Challenger Tractor MT545B Parts Catalog 3906153
Brand: Challenger
Model: Challenger MT545B With Techstar CVT Tier 3 Caterpillar Engine Tractor
Part Number: 3906153
Number of Pages: 900 Pages
Dealer Stocking List
Quantity By Tractor
Engine & Equipment
Alternator & Bracket
Starter
Air Compressor
110 V
220 V
Engine Part
Water Fuel Separator
Fuel Tank & Attachments
Up To Serial Or Engine Number U043085
From Serial Or Engine Number U043086
North America Only
United States Only
Batteries And Cables
Without Battery Cut-Off
With Battery Cut-Off
Air Conditioned Installation
Compresser
Pivoting Chassis
Air Cooler
Dual Element
Vertical Exhaust On The Side
Throttle Controls
Clutch
Front Spacer
Flywheel & Flywheel Housing
Clutch Control
From Serial No B132016
Housing
Gear Box
Inner Housing
Power Management
Planetary Drive
Pump Shaft
Accumulator Shaft
Hydraulique Motor
Duct Plate
Adjusting Device
Transmission Control
Linings System Comfort
Group Gear Shifting
Drive Line
Range
Control Armrest
Joystick For Distributor With Electrodynamique Control
Fingertip
Control
Rear Axle
Handbrake
Without Breake Beam
Not For Usa
Not For Usa Power Management
For United States Of America Power Management
Oil Level Indicator
Bevel Drive
Not For North America
Inner Final Drive Gear
Disc Brakes
Cardan Brake
Lift Arms
Angle Sensor
Linkage
Up To Serial Or Engine Number 701 03962
From Serial Or Engine Number 701 03963
Up To Serial Or Engine Number 701 03475
From Serial Or Engine Number 701 03476
Lift Cylinders Feeding
Levelling Box
Top Link With Hook End
Top Link With Ball End
Top Link Lock
Sensing Pin
Telescopic Lower Bar
Lower Bar With Hook
Cat. 3
Tube Stabilizers
Automatic Stabilizers
Iso Standard
Sae Standard
Without Rings
Hitch
Up To D151063
From D151064
Protection Guard
Up To Serial Or Engine Number C060045
From Serial Or Engine Number C060046
Up To Serial Or Engine Number B250046
From Serial Or Engine Number B250047
With Front Dual Control
Lift External Control
Without Linkage
2-3-4 Distributors
Hydraulic
Load Sensing
4 Quick Couplers
Accumulator
Frame
Up To Serial Or Engine Number C192032
From Serial Or Engine Number C192033
Load Sensing Up To C192032
Load Sensing From C192033
Pto Drive Mechanism
Independant Power Take Off Clutch
Brake
With 3 Speed Shiftable Ipto
Bridle
Hydraulic Lines
Pto
With Clevis Quick Adjustment
Up To Serial Or Engine Number V068035
From V068036 & Up To D099042
From Serial Or Engine Number D099043
Up To Serial Or Engine Number U118058
From U118059 Up To U155020
From Serial Or Engine Number U155021
Ipto Clutch
Front Axle
Weight Carrier & Runner
Belly Weight
Front Axle Fixed
With Suspended Front Axle
Differential Lock Mechanism
Final Drive
Up To Serial Or Engine Number V025051
From Serial Or Engine Number V025052
Autoguide
Steering Wheel And Telescopic Column
With Dot Matrix
Four Wheel Drive
Front Suspension Hydraulic Lines
Brackets Pedal
With Power Brakes
Pipes And Fitting
Up To V033031
From V033032
Up To 14-03-2011
From 15-03-2011
Hydraulic Brake Assy
Pump Drive
Filter
Pump Installation
Gear Box Lubrication
Interior
Up To Serial Or Engine Number 701 6018
From Serial Or Engine Number 701 6019
Hydraulic Valve Block
Auxiliary Hydraulics
Up To Serial Or Engine Number V341072
From Serial Or Engine Number V341073
Without Trailer Braking
Hydraulique Manifold
Male Coupler
Auxiliary Distributors Installation
3 Distributors With Mechanical Control
2 Distributors Electrodynamique And 1 Mechanical Control
2 Distributors Electrodynamique And 2 Mechanical Control
4 Distributors Electrodynamique
4 Distributors With Mechanical Control
Hydraulic Lift Distributor
3 Distributors
4 Distributors
Control Casing
Decal Hydraulic Controls
Electrical Equipment & Instrument Panel
Electric Equipment & Instrument Panel
Side Console Switches
Industrial Cab
Engine Harness
Front Pto Harness
Up To Serial Or Engine Number V061004
Up To V197008
From Serial Or Engine Number V197009
Armrest
External Controls Fitted On The Rear Fenders
Plate Relay & Fuse Holder
Roof Harness
Up To V169009
From V169010
Standard Roof
Auto Guide
Hand Rail
Pillar Harness
Rear Lightning Harness
Trailor Electric Socket
Harness Front Electrical Plug
Automatic Air Conditioner Harness & Sensors
Electronic Equipment
Without Parking Brake
With Parking Brake
With Dual Control
Without Dual Control
Console
Sensors
Auto-Guide
Aboard Computer And Plate Lighting Equipement
Radar
Up To U268039 For Great Britain
From U268040 For Great Britain
Fieldstar
With Autotronic 5
Control Box Harness & Cab Controls
Front Axle Suspended Harness Control Box
Up To Serial Or Engine Number U279000
From U279001 Up To V034031
From V034032
Body
Excepted North America
Hood
Left Side
Up To T007071
From T007072
Right Side
Tool Box
Up To V181014
From V181015
Speed Charts
Up To U068065
See Next Page For Decal Location
Literature
With Auto-Guide
Tractor Cab
Cab Mountings
Up To S333079
From S333080
Suspended Cab Control Unit
Pressue Regulator And Filter
Up To S331034
From S331035
Doors
Glass
Window Fixation
Side Window Mechanism
Cladding
Rear Window Mechanism
Roof
Dressing Roof
High Visibility Roof
Window
Instrument Panel Cladding
Cab Insulation
Fenders
Manual Air Conditioner
Hose
Cab Filter
Front Windscreen Wiper
Rear Window Wiper
Canopy
Windscreen Washer
Radio Installation
Agcommand
Internal Mirrors
Up To T014047
From T014048
Up To T014046
From T014047
Luxuy
Air Pressure Seat
Adjustable Damper
Seat Belt
Secondary Seat
Lighting
Front
Working Light
With High Visibility Roof
Rear
Traffic Warning
Rotating Light
Rims & Wheels Weights
Wheel Hub 10 Holes Assembling
Rigid
Up To .....
From .....
Compatible For Way Foward 60 Up To ...
Compatible For Way Foward 60 From ...
Pivoting
With 8 Hole Fixing
Shaft Diameter 82 Mm Steel Steel Wheels
Shaft Diameter 95 Mm
Shaft Diameter 95 Mm Cone Wheel Hub Reversed
Distance Spacer For Wide Way
Wheel Weights
Technology Systems
Top Dock
Base Station
Radio Antenna
Tripod
Brand: Challenger
Quantity By Tractor
Engine & Equipment
Starter
Air Compressor
110 V
220 V
Engine Part
North America Only
United States Only
Compresser
Pivoting Chassis
Air Cooler
Dual Element
Throttle Controls
Clutch
Front Spacer
Clutch Control
Housing
Gear Box
Inner Housing
Power Management
Planetary Drive
Pump Shaft
Accumulator Shaft
Hydraulique Motor
Duct Plate
Adjusting Device
Group Gear Shifting
Drive Line
Range
Control Armrest
Fingertip
Control
Rear Axle
Handbrake
Without Breake Beam
Not For Usa
Oil Level Indicator
Bevel Drive
Disc Brakes
Cardan Brake
Lift Arms
Angle Sensor
Linkage
Levelling Box
Top Link Lock
Sensing Pin
Lower Bar With Hook
Cat. 3
Tube Stabilizers
Iso Standard
Sae Standard
Without Rings
Hitch
Up To D151063
From D151064
Protection Guard
Without Linkage
2-3-4 Distributors
Hydraulic
Load Sensing
4 Quick Couplers
Accumulator
Frame
Pto Drive Mechanism
Brake
Bridle
Hydraulic Lines
Pto
Ipto Clutch
Front Axle
Belly Weight
Front Axle Fixed
Final Drive
Autoguide
With Dot Matrix
Four Wheel Drive
Brackets Pedal
With Power Brakes
Pipes And Fitting
Up To V033031
From V033032
Up To 14-03-2011
From 15-03-2011
Pump Drive
Filter
Pump Installation
Interior
Male Coupler
3 Distributors
4 Distributors
Control Casing
Industrial Cab
Engine Harness
Front Pto Harness
Up To V197008
Armrest
Roof Harness
Up To V169009
From V169010
Standard Roof
Auto Guide
Hand Rail
Pillar Harness
With Parking Brake
With Dual Control
Console
Sensors
Auto-Guide
Radar
Fieldstar
With Autotronic 5
From V034032
Body
Hood
Left Side
Up To T007071
From T007072
Right Side
Tool Box
Up To V181014
From V181015
Speed Charts
Up To U068065
Literature
With Auto-Guide
Tractor Cab
Cab Mountings
Up To S333079
From S333080
Up To S331034
From S331035
Doors
Glass
Window Fixation
Cladding
Roof
Dressing Roof
Window
Cab Insulation
Fenders
Hose
Cab Filter
Rear Window Wiper
Canopy
Windscreen Washer
Radio Installation
Agcommand
Internal Mirrors
Up To T014047
From T014048
Up To T014046
From T014047
Luxuy
Air Pressure Seat
Adjustable Damper
Seat Belt
Secondary Seat
Lighting
Front
Working Light
Rear
Traffic Warning
Rotating Light
Rigid
Up To .....
From .....
Pivoting
With 8 Hole Fixing
Wheel Weights
Technology Systems
Top Dock
Base Station
Radio Antenna
Tripod
