Challenger Tractor MT635B MT645B Parts Catalog 1637451
Brand: Challenger
Model: Challenger MT635B, MT645B Tier 2 Tractor
Serial Number: P336034 - 1637451
Part Number: 1637451
Number of Pages: 669 Pages
Engine & Equipment
Engine And Equipment
Alternator & Bracket
150 Amp
Starter
Timing Gear Housing
For United States Of America
Not For Usa
Oil Sump
Lubricating Oil Cooler And Filter
Low Pressure Fuel System
Pipes
110 V
220 V
Engine Part
Fuel Tank & Attachments
Additional Tank
Fuel Pipes
Without Battery Cut-Off W O Positive Connection
Without Battery Cut-Off With Positive Connection
With Battery Cut-Off
Air Conditioned Installation
Compresser
Air Cooler
Dual Element
Vertical Exhaust On The Side
Throttle Controls
Clutch
Front Spacer
Flywheel & Flywheel Housing
Clutch Control
Housing
Gear Box
Inner Housing
Planetary Drive
Pump Shaft
Accumulator Shaft
Hydraulique Motor
Duct Plate
Adjusting Device
Up To 903 1779
From 903 1780
Group Gear Shifting
Drive Line
Fingertip
Control Armrest
Control
Rear Axle
Handbrake
Without Breake Beam
Tie Rod
Wheel Shaft Housing
Oil Level Indicator
Bevel Drive
Inner Final Drive Gear
Disc Brakes
Cardan Brake
Lift Arms
Angle Sensor
Linkage
From 903 00101 -Up To 903 00300 -From 903 01001- Up To 906 01470
From 903 01471
Up To 903 00300 -From 903 01001- Up To 906 01613
From 903 01614
Lift Cylinders Feeding
Levelling Box
Top Link With Hook End
Top Link With Ball End
Top Link Lock
Sensing Pin
Lower Bar With Hook
Lower Bar With Toogle
Tube Stabilizers
Automatic Stabilizers
Shoe Stabilizers
Drawbar
Swinging Drawbar
Iso Standard
With Rollers
Sae Standard
Piton Attachment
Ball And Sscket Hitch
Swinging Drawbar Support
With Long Hay Ladder
Long Hay Ladder
With Dromone Automatic Hook
Hitch
For Italy Only Or Any Text In Italian Only
For Germany Only Or Any Text In German Only
With Remote Control
Hydraulic
Accumulator
With Front Linkage 35000n
With Front Linkage 50000n
Pto Drive Mechanism
Up To 903 00200
From 903 01001
Bridle
Cylinder
With Clevis Quick Adjustment
Pto
Front Axle
Weight Frame And Tow Pin
With Front Lift
Belly Weight
Bracket
Differential Lock Mechanism
Guard And Transmission Shaft
Front Axle 4 Wheel Drive
Final Drive
Steering Wheel And Telescopic Column
Lighting Power Shuttle Drive
Steering Pump
Steering Hydraulic Lines
Brackets Pedal
Brake Pedals
Hydraulic Pipes
Hydraulic Brake Assy
Pump Drive
Filter
System Comfort
Gear Box Lubrication
Interior
Hydraulic Valve Block
Pressure Filter
Up To 903 00104
Hydraulic Lines
Transmission Hydraulic
Tank
Trailer Braking
Auxiliary Hydraulics
From Serial Or Engine Number P066022
Hydraulique Manifold
Pump Filter Suction
Hydraulic Lines With 4 Distributors
Hydraulic Lines With 5 Distributors
Hydraulic Lines With 6 Distributors
4 Distributors Electrodynamique
5 Distributors Electrodynamique
6 Distributors Electrodynamique
Auxiliary Distributor
Hydraulic Coupling
Male Coupler
Oil Recovery
Module Fingertip
Electrical Equipment & Instrument Panel
With Dot Matrix
Electric Equipment & Instrument Panel
Side Console Switches
External Controls Fitted On The Rear Fenders
Engine Harness
Instrument Panel Harness
Plate Relay & Fuse Holder
Up To Serial Or Engine Number N344027
From Serial Or Engine Number N344028
Pillar Harness
Handold
Automatic Air Conditioner Harness & Sensors
Electronic Equipment
Without Electronic Lift
With Dual Control
Sensor Harness Dual Control
Without Dual Control
Without Radar
With Radar
Aboard Computer And Plate Lighting Equipement
Up To 05 2006
From 03 2006
Fieldstar
Up To Serial Or Engine Number P054006
From Serial Or Engine Number P054007
Control Box Harness & Cab Controls
Transmission Main Harness
Sensors
Body
Hood
Hood Frame
Footstep
Emblems
See Next Page For Decal Location
For Uk Only Or Any Text In English Only
Literature
Tractor Cab
Cab Mountings
With Suspension
Suspended Cab Control Unit
Pressue Regulator And Filter
Compressor
Air Tank
Doors
Glass
Side Window Mechanism
Rear Window Mechanism
Roof
Cladding
Dressing Roof
Instrument Panel Cladding
Cab Insulation
Fenders
Hose
Manual Air Conditioner
High Cold
Cab Filter
Heater Control
Front Windscreen Wiper
Windscreen Washer
Up To Serial Or Engine Number N271049
From Serial Or Engine Number N271050
Standard Roof
Radio Installation
Internal Mirrors
External Mirrors
Electric Control Rear Reflecting Miror
Luxuy
Seat Belt
Secondary Seat
Lighting
North America Only
Front
Field Lights
Xenon Pivoting
Traffic Warning
Rear
Rotating Light
Rims & Wheels Weights
Wheel Hub 10 Holes Assembling
Wheel Hub 12 Holes Assembling
Rigid
Up To P033045
From P033046
Mudguards And Supports
Shaft Diameter 110 Mm Cone Wheel Hub Reversed
With Spacers For Dual Wheels Cone Wheel Hub Reversed
Wheel Weights
Wheel Wedges
Brand: Challenger
Engine & Equipment
150 Amp
Starter
Timing Gear Housing
Not For Usa
Oil Sump
Pipes
110 V
220 V
Engine Part
Additional Tank
Fuel Pipes
Compresser
Air Cooler
Dual Element
Throttle Controls
Clutch
Front Spacer
Clutch Control
Housing
Gear Box
Inner Housing
Planetary Drive
Pump Shaft
Accumulator Shaft
Hydraulique Motor
Duct Plate
Adjusting Device
Up To 903 1779
From 903 1780
Group Gear Shifting
Drive Line
Fingertip
Control Armrest
Control
Rear Axle
Handbrake
Without Breake Beam
Tie Rod
Wheel Shaft Housing
Oil Level Indicator
Bevel Drive
Disc Brakes
Cardan Brake
Lift Arms
Angle Sensor
Linkage
From 903 01471
From 903 01614
Levelling Box
Top Link Lock
Sensing Pin
Lower Bar With Hook
Tube Stabilizers
Shoe Stabilizers
Drawbar
Swinging Drawbar
Iso Standard
With Rollers
Sae Standard
Piton Attachment
Long Hay Ladder
Hitch
With Remote Control
Hydraulic
Accumulator
Pto Drive Mechanism
Up To 903 00200
From 903 01001
Bridle
Cylinder
Pto
Front Axle
With Front Lift
Belly Weight
Bracket
Final Drive
Steering Pump
Brackets Pedal
Brake Pedals
Hydraulic Pipes
Pump Drive
Filter
System Comfort
Interior
Pressure Filter
Up To 903 00104
Hydraulic Lines
Tank
Trailer Braking
Pump Filter Suction
Hydraulic Coupling
Male Coupler
Oil Recovery
Module Fingertip
With Dot Matrix
Engine Harness
Pillar Harness
Handold
With Dual Control
Without Radar
With Radar
Up To 05 2006
From 03 2006
Fieldstar
Sensors
Body
Hood
Hood Frame
Footstep
Emblems
Literature
Tractor Cab
Cab Mountings
With Suspension
Compressor
Air Tank
Doors
Glass
Roof
Cladding
Dressing Roof
Cab Insulation
Fenders
Hose
High Cold
Cab Filter
Heater Control
Windscreen Washer
Standard Roof
Radio Installation
Internal Mirrors
External Mirrors
Luxuy
Seat Belt
Secondary Seat
Lighting
North America Only
Front
Field Lights
Xenon Pivoting
Traffic Warning
Rear
Rotating Light
Rigid
Up To P033045
From P033046
Wheel Weights
Wheel Wedges
