Assembly
3 Point Hitch
With Hydraulic Trailer Brakes
Completing Arrangement, Without Hydraulic Trailer Brake
Park Brake Cable Installation
Compressed Air System
Mt855, Mt865, Mt875
Air Tank Adapter Assembly
Air Dryer Group, B
Air Compressor Pressure Relief Valve Assembly
Air Compressor Group
Cap, M18 Tube
Air Tank Group, Mt900
Air Pressure Service Kit
4 Bank Valve Group
Dust Cover Kit, 1 2 Coupler
Implement Inlet Valve Assembly
Ls Plug Kit
Rear Stack End Cover
Without 3 Point Hitch
Valve Control Service Kit
Standard Compensator Spring Kit
Proportional Solenoid Kit
Directional Solenoid Kit
Coupler Interface Seal Kit
Coupler Kit, .050 Inch
1 2 Inch Coupler Interface Seal Kit
Handle Kit
Poppet Valve Kit
Relief Valve Kit
Relief Valve Seal Kit
Electrical Group, Husco Lsvc
5 Bank Valve Group
6 Bank Valve Group
4 Implement Valve Group, With Hitch
Valve Group, Implement, Standard Flow
Hitch Lift Valve Assembly
Poppet Valve Kit, Hitch
Section Interface Seal Kit
Tie Rod Kit, 4 With Hitch
5 Implement Valve Group, Hitch
4 Bank Valve Group, 3 4 Inch Coupler
Implement Valve Group, Hf, Top, Mid, .075
Coupler Kit, 3 4
3 4 Inch Coupler Seal Kit
3 4 Inch Coupler Interface Seal Kit
Dust Cover Kit, 3 4 Coupler
Bottom High Flow 3 4 Inch Implement Valve Assembly
6 Bank Valve Group, 3 4 Inch Coupler
Reducing Valve Kit
Bracket Assembly, Straight, Short, 1.00 P-Clip, Reversed U
4 Implement Valve Coupler, With 3 Point Hitch
5 Implement Valve Coupler, With 3 Point Hitch
Guard, 4 Implement Valves
Guard, 5 Implement Valves
Guard, 6 Implement Valves
4 To 5 Implement Valve Conversion Kit
5 To 6 Implement Valve Conversion Kit
5 Implement Control Group
6 Implement Control Group
Implement Lines Group, 4 Hitch
Top And Middle I 2 Inch Implement Valve Assembly
Implement Lines Group, 5 Hitch
4 To 6 High Flow Valve Conversion Kit
5 And 6 Implement Control Kit
High Flow Compensator Spring Kit
4 To 5 Implement Valve Conversion, With 3 Point Hitch
Remote Coupler Valve Assembly
3 4 Inch Power Beyond Coupler Group
3 4 Inch Bottom Implement Valve Conversion Kit
3 4 Inch Top And Middle Implement Valve Conversion Kit
1 2 Inch Bottom Implement Valve Conversion Kit
Threaded Coupler Conversion Kit
1 2 Inch Top And Middle Implement Valve Conversion Kit
High Flow Valve Bottom With Threaded Ports
Valve Cover Group
Male Coupler Group, Vep 15
Hydraulic Gear Pump, 36cc
Hydraulic Piston Pump, 85cc
Pump Control Valve Group
Load Shuttle Blocking Valve Assembly
Solenoid Valve Assembly, Normally Open
Implement
4 Bank Valve Group, High Flow, Threaded Port
High Flow Valve With Threaded Ports
6 Bank Valve Group, High Flow, Threaded Port
High Flow Stucchi 4 Valve Threaded Coupler Group
Lines
Oil Cooler Heat Exchanger
Drawbar And Hitch
Case Drain Arrangement, Flat Face, Hitch
Case Drain Arrangement, Pioneer, Hitch
Plug
Plug Installation Without Implement Case Drain
126 Cc
Hydraulic Piston Pump, 126cc
Transmission Lines Group
Implement Valve Drain Lines
Implement Lines Group, Valve With Hitch
Pump Group, 85cc
Valve
Pto
Hitch
High Flow 6 Valve Threaded Coupler Group
Hydraulic Heater Group, 120 Volts
Hydraulic Heater Group, 240 Volts
Hydraulic Tank Group
Fender Light Group, Rear
Worklight
Lighting Group, Front Fender, Standard
Lighting Group, Front Fender, Hid
Worklight, Hid
Lighting Group, Rear Fender, Hid
Pto Switch Group
Antenna Base Assembly
Trailer Wiring Group
Trailer Jumper Wiring Group
Electrical Group, Sauer Mc050-045
Pressure Switch Assembly, 10700 Kpa
Differential Lock Switch
Battery Cable Clamp Kit
Backup Alarm Warning Group, Drawbar
Backup Alarm Warning Group, 3 Point Hitch
Powerstrip Assembly
Rotating Beacon Group Installation
Non Ce
Lighting Kit, Deluxe To Double Hid, Field Installation
Worklight, Hid, Right Hand
Hid Lamp
Worklight, Hid, Left Hand
Light, Hid, L1
Light, Hid, R1
Light, Hid, L3
Light, Hid, R3
Rotating Beacon Kit
Rotating Beacon Installation
Rotating Beacon Lamp Assembly
Beacon Lights
Porch Lamp Group
Worklight Assembly, Right Hand
Worklight Assembly, Left Hand
Halogen
Light, Halogen, Short Range
Light, Halogen, Long Range
Light Bezel, Left
Light Bezel, Right
Worklight Light Assembly, Hid, Left Hand
Worklight Light Assembly, Hid, Right Hand
Light Assembly, Left, Hid
Light Assembly, Right, Hid
Light, Halogen, R3
Light Assembly, Left, Double Hid
Light Assembly, Right, Double Hid
Light, Halogen, L3
4 Battery Mounting Group
Battery, Maintenance Free, Wet
Battery Decal Installation
Signal Light Group
Fender Lamp Assembly, Left Hand
Fender Lamp Assembly, Right Hand
Extremity Arm Light Group, Right Hand
Turn Lamp Assembly
Extremity Arm Light Group, Left Hand
Cab Wiring Group
Dome Lamp Assembly
Receptacle Assembly, Power Port, 12 Volts Dc
Intermittent Wiper Switch Assembly, 12 Volt
Vehicle Wiring Group
With 3 Point Hitch
Engine Power Switch Kit
Lighting
Lighting Group, Deluxe
Lighting Group, Hid
Lighting Group, Standard Lights
Bonnet
Hood Lighting Arrangement, Led, Worklight
Lighting Group, Standard Lights, Hid Worklight
Lighting Group, Hid, Halogen Worklight
Lighting Group, Double Hid
Battery Group, With Disconnect
Led
Radio Speaker Group
Radio Antenna Installation
Cab Front Visor Group
Cab Rear Visor Group
Cab Side Visors Group
Window Sun Screen, Left Hand
Knob Kit
Knob Group
Charcoal Filter Baffle Group
Cap, With Lanyard Assembly
Cover Group, Subwoofer
Front Console Service Kit
Access Bar Plug Installation
Transmission Control Group, Shift Handle
Transmission Shifter Control Handle. B
Pushbutton Switch Installation
Arm Pad
Decelerator Control Group
Armrest Group, 4 Valve, With Hitch
Armrest Group, 5 Valve, With Hitch
Armrest Group, 4 Valve, Without Hitch
Armrest Group, 5 Valve, Without Hitch
Armrest Group, 6 Valve, Without Hitch
Basic
Tlv (Toggle Link Vertical)
Seat Group, Training
Trainer Seat, Cloth
Seat Group, Basic
Seat Group, Deluxe
Operator Seat
Seat Group, Deluxe, Leather
Seat Group, Training, Leather
Instructor Seat
Leather Seat Group, Vented
Cab Headliner Assembly
Brake Control Group, With Clutch
Mirror Group, Electric
Falling Object Protective Structure, (Fops)
Cab Roof Group, Non Ce
Weather Insulation Group
Roof Assembly, Inner
A2000 Passive Suspension Service Kit
Windshield Glass Group
Console Mount, Right Hand
Semi Active Seat Suspension Kit
Semi Active Suspension
Passive
Compressor Service Kit
Antenna Group, Satellite Ready
Compact Drive 12 Volt Motor
Wiper Group, Basic
Wiper Arm Assembly, Wet
Windshield Wiper Motor
Right Hand
Wiper Group, Deluxe
Windshield Washer Bottle
Handle Assembly, Interior
Latch Mount Assembly
Lid Assembly
Cab Group
Cab Insulation
Monitor Mounting Group
Console Assembly, Right Hand
Door Latch Assembly
Trim Group
1Air Conditioning And Heating System
Heating, Ventilation And Air Conditioning
Basic Air And Temperature Control Group
Filter Duct Group
Adapter, Left Hand
Adapter, Right Hand
Deluxe
Air Conditioner Compressor
Air Conditioner
Basic Air Conditioner Kit, With Blower Housing And Fan
Fan Blower Kit
Deluxe Air Conditioner Kit With Blower Housing, Fan, And Valve
Hvac Valve Kit
Air Conditioner Hose
Air Conditioner Tube
Air Conditioner Drain Lines Installation
Deluxe Air And Temperature Control Group
Txv Adapter Tube Assembly
Thermistor Kit
Manual Water Valve Kit
Manual Water Valve Installation
Parts Bag
1Chassis
Fender Group, Rear, Right Hand
Fender Group, Rear, Left Hand
Fender Group, Front, Right Hand
Fender Group, Front, Left Hand
Fender Support Assembly
Service Cabinet Group
Hitch Brace Group
Center Link Step Kit
Hood Group
Cover Group
Hood Closure Gas Strut
Bracket Group
Hood Strap Group
Hood Support Group
Grille Assembly
Vibration Damper
Engine Fan
Guard
Deflector Arrangement, Fan Blast
Step Group, Rear
Step Group, Right Hand
Step Group, Left Hand
Step Support Assembly
Link Assembly, Articulation
Mud Guard Assembly
Fender
1Decals
Mt955e
Mt965e
Mt975e
Fuse
Emblem Assembly, Challenger
North American
International
Hydraulic Decal Installation
Blank
Decal Prop 65
1Wheels
With Single Tire Option
With Duals Option
With Triples Option
Wheel Counterweight Group, Special Application
Wheel And Hub Assembly
Hub Group
Wheel Assembly
1Implement Drive System
Clutch Group, Power Take Off
Connector Assembly, Orfs
Power Take Off Assembly
Power Take Off Spacer Group
Gearbox, Rear Pto, Type 3
Pto Lines Group
Pto Lubrication Valve Assembly
Pto Shaft Guard Kit
1Implement Lift System Rear
Quick Coupler Group
Quick Coupler Group, Category 4
3 Point Hitch Group, 3 4n
Rockshaft Group
Lift Link Group
Limiter Assembly, Left Hand
Link Group, Upper
Limiter Assembly, Right Hand
3 Point Hitch Control Group
Linkage Group, Catagory 4, 3 Point
Hitch Compensator Spring Kit
Hitch Cartridge Valve Kit
Hydraulic Cylinder Group, Lift, 125mm Bore X 345mm Stroke
Cylinder
Hydraulic Cylinder Group, Seal, 3 Point Hitch Lift
1Precision Farming Systems
And Base Station Components
Auto Guidance Kit
Auto Guide Control Switch
Autoguide Ready Mounting Group
Field Kit, Autoguide Mounting
Articulation Angle Sensor Group
Telemetry Arrangement
Telemetry Installation
Telementry Hardware Group
Gateway
Gateway, Mid Spec, Gsm
Gateway, Mid Spec, Lte
Agi4 Topdock Kit
Terminal Installation, C3000, Ag3000
Field Installation Kit
Plug Installation Without Autoguide
Ground Speed Sensor
Not Autoguide Ready
Radar Group, Ground Speed Sensor
1Attachments
Plug Installation Without Front Counterweights
Counterweight Group, Front, 1440 Kilograms, 3175 Pounds
Non-Ce
Wheel Counterweight Group, 454 Kg
Wheel Counterweight Group, 1000 Lb
Wheel Counterweight Arrangement, 1816 Kilograms
Wheel Counterweight Group, Rear
Fire Extinguisher Mounting Kit
Drawbar Lynch Pin Installation
Drawbar Pin With Lynch Pin Kit
Toolbox Arrangement
Toolbox Group
Toolbox Arrangement, Field Installation
Category 4 Drawbar
Without Tow Cable
Tow Cable Installation
Category 5
Category 4
Slow Moving Vehicle Warning Group, Hitch
Single
Duals And Triples
1Accessories
Articulated Front Frame Steering Cylinder Mounts Repair Kit
Articulated Front Frame Upper Articulation Pin Hole Repair Kit
Articulated Rear Frame Steering Cylinder Mounts Repair Kit
Articulated Rear Frame Upper Link Repair Kit
Articulated Front Frame Repair Kit
Air Tank
Bearing Driver Group
Cab Side Visors Group, Field Installed
Steering Kit, Electronic Enhanced
Field Accessories, Telemetry
Telemetry Hardware Kit
Field Kit
Hardware
Hydraulic Implement Pump, 85 Gpm
Field Accessories
Led Lighting Arrangement
Radio Installation, Blue Tooth, Usb
Radio, Deluxe
Radio, Deluxe Xm
Pioneer Implement Case Drain Kit
Hydraulic Trailer Brake Kit, Drawbar
Hydraulic Trailer Brake Kit, Hitch
Case Drain Kit
1 2 Inch Top Or Middle Coupler Conversion Kit
1 2 Inch Bottom Coupler Conversion Kit
3 4 Inch Top Or Middle Coupler Conversion Kit
3 4 Inch Bottom Coupler Conversion Kit
Greater Than 60 Liters Per Minute
4 To 5 Implement Valve Arrangement With 3 Point Hitch
4 To 6 Valve, 3 4 Inch High Flow Valve Conversion Kit
5 To 6 Standard Implement Valve Conversion Kit
Threaded Ports Coupler Kit
Pto Kit, Field Installation
Transmission Control Handle Pushbutton Switches Kit
Brand: Challenger
Mt900e
2016
Coolant Piping
Intake Manifold
Exhaust Manifold
Oil Pump And Sump
Fuel Filters
Engine Assemblies
Valve Rocker Cover
Control Units
Belt Tensioner
Cooling Group
Cooler Assembly
Fuel Lines Group
Exhaust Group
16.8 L Engine
Def
2017
Shim Pack Kit, Bz
Shim Pack Kit, Am
Park Brake Assembly
Differential Lock
Plug Group
Special Application
Frame Group, Front
Frame Group, Center
Steering Group
Steering
Case Assembly
Lock
Clutch Group
Transfer Gear Group
Pump Drive Group
Yoke Group, Input
Yoke Group, Output
Case Assembly, Rear
Spool Assembly
Sight Gauge
Front
Rear
Service Kit
Input Shaft
Planetary
Transmission Filter
Front Case
Hydraulic Control
Brake
Valve-Brake Charge
Brake Lines Group
3 Point Hitch
Mt855, Mt865, Mt875
Air Dryer Group, B
Cap, M18 Tube
4 Bank Valve Group
Ls Plug Kit
Handle Kit
Poppet Valve Kit
Relief Valve Kit
5 Bank Valve Group
6 Bank Valve Group
Coupler Kit, 3 4
Reducing Valve Kit
Valve Cover Group
Implement
Lines
Drawbar And Hitch
Plug
126 Cc
Pump Group, 85cc
Valve
Pto
Hitch
Worklight
Worklight, Hid
Pto Switch Group
Powerstrip Assembly
Non Ce
Hid Lamp
Light, Hid, L1
Light, Hid, R1
Light, Hid, L3
Light, Hid, R3
Rotating Beacon Kit
Beacon Lights
Porch Lamp Group
Halogen
Light Bezel, Left
Light Bezel, Right
Light, Halogen, R3
Light, Halogen, L3
Signal Light Group
Turn Lamp Assembly
Cab Wiring Group
Dome Lamp Assembly
With 3 Point Hitch
Lighting
Lighting Group, Hid
Bonnet
Led
Radio Speaker Group
Knob Kit
Knob Group
Arm Pad
Basic
Trainer Seat, Cloth
Seat Group, Basic
Seat Group, Deluxe
Operator Seat
Instructor Seat
Passive
Wiper Group, Basic
Right Hand
Wiper Group, Deluxe
Lid Assembly
Cab Group
Cab Insulation
Door Latch Assembly
Trim Group
Filter Duct Group
Adapter, Left Hand
Adapter, Right Hand
Deluxe
Air Conditioner
Fan Blower Kit
Hvac Valve Kit
Thermistor Kit
Parts Bag
1Chassis
Hitch Brace Group
Hood Group
Cover Group
Bracket Group
Hood Strap Group
Hood Support Group
Grille Assembly
Vibration Damper
Engine Fan
Guard
Step Group, Rear
Mud Guard Assembly
Fender
1Decals
Mt955e
Mt965e
Mt975e
Fuse
North American
International
Blank
Decal Prop 65
1Wheels
With Duals Option
With Triples Option
Hub Group
Wheel Assembly
Pto Lines Group
Pto Shaft Guard Kit
Quick Coupler Group
Rockshaft Group
Lift Link Group
Link Group, Upper
Cylinder
Auto Guidance Kit
Gateway
Agi4 Topdock Kit
Ground Speed Sensor
Not Autoguide Ready
1Attachments
Non-Ce
Toolbox Arrangement
Toolbox Group
Category 4 Drawbar
Without Tow Cable
Category 5
Category 4
Single
Duals And Triples
1Accessories
Air Tank
Field Kit
Hardware
Field Accessories
Radio, Deluxe
Radio, Deluxe Xm
Case Drain Kit
