Challenger Tractor MT655B MT665B Parts Catalog 3906075
Brand: Challenger
Model: Challenger MT655B, MT665B Tier 3 Tractor
Part Number: 3906075
Number of Pages: 757 Pages
Dealer Stocking List
Quantity By Tractor
Engine & Equipment
Except Tractor S N S04 4024
Valid For Tractor S0440 24
Alternator & Bracket
150 Amp
Up To S N S045021 For Mt665b
From S N S045022 For Mt665b
Up To U1000
From U1001
Timing Gear Housing
Crankshaft, Piston & Connecting Rods
Valve Mechanism And Camshaft
Oil Sump
Lubricating Oil Cooler And Filter
Injection System
Low Pressure Fuel System
Air Induction & Exhaust
Up To Serial Or Engine Number S19673
From Serial Or Engine Number S19674
Belt Tensioner
Piston- Cylinder Head With Valves
Engine Gaskets Sets
110 V
220 V
Centrigual Oil Filter
Engine Part
Fuel Tank & Attachments
Additional Tank
Fuel Pipes
Fuel System
Without Battery Cut-Off W O Positive Connection
Without Battery Cut-Off With Positive Connection
With Battery Cut-Off
Air Conditioned Installation
Compresser
Air Cooler
Up To Mt655b R352036 Mt665b R341079
From Mt655b R352037 Mt665b R341080
Dual Element
Throttle Controls
Clutch
Front Spacer
Flywheel & Flywheel Housing
Clutch Control
Housing
Gear Box
Inner Housing
Planetary Drive
Pump Shaft
Accumulator Shaft
Hydraulique Motor
Duct Plate
Adjusting Device
Up To 903 1783
Up To 903 2712
From 903 2713
Group Gear Shifting
Drive Line
From 903 1784
Fingertip
Control Armrest
Control
Rear Axle
Handbrake
Without Breake Beam
Tie Rod
Wheel Shaft Housing
Oil Level Indicator
Bevel Drive
Inner Final Drive Gear
Disc Brakes
Cardan Brake
Lift Arms
Angle Sensor
Linkage
Up To 903 01470
From 903 01471
Lift Cylinders Feeding
Levelling Box
Top Link With Hook End
Top Link With Ball End
Top Link Lock
Sensing Pin
Lower Bar With Hook
Lower Bar With Toogle
Tube Stabilizers
Shoe Stabilizers
Swinging Drawbar
Iso Standard
Sae Standard
Piton Attachment
Swinging Drawbar Support
With Long Hay Ladder
For Germany Only Or Any Text In German Only
Hydraulic
Accumulator
With Front Linkage 35000n
With Front Linkage 50000n
Up To S155024
From S155025
Pto Drive Mechanism
Up To 903 00200
From 903 01001
Bridle
Cylinder
Pipes
With Clevis Quick Adjustment
Pto
Front Axle
Weight Frame And Tow Pin
With Front Lift
Belly Weight
Front Axle Fixed
With Suspended Front Axle
Differential Lock Mechanism
Up To Serial Or Engine Number R292043
With Fixed Front Axle From R292044 Up To T042082
With Fixed Front Axle From T042083
With Suspended Front Axle From R292044 Up To T023052
With Suspended Front Axle From T023053
Up To T042082
From T042083
Auto Guide Sensor Up To .....
Auto Guide Sensor From ... Type 760 601 I-Ita-36 0199 Type 760 602 Front Axle Suspend
Auto Guide Sensor From I-Ita-334141 Type 760 521 K-Ita-308204 Type 760 523 Front Axle
Hydraulic Valve Block
Steering Wheel And Telescopic Column
Lighting Power Shuttle Drive
Steering Pump
Autoguide
Steering Hydraulic Lines
Autoguide Up To T049002
Autoguide From T049003
Front Suspension Hydraulic Lines
Brackets Pedal
Brake Pedals
Up To Serial Or Engine Number T009011
From Serial Or Engine Number T009012
Hydraulic Pipes
Brake Valve
Hydraulic Brake Assy
Pump Drive
Filter
System Comfort
Up To 903 3249
From No 903 3250
Interior
Up To 903 3233
From 903 3234
Solenoid Valve
Hydraulic Lines
Transmission Hydraulic
Tank
Up To R321048 Except R313045
R313045 & From R321049
Auxiliary Hydraulics
Up To Serial Or Engine Number R285062
Hydraulique Manifold
From Serial Or Engine Number R285063
Pump Filter Suction
Hydraulic Lines With 4 Distributors
Hydraulic Lines With 5 Distributors
Hydraulic Lines With 6 Distributors
4 Distributors Electrodynamique
5 Distributors Electrodynamique
6 Distributors Electrodynamique
Auxiliary Distributor
Hydraulic Coupling
Oil Recovery
Module Fingertip
Electrical Equipment & Instrument Panel
With Dot Matrix
Electric Equipment & Instrument Panel
Side Console Switches
External Controls Fitted On The Rear Fenders
Engine Harness
Instrument Panel Harness
Plate Relay & Fuse Holder
Roof Harness
Up To Serial Or Engine Number T059059
From Serial Or Engine Number T059060
Pillar Harness
For United States Of America
Not For Usa
Handold
Automatic Air Conditioner Harness & Sensors
Electronic Equipment
Main Harness
Up To R298036
From R298037
Without Radar
Aboard Computer And Plate Lighting Equipement
Radar
Auto-Guide
Top Dock
Harness Isobus
Fieldstar
Front Axle Suspended Harness Control Box
With Autotronic 5
Control Box Harness & Cab Controls
Up To Serial Or Engine Number R298036
From Serial Or Engine Number R298037
Sensors
Body
Hood
Invalid For Tractor T176054
Valid Also For Tractor T176054
Footstep
Emblems
Speed Charts
See Next Page For Decal Location
For Uk Only Or Any Text In English Only
Literature
With Auto-Guide
Tractor Cab
Cab Mountings
Up To S333079
From S333080
Suspended Cab Control Unit
Pressue Regulator And Filter
Up To S331034
From S331035
Doors
Glass
Side Window Mechanism
Rear Window Mechanism
Roof
Cladding
Dressing Roof
Instrument Panel Cladding
Cab Insulation
Fenders
Hose
Manual Air Conditioner
Cab Filter
Heater Control
Front Windscreen Wiper
Windscreen Washer
Rear Window Wiper
Standard Roof
Radio Installation
Internal Mirrors
External Mirrors
Up To T014046
From T014047
Luxuy
Adjustable Damper
Air Pressure Seat
Seat Belt
Secondary Seat
Lighting
North America Only
Front
Field Lights
Xenon Pivoting
Traffic Warning
Rear
Rotating Light
Rims & Wheels Weights
Wheel Hub 12 Holes Assembling
Wheel Hub 10 Holes Assembling
Rigid
Pivoting
With Spacers For Dual Wheels Cone Wheel Hub Reversed
Shaft Diameter 110 Mm Cone Wheel Hub Reversed
Wheel Weights
Brand: Challenger
Quantity By Tractor
Engine & Equipment
150 Amp
Up To U1000
From U1001
Timing Gear Housing
Oil Sump
Injection System
Belt Tensioner
Engine Gaskets Sets
110 V
220 V
Engine Part
Additional Tank
Fuel Pipes
Fuel System
Compresser
Air Cooler
Dual Element
Throttle Controls
Clutch
Front Spacer
Clutch Control
Housing
Gear Box
Inner Housing
Planetary Drive
Pump Shaft
Accumulator Shaft
Hydraulique Motor
Duct Plate
Adjusting Device
Up To 903 1783
Up To 903 2712
From 903 2713
Group Gear Shifting
Drive Line
From 903 1784
Fingertip
Control Armrest
Control
Rear Axle
Handbrake
Without Breake Beam
Tie Rod
Wheel Shaft Housing
Oil Level Indicator
Bevel Drive
Disc Brakes
Cardan Brake
Lift Arms
Angle Sensor
Linkage
Up To 903 01470
From 903 01471
Levelling Box
Top Link Lock
Sensing Pin
Lower Bar With Hook
Tube Stabilizers
Shoe Stabilizers
Swinging Drawbar
Iso Standard
Sae Standard
Piton Attachment
Hydraulic
Accumulator
Up To S155024
From S155025
Pto Drive Mechanism
Up To 903 00200
From 903 01001
Bridle
Cylinder
Pipes
Pto
Front Axle
With Front Lift
Belly Weight
Front Axle Fixed
Up To T042082
From T042083
Steering Pump
Autoguide
Brackets Pedal
Brake Pedals
Hydraulic Pipes
Brake Valve
Pump Drive
Filter
System Comfort
Up To 903 3249
From No 903 3250
Interior
Up To 903 3233
From 903 3234
Solenoid Valve
Hydraulic Lines
Tank
Pump Filter Suction
Hydraulic Coupling
Oil Recovery
Module Fingertip
With Dot Matrix
Engine Harness
Roof Harness
Pillar Harness
Not For Usa
Handold
Main Harness
Up To R298036
From R298037
Without Radar
Radar
Auto-Guide
Top Dock
Harness Isobus
Fieldstar
With Autotronic 5
Sensors
Body
Hood
Footstep
Emblems
Speed Charts
Literature
With Auto-Guide
Tractor Cab
Cab Mountings
Up To S333079
From S333080
Up To S331034
From S331035
Doors
Glass
Roof
Cladding
Dressing Roof
Cab Insulation
Fenders
Hose
Cab Filter
Heater Control
Windscreen Washer
Rear Window Wiper
Standard Roof
Radio Installation
Internal Mirrors
External Mirrors
Up To T014046
From T014047
Luxuy
Adjustable Damper
Air Pressure Seat
Seat Belt
Secondary Seat
Lighting
North America Only
Front
Field Lights
Xenon Pivoting
Traffic Warning
Rear
Rotating Light
Rigid
Pivoting
Wheel Weights
