702,019
Challenger Tractor MT565 Parts Catalog 1637425
Brand: Challenger
Model: Challenger MT565 Tractor
Part Number: 1637425
Number of Pages: 715 Pages
Engine And Equipment
Alternator And Bracket
Iskra
Timing Gear Housing
Flywheel Housing
Crankshaft, Pistons And Connecting Rods
Valve Mechanism And Camshaft
Cylinder Head Cover
Thermostat
Lubricating Oil Sump
Lubricating Oil Pump
Lubricating Oil Cooler And Filter
Fuel Injection Equipment (Diesel)
Low Pressure Fuel System
Air Induction And Exhaust System
Pipes
Cold Starting Device
Belt Tensioner
Piston- Cylinder Head With Valves
Engine Gaskets Sets
Heater Engine Block
Without Battery Cut-Off With Positive Connection
Air Conditioned Installation
Sanden Compresser
Engine Part
With Additional Tank
Fuel Filters And Pipes
With Fuel Cooler
Sedimenter
Fuel Tank And Attachments
Dual Element
Air Cooler
Vertical Exhaust On The Side
Throttle Controls
With Autodrive
Clutch
Dynashift
With Full Powershift
Wet Clutch With Power Shuttle
Power Shuttle
Front Spacer With Power Shuttle
Engine-Transmission Assembling
Without Dual Control
Up To M238025
From M238026
Valve
Up To L289038
From L289039
Up To Serial Or Engine Number L270016
From Serial Or Engine Number L270017
Master Cylinder
Housing
Dynashift With Power Shuttle
Layshaft
Mainshaft
With Power Shuttle
Output Shaft
Without Creeper Gear
Controle Full Powershift
Joystick For Distributor With Electrodynamique Control
Gear Box Full Power Shift
Pump
Input Shaft
2 Nd Gears
3 Rd Gears
4 Th Gears
5 Th Gears
6 Th Gears
7 Th Gears
Cowl
Rear Axle
Lower Control
Handbrake
With Powershift
Centre Housing
Shaft Diameter 95 Mm With Sealed Housing
5 Differential
Linkage
Lift Arms
Lift Cylinders
Levelling Box
Top Link With Ball End
Top Link Lock
Lower Cat 2 And 3
Swinging Drawbar Support
Swinging Drawbar
With Trailed Implememt Control
With Sealed Rear Axle Housings
Full Powershift
With Carraro Front Axle
Front Linkage 50000n
With Front Dual Control
Lift External Control
Single Acting-With Accumulator-With Carraro Front Axle
Two Way-With Accumulator-With Carraro Front Axle
Pto-Drive Mechanism
6 Discs
Brakes
Independant Power Take Off Clutch
Pto Shaft
Clock Wise Drive Front Pto
Drive
Ipto Clutch
Lines
Front Axle
Support
Weight Frame And Tow Pin
Bracket 2 Wheel Drive
Bracket 4 Wheel Drive
Heavy Duty
Cylinders
Two Wheel Drive
Differential Lock Mechanism
Guard And Transmission Shaft
Front Axle Fixed Carraro
Front Axle Suspended Carraro
Final Drive
Arms
Shock Absorber
Accumulator
Hydraulics
Steering Wheel And Telescopic Column
Lighting Power Shuttle
Steering Pump
2 Wheels Drive
Cover Lh-Pump Filter
With Pump 45cc
Without Trailer Braking
Up To L207014
From L207015
Pump 45cc Hydr. Lines
Pump 45cc Hydr. Lines Without Trailor Braking
With Cab And Power Brakes From
With Power Brakes
Hydraulic Pipes
Hydraulic Lift Distributor
Load Sensing
3 Distributors With 2 Electric Control
Usa
2 Distributors Electrodynamique And 2 Mechanical Control
2 Distributors Electrodynamique 1 Mechanical And 1 Dual Control
Auxiliary Distributor
Hydraulic Coupling
Dipstick Centre Housing
213_3 Distributors Control
214_4 Distributors Control
And 1 Mechanical Control
+1 Mechanical Control+ 1 Dual
Electric Equipment & Instrument Panel
Switches
With Speedometer With Power Shuttle
Engine Harness
Instrument Panel Harness
Armrest
Roof Harness
Roof
Guideway Footsteps Fenders
Electronic Equipment
Main Harness
Dual Control
Console
Sensors
Aboard Computer
Transfers
Wiring
Fieldstar
Transmission Main Harness
Emergency Harness
Sheet Metal
Hood
Hood Handle
Screen Frame
Hood Frame
Cab Mountings And Step Stairs
Without Additional Tank
Emblems
Tool Box
For United States Of America
Safety
For Mexico Market Only
Literature
Tractor Cab
Doors
Glass
Side Window Mechanism
Rear Window Mechanism
Heating Hatchway
Air Hatchway
Cladding
For Australian Market
Instrument Panel Cladding
Cab Insulation
Fenders
Hose
Heater Hoses
Air Conditioner
Heater
Windscreen Washer
Front Windscreen Wiper
Rear Window Wiper
Canopy
Radio Installation
Watch
Electrical Plug And Cigar Lighter
External Mirrors
Internal Mirrors
Grammer
Air Pressure Seat With Manual Adjustment
Luxuy
Up To L303040
From L303041
Secondary Seat
Lighting Equipment
Rear
Traffic Warning
Trailor Electric Socket
Field Lights
Guideway Footsteps
For Australia
Rotating Light
Rims And Wheels Weights
Fitting 8 Screws
Wheel Hub 10 Holes Assembling
Pivoting
Shaft Diameter 95 Mm Cone Wheel Hub Standard
Shaft Diameter 95 Mm Cone Wheel Hub Reversed
Repair Kits
Repair Kit
Fuel Heater
Creeper Gear Dynashift Transmission
Creeper Gear Full Powershift Transmission
With Fixed Carraro Front Axle
With Suspended Carraro Front Axle
Up To L337008
From L337009
4 Th Load Sensing Vertical Spool Valve Kit With Me Chanical Control For Cab
5 Th Load Sensing Vertical Spool Valve Kit With Me Chanical Control For Cab
With Dynashift-With Fuel Flowmeter
With Dynashift-Without Fuel Flowmeter
With Fuel Flowmeter
With Full Powershift-Without Fuel Flowmeter
Stock
Appliance Bracket Boarded For Cab
Seat Belt
Sensor Harness-Rear Dual Control
