Challenger Tractor MT565B Parts Catalog 3906114
Brand: Challenger
Model: Challenger MT565B With AutoPower VI Tier 3 Caterpillar Engine Tractor
Part Number: 3906114
Number of Pages: 836 Pages
Dealer Stocking List
Quantity By Tractor
Engine & Equipment
Up To Serial Or Engine Number R290060
From Serial Or Engine Number R290061
Alternator & Bracket
Starter
110 V
220 V
Engine Part
Water Fuel Separator
Fuel Tank & Attachments
North America Only
Up To Serial Or Engine Number U061044
From Serial Or Engine Number U061045
United States Only
Without Battery Cut-Off
With Battery Cut-Off
Air Conditioned Installation
Compresser
Pivoting Chassis
Dual Element
Air Cooler
Vertical Exhaust On The Side
Throttle Controls
Clutch
Front Spacer
Flywheel & Flywheel Housing
With Power Shuttle
Up To S344050
From Serial No B130071
Housing
Multiplicateur
Dual Clutch
Reverse Gear
Layshaft
Output Shaft
Synchro
Cover
Up To V126026
From V126027
Up To No T329040
Up To N° V126026
With Brakes High Pressure- Without Trailer Braking From V126027
Up To Serial Number T107046
Up To Serial N° V126
From Serial N° V126027
Hydraulique Manifold
From Serial Number U107047
Fork
Without Creeper Gear
Transmission Control
Control Armrest
Joystick For Distributor With Electrodynamique Control
Control
Fingertip
Rear Axle
Up To Serial Or Engine Number S199084
From Serial Or Engine Number S199085
Mechanism
Centre Housing
5 Differential
Normal Duty Wheel Driver 95 Mm
Normal Duty Wheel Driver 95 Mm With 50kph Tractor
Linkage
Lift Arms
Lift Cylinders
From V126027 Up To B314046
From Serial Or Engine Number B314047
Top Link Lock
Up To Serial Or Engine Number S255050
From Serial Or Engine Number S255051
Top Link With Hook End
Top Link With Ball End
Sensing Pin
Lower Bar With Hook
Telescopic Lower Bar
Tube Stabilizers
Shoe Stabilizers
40km H 24.8 Mph
Sae
Iso Standard
Up To U042037
From U042038
Bearing Carrier
Long Hay Ladder
Up To Serial Or Engine Number ...
From Serial Or Engine Number ...
Hitch
2-3-4 Distributors
Up To Serial Or Engine Number B250046
From Serial Or Engine Number B250047
Without Linkage
Without Front Lift
Control Lever
Load Sensing
Pto Drive Mechanism
Pto Shaft
6 Discs
P.T.O
Cable Control Up To N° T319059
Cable Control From N° T319060
Cable Control
Pto-Coupling Drive Mechanism
Four Speed
Sae Standard
Front Axle
Weight Carrier & Runner
Weight Frame And Tow Pin
Belly Weight
Bracket
Front Axle Fixed
With Suspended Front Axle
Front Axle 2 Wheel Drive
Up To Serial Or Engine Number T015033
From Serial Or Engine Number T015034
Guard
Differential Lock Mechanism
Up To C045068
From C045069
Auto Guide Sensor From S253066 Up To C045068
Front Axle Suspended From C045069
Up To Serial Or Engine Number U309009
From Serial Or Engine Number U309010
Hydraulic
Steering Wheel And Telescopic Column
With Dot Matrix
Lighting Power Shuttle Drive
Two Wheel Drive
Four Wheel Drive
Autoguide
Front Suspension Hydraulic Lines
Up To No T038032
From No T038033
Brackets Pedal
With 50 Km H Tractor
Brake Valve
Brake Pedals
With 50kph Tractor
Up To U085044
From U085045
Oiling
Pump
Up To Serial Or Engine Number B040053
From Serial Or Engine Number B040054
Without Trailer Braking Up To V126026
With Brakes High Pressure- Without Trailer Braking Up To N° S185050
Up To N° T329040
With Brakes High Pressure- Without Trailer Braking From N°T329041 Up To V126026
Cover Right
Up To U330004
From U330005
Up To B314046
From B314047
Right Cover
Air Intake Tubes Rear Axle
Oil Filler Pipe
Up To C131025
Without Hydraulic Coupling
3 Distributors With Mechanical Control
4 Distributors With Mechanical Control
2 Distributors Electrodynamique And 2 Mechanical Control Up To S040053
2 Distributors Electrodynamique And 2 Mechanical Control From S040054
3 Distributors Electrodynamique And 1 Mechanical Control
4 Distributors Electrodynamique Up To S040053
4 Distributors Electrodynamique From S040054
Up To Serial Or Engine Number S040053
From No S040054 Up To U295005
Auxiliary Distributor
Hydraulic Lift Distributor
3 Distributors
4 Distributors
Control Casing
Decal Hydraulic Controls
Electrical Equipment & Instrument Panel
Instrument Panel & Instruments
Electric Equipment & Instrument Panel
Side Console Switches
External Controls Fitted On The Rear Fenders
Engine Harness
Up To S267082
Up To V165036
From Serial Or Engine Number V165037
Armrest
Plate Relay & Fuse Holder
Roof Harness
Auto Guide
Pillar Harness
Not For Usa
For United States Of America
Trailor Electric Socket
Handold
Automatic Air Conditioner Harness & Sensors
Electronic Equipment
Main Harness
With Dual Control
Sensors
Aboard Computer And Plate Lighting Equipement
Console
Auto-Guide
Up To Serial Or Engine Number U310040
From Serial Or Engine Number U310041
Open Centre Hydraulic
Not For Italy
Front Axle Suspended Harness Control Box
Up To Serial Or Engine Number U239046
From Serial Or Engine Number U239047
Transmission Main Harness
Body
Excepted North America
Hood
Left Side
Up To 27-Sep-2006
Up To T022027
From T022028
Right Side
4 Th Stair
Tool Box
Up To V181014
From V181015
Speed Charts
Up To U068065
From U068066
Literature
Tractor Cab
Cab Mountings
Up To S333079
From S333080
Suspended Cab Control Unit
Pressue Regulator And Filter
Up To S331034
From S331035
Doors
Glass
Side Window Mechanism
Rear Window Mechanism
Roof
Cladding
Dressing Roof
Fenders
Instrument Panel Cladding
Cab Insulation
Manual Air Conditioner
Hose
Air Conditioner
Cab Filter
Heater Control
Front Windscreen Wiper
Rear Window Wiper
Windscreen Washer
Canopy
Radio Installation
Agcommand
Internal Mirrors
Up To T014047
From T014048
Electric Control Rear Reflecting Miror
Luxuy
Air Pressure Seat
Adjustable Damper
Seat Belt
Secondary Seat
Lighting
Front
Working Light
Standard Roof
Traffic Warning
Rear
Rotating Light
Rims & Wheels Weights
Fitting 8 Screws
Wheel Hub 8 Holes Fixing
Wheel Hub 10 Holes Assembling
Wheel Hub 10 Holes Fixing 6 Bridge Pieces
Up To .....
From .....
Compatible For Way Foward 60 Up To ...
Compatible For Way Foward 60 From ...
Pivoting
Rigid
With 8 Hole Fixing
Shaft Diameter 95 Mm
Shaft Diameter 95 Mm Cone Wheel Hub Reversed
Distance Spacer For Wide Tread
Wheel Weights
Repair Kit
Input Box & Dual Clutch
Gear Box For Power Shuttle
Technology Systems
Top Dock
Base Station
Radio Antenna
Tripod
Brand: Challenger
Quantity By Tractor
Engine & Equipment
Starter
110 V
220 V
Engine Part
North America Only
United States Only
Compresser
Pivoting Chassis
Dual Element
Air Cooler
Throttle Controls
Clutch
Front Spacer
With Power Shuttle
Up To S344050
Housing
Multiplicateur
Dual Clutch
Reverse Gear
Layshaft
Output Shaft
Synchro
Cover
Up To V126026
From V126027
Up To No T329040
Up To N° V126026
Fork
Control Armrest
Control
Fingertip
Rear Axle
Mechanism
Centre Housing
5 Differential
Linkage
Lift Arms
Lift Cylinders
Top Link Lock
Sensing Pin
Lower Bar With Hook
Tube Stabilizers
Shoe Stabilizers
40km H 24.8 Mph
Sae
Iso Standard
Up To U042037
From U042038
Bearing Carrier
Long Hay Ladder
Hitch
2-3-4 Distributors
Without Linkage
Without Front Lift
Control Lever
Load Sensing
Pto Drive Mechanism
Pto Shaft
6 Discs
P.T.O
Cable Control
Four Speed
Sae Standard
Front Axle
Belly Weight
Bracket
Front Axle Fixed
Guard
Up To C045068
From C045069
Hydraulic
With Dot Matrix
Two Wheel Drive
Four Wheel Drive
Autoguide
Up To No T038032
From No T038033
Brackets Pedal
Brake Valve
Brake Pedals
With 50kph Tractor
Up To U085044
From U085045
Oiling
Pump
Up To N° T329040
Cover Right
Up To U330004
From U330005
Up To B314046
From B314047
Right Cover
Oil Filler Pipe
Up To C131025
3 Distributors
4 Distributors
Control Casing
Engine Harness
Up To S267082
Up To V165036
Armrest
Roof Harness
Auto Guide
Pillar Harness
Not For Usa
Handold
Main Harness
With Dual Control
Sensors
Console
Auto-Guide
Not For Italy
Body
Hood
Left Side
Up To 27-Sep-2006
Up To T022027
From T022028
Right Side
4 Th Stair
Tool Box
Up To V181014
From V181015
Speed Charts
Up To U068065
From U068066
Literature
Tractor Cab
Cab Mountings
Up To S333079
From S333080
Up To S331034
From S331035
Doors
Glass
Roof
Cladding
Dressing Roof
Fenders
Cab Insulation
Hose
Air Conditioner
Cab Filter
Heater Control
Rear Window Wiper
Windscreen Washer
Canopy
Radio Installation
Agcommand
Internal Mirrors
Up To T014047
From T014048
Luxuy
Air Pressure Seat
Adjustable Damper
Seat Belt
Secondary Seat
Lighting
Front
Working Light
Standard Roof
Traffic Warning
Rear
Rotating Light
Fitting 8 Screws
Up To .....
From .....
Pivoting
Rigid
With 8 Hole Fixing
Wheel Weights
Repair Kit
Technology Systems
Top Dock
Base Station
Radio Antenna
Tripod
