702,019
Challenger Tractor MT585B Parts Catalog 3906274
Brand: Challenger
Model: Challenger MT585B With AutoPower VI Tier 3 SISU Engine Tractor
Part Number: 3906274
Number of Pages: 708 Pages
Dealer Stocking List
Quantity By Tractor
Engine & Equipment
Alternator & Bracket
With 175 Amp Alternator
Timing Gear Housing
Crankshaft, Pistons & Connecting Rods
Valve Mechanism And Camshaft
Cylinder Head Cover
Oil Sump
Lubricating Oil Cooler And Filter
Injection System
Low Pressure Fuel System
Air Induction & Exhaust
Pipes
Electronic Engine Management
Piston- Cylinder Head With Valves
Engine Gaskets Sets
220 V
Engine Part
Fuel Tank & Attachments
North America Only
Fuel Pipes
United States Only
Up To Serial Or Engine Number V288055
From Serial Or Engine Number V288056
Without Battery Cut-Off
With Battery Cut-Off
Air Conditioned Installation
Compresser
Pivoting Chassis
Dual Element
Air Cooler
Vertical Exhaust On The Side
Throttle Controls
Clutch
Front Spacer
Flywheel & Flywheel Housing
With Power Shuttle
From Serial No B130071
Housing
Multiplicateur
Dual Clutch
Reverse Gear
From V126027
Layshaft
Output Shaft
Synchro
Cover
Up To V126026
With Trailer Braking Up To V126026
From Serial N° V126027
Up To N° V126026
With Brakes High Pressure- Without Trailer Braking From V126027
Fork
Without Creeper Gear
Transmission Control
With Autodrive
Control Armrest
Joystick For Distributor With Electrodynamique Control
Rear Axle
Handbrake
Mechanism
Centre Housing
7 Differential
With 50kph Tractor
With Composite Reducer
With Sealed Rear Axle Housing
Linkage
Lift Arms
Lift Cylinders
From V126027 Up To B314046
From Serial Or Engine Number B314047
Levelling Box
Top Link With Hook End
Top Link With Ball End
Top Link Lock
Sensing Pin
Lower Bar With Hook
Telescopic Lower Bar
Tube Stabilizers
Shoe Stabilizers
Bearing Carrier
Iso Standard
Sae Standard
40km H 24.8 Mph
Sae
Short Hay Ladder
Long Hay Ladder
Hitch
Up To Serial Or Engine Number B250046
From Serial Or Engine Number B250047
Without Linkage
2-3-4 Distributors
With Front Linkage 40000n
Accumulator
Up To N093021
Pto Drive Mechanism
Pto Shaft
6 Discs
P.T.O
Cable Control
Pto-Coupling Drive Mechanism
540 E
Drive
Ipto Clutch
Front Axle
Weight Carrier & Runner
Weight Frame And Tow Pin
Belly Weight
Front Axle Fixed
With Suspended Front Axle
Differential Lock Mechanism
Hydraulic Valve Block
Hydraulic
Steering Wheel And Telescopic Column
With Dot Matrix
Lighting Power Shuttle Drive
Four Wheel Drive
Autoguide
Front Suspension Hydraulic Lines
Transmission Hydraulic
Brackets Pedal
With 50 Km H Tractor
Brake Valve
Brake Pedals
Oiling
Pump
Up To Serial Or Engine Number B040053
From Serial Or Engine Number B040054
Without Trailer Braking Up To V126026
With Brakes High Pressure- Without Trailer Braking Up To V126026
Cover Right
Up To U330004
From U330005
Up To B314046
From B314047
Right Cover
With Sealed Housing
Oil Filler Pipe
Load Sensing
Male Coupler
Up To C131025
Without Hydraulic Coupling
3 Distributors With Mechanical Control
4 Distributors With Mechanical Control
2 Distributors Electrodynamique And 2 Mechanical Control
Hydraulic Lift Distributor
Auxiliary Distributor
3 Distributors
4 Distributors
Control Casing
Decal Hydraulic Controls
Electrical Equipment & Instrument Panel
Instrument Panel & Instruments
Electric Equipment & Instrument Panel
External Controls Fitted On The Rear Fenders
Side Console Switches
Engine Harness
Up To Serial Or Engine Number V165036
From Serial Or Engine Number V165037
Armrest
Roof Harness
Plate Relay & Fuse Holder
Handold
Pillar Harness
Not For Usa
For United States Of America
Rear Lightning Harness
Trailor Electric Socket
Harness Front Electrical Plug
Electronic Equipment
Sensors
Main Harness
Console
Aboard Computer And Plate Lighting Equipement
Up To Serial Or Engine Number U310040
From Serial Or Engine Number U310041
Front Axle Suspended Harness Control Box
Transmission Main Harness
Up To Serial Or Engine Number U239046
From Serial Or Engine Number U239047
Auto-Guide
Harness Isobus
Auto Guide
Body
Excepted North America
Hood
Left Side
Right Side
4 Th Stair
Tool Box
Up To V182034
From V182035
Speed Charts
Safety
See Next Page For Decal Location
Literature
Tractor Cab
Cab Mountings
Suspended Cab Control Unit
Pressue Regulator And Filter
Compressor
Air Tank
Sheet Metal Seal
Doors
Glass
Side Window Mechanism
Rear Window Mechanism
Roof
Fenders
Dressing Roof
Cladding
Instrument Panel Cladding
Cab Insulation
Hose
Manual Air Conditioner
Cab Filter
Heater Control
Front Windscreen Wiper
Rear Window Wiper
Windscreen Washer
Canopy
Radio Installation
Agcommand
Internal Mirrors
External Mirrors
Electric Control Rear Reflecting Miror
Secondary Seat
Seat Belt
Lighting
Front
Working Light
Traffic Warning
Rear
Rotating Light
Rims & Wheels Weights
Wheel Hub 8 Holes Fixing
Wheel Hub 10 Holes Assembling
Wheel Hub 10 Holes Fixing 8 Bridge Pieces
Rigid
Compatible For Way Foward 60
Compatible For Way Foward 60 From ...
Pivoting
Shaft Diameter 110 Mm
Repair Kit
Gear Box For Power Shuttle
