Challenger Tractor MT945B MT955B MT965B MT975B Parts Catalog 512631D1
Brand: Challenger
Model: Challenger MT945B, MT955B, MT965B, MT975B Tractor
Serial Number: ..SXX1001 - ..TXX9999
Part Number: 512631D1
Number of Pages: 6540 Pages
Publication Information
Belt And Filter Guide For Mt900b
Mt945b
Lines Group-Coolant
Cooling Group-Mounting Baffles(Atlas Engineering)
Core Group-Assembly(Atlas Engineering)
Tank Group Expansion Coolant
Gage-Sight
Connector-Orfsxstor 25.4
Pulley Group
Tightener-Belt
Pulley Assembly-Idler
Drive Group-Fan
Drive Group-Accessory
Fan Group-Engine (11 Blade Composite)
Shroud Assembly
Alternator With Mounting Group
Alternator-12 Volts 185 Amps
Oil Level Indicator Install
Indicator-Oil Level
Positive Battery Jumber Terminal
Lines Group-Eng Oil Drain
Lines Group-Air
Cleaner Group-Air
Air Cleaner Assembly
Filter Group-Water Fuel Separator
Filter Assembly-(Fuel Water Separator)
Lines Group-Fuel
Lines Group-Dust Ejector
Muffler Group
Aid Group-Ether Starting
Mounting Group-Ether
Valve Group-Ether
Coupling Group-Input
Mounting Group-Engine
Mount Assembly
Mounting Group-Compressor
Compressor Group-Clutch
Valve-Pressure Relief W O-Ring
Lines Group-A C
Hose Assembly(10.3 Id Sae J2064 Hose)
Hose Assembly(7.9 Id Sae J2064 Hose)
Mt955b
Mt965b
Mt975b
Cooler Group-Mounting-Modine Manufacturing
Core Group-Assembly-Modine Manufacturing
Connector Assembly-12 Orfsx 12stor
Connector Assembly-10orfs X 8stor
Fan Group-Engine (Spider Fan Assembly)
Motor Group-Electric Starting(Dual Motors)Service
Motor Group-Electric-C(Right Side)Service Parts
Motor Group-Electric-C(Left Side)Service Parts
Cap-Fuel
Sensor Assembly-Fuel Level
Heater Group-Jacket Water,120v
Element Assembly-Heater,120v 1500w
Heater Group-Jacket Water,240v
Element Assembly-Heater,240v 1500w
Connector Assembly-8orfsx8stor(Viton O-Rings)
Connector Assembly-45 Elbow(Viton O-Rings)
Connector Assembly-12storx8orfs(Viton O-Rings)
Connector Assembly-90 Elbow-8orfs(Viton O-Rings)
Connector Assembly-16storx25.4 Barb
Connector Assembly-90 Elbow(Viton O-Rings)
Elbow Assembly-90deg 10 Orfs X M22
Tee-M18 X 3
Axle Arrangement
Axle Assembly-Front(Hcd)
Axle-Front(Hcd)
Differential Assembly-Front(Hc-Differential)
Kit-Shim Pack-Bz
Kit-Shim Pack-Am
Axle Assembly-Final Drive
Bearing Assembly
Kit-Shim Pack-Final Drive
Housing Assembly-Differential
Cover-Center Box
Plug Assembly-10 Stor Zn Hshd And Oring
Plug Assembly-16 Stor Zn Hshd And Oring
Park Brake Assembly-With
Kit-Shim Pack-Park Brake
Adptr-10 Stor X -10 Orfs X 6mm
Tee Assembly-6orfs X 6orfs X 6stor
Connector Assembly-16 Storx16 Orfs
Connector Assembly-6 Stor -6 Orfs
Axle Assembly-Rear(Hcd)
Differential Assembly-Rear(Hc-Differential)
Park Brake Assembly-Without
Plug Assembly-6 Stor
Elbow Assembly-90-6stor X 6orfs
Tee Assembly-6orfs X 6orfsx 6stor
Shaft Group-Input
Driveshaft Assembly-Engine Transmission
Shaft Group-Front
Driveshaft Assembly-Front Axle
Shaft Group-Rear
Driveshaft Assembly-Articulation
Driveshaft Assembly-Axle (Rear)
Axle Assembly-Front(Needle Bearing Differential)
Axle-Front(Needle Bearing Carbonitride)
Differential Assembly-Front(Needle Bearing)
Kit-Shim Pack-X
Kit-Shim Pack-At
Plug-9 16-18 Stor
Axle Assembly-Rear(Needle Bearing Differential)
Axle-Rear Mt900b(Needle Bearing Carbonitride)
Differential Assembly-Rear(Needle Bearing)
Frame And Suspension
Frame Group-Front
Frame Group-Center
Link Assembly-Articulation
Frame Group-Rear(Includes Fuel Tank)
Mounting Group-Transmission
Mounting Group-Cab(Basic)
Column Assembly-Steering
Kit-Steering Column,Bushing Pin
Control Group-Mounting And Steering
Steering Group-Hydraulic,Common
Lines Group-Hydraulic Steering Valve
Lines Group-Hydraulic Steering Cylinders
Elbow Assembly-90deg 8orfs
Tee Assembly-Blkhd Union 8orfs
Cylinder Group-Steering
Cylinder-Hydraulic Steering
Yoke Assembly-Steering Cylinder
Elbow Assembly-90d 8stor-8orfs
Steering Kit-Electronic Enhanced
Valve Assemby-Steering Priority
Steering Assembly-Pilot
Connector Assembly-Str-8stor-6orfs
Elbow Assembly-90deg-8stor-10orfs
Adapter Assembly-Str-12 Stor-8 Port
Elbow Assembly-90deg 6orfs X 8stor
Connector Assembly -8orfs-8stor
Elbow Assembly-45 6orfs X 8stor
Tee Assembly-4orfs X 4orfs X 4stor
Steering Group-Hydraulic Electric
Valve Assembly-Steer Priority,Elec
Steering Assembly-Pilot Electric
Powertrain Arrangement-With Out Power-Take-Off
Lines Group-Transmission
Elbow Assembly-90deg-16 Orfs Run
Completing Arrangement-Transmission
Completing Group-Transmission
Adapter Assembly-Spl90-16storx-16orfs
Elbow Assembly-12storx12nptf,6stor
Standpipe Group-Axle Lube
Gauge Install-Transmission, Sight
Filler Group-Transmission
Transmission Arrangement-W O Power-Take-Off
Trans-16spd Powershift Mt900,W O Pto R B 539437d1
Clutch Group
Case And Parts Group-Planetary
Case Assembly-Front
Elbow Assembly
Nipple Assembly
Plug Assembly-Hs
Gear Group-Transfer
Drive Group-Pump
Control Group-Transmission
Plug Assembly-20 Stor
Yoke Group(Input)
Yoke Group(Output)
Cover Group-Transmission
Lines Group-Axle Lube W 0 Pto
Elbow Assembly-90deg 12stor X 12orfs
Brake Arrangement-Common
Lines Group-Brakes
Brake Group-Service Hydraulic
Control Assembly-Service Brake
Valve Assembly-Check
Connector Assembly-Str-8stor-8orfs
Tee Assembly-Union -6 Orfs And O-Rings
Accumulator Assembly
Tee Assembly-6stor X 8stor X 8orfs
Switch Assembly-Pressure-10700 Kpa
Cable Install-Park Brake
Pump Arrangement-Transmission Axle-W O Pto
Tee Assembly-Branch-10stor X-10orfs
Pump-Hydraulic Triple
Connector Assembly-Str-24stor-24orfs
Elbow Assembly-90deg 16stor 16orfs
Completing Arrangement-No Pto
Powertrain Arrangement-With Power-Take-Off
Trans-16 Speed Powershift,Mt900 W Pto R B 539438d1
Clutch Group-Power Take-Off
Housing Assembly-Front
Lines Group-Axle Lube W Pto
Filter Assembly-Axle Lube
Block Assembly-Axle Lube
Valve-Relief-Ep16-S35
Plug-Cavity-Cp10
Nipple Assembly-Test,Pd,-6 Stor
Elbow Assembly-45 -12stor-12orfs
Pto Arrangement
Support-Intermediate Drive Shaft
Gearbox-Rear Pto Type 3
Spacer Group-Pto
Driveshaft-Pto Articulated
U-Joint;7c-Lube For Life W Metric Fasteners
Driveshaft-Pto Rear
Lines Group-Pto
Elbow Assembly-90l,-06stor X-06orfs
Transmission-16 Speed Powershift, Mt900 W Pto
Adapter Assembly
Connector Assembly(Orfs)
Plug Assembly
Case Assembly-Rear
Elbow Assembly(Orfs)
Plug Assembly-Hshsto
Valve Group-Rlf-C
Spool Assembly
Valve Group-Mdl-C
Plug 3 4-16 Special Bore
Diff Lock Group
Diff Lock Group-Hydraulic
Elbow Assembly-90deg-8 Orfs,Diff Lock
Valve Asm-Solenoid,3-Way
Valve-Solenoid,3-Way
Elbow Assembly-90deg-6stor-8orfs
Control Group-Diff Lock
Diff Lock-Electrical Field
Plug Group-No Diff Lock
Kit-Relief Valve
Kit-Differential Assembly-Service(Needle Bearing)
Kit-Diff Assembly Half-Service (Needle Bearing)
Transmission-16 Speed Powershift Mt900,W O Pto
Install-Jumper Harness
Shaft Group-Input R B 532208d1
Driveshaft Assembly-Eng Trans R B 532207d1
Kit-Lines Group-Axle Lube-Filtered
Filter Assembly-Axle Lube Field Kit
Switch Assembly-Pressure, 8 Pdi
Tee Assembly-Special-16stor X -12orfs
Powertrain Bolt List
1Brake System
Tee-Swivel 3x -8 Orfs
Tee Assembly-Bulkhead-6 Orfs
Reducer Assembly-10 Orfs X -6 Orfs
Filter Assembly-Brakes
Filter Assembly-Hydraulic,3000 Psi
Connector Assembly-Str-12stor-8orfs
Valve Assembly-Brake Charge
Valve Assembly-Accumulator Charge
Elbow Assembly-90deg 8orfs X 8stor
Valve Group-Park Brake
Valve Assembly-Park Brake
Valve Group-Manual
Valve-Check
Valve-Solenoid, 3-Way
Valve-Solenoid, 2-Way, Man
Valve As-Balanced Poppet,Nc
Connector Assembly-6stor X 6orfs
Connector Assembly-Str-6stor-8orfs
Brake Group-Hydraulic Trailer Brakes
Coupler-Quick Connect 12stor Ml
Valve Group-Brake Control
Plug Assembly-M27x2 Thd
Plug Assembly-Special
Adapter Assembly-6 Stor X 4 Stor
Adaptor Assembly-4 Stor X -4 Stor
Adapter Assembly-16stor X -8 Orfs
Connector Assembly-Str-6stor-4orfs
Completing Arrangement-No Hydraulic Trailer Brake
Elbow Assembly-90deg 4stor X 4orfs
Brake Group-Hydraulic Trailer(Field Installed)
Tee Assembly-6 Orfs X 3
Elbow Assembly-4 Port-Orp 90deg And Oring
Plug Assembly-16 Stor Hhd Zn
1Compressed Air System
Compressor Group-Air
Valve Assembly-Pressure Relief
Air Tank Switch
Compressor Group-Air,Mt900
Connector Assembly-Str -4stor -4orfs
Lines Group-Air Tank,Mt900
Elbow Assembly-(M22-1.5m X 7 16-20m Orfs)
Lines Group-Coupler,Mt900
Dryer Group-Air(B)
Sensor Group-Pressure
Lines Group-Coupler
Cap-M18 Tube
Completing Arrangement W No Air Compressor
1Hydraulic System
Hydraulic Arrangement-Common
Filter Group-Hydraulic
Filter Group-Oil Mt900
Valve Assembly-4 3500 Kpa
Tank Group-Hydraulic
Adapter-2 1 2tubex-48orb
Lines Group-Implement Filter Cooler
Lines Group-Hydraulic Cooler
Pump Arrangement-Hydraulic Implement,63cc
Pump Group-63cc
Pump-Hydraulic Gear 36cc
Pump-Hydraulic Piston,63cc
Valve Group-Pump Control
Plug Assembly-Hex -4stor
Plug Assembly-Control
Lines Group-Implement Pump
Adapter Assembly-Str,-24mor X -200rfs
Valve Assembly-Ls Blocking
Valve Group-Solenoid
Solenoid Assembly
Valve Assembly-Check,1psi
Connector Assembly-20 Orfs X 20 Stor
Pump Arrangement-Hydraulic Implement, 85cc
Pump Group-85cc
Pump-Hydraulic Piston,85cc
Piston Assembly-Control
Pump-Hydraulic Triple(R B 526310d1)
Kit-Pump Arrangement
Plug Group-Tank
Drain Group-Tank Plugs
Drain Group-Ecology
Drain Assembly
Valve Arrangement-Imp 4
Valve Group-Bank-4
Valve Group-Fcont-E
Valve Group-Flow Control
Valve Group-Relief (A)
Valve Group-Cont-T
Solenoid
Valve Group-Check
Plate Assembly
Coupling Group
Cap Assembly
Plug As-M28 Stor
Plug Assembly-Stor, M28
Lines Group-Imp Valve Drain
Imp 5
Valve Group-Bank-5
Control Group-Wiring
Electric Group-A2001(Ag Tractor Implement 5 6)
Control Group-Electric(Bsc)(Sdm-L)
Valve Arrangement-Imp 6
Valve Group-Bank-6
Valve Arrangement-Implement 4 Hf
Valve Group-High Flow-Bank-4
Valve Group-Cont-High Flow
Valve Arrangement-Implement 6 Hf
Valve Group-High Flow-Bank-6
Kit-Implement Valve
Kit-Hydraulic, Convert 4 To 5 Remote Valve
Control Group-6 Implement
Control Group-Electronic (G)
Control Assembly-Electronic
Valve Assembly-Check,65 Psi
Hydraulic Kit-Power Beyond(0-60 Lpm)
Adapter Assembly-90deg 6 Stor X 6 Stor
Adapter Assembly-16stor X 12 Stor
Connector Assembly-6stor X 6stor
Coupler Assembly
Nipple-Quick Couple 6stor
Hydraulic Kit-Power Beyond(Greater Than 60 Lpm)
Hose Assembly(For 15.9 Id Sae J2064 Hose)
Hose Assembly(For 12.7 Id
Valve Assembly-Solenoid, 3-Way
Case Drain Group-Flat Face
Coupler Assembly(6-Flat Face)
Elbow Assembly-45 -8stor-8orfs
Case Drain Group-Pioneer
Connector Assembly-Str -8stor-12orfs
Case Drain Group-Flat Face(Field)
Case Drain Group-Pioneer(Field)
Plug Group-No Heater
Plug Group-No Implement Case Drain
Kit-Implement Valve Cover(Extend)
Kit-Implement Valve Cover(Retract)
Kit-Implement Valve-4 To 5 Bank
Kit-Hydraulic
Control Group-Implement
Elbow Assembly-45deg-10 Mor X-8 Orfs
Tee Assembly-Br.-12stor X -12 Orfs
1Electrical System
Electrical Arrangement-Common
Wiring Group-Battery
Battery Group(Mt900)
Wiring Group-Vehicle
Receptacle Assembly
Light Group-Signal
Lamp Assembly-Fender(Left Hand)
Lamp Assembly-Fender(Right Hand)
Light Group-Extremity Arm, Right Hand
Lamp Assembly-Turn
Light Group-Extremity Arm, Left Hand
Battery-Manitenance Free, 12 Volt, Wet
Battery-Decal Install
Mounting Group-Battery
Breaker Group-Circuit
Switch Assembly-Master Disconnect(2x1900amp)
Electric Group(Machine Main Module)
Switch Assembly-Pressure, 103.4kpa
Switch Assembly-Pressure Hi-Low
Wiring Group-Cab
Switch Assembly-Starting
Lock Assembly-Cylinder With Key
Panel Assembly-Service
Cap W Lanyard Assembly
Housing Assembly-Power Port(Cell Phone)
Fuse Group
Block Assembly-Fuse
Lamp Assembly-Dome
Control Group-Iso Ready Upgrade
Elek Group-A3008
Lighting Group(Standard)
Lamp Group(Hood)(Halogen)
Headlamp Assembly-Left Hand
Headlamp Assembly-Right Hand
Light Assembly, Work Light-Right Hand
Light Assembly, Work Light-Left Hand
Lamp Group-Porch, 12 Volts
Lighting Group-Warning
Lighting Group-Warning(Field Install)
Kit-Beacon Lamp(12volts)
Plug Group-W 0 Rotory Beacons
Lighting Group(Deluxe)
Lighting Group(Hid)
Light-Work, Hid, Right Hand
Lamp, Hid
Light-Work, Hid, Left Hand
Lamp Group (Hood)
Headlamp Assembly-Hid, Left Hand
Headlamp Assembly-Hid, Right Hand
Kit-Lighting(Standard To Deluxe)
Kit-Lighting(Standard To Hid)
Kit-Lighting(Deluxe To Hid)
Lighting Group-Front Fender, Standard
Work Light
Lighting Group-Rear Fender, Standard
Lighting Group-Front Fender, Hid
Light-Work,Hid
Lighting Group-Rear Fender, Hid
Warning Group-Backup
Alarm-Back Up
Kit-Pushbutton Switches
Heater Group Hydraulic(120 Volts)
Heater Group Hydraulic(240 Volts)
Wiring Group-Rear Console
Plug Group-Rear Console
Wiring Group-Trailer, Connector Switches
Switch Assembly-Fender-3 Point Hitch, Up And Down
Wiring Group-Lighting Shutoff Relay
Wiring Group-Engine Idle Timer
Plug Group-Panel Opening-No Engine Idle Timer
Electric Group-A2004
Wiring Group-Trailer Jumper
Wiring Group-Armrest(W Pto)
Switch Assembly-Pto
Control Group-Transmission-Arm Rest Component
Wiring Group-(Iso Ready)
Wiring Group-Iso
Connector Assembly-Jumper
Kit-Battery Cable Clamp
Terminal Assembly-4 0 Awg Rh Negative
Terminal Assembly-4 0 Awg Inline Negative
Terminal Assembly-4 0 Awg Inline Positive
Radio Group-Am Fm
Radio-Am Fm
Radio Group-Cd
Radio Group-Cd (Xm)
Radio Group-Cd (Sirius)
2Cab
Cab Arrangement-Basic
Trim Group
Cab Group W O Inching Mount
Glass Group-Windshield
Door Group
Door Latch Assembly
Handle Assembly-Interior
Mount Assembly-Latch
Roof Group-Cab
Insulation Group-Weather
Roof Assembly-Inner
Liner Group-Operator
Mirror Group-Electric
Mirror Assembly-Electric
Console Group-Mounting
Console Group-Operator (A)
Control Group-Governor
Cab Armrest
Console Group(With Basic Hvac)
Console Assembly-Rh
Console Assembly-Lh
Control Group-Brake And Clutch
Control Group-Decelerator
Antenna Group-Radio
Lines Group-Heater
Conditioner Group Mounting
Duct Group-Filter
Adapter Assembly-Rh
Adapter Assembly-Lh
Control Group-Air And Temperature(Basic)
Cab Arrangement-Deluxe (Basic Hvac)
Wiper Group (Deluxe)
Bottle Group-Windshield
Arm Assembly-Wiper(Wet)
Visor Group-Cab(Front)
Speaker Group-Radio
Console Group(With Deluxe Hvac)
Conditioner Group Mounting(Deluxe)
Conditioner Group-Air-Deluxe
Kit, Fan Blower
Plate Group-Fops,Mt900b
Wiper Group-Basic
Motor-Wiper,Windshield
Kit-Wiper (Rh)
Motor Group-Compact Drive
Switch Assembly-Wiper Intermitentt 12v
Motor Group-Compact Drive 12v
Visor Group-Cab(Left Hand And Right Hand)
Screen-Sun Lh Window
Kit-Knob
Knob Group
Visor Group-Cab(Rear)
Visor Group-Cab(Field Installed)
Armrest Group-4 Implement, W Pto, W O Hitch
Control Group-4 Implement
Armrest Group-4 Implement, W O Pto, W O Hitch
Armrest Group-4 Implement, W O Pto W Hitch
Control Group-Hitch
Armrest Group-5 Implement. W Pto, W O Hitch
Control Group-5 Implement
Armrest Group-5 Implement, W O Pto, W O Hitch
Armrest Group-5 Implement, W O Pto W Hitch
Armrest Group-6 Implement, W Pto, W O Hitch
Armrest Group-6 Implement, W O Pto, W O Hitch
Armrest Group-6 Implement, W O Pto W Hitch
Kit-3 Point Sensor
Control Group-Handle
Mounting Group (Monitor)
Seat Group-Basic
Kit-Suspension Group(Seat)
Kit-Spring And Shock Assembly
Seat Group-Deluxe
Baffle Group
Kit-Suspension Group R B 520478d1
Kit-Suspension Group R B 520479d1
Seat Group-Training
Seat Assembly
Seat Group-Deluxe(Semi-Active)
Kit-Suspension Group (Seat)
Seat Group-Leather
Seat Group-Basic(Leather)
Kit-Leather (Basic)
Seat Group-Training (Leather)
Seat Assembly (Leather)
Seat Group-Deluxe(Semi-Active Leather)
Kit-Leather (Deluxe)
Speaker Group-Radio, Subwoofer
Antenna Group-Satellite Ready
Cover Group-No Subwoofer
2Air Conditioning And Heating System
Hose Assembly-For(7.9 Id Sae J2064 Hose)
Kit-Rework A C Condenser Adapters
Adapter Assembly-A C Repair, -06
Adapter Assembly-A C Repair, -08
Tube Assembly-A C
Adapter-A C
Conditioner Group-Air(Deluxe)R B 536450d1
Kit-A C Gasket
Kit-Valve Hvac
Conditioner Group-Air(Deluxe)New Sensor
Conditioner Group-Mounting, Basic
Conditioner Group-Air(Basic)R B 524151d1
Thermistor Kit
Conditioner Group-Mounting(Deluxe)
Conditioner Group-Air (Basic)
Conditioner Group-Air(Deluxe) R B 536450d1
Kit-Air Conditioner Group-Basic
Kit-Air Conditioner Group-Deluxe
Kit-Rework,Txv (Mt800 Mt900 W Lines Group)
Kit-Mannual Water Valve
Mannual Water Valve Installation
2Chassis
Chassis Arrangement-Common
Hood Group-Guard
Cover Group
Strap Group-Hood
Support Group-Component
Step Group-Support
Guard Group-Powertrain
Fender Group-Rear
Fender Group-Rear, Rh
Fender Group-Rear, Lh
Step Group, Cab
Step Group-Lh
Step Group-Rh
Fender Group,Front
Fender Group-Front, Rh
Fender Group-Front, Lh
Fender Assembly-Front, Lh
Step Group, Rear
Cabinet Group-Service
Support Group-Step
Seal Group-Articulation
Film Group-Challenger, Mt900
Emblem Assembly-Challenger
Warning Group,Smv
Chassis Arrangement-Common, Special Application
Cable Group-Tow
Guide Group-Tow Cable
Brace Group-Hood
Strut-Gas(Hood Closure)
Guard Group-Fan
Guard Arrangement-Engine(Field Install)
Guard Group-Engine
Guard Group-Frame
Support Group-Step-Articulation Link
2Decals
Decal Sheet-Cab
Film Group-Mt945b
Film Group-Mt955b
Film Group-Mt965b
Film Group-Mt975b
Film And Paint Group-Decals (North American)
Film And Paint Group-Decals (International)
2Wheels
Wheel Arrangement-Tire,710 70r38,Dl,M
Wheel Assembly-710 70r38 Lh, M
Hub Group
Wheel Assembly-710 70r38 Rh, M
Wheel Arrangement-Tire,800 70r38,Dl,M
Wheel Assembly-800 70r38 Lh, M
Wheel Assembly-800 70r38 Rh, M
Wheel Arrangement-Tire,800 70r38if,Dl,M
Wheel Assembly-800 70r38if Lh, M
Wheel Assembly-800 70r38if Rh, M
Wheel Arrangement-Tire,480 80r46,Tri,M
Wheel Assembly-480 80r46 Lh, M
Wheel Assembly-480 80r46 Rh, M
Wheel Arrangement-Tire,480 80r50,Tri,M
Wheel Assembly-480 80r50 Lh, M
Wheel Assembly-480 80r50 Rh, M
Wheel Arrangement-Tire,520 85r42,Tri,M
Wheel Assembly-520 85r42 Lh, M
Wheel Assembly-520 85r42 Rh, M
Wheel Arrangement-Tire,520 85r46,Tri,M
Wheel Assembly-520 85r46 Lh, M
Wheel Assembly-520 85r46 Rh, M
Wheel Arrangement-Tire,520 85r46r2,Tri,G
Wheel Assembly-520 85r46r2 Lh, G
Wheel Assembly-520 85r46r2 Rh, G
Wheel Arrangement-Tire,620 70r46,G
Wheel Assembly-620 70r46 Rh, G
Wheel Assembly-620 70r46 Lh, G
Wheel Arrangement-Tire,620 70r46,Dl,T
Wheel Assembly-620 70r46 Rh, T
Wheel Assembly-620 70r46 Lh, T
Wheel Arrangement-Tire,620 70r46,Dl,M
Wheel Assembly-620 70r46 Rh, M
Wheel Assembly-620 70r46 Lh, M
Wheel Arrangement-Tire,650 85r38,Dl,G
Wheel Assembly-650 85r38 Lh, G
Wheel Assembly-650 85r38 Rh, G
Wheel Arrangement-Tire,650 85r38,Dl,F
Wheel Assembly-650 85r38 Rh, F
Wheel Assembly-650 85r38 Lh, F
Wheel Arrangement-Tire,650 85r38,Dl,M
Wheel Assembly-650 85r38 Rh, M
Wheel Assembly-650 85r38 Lh, M
Wheel Arrangement-Tire,710 70r38,Dl,G
Wheel Assembly-710 70r38 Lh, G
Wheel Assembly-710 70r38 Rh, G
Wheel Arrangement-Tire,710 70r38,Dl,F
Wheel Assembly-710 70r38 Lh, F
Wheel Assembly-710 70r38 Rh, F
Wheel Arrangement-Tire,710 70r42,Dl,G
Wheel Assembly-710 70r42 Lh, G
Wheel Assembly-710 70r42 Rh, G
Wheel Arrangement-Tire,710 70r42,Dl,F
Wheel Assembly-710 70r42 Lh, F
Wheel Assembly-710 70r42 Rh, F
Wheel Arrangement-Tire,710 70r42,Dl,M
Wheel Assembly-710 70r42 Lh, M
Wheel Assembly-710 70r42 Rh, M
Wheel Arrangement-Tire,800 70r38,Dl,G
Wheel Assembly-800 70r38 Rh, G
Wheel Assembly-800 70r38 Lh, G
Wheel Arrangement-Tire,800 70r38,Dl,F
Wheel Assembly-800 70r38 Lh, F
Wheel Assembly-800 70r38 Rh, F
Wheel Arrangement-Tire,800 70r38,Dl,T
Wheel Assembly-800 70r38 Rh, T
Wheel Assembly-800 70r38 Lh, T
Wheel Arrangement-Tire,480 80r46,Tri,G
Wheel Assembly-480 80r46 Lh, G
Wheel Assembly-480 80r46 Rh, G
Wheel Arrangement-Tire,480 80r46,Tri,F
Wheel Assembly-480 80r46 Lh, F
Wheel Assembly-480 80r46 Rh, F
Wheel Arrangement-Tire,480 80r50,Tri,G
Wheel Assembly-480 80r50 Rh, G
Wheel Assembly-480 80r50 Lh, G
Wheel Arrangement-Tire,480 80r50,Tri,F
Wheel Assembly-480 80r50 Rh, F
Wheel Assembly-480 80r50 Lh, F
Wheel Arrangement-Tire,480 80r50,Tri,T
Wheel Assembly-480 80r50 Lh, T
Wheel Assembly-480 80r50 Rh, T
Wheel Arrangement-Tire,520 85r42,Tri,G
Wheel Assembly-520 85r42 Lh, G
Wheel Assembly-520 85r42 Rh, G
Wheel Arrangement-Tire,520 85r42,Tri,F
Wheel Assembly-520 85r42 Rh, F
Wheel Assembly-520 85r42 Lh, F
Wheel Arrangement-Tire,520 85r46,Tri,G
Wheel Assembly-520 85r46 Rh, G
Wheel Assembly-520 85r46 Lh, G
Wheel Arrangement-Tire,520 85r46,Tri,F
Wheel Assembly-520 85r46 Lh, F
Wheel Assembly-520 85r46 Rh, F
Wheel Arrangement-Tire,520 85r46,Tri,T
Wheel Assembly-520 85r46 Lh, T
Wheel Assembly-520 85r46 Rh, T
Wheel Arrangement-Tire, 35.5l32, Sgl, F
Wheel Assembly-35.5l32 Rh, F
Wheel Assembly-35.5l32 Lh, F
Wheel Arrangement-Tire,620 70r46,Dl,G
Hardware Kit-Duals
Hardware Kit-Triples
Counterweight Group-Wheel,Rear
Counterweight Group-Wheel,1000lb
Counterweight Group-Wheel,Spl App
Counterweight Group-Wheel, Rear
3Implement Drive System
Housing Assembly-Rear
Valve Assembly-Pto Lube
Valve-Piloted Control
Valve-3way, Piloted
Kit-Pto-Field Instal-Units Made Prior 4 17 2008
Kit-Pto Shaft Guard
Kit-Pto Group-Field Installed W O Pump Kit
3Implement Lift System
Linkage Group-3 Point-3 4n
Rockshaft Group
Link Group-Lift
Limiter Assembly-Left Hand
Link Group-Upper
Limiter Assembly-Right Hand
Linkage Group-Catagory 4 3 Point
Cylinder Group-Seal(Lift)
Cylinder Group-0125-0345-Y
Brace Group-Hitch
3Guidance System
Radar Group-Ground Speed Sensor
Sensor-Ground Speed
Sensor Group-Mt900-Articulation Angle
Mounting Install-Autoguide
Autoguide Installation-Monitor And B4
Autoguide Install- Monitor And B4 Fm
Autoguide Kit-B4
Autoguide Kit-B4 W Freewave
Mounting Kit, Autoguide, Mt900
Mounting Install-Autoguide,Mt900
Sensor Group-Articulation Angle 16-140
B4 Autoguide Topdock Install
Auto Guide Ready Install, Mt900
B4 Autoguide W Freewave Install
B4 Autoguide, Topdock Install
Terminal Kit
Radar W Slip Control And Performance
3Attachments
Kit-Mounting(Fire Extinguisher)
Hitch Arrangement-Drawbar
Drawbar Group-Swinging
Clevis-Assembly
Hitch-Scraper Option
Kit-Drawbar Pin W Lynch Pin
Counterweight Group-Front
Plug Group (No Counterweight)
Cable Arrangement-Tow
3Accessories
Tools Group-Service And Install
Kit-Rear Frame Repair, Upper Link
Kit-Front Frame Repair, Artic
Kit-Service, Front Console
Brand: Challenger
Mt945b
Lines Group-Coolant
Gage-Sight
Pulley Group
Tightener-Belt
Drive Group-Fan
Shroud Assembly
Indicator-Oil Level
Lines Group-Air
Cleaner Group-Air
Lines Group-Fuel
Muffler Group
Valve Group-Ether
Mount Assembly
Lines Group-A C
Mt955b
Mt965b
Mt975b
Cap-Fuel
Tee-M18 X 3
Axle Arrangement
Axle-Front(Hcd)
Kit-Shim Pack-Bz
Kit-Shim Pack-Am
Bearing Assembly
Cover-Center Box
Shaft Group-Input
Shaft Group-Front
Shaft Group-Rear
Kit-Shim Pack-X
Kit-Shim Pack-At
Plug-9 16-18 Stor
Frame Group-Front
Frame Group-Center
Clutch Group
Case Assembly-Front
Elbow Assembly
Nipple Assembly
Plug Assembly-Hs
Gear Group-Transfer
Drive Group-Pump
Yoke Group(Input)
Yoke Group(Output)
Lines Group-Brakes
Plug-Cavity-Cp10
Pto Arrangement
Spacer Group-Pto
Driveshaft-Pto Rear
Lines Group-Pto
Adapter Assembly
Plug Assembly
Case Assembly-Rear
Valve Group-Rlf-C
Spool Assembly
Valve Group-Mdl-C
Diff Lock Group
Kit-Relief Valve
1Brake System
Valve Group-Manual
Valve-Check
Air Tank Switch
Dryer Group-Air(B)
Lines Group-Coupler
Cap-M18 Tube
1Hydraulic System
Pump Group-63cc
Solenoid Assembly
Pump Group-85cc
Plug Group-Tank
Drain Group-Ecology
Drain Assembly
Valve Group-Bank-4
Valve Group-Fcont-E
Valve Group-Cont-T
Solenoid
Valve Group-Check
Plate Assembly
Coupling Group
Cap Assembly
Plug As-M28 Stor
Imp 5
Valve Group-Bank-5
Valve Group-Bank-6
Kit-Implement Valve
Coupler Assembly
Kit-Hydraulic
1Electrical System
Receptacle Assembly
Light Group-Signal
Lamp Assembly-Turn
Wiring Group-Cab
Fuse Group
Block Assembly-Fuse
Lamp Assembly-Dome
Elek Group-A3008
Lighting Group(Hid)
Lamp, Hid
Lamp Group (Hood)
Work Light
Light-Work,Hid
Alarm-Back Up
Switch Assembly-Pto
Wiring Group-Iso
Radio Group-Am Fm
Radio-Am Fm
Radio Group-Cd
Radio Group-Cd (Xm)
2Cab
Trim Group
Door Group
Door Latch Assembly
Roof Group-Cab
Roof Assembly-Inner
Cab Armrest
Console Assembly-Rh
Console Assembly-Lh
Antenna Group-Radio
Lines Group-Heater
Duct Group-Filter
Adapter Assembly-Rh
Adapter Assembly-Lh
Speaker Group-Radio
Kit, Fan Blower
Wiper Group-Basic
Kit-Wiper (Rh)
Kit-Knob
Knob Group
Control Group-Hitch
Kit-3 Point Sensor
Seat Group-Basic
Seat Group-Deluxe
Baffle Group
Seat Group-Training
Seat Assembly
Seat Group-Leather
Kit-Leather (Basic)
Tube Assembly-A C
Adapter-A C
Kit-A C Gasket
Kit-Valve Hvac
Thermistor Kit
2Chassis
Hood Group-Guard
Cover Group
Strap Group-Hood
Step Group-Support
Fender Group-Rear
Step Group, Cab
Step Group-Lh
Step Group-Rh
Fender Group,Front
Step Group, Rear
Support Group-Step
Warning Group,Smv
Cable Group-Tow
Brace Group-Hood
Guard Group-Fan
Guard Group-Engine
Guard Group-Frame
2Decals
Decal Sheet-Cab
Film Group-Mt945b
Film Group-Mt955b
Film Group-Mt965b
Film Group-Mt975b
2Wheels
Hub Group
Hardware Kit-Duals
Valve-3way, Piloted
Kit-Pto Shaft Guard
Rockshaft Group
Link Group-Lift
Link Group-Upper
Brace Group-Hitch
3Guidance System
Sensor-Ground Speed
Autoguide Kit-B4
Terminal Kit
3Attachments
Clevis-Assembly
3Accessories
