Challenger Tractor MT685C Parts Catalog 3906235
Brand: Challenger
Model: Challenger MT685C Tractor
Part Number: 3906235
Number of Pages: 750 Pages
Dealer Stocking List
Quantity By Tractor
Engine & Equipment
Agco Power Sisu W E3 Technology
Tier2 Engine
Alternator & Bracket
Engine With Air Compressor
Timing Gear Housing
Crankshaft, Piston & Connecting Rods
Valve Mechanism And Camshaft
Cylinder Head Cover
Oil Sump
Lubricating Oil Cooler And Filter
Injection System
Air Induction & Exhaust
Pipes
Up To V174005
From V174006
Electronic Engine Management
Piston- Cylinder Head With Valves
Engine Gaskets Sets
Agco Power Sisu Iegr Up To V118035
Agco Power Sisu Iegr From V118036
With Engine Bloc Heater
Up To U139025
From U139026
Additional Tank
Fuel System
Batteries And Cables
Air Conditioned Installation
Compresser
Air Cooler
Dual Element
Throttle Controls
Clutch
Front Spacer
Flywheel & Flywheel Housing
Clutch Control
Housing
Gear Box
Inner Housing
Planetary Drive
Pump Shaft
Accumulator Shaft
Hydraulique Motor
Duct Plate
Adjusting Device
Group Gear Shifting
Drive Line
Range
Transmission Control
Control Armrest
Control
Rear Axle
With Trailer Braking
Without Trailer Braking
Up To No 903 7000
From Serial Or Engine Number 903 7001
Bevel Drive
Disc Brakes
Lift Arms
Angle Sensor
Linkage
Lift Cylinders
Lift Cylinders Feeding
Levelling Box
Top Link With Hook End
Hydraulic
Top Link With Ball End
Top Link Lock
Sensing Pin
Lower Bar With Hook
Lower Bar With Toogle
Tube Stabilizers
Shoe Stabilizers
Up To Diameter 25 Mm
From Diameter 22,5 Mm
Iso Standard
Sae Standard
Iso Standard Up To U294039
Iso Standard From U294040
Heavy Duty
Iso Standard From U294040 Up To V336027
Diameter 21,75 Mm
Hitch
From Serial Or Engine Number V336028
Quick Coupler
Without Remote Control
Front Linkage 50000n
4 Quick Couplers
Pto Drive Mechanism
From N° 903 7001
Cylinder
With Clevis Quick Adjustment
Ipto Clutch
Front Axle
Weight Frame And Tow Pin
Belly Weight
With Front Axle Suspended
Differential Lock Mechanism
Guard And Transmission Shaft
With Front Axle Fixed
Front Axle 4 Wheel Drive
With Suspended Front Axle
Front Axle Fixed
Steering Wheel And Telescopic Column
Lighting Power Shuttle Drive
Steering Pump
Autoguide
Steering Hydraulic Lines
Front Suspension Hydraulic Lines
Cab Suspension Hydraulic Lines
Brake Pedals
Up To Serial Or Engine Number U323012
From Serial Or Engine Number U323013
Up To U261019
From U261020
With Pneumatic Braking Of Trailer
With Brakes High Pressure
Pneumatic Feeding
50 Km H
Set Of Transmission Identific Ation Number 4297...M92
Up To No 903 4231
Up To No 903 5332
Up To No 903 5553
Pump Drive
Filter
System Comfort
Gear Box Lubrication
Interior
Hydraulic Valve Block
Pressure Filter
Solenoid Valve
Fixing By Supports
Hydraulic Lines
Auxiliary Hydraulics
With Suspended Axle
With Fixed Axle
Without Front Loader
With Hay Ladder
With Front Quick Couplers
4 Distributors Electrodynamique
5 Distributors Electrodynamique
6 Distributors Electrodynamique
Auxiliary Distributor
Up To V295060
From V295061
Hydraulic Lift Valve
Hydraulic Coupling
Male Coupler
4 Distributors
5-6 Distributors
Electrical Equipment & Instrument Panel
Instrument Panel & Instruments
Side Console Switches
External Controls Fitted On The Rear Fenders
Instrument Panel Harness
Armrest
Plate Relay & Fuse Holder
Automatic Air Conditioner
Manual Air Conditioner
Harness
With Isobus
Front Lightning Harness
Rear Lightning Harness
Handold
Electronic Equipment
Console
With Front Linkage
Without Front Quick Couplers Without Front Loader Without Front Linkage
Auto-Guide
Aboard Computer
Plate Lighting Equipement
Up To U268039 For Great Britai N
From U268040 For Great Britain
Harness Isobus
Not For Usa
For United States Of America
Front Axle Suspended Harness Control Box
Control Box Harness & Cab Controls
Cab Suspension Harness Control Box
With Datatronic 3
Sensors
Body
Grille
Hood
Hood Frame
Tool Box
Footstep
Emblems
Speed Charts
Safety
Literature
Tractor Cab
Cab Mountings
Optiride Suspension
Optiride Plus Suspension
Optiride Suspension And Optiride Plus Suspension
Left Side
Right Side
Glass
Rear Window Mechanism
Roof
Cladding
Dressing Roof
Instrument Panel Cladding
Cab Insulation
Fenders
Fenders Extension
Hose
Up To 15-Nov-2009
From 16-Nov-2009
Standard Roof
Cab Filter
Windscreen Wiper
Canopy
Radio Installation
Agcommand
Eec Standard
Internal Mirrors
External Mirrors
Electric Control Rear Reflecting Miror
Air Pressure Seat
Adjustable Damper
Secondary Seat
Lighting
Front
Working Light
Traffic Warning
For Export Europe
Rotating Light
Rims & Wheels Weights
Wheel Hub 12 Holes Assembling
Pivoting
Multi Positions Up To U274028
Up To U274028 Multi Positions Only
Multi Positions From U274029
Multi Positions From U274029 Up To B053001
Multi Positions From B053002
For Way Foward 60
Wheel Hub 10 Holes Assembling
Fixing By Cone
Shaft Diameter 110 Mm Cone Wheel Hub Reversed
With Spacers For Dual Wheels Cone Wheel Hub Reversed
Wheel Weights
Brand: Challenger
Quantity By Tractor
Engine & Equipment
Tier2 Engine
Timing Gear Housing
Cylinder Head Cover
Oil Sump
Injection System
Pipes
Up To V174005
From V174006
Engine Gaskets Sets
Up To U139025
From U139026
Additional Tank
Fuel System
Compresser
Air Cooler
Dual Element
Throttle Controls
Clutch
Front Spacer
Clutch Control
Housing
Gear Box
Inner Housing
Planetary Drive
Pump Shaft
Accumulator Shaft
Hydraulique Motor
Duct Plate
Adjusting Device
Group Gear Shifting
Drive Line
Range
Control Armrest
Control
Rear Axle
Up To No 903 7000
Bevel Drive
Disc Brakes
Lift Arms
Angle Sensor
Linkage
Lift Cylinders
Levelling Box
Hydraulic
Top Link Lock
Sensing Pin
Lower Bar With Hook
Tube Stabilizers
Shoe Stabilizers
Iso Standard
Sae Standard
Heavy Duty
Diameter 21,75 Mm
Hitch
Quick Coupler
4 Quick Couplers
Pto Drive Mechanism
From N° 903 7001
Cylinder
Ipto Clutch
Front Axle
Belly Weight
Front Axle Fixed
Steering Pump
Autoguide
Brake Pedals
Up To U261019
From U261020
Pneumatic Feeding
50 Km H
Up To No 903 4231
Up To No 903 5332
Up To No 903 5553
Pump Drive
Filter
System Comfort
Interior
Pressure Filter
Solenoid Valve
Fixing By Supports
Hydraulic Lines
With Suspended Axle
With Fixed Axle
With Hay Ladder
Up To V295060
From V295061
Hydraulic Coupling
Male Coupler
4 Distributors
5-6 Distributors
Armrest
Harness
With Isobus
Handold
Console
With Front Linkage
Auto-Guide
Aboard Computer
Harness Isobus
Not For Usa
With Datatronic 3
Sensors
Body
Grille
Hood
Hood Frame
Tool Box
Footstep
Emblems
Speed Charts
Safety
Literature
Tractor Cab
Cab Mountings
Optiride Suspension
Left Side
Right Side
Glass
Roof
Cladding
Dressing Roof
Cab Insulation
Fenders
Fenders Extension
Hose
Up To 15-Nov-2009
From 16-Nov-2009
Standard Roof
Cab Filter
Windscreen Wiper
Canopy
Radio Installation
Agcommand
Eec Standard
Internal Mirrors
External Mirrors
Air Pressure Seat
Adjustable Damper
Secondary Seat
Lighting
Front
Working Light
Traffic Warning
For Export Europe
Rotating Light
Pivoting
For Way Foward 60
Fixing By Cone
Wheel Weights
