Challenger Tractor MT575B Parts Catalog 3906118
Brand: Challenger
Model: Challenger MT575B With Techstar CVT Tier 3 Caterpillar Engine Tractor
Part Number: 3906118
Number of Pages: 851 Pages
Dealer Stocking List
Quantity By Tractor
Engine & Equipment
Up To Serial Or Engine Number R290060
From Serial Or Engine Number R290061
Alternator & Bracket
Starter
110 V
220 V
Engine Part
Water Fuel Separator
Fuel Tank & Attachments
North America Only
Up To Serial Or Engine Number U061044
From Serial Or Engine Number U061045
United States Only
Without Battery Cut-Off
With Battery Cut-Off
Air Conditioned Installation
Compresser
Pivoting Chassis
Dual Element
Air Cooler
Vertical Exhaust On The Side
Throttle Controls
Clutch
Front Spacer
Flywheel & Flywheel Housing
Clutch Control
From Serial No B132016
Housing
Power Management
Gear Box
Inner Housing
Planetary Drive
Pump Shaft
Accumulator Shaft
Hydraulique Motor
Duct Plate
Adjusting Device
Up To 701 5030
From 701 5031
Linings System Comfort
Group Gear Shifting
Drive Line
Range
Control Armrest
Fingertip
Joystick For Distributor With Electrodynamique Control
Control
Rear Axle
Handbrake
Without Breake Beam
For Europe
Oil Level Indicator
Hydraulic Lines
Bevel Drive
Inner Final Drive Gear
Up To 701 5233
From 701 5234
Cardan Brake
Lift Arms
Angle Sensor
Linkage
Lift Cylinders
Lift Cylinders Feeding
Levelling Box
Top Link With Hook End
Top Link With Ball End
Top Link Lock
Sensing Pin
Lower Bar With Hook
Telescopic Lower Bar
Tube Stabilizers
Without Rings
Iso Standard
Sae Standard
Hitch
For Germany Only Or Any Text In German Only
Peak On Scale
Swinging Drawbar Tidying
Protection Guard
Up To Serial Or Engine Number B250046
From Serial Or Engine Number B250047
With Front Dual Control
Without Linkage
2-3-4 Distributors
Hydraulic
Load Sensing
4 Quick Couplers
Accumulator
Without Front Linkage
Control Lever
Pto Drive Mechanism
Independant Power Take Off Clutch
Brake
With 3 Speed Shiftable Ipto
Bridle
With Clevis Quick Adjustment
Pto
Up To Serial Or Engine Number V068035
From Serial Or Engine Number V068036
Up To Serial Or Engine Number U118058
From U118059 Up To U155020
From Serial Or Engine Number U155021
Ipto Clutch
Front Axle
Weight Carrier & Runner
Weight Frame And Tow Pin
Belly Weight
Front Axle Fixed
With Suspended Front Axle
Differential Lock Mechanism
C048027
Auto Guide Sensor Up To S253065
Up To Serial Or Engine Number U285038
From Serial Or Engine Number U285039
Steering Wheel And Telescopic Column
Lighting Power Shuttle Drive
Four Wheel Drive
Autoguide
Front Suspension Hydraulic Lines
Transmission Hydraulic
Auxiliary Hydraulics
Brackets Pedal
Brake Pedals
Pipes And Fitting
Hydraulic Brake Assy
Pump Drive
Filter
Pump Installation
Gear Box Lubrication
Interior
Up To Serial Or Engine Number 701 6018
From Serial Or Engine Number 701 6019
Hydraulic Valve Block
From R......
Up To Serial Or Engine Number V341072
From Serial Or Engine Number V341073
With Parking Brake
Hydraulique Manifold
Male Coupler
Auxiliary Distributors Installation
3 Distributors With Mechanical Control
2 Distributors Electrodynamique And 1 Mechanical Control
4 Distributors With Mechanical Control
2 Distributors Electrodynamique And 2 Mechanical Control
4 Distributors Electrodynamique
Hydraulic Lift Distributor
3 Distributors
4 Distributors
Control Casing
Decal Hydraulic Controls
Electrical Equipment & Instrument Panel
With Dot Matrix
Electric Equipment & Instrument Panel
Side Console Switches
External Controls Fitted On The Rear Fenders
Engine Harness
Front Pto Harness
Up To Serial Or Engine Number V061004
Up To V197008
From Serial Or Engine Number V197009
Armrest
Plate Relay & Fuse Holder
Roof Harness
Up To Serial Or Engine Number T059059
From Serial Or Engine Number T059060
Pillar Harness
Not For Usa
For United States Of America
Trailor Electric Socket
Handold
Harness Front Electrical Plug
Automatic Air Conditioner Harness & Sensors
Electronic Equipment
Without Parking Brake
With Dual Control
Without Dual Control
Console
Aboard Computer And Plate Lighting Equipement
Up To U268039 For Great Britai N
From U268040 For Great Britain
Auto-Guide
Harness Isobus
Fieldstar
With Autotronic 5
Front Axle Suspended Harness Control Box
Control Box Harness & Cab Controls
Up To Serial Or Engine Number U279000
From U279001 Up To V034031
From V034032
Sensors
Body
Excepted North America
Hood
Left Side
Up To 27-Sep-2006
Up To T022027
From T022028
Right Side
4 Th Stair
Tool Box
Up To V181014
From V181015
Speed Charts
Up To U068065
From U068066
Literature
With Auto-Guide
Tractor Cab
Cab Mountings
Up To S333079
From S333080
Suspended Cab Control Unit
Pressue Regulator And Filter
Up To S331034
From S331035
Doors
Glass
Side Window Mechanism
Rear Window Mechanism
Roof
Cladding
Dressing Roof
Instrument Panel Cladding
Cab Insulation
Fenders
Manual Air Conditioner
Hose
Air Conditioner
Cab Filter
Heater Control
Front Windscreen Wiper
Rear Window Wiper
Windscreen Washer
Canopy
Radio Installation
Agcommand
Internal Mirrors
Up To T014047
From T014048
From T014047
Up To T014046
Luxuy
Adjustable Damper
Air Pressure Seat
Seat Belt
Secondary Seat
Lighting
Front
Working Light
Standard Roof
Traffic Warning
Rear
Rotating Light
Rims & Wheels Weights
Wheel Hub 10 Holes Assembling
Rigid
Up To .....
From .....
Compatible For Way Foward 60 Up To ...
Compatible For Way Foward 60 From ...
Pivoting
With 8 Hole Fixing
Shaft Diameter 95 Mm
Shaft Diameter 95 Mm Cone Wheel Hub Reversed
Short Shaft Diameter 95 Mm With Spacers For Dual Wheels Cone Wheel Hub Reversed
Distance Spacer For Wide Tread
Wheel Weights
Technology Systems
Top Dock
Base Station
Radio Antenna
Tripod
Brand: Challenger
Quantity By Tractor
Engine & Equipment
Starter
110 V
220 V
Engine Part
North America Only
United States Only
Compresser
Pivoting Chassis
Dual Element
Air Cooler
Throttle Controls
Clutch
Front Spacer
Clutch Control
Housing
Power Management
Gear Box
Inner Housing
Planetary Drive
Pump Shaft
Accumulator Shaft
Hydraulique Motor
Duct Plate
Adjusting Device
Up To 701 5030
From 701 5031
Group Gear Shifting
Drive Line
Range
Control Armrest
Fingertip
Control
Rear Axle
Handbrake
Without Breake Beam
For Europe
Oil Level Indicator
Hydraulic Lines
Bevel Drive
Up To 701 5233
From 701 5234
Cardan Brake
Lift Arms
Angle Sensor
Linkage
Lift Cylinders
Levelling Box
Top Link Lock
Sensing Pin
Lower Bar With Hook
Tube Stabilizers
Without Rings
Iso Standard
Sae Standard
Hitch
Peak On Scale
Protection Guard
Without Linkage
2-3-4 Distributors
Hydraulic
Load Sensing
4 Quick Couplers
Accumulator
Control Lever
Pto Drive Mechanism
Brake
Bridle
Pto
Ipto Clutch
Front Axle
Belly Weight
Front Axle Fixed
C048027
Four Wheel Drive
Autoguide
Brackets Pedal
Brake Pedals
Pipes And Fitting
Pump Drive
Filter
Pump Installation
Interior
From R......
With Parking Brake
Male Coupler
3 Distributors
4 Distributors
Control Casing
With Dot Matrix
Engine Harness
Front Pto Harness
Up To V197008
Armrest
Roof Harness
Pillar Harness
Not For Usa
Handold
With Dual Control
Console
Auto-Guide
Harness Isobus
Fieldstar
With Autotronic 5
From V034032
Sensors
Body
Hood
Left Side
Up To 27-Sep-2006
Up To T022027
From T022028
Right Side
4 Th Stair
Tool Box
Up To V181014
From V181015
Speed Charts
Up To U068065
From U068066
Literature
With Auto-Guide
Tractor Cab
Cab Mountings
Up To S333079
From S333080
Up To S331034
From S331035
Doors
Glass
Roof
Cladding
Dressing Roof
Cab Insulation
Fenders
Hose
Air Conditioner
Cab Filter
Heater Control
Rear Window Wiper
Windscreen Washer
Canopy
Radio Installation
Agcommand
Internal Mirrors
Up To T014047
From T014048
From T014047
Up To T014046
Luxuy
Adjustable Damper
Air Pressure Seat
Seat Belt
Secondary Seat
Lighting
Front
Working Light
Standard Roof
Traffic Warning
Rear
Rotating Light
Rigid
Up To .....
From .....
Pivoting
With 8 Hole Fixing
Wheel Weights
Technology Systems
Top Dock
Base Station
Radio Antenna
Tripod
