702,019
Challenger Tractor MT575B Parts Catalog 3906065
Brand: Challenger
Model: Challenger MT575B With Techstar CVT SISU Engine Tractor
Part Number: 3906065
Number of Pages: 543 Pages
Engine & Equipment
Alternator & Bracket
120 Amp
150 Amp
Starter
Timing Gear Housing
Flywheel & Flywheel Housing
Crankshaft, Piston & Connecting Rods
Valve Mechanism And Camshaft
Cylinder Head Cover
Thermostat
Oil Sump
Lubricating Oil Pump
Lubricating Oil Cooler And Filter
Injection System
Low Pressure Fuel System
Air Induction & Exhaust
Pipes
Electronic Engine Management
Piston- Cylinder Head With Valves
Engine Gaskets Sets
220 V
Engine Part
Fuel Tank & Attachments
Fuel System
Fuel Pipes
Without Battery Cut-Off
With Battery Cut-Off
Air Conditioned Installation
Compresser
Dual Element
Vertical Exhaust On The Side
Throttle Controls
Clutch
Front Spacer
Clutch Control
Housing
Gear Box
Inner Housing
Planetary Drive
Pump Shaft
Accumulator Shaft
Hydraulique Motor
Duct Plate
Adjusting Device
Up To 701 3831
From 701 3832
Linings System Comfort
Group Gear Shifting
Drive Line
Control Armrest
Joystick For Distributor With Electrodynamique Control
Rear Axle
Handbrake
Wheel Shaft Housing
Oil Level Indicator
Hydraulic Lines
Bevel Drive
Inner Final Drive Gear
Disc Brakes
Cardan Brake
Lift Arms
Angle Sensor
Linkage
Lift Cylinders
Lift Cylinders Feeding
Levelling Box
Top Link With Hook End
Top Link Lock
Sensing Pin
Lower Bar With Hook
Tube Stabilizers
Iso Standard
Without Rings
Hitch
For Germany Only Or Any Text In German Only
Protection Guard
Pto Drive Mechanism
Independant Power Take Off Clutch
Brakes
With 3 Speed Shiftable Ipto
Bridle
With Clevis Quick Adjustment
Front Axle
Weight Frame And Tow Pin
Belly Weight
Bracket
Differential Lock Mechanism
Guard And Transmission Shaft
Front Axle Suspended Carraro
Final Drive
Arms
Shock Absorber
Up To P328069
From P328070
Hydraulic
Steering Wheel And Telescopic Column
Lighting Power Shuttle Drive
Four Wheel Drive
Steering Hydraulic Lines
Front Suspension Hydraulic Lines
Brackets Pedal
Brake Pedals
Pipes And Fitting
Hydraulic Brake Assy
Pump Drive
Filter
Up To 701 1551
From 701 1552
Gear Box Lubrication
Interior
Pressure Filter
Hydraulic Valve Block
Pump Installation
Transmission Hydraulic
Auxiliary Hydraulics
With Suspended Front Axle
Hydraulique Manifold
Auxiliary Distributors Installation
3 Distributors With Mechanical Control
2 Distributors Electrodynamique And 2 Mechanical Control
Hydraulic Lift Distributor
Load Sensing
3 Distributors
4 Distributors
Control Casing
Decal Hydraulic Controls
Electrical Equipment & Instrument Panel
With Dot Matrix
Electric Equipment & Instrument Panel
Side Console Switches
External Controls Fitted On The Rear Fenders
Engine Harness
Instrument Panel Harness
With Autotronic 5
Armrest
Plate Relay & Fuse Holder
Roof Harness
Pillar Harness
Rear Lightning Harness
Trailor Electric Socket
Handold
Automatic Air Conditioner Harness & Sensors
Electronic Equipment
Main Harness
With Autotronic 5 Up To R093029
With Autotronic 5 From R093030
Console
Aboard Computer And Plate Lighting Equipement
Up To ...
From ...
Fieldstar
Front Axle Suspended Harness Control Box
Control Box Harness & Cab Controls
Up To Serial Or Engine Number R087007
From Serial Or Engine Number R087008
Sensors
Body
Grille
Hood
Left Side
Right Side
Brackets And Assembling Parts
Tool Box
Emblems
For Uk Only Or Any Text In English Only
Literature
Tractor Cab
With Suspension
Suspended Cab Control Unit
Pressue Regulator And Filter
Compressor
Air Tank
Doors
Glass
Side Window Mechanism
Rear Window Mechanism
Roof
Cladding
Dressing Roof
Instrument Panel Cladding
Cab Insulation
Fenders
Hose
Manual Air Conditioner
Standard Roof
Heater Control
Windscreen Washer
Front Windscreen Wiper
Rear Window Wiper
Radio Installation
Internal Mirrors
External Mirrors
Luxuy
Secondary Seat
Seat Belt
Lighting
Front
Field Lights
Rear
Rotating Light
Rims & Wheels Weights
Wheel Hub 10 Holes Assembling
Up To P033045
From P033046
Mudguards And Supports
With 8 Hole Fixing
Distance Spacer For Wide Tread
With 10 Hole Fixing
Shaft Diameter 95 Mm
