702,019
Challenger Tractor MT585D Parts Catalog 3906359
Brand: Challenger
Model: Challenger MT585D With AutoPower VI Tractor
Serial Number: B356075 - E272016
Part Number: 3906359
Number of Pages: 989 Pages
Engine & Equipment
Engine Tier 2
Cylinder-Block
Timing Gear Housing
Flywheel & Flywheel Housing
Crankshaft, Pistons & Piston Rod
Camshaft & Valve Mechanism
Cylinder Head Cover
Oil Sump
Oil Cooler & Filter
Engine Breather
Injection System
Low Pressure Fuel System
Intake & Exhaust Manifold
Pipes
Electronic Engine Management
Engine Parts
Piston- Cylinder Head With Valves
Engine Gaskets Sets
1 Alternator
2 Alternators
110 V
220 V
Engine Part
Fuel Tank & Attachments
Fuel Tank (Components)
(Components)
Breather Line
Fuel System
Air Conditioned Installation
Oil Recovery
Dual Element
Vertical Exhaust On The Side
Pollution Control
Throttle Controls
Weight Carrier & Runner
Weight Frame And Tow Pin
265 Kg
With Front Linkage 40000n
Bracket
Differential Lock Mechanism
Guard And Transmission Shaft
Clutch
Front Axle 4 Wheel Drive
Housing
Final Drive
Hydraulic Valve Block
Steering Wheel And Telescopic Column
Steering Hydraulic Lines
With Auto-Guide
Auto Guide
Damper
Multiplicateur
Dual Clutch
Reverse Gear
Layshaft
Output Shaft
Synchro
Fork
Cover
Wet Clutch With Power Shuttle
Creeper Gear
Without Creeper Gear
Control Armrest
Centre Housing
Multidiscs
Rear Axle Differential
Outer Final Drive Gear
Double Clutch
Input Box & Dual Clutch
Gear Box For Power Shuttle
Pipes And Fitting
Brake Pedals
Pneumatic Feeding
Trailor Brake
Handbrake
Lower Control
Disc Brakes
Compressed Air System
Air Compressor
Front Suspension Hydraulic Lines
Oiling
Load Sensing Hydraulic
Cover Right
Right Cover
Rear Axle
Air Intake Tubes Rear Axle
Hydraulic Coupling
Oil Filler Pipe
Auxiliary Distributor
Load Sensing
2 Distributors Electrodynamique And 2 Mechanical Control
3 Distributors
Control With 2 Distributors Electrodynamique
Batteries And Cables
Instrument Panel & Instruments
Side Console Switches
Without Multifunction Armrest
Lighting & Power Shuttle Drive
External Controls Fitted On The Rear Fenders
Engine Harness
Plate Relay & Fuse Holder
Decal
Roof Harness
Autoguide 3000 & C3000
Auto-Guide
Field Lights Harness
Front Lightning Harness
Rear Lightning Harness
Sensors
Main Harness
Console
Aboard Computer
Plate Lighting Equipement
Radar
Autoguide 3000
Harness Isobus
Front Axle Suspended Harness Control Box
Control Box Harness & Cab Controls
Transmission Main Harness
Grill
Front
Working Light
Traffic Warning
Rear
Extension
Rotating Light
Cab Mountings
With Suspension
Tractor Cab
Glass
Left Side
Right Side
Rear Window Mechanism
Roof
Cladding
Instrument Panel Cladding
Cab Insulation
Fenders
Standard Roof
Manual Air Conditioner
Automatic Air Conditioner
Heater Control
Radio Installation
Electrical Plug & Cigar Lighter
Eec Standard
Sae Standard
Internal Mirrors
External Mirrors
Electric Control Rear Reflecting Miror
Seat Belt
Secondary Seat
Grille
Hood
Hood Frame
Tool Box
Literature
Basic
Emblems
With Electro-Hydraulic Control
Decal Hydraulic Controls
Speed Charts
Safety
4 Wheels Drive
Mudguards And Supports
Wheel Hub 10 Holes Assembling
Fixing By Cone
Rear Wheel Weights
Implement Drive System
Pto Shaft
Independant Power Take Off Clutch
Brake
Pto-Coupling Drive Mechanism
Drive
Pump
Ipto Clutch
Lift Arms
Lift Cylinders
Lift Cylinders Feeding
Linkage
Levelling Box
Top Link With Hook End
Hydraulic
Top Link With Ball End
Top Link Lock
Sensing Pin
Lower Bar With Toogle
Lower Bar With Hook
Tube Stabilizers
Shoe Stabilizers
Swinging Drawbar
Bearing Carrier
Swinging Drawbar Support
Short Hay Ladder
Germany
Hitch
Iso Standard
Hydraulic Lines
Lift External Control
Controls
Front Rear Loaders
Frame
Alternator & Bracket
Heater Engine Block
Kit
Beam Support
Water Fuel Separator
Front Pto
80mm
Front Linkage
Quick Coupling
Complemantary Products
Datatronic Kit
Video Camera Kit
Axle Kit Follower
Appliance Bracket Boarded For Cab
Dealer Stocking List
