702,019
Challenger Tractor MT645 Parts Catalog 1637427
Brand: Challenger
Model: Challenger MT645 Tractor
Part Number: 1637427
Number of Pages: 550 Pages
Engine And Equipment
Alternator And Bracket
Iskra
Timing Gear Housing
Flywheel Housing
Crankshaft, Pistons And Connecting Rods
Valve Mechanism And Camshaft
Cylinder Head Cover
Thermostat
Lubricating Oil Sump
Lubricating Oil Pump
Lubricating Oil Cooler And Filter
Fuel Injection Equipment (Diesel)
Feed Pump
Stop Magnet
Low Pressure Fuel System
Air Induction And Exhaust System
Pipes
Cold Starting Device
Belt Tensioner
Piston- Cylinder Head With Valves
Engine Gaskets Sets
Heater Engine Block
Battery & Cables
Air Conditioned Installation
Sanden Compresser
Support
Up To Serial Or Engine Number N190017
From Serial Or Engine Number N190018
Engine Part
Fuel Tank And Attachments
Without Fuel Flowmeter
With Flow Fuel
Sedimenter
Dual Element
Vertical Exhaust On The Side
Throttle Controls
Clutch
Flywheel
Up To Serial Or Engine Number L270016
From Serial Or Engine Number L270017
With Hydraulic Pump 110 L Mn
With Pump 150 L Mm
Without Creeper Gear
Control Armrest
Controle Full Powershift
Joystick For Distributor With Electrodynamique Control
Engine-Transmission Assembling
Gear Box Full Power Shift
Pump
Input Shaft
2 Nd Gears
3 Rd Gears
4 Th Gears
5 Th Gears
6 Th Gears
7 Th Gears
Cowl
Rear Axle
Intermediary Housing
Lower Control
Handbrake
With Powershift
Centre Housing
With Dual Reducer
Multidiscs
Linkage
Lift Arms
Lift Cylinders
Levelling Box
Top Link With Ball End
Top Link Lock
Lower Cat 2 And 3
Swinging Drawbar Support
Swinging Drawbar
Shoe Stabilizers
Pto-Drive Mechanism
Pto Shaft
7 Disc
Brakes
Independant Power Take Off Clutch
Front Axle
Weight Frame And Tow Pin
Differential Lock Mechanism
Guard And Transmission Shaft
Front Axle 4 Wheel Drive
Steering Cylinders
Housing
Final Drive
Hydraulics
Steering Wheel And Telescopic Column
Lighting Power Shuttle
Steering Pump
Steering Hydraulic Lines
Cover Lh-Pump Filter
Without Trailer Braking
Up To L207014
From L207015
Hydr. Lines
Hydraulic Pump 150 L Mn
With Full Powershift
Hydraulic Valve
With Cab And Power Brakes From
With Power Brakes
Assisted
Hydraulic Pipes
Hydraulic Lift Distributor
Load Sensing
Usa
2 Distributors Electrodynamique And 2 Mechanical Control
2 Distributors Electrodynamique 1 Mechanical And 1 Dual Control
3 Distributors Electrodynamique And 2 Mechanical Control
Auxiliary Distributor
Hydraulic Coupling
Dipstick Centre Housing
159_4 Distributors Control
Electric Equipment & Instrument Panel
Switches
Engine Harness
Instrument Panel Harness
Armrest
Harness Console
Roof Harness
Roof
Guideway Footsteps Fenders
Electronic Equipment
Main Harness
Console
Sensors
Fieldstar
Transmission Main Harness
Emergency Harness
Sheet Metal
Hood
Brackets And Assembling Parts
Grille
Hood Frame
Speed Charts
Footstep And Battery Box
Cab Mountings And Step Stairs
Tool Box
Emblems
Safety
For Mexico Market Only
Literature
Tractor Cab
Doors
Glass
Side Window Mechanism
Rear Window Mechanism
Heating Hatchway
Air Hatchway
Cladding
For Australia
Instrument Panel Cladding
Cab Insulation
Fenders
Hose
Heater Hoses
Air Conditioner
Heater
Windscreen Washer
Front Windscreen Wiper
Rear Window Wiper
Canopy
Radio Installation
Watch
Electrical Plug And Cigar Lighter
External Mirrors
Internal Mirrors
Grammer
Air Pressure Seat With Manual Adjustment
Luxuy
Up To L303040
From L303041
Secondary Seat
Lighting Equipment
Front
Rear
Traffic Warning
Trailor Electric Socket
Field Lights
Rotating Light
Rims And Wheels Weights
Wheel Hub 10 Holes Assembling
Pivoting
Shaft Diameter 110 Mm Cone Wheel Hub Reversed
Repair Kits
Repair Kit
Fuel Heater
Creeper Gear Full Powershift Transmission
Up To Serial Or Engine Number L239021
From Serial Or Engine Number L239022
Two Ways Kit For Rams
With Front Dual Control
Accumulator Kit
Front Linkage 50000n
Front Pto
4 Th Load Sensing Vertical Spool Valve Kit With Me Chanical Control For Cab
5 Th Load Sensing Vertical Spool Valve Kit With Me Chanical Control For Cab
With Fuel Flowmeter
Stock
Appliance Bracket Boarded For Cab
Seat Belt
Sensor Harness-Rear Dual Control
