Challenger Tractor MT575B Parts Catalog 3906067
Brand: Challenger
Model: Challenger MT575B With AutoPower IV SISU Engine Tractor
Part Number: 3906067
Number of Pages: 526 Pages
Engine & Equipment
Alternator & Bracket
150 Amp
120 Amp
Starter
Timing Gear Housing
Crankshaft, Piston & Connecting Rods
Valve Mechanism And Camshaft
Cylinder Head Cover
Thermostat
Oil Sump
Lubricating Oil Pump
Lubricating Oil Cooler And Filter
Injection System
Low Pressure Fuel System
Air Induction & Exhaust
Pipes
Electronic Engine Management
Piston- Cylinder Head With Valves
Engine Gaskets Sets
220 V
Engine Part
Fuel Tank & Attachments
Fuel System
Fuel Pipes
Without Battery Cut-Off
With Battery Cut-Off
Air Conditioned Installation
Compresser
Dual Element
Vertical Exhaust On The Side
Throttle Controls
Clutch
Front Spacer
Flywheel & Flywheel Housing
Wet Clutch With Power Shuttle
Power Shuttle
Front Spacer With Power Shuttle
Load Sensing
With Power Shuttle
Housing
Dynashift With Power Shuttle
Layshaft
Mainshaft
Output Shaft
Cover
Dynashift Transmission Without Creeper Gear
Shift Lever
Control Armrest
Joystick For Distributor With Electrodynamique Control
Rear Axle
Handbrake
Mechanism
Centre Housing
7 Differential
Shaft Diameter 95 Mm With Sealed Housing Up To ...
With Shaft Diameter 95 Mm With Sealed Rear Axle Housing From
With Sealed Rear Axle Housing From Serial Number
Linkage
Lift Arms
Lift Cylinders
Lift Cylinders Feeding
Levelling Box
Top Link With Hook End
Top Link Lock
Sensing Pin
Lower Bar With Hook
Tube Stabilizers
With Shoes
With Long Hay Ladder With Ring
With Or Without Rings
Cramer
Pto Drive Mechanism
Pto Shaft
6 Discs
P.T.O
Cable Control
Four Speed
Pto-Coupling Drive Mechanism
Iso Standard
Front Axle
Weight Frame And Tow Pin
Belly Weight
Chassis Structure
Bracket
Differential Lock Mechanism
Guard And Transmission Shaft
Front Axle Fixed Carraro
Front Axle Suspended Carraro
Final Drive
Arms
Shock Absorber
Up To P328069
From P328070
Hydraulic
Steering Wheel And Telescopic Column
Lighting Power Shuttle Drive
Four Wheel Drive
Four Wheel Drive Load Sensing
Brackets Pedal
Brake Pedals
Without Trailer Braking
Oiling
With Hydraulic Pump 110 L Mn
Without Trailor Braking
With Load Sensing
Air Intake Tubes Rear Axle
Oil Filler Pipe
2-3-4 Distributors
Up To ...
From ...
3 Distributors With Mechanical Control
2 Distributors Electrodynamique And 2 Mechanical Control
Auxiliary Distributor
Hydraulic Lift Distributor
3 Distributors
4 Distributors
Control Casing
Decal Hydraulic Controls
Electrical Equipment & Instrument Panel
With Dot Matrix
Instrument Panel & Instruments
Electric Equipment & Instrument Panel
Side Console Switches
External Controls Fitted On The Rear Fenders
Engine Harness
Up To P180005 Without Datatronic 2
From P180006 Without Datatronic 3
Armrest
Plate Relay & Fuse Holder
Roof Harness
Pillar Harness
Rear Lightning Harness
Trailor Electric Socket
Handold
Electronic Equipment
Console
Main Harness
Without Dual Control
Diagnostic Harness
Aboard Computer And Plate Lighting Equipement
Fieldstar
With Parking Brake-Up To P180005 Without Datatronic 2
Without Parking Brake-Up To P180005 Without Datatronic 2
Front Axle Suspended Harness Control Box
With Parking Brake Load Sensing
Without Parking Brake Load Sensing
Sensors
Body
Grille
Hood
Pivoting Front Hood
Brackets And Assembling Parts
Left Side
Right Side
Tool Box
Speed Charts
For Uk Only Or Any Text In English Only
Emblems
Literature
Tractor Cab
Cab Mountings
With Suspension
Suspended Cab Control Unit
Pressue Regulator And Filter
Compressor
Air Tank
Doors
Glass
Side Window Mechanism
Rear Window Mechanism
Roof
Cladding
Dressing Roof
Instrument Panel Cladding
Cab Insulation
Fenders
Hose
Manual Air Conditioner
Standard Roof
Heater Control
Windscreen Washer
Front Windscreen Wiper
Rear Window Wiper
Radio Installation
Internal Mirrors
External Mirrors
Seat Belt
Secondary Seat
Lighting
Front
Field Lights
Rear
Rotating Light
Rims & Wheels Weights
Wheel Hub 10 Holes Assembling
Wheel Hub 10 Holes Fixing 6 Bridge Pieces
Mudguards And Supports
Rigid
With 8 Hole Fixing
Rear Wheels Titan
Distance Spacer For Wide Tread
Repair Kit
Gear Box For Power Shuttle
Brand: Challenger
Engine & Equipment
150 Amp
120 Amp
Starter
Timing Gear Housing
Cylinder Head Cover
Thermostat
Oil Sump
Injection System
Pipes
Engine Gaskets Sets
220 V
Engine Part
Fuel System
Fuel Pipes
Compresser
Dual Element
Throttle Controls
Clutch
Front Spacer
Power Shuttle
Load Sensing
With Power Shuttle
Housing
Layshaft
Mainshaft
Output Shaft
Cover
Shift Lever
Control Armrest
Rear Axle
Handbrake
Mechanism
Centre Housing
7 Differential
Linkage
Lift Arms
Lift Cylinders
Levelling Box
Top Link Lock
Sensing Pin
Lower Bar With Hook
Tube Stabilizers
With Shoes
Cramer
Pto Drive Mechanism
Pto Shaft
6 Discs
P.T.O
Cable Control
Four Speed
Iso Standard
Front Axle
Belly Weight
Chassis Structure
Bracket
Final Drive
Arms
Shock Absorber
Up To P328069
From P328070
Hydraulic
Four Wheel Drive
Brackets Pedal
Brake Pedals
Oiling
With Load Sensing
Oil Filler Pipe
2-3-4 Distributors
Up To ...
From ...
3 Distributors
4 Distributors
Control Casing
With Dot Matrix
Engine Harness
Armrest
Roof Harness
Pillar Harness
Handold
Console
Main Harness
Diagnostic Harness
Fieldstar
Sensors
Body
Grille
Hood
Pivoting Front Hood
Left Side
Right Side
Tool Box
Speed Charts
Emblems
Literature
Tractor Cab
Cab Mountings
With Suspension
Compressor
Air Tank
Doors
Glass
Roof
Cladding
Dressing Roof
Cab Insulation
Fenders
Hose
Standard Roof
Heater Control
Windscreen Washer
Rear Window Wiper
Radio Installation
Internal Mirrors
External Mirrors
Seat Belt
Secondary Seat
Lighting
Front
Field Lights
Rear
Rotating Light
Rigid
With 8 Hole Fixing
Rear Wheels Titan
Repair Kit
