Challenger Tractor MT585B Parts Catalog 3906276
Brand: Challenger
Model: Challenger MT585B With Techstar CVT Tier 3 SISU Engine Tractor
Part Number: 3906276
Number of Pages: 717 Pages
Dealer Stocking List
Quantity By Tractor
Engine & Equipment
With 175 Amp Alternator
Starter
Timing Gear Housing
Crankshaft, Pistons & Connecting Rods
Valve Mechanism And Camshaft
Cylinder Head Cover
Oil Sump
Lubricating Oil Cooler And Filter
Injection System
Low Pressure Fuel System
Air Induction & Exhaust
Pipes
Electronic Engine Management
Piston- Cylinder Head With Valves
Engine Gaskets Sets
110 V
220 V
Engine Part
Fuel Tank & Attachments
North America Only
Without Additional Tank
United States Only
Up To Serial Or Engine Number V288055
From Serial Or Engine Number V288056
Without Battery Cut-Off
With Battery Cut-Off
Air Conditioned Installation
Compresser
Pivoting Chassis
Dual Element
Air Cooler
Vertical Exhaust On The Side
Throttle Controls
Clutch
Front Spacer
Flywheel & Flywheel Housing
Clutch Control
From Serial No B132016
Housing
Gear Box
Inner Housing
Planetary Drive
Pump Shaft
Accumulator Shaft
Hydraulique Motor
Duct Plate
Adjusting Device
Transmission Control
Linings System Comfort
Group Gear Shifting
Drive Line
Range
Joystick For Distributor With Electrodynamique Control
Control Armrest
Fingertip
Control
Rear Axle
Handbrake
Without Breake Beam
For Europe
Oil Level Indicator
Hydraulic Lines
Bevel Drive
Inner Final Drive Gear
Disc Brakes
Cardan Brake
Lift Arms
Angle Sensor
Linkage
Lift Cylinders
Lift Cylinders Feeding
Weight Frame And Tow Pin
Levelling Box
Top Link With Hook End
Lower Bar With Hook
Top Link With Ball End
Top Link Lock
Sensing Pin
Telescopic Lower Bar
Tube Stabilizers
Sae Standard
Iso Standard
Without Rings
Swinging Drawbar Support
Hitch
For Germany Only Or Any Text In German Only
Protection Guard
Up To Serial Or Engine Number B250046
From Serial Or Engine Number B250047
With Front Dual Control
Lift External Control
With Front Linkage 40000n
2-3-4 Distributors
Pto Drive Mechanism
Independant Power Take Off Clutch
Brake
With 3 Speed Shiftable Ipto
Bridle
With Clevis Quick Adjustment
Pto
Up To Serial Or Engine Number V068035
From Serial Or Engine Number V068036
Ipto Clutch
Front Axle
Weight Carrier & Runner
Belly Weight
Front Axle Fixed
With Suspended Front Axle
Differential Lock Mechanism
Hydraulic Valve Block
Hydraulic
Steering Wheel And Telescopic Column
Lighting Power Shuttle Drive
Steering Pump
Autoguide
Steering Hydraulic Lines
Front Suspension Hydraulic Lines
Transmission Hydraulic
Auxiliary Hydraulics
Brackets Pedal
With Power Brakes
Pipes And Fitting
Hydraulic Brake Assy
Pump Drive
Filter
Pump Installation
Gear Box Lubrication
Interior
Pressure Filter
Up To Serial Or Engine Number V341072
From Serial Or Engine Number V341073
With Parking Brake
Hydraulique Manifold
Load Sensing
Male Coupler
Auxiliary Distributors Installation
3 Distributors With Mechanical Control
4 Distributors With Mechanical Control
2 Distributors Electrodynamique And 2 Mechanical Control
4 Distributors Electrodynamique
Hydraulic Lift Distributor
3 Distributors
4 Distributors
Control Casing
Decal Hydraulic Controls
Electrical Equipment & Instrument Panel
With Dot Matrix
Side Console Switches
Electric Equipment & Instrument Panel
External Controls Fitted On The Rear Fenders
Engine Harness
Front Pto Harness
Up To Serial Or Engine Number V061004
Up To V197008
From Serial Or Engine Number V197009
Armrest
Plate Relay & Fuse Holder
Roof Harness
Auto Guide
Handold
Pillar Harness
Not For Usa
For United States Of America
Rear Lightning Harness
Trailor Electric Socket
Harness Front Electrical Plug
Automatic Air Conditioner Harness & Sensors
Electronic Equipment
Without Parking Brake
With Dual Control
Console
Aboard Computer And Plate Lighting Equipement
Up To Serial Or Engine Number U310040
From Serial Or Engine Number U310041
Auto-Guide
Harness Isobus
Control Box Harness & Cab Controls
Front Axle Suspended Harness Control Box
Transmission Main Harness
Sensors
Body
Excepted North America
Hood
Left Side
Right Side
4 Th Stair
Tool Box
Up To V182034
From V182035
Speed Charts
Safety
See Next Page For Decal Location
Literature
With Auto-Guide
Tractor Cab
Cab Mountings
With Suspension
Suspended Cab Control Unit
Pressue Regulator And Filter
Compressor
Air Tank
Sheet Metal Seal
Doors
Glass
Side Window Mechanism
Rear Window Mechanism
Roof
Dressing Roof
Cladding
Instrument Panel Cladding
Cab Insulation
Fenders
Hose
Manual Air Conditioner
Cab Filter
Heater Control
Front Windscreen Wiper
Rear Window Wiper
Windscreen Washer
Canopy
Radio Installation
Agcommand
Electrical Plug & Cigar Lighter
Internal Mirrors
External Mirrors
Electric Control Rear Reflecting Miror
Luxuy
Air Pressure Seat With Manual Adjustment
Adjustable Damper
Secondary Seat
Seat Belt
Lighting
Front
Working Light
Standard Roof
Traffic Warning
Rear
Rotating Light
Rims & Wheels Weights
Wheel Hub 10 Holes Assembling
Rigid
Up To .....
From .....
Compatible For Way Foward 60
Compatible For Way Foward 60 From ...
Pivoting
Shaft Diameter 95 Mm
Shaft Diameter 95 Mm Cone Wheel Hub Reversed
Wheel Weights
Brand: Challenger
Quantity By Tractor
Engine & Equipment
Starter
Timing Gear Housing
Cylinder Head Cover
Oil Sump
Injection System
Pipes
Engine Gaskets Sets
110 V
220 V
Engine Part
North America Only
United States Only
Compresser
Pivoting Chassis
Dual Element
Air Cooler
Throttle Controls
Clutch
Front Spacer
Clutch Control
Housing
Gear Box
Inner Housing
Planetary Drive
Pump Shaft
Accumulator Shaft
Hydraulique Motor
Duct Plate
Adjusting Device
Group Gear Shifting
Drive Line
Range
Control Armrest
Fingertip
Control
Rear Axle
Handbrake
Without Breake Beam
For Europe
Oil Level Indicator
Hydraulic Lines
Bevel Drive
Disc Brakes
Cardan Brake
Lift Arms
Angle Sensor
Linkage
Lift Cylinders
Levelling Box
Lower Bar With Hook
Top Link Lock
Sensing Pin
Tube Stabilizers
Sae Standard
Iso Standard
Without Rings
Hitch
Protection Guard
2-3-4 Distributors
Pto Drive Mechanism
Brake
Bridle
Pto
Ipto Clutch
Front Axle
Belly Weight
Front Axle Fixed
Hydraulic
Steering Pump
Autoguide
Brackets Pedal
With Power Brakes
Pipes And Fitting
Pump Drive
Filter
Pump Installation
Interior
Pressure Filter
With Parking Brake
Load Sensing
Male Coupler
3 Distributors
4 Distributors
Control Casing
With Dot Matrix
Engine Harness
Front Pto Harness
Up To V197008
Armrest
Roof Harness
Auto Guide
Handold
Pillar Harness
Not For Usa
With Dual Control
Console
Auto-Guide
Harness Isobus
Sensors
Body
Hood
Left Side
Right Side
4 Th Stair
Tool Box
Up To V182034
From V182035
Speed Charts
Safety
Literature
With Auto-Guide
Tractor Cab
Cab Mountings
With Suspension
Compressor
Air Tank
Sheet Metal Seal
Doors
Glass
Roof
Dressing Roof
Cladding
Cab Insulation
Fenders
Hose
Cab Filter
Heater Control
Rear Window Wiper
Windscreen Washer
Canopy
Radio Installation
Agcommand
Internal Mirrors
External Mirrors
Luxuy
Adjustable Damper
Secondary Seat
Seat Belt
Lighting
Front
Working Light
Standard Roof
Traffic Warning
Rear
Rotating Light
Rigid
Up To .....
From .....
Pivoting
Wheel Weights
