702,019
Challenger Tractor MT535B Parts Catalog 3906149
Brand: Challenger
Model: Challenger MT535B With AutoPower VI Tier 3 Caterpillar Engine Tractor
Part Number: 3906149
Number of Pages: 876 Pages
Dealer Stocking List
Quantity By Tractor
Engine & Equipment
Alternator & Bracket
Starter
110 V
220 V
Engine Part
Water Fuel Separator
Fuel Tank & Attachments
Up To Serial Or Engine Number U043085
From Serial Or Engine Number U043086
United States Only
North America Only
Batteries And Cables
Without Battery Cut-Off
Air Conditioned Installation
Compresser
Pivoting Chassis
Air Cooler
Dual Element
Vertical Exhaust On The Side
Throttle Controls
Clutch
Front Spacer
Flywheel & Flywheel Housing
With Power Shuttle
Up To S344050
From Serial No B130071
Up To U295005
From U295006
From U295005
From U295006 Up To B257037
Excepted B257052 064 075-B258003
With Brakes High Pressure
Hydraulique Manifold
Housing
Open Centre Hydraulic Up To U295005
Open Centre Hydraulic From U295006
With Load Sensing
Multiplicateur
Dual Clutch
Reverse Gear
Layshaft
Output Shaft
Synchro
Up To Serial Or Engine Number U295005
From Serial Or Engine Number U295006
With 50kph Tractor
Cover
Fork
Creeper Gear
Creeper Gearbox Control
Transmission Control
With Autodrive
Control Armrest
Joystick For Distributor With Electrodynamique Control
Fingertip
Control
Rear Axle
Handbrake
Mechanism
Centre Housing
Hydromechanical
Open Center Hydraulic
Hydraulic Lines
5 Differential
5 Differential With 50kph Tractor
Inner Final Drive Gear
Up To Serial Or Engine Number S180004
From Serial Or Engine Number S180005
Distributor Holder
Without Lift
Linkage
Ram 75mm
Up To Serial Or Engine Number S116004
From S116005 Up To V098037
With Load Sensing From V098038
Up To Serial Or Engine Number S207081
From Serial Or Engine Number S207082
Top Link With Hook End
Top Link With Ball End
Top Link Lock
Sensing Pin
Telescopic Lower Bar
Lower Bar With Hook
Up To Serial Or Engine Number V014001
From Serial Or Engine Number V014002
Shoe Stabilizers
Swinging Drawbar Support
Iso Standard Up To
Iso Standard From
Iso Standard Up To B167040
Iso Standard From B167041
Sae Standard
Up To B166017
Without Front Linkage
Up To Serial Or Engine Number C192032
From Serial Or Engine Number C192033
Load Sensing Up To C192032
Load Sensing From C192033
Load Sensing
Pto Drive Mechanism
Pto Shaft
5 Disc
Two Speed
Four Speed
P.T.O Control 1550 2000 Tr Mn
Pto-Dismountable Drive Mechanism
Pto-Coupling Drive Mechanism
P.T.O Control 540 1000 Tr Mn
Control Lever
Pto
Front Axle
Weight Frame And Tow Pin
Belly Weight
Chassis Structure
Bracket
Front Axle Fixed
With Suspended Front Axle
Front Axle 2 Wheel Drive
Up To Serial Or Engine Number T015033
From Serial Or Engine Number T015034
Guard
Differential Lock Mechanism
Final Drive
Hydraulic Valve Block
From Serial Or Engine Number V025011
Hydraulic
Steering Wheel And Telescopic Column
With Dot Matrix
Lighting Power Shuttle Drive
Two Wheel Drive
Four Wheel Drive
From No U295006
Load Sensing Up To V098037
4 Wheel Drive-Load Sensing- Brakes High Pressure W O Trailer Braking
Up To N° V098037
From N° V098038
Front Suspension Hydraulic Lines
With Fixed Front Axle From U295006 Up To C051027
With Fixed Front Axle From C051028
With Suspended Front Axle From U295006 Up To C051027
From C051028
Up To T036016
From T036017
With Power Brakes
With 50 Km H Tractor
Without Trailer Braking
With Trailer Braking
Brake Valve
Up To D141016
From D141017
Up To Serial Or Engine Number S123085
From Serial Or Engine Number S123086
With Front Axle Suspended From S123086
Up To Serial Or Engine Number B040053
From Serial Or Engine Number B040054
Without Trailer Braking Up To V098037
Without Trailer Braking From V098038
Hydraulic Lines Up To U295005
Hydraulic Lines From U295006
Up To U330004
From U330005
Up Tov098037
Fromv098038
2 Distributors With Mechanical Control
3 Distributors With Mechanical Control
4 Distributors With Mechanical Control
4 Distributors Electrodynamique
2 Distributors Electrodynamique And 2 Mechanical Control
Auxiliary Distributor
Hydraulic Lift Distributor
Control Casing
Decal Hydraulic Controls
Electrical Equipment & Instrument Panel
Instrument Panel & Instruments
Electric Equipment & Instrument Panel
Side Console Switches
Engine Harness
Up To Serial Or Engine Number V165036
From Serial Or Engine Number V165037
Armrest
External Controls Fitted On The Rear Fenders
Plate Relay & Fuse Holder
Roof Harness
Up To V169009
From V169010
Hand Rail
Pillar Harness
Not For Usa
For United States Of America
Trailor Electric Socket
Harness Front Electrical Plug
Automatic Air Conditioner Harness & Sensors
Electronic Equipment
Without Electronic Lift
Main Harness
With Dual Control
Console
Sensors
Diagnostic Harness
Aboard Computer And Plate Lighting Equipement
Radar
Up To U268039 For Great Britain
From U268040 For Great Britain
Harness Isobus
Front Axle Suspended Harness Control Box
Transmission Main Harness
Up To U163035
From U163036
Body
Excepted North America
Hood
Left Side
Up To T007071
From T007072
Tool Box
Right Side
Up To V181014
From V181015
Speed Charts
Up To U068065
See Next Page For Decal Location
Literature
Tractor Cab
Cab Mountings
From S333080
Suspended Cab Control Unit
Pressue Regulator And Filter
Compressor
Air Tank
Doors
Glass
Side Window Mechanism
Rear Window Mechanism
Roof
Cladding
Dressing Roof
High Visibility Roof
Window
Instrument Panel Cladding
Fenders
Cab Insulation
Manual Air Conditioner
Hose
Cab Filter
Standard Roof
Front Windscreen Wiper
Rear Window Wiper
Windscreen Washer
Radio Installation
Agcommand
Iso Standard
Internal Mirrors
Up To T014047
From T014048
Up To T014046
From T014047
Luxuy
Adjustable Damper
Seat Belt
Secondary Seat
Lighting
Front
Working Light
With High Visibility Roof
Rear
Traffic Warning
Rotating Light
Rims & Wheels Weights
Fitting 8 Screws
Wheel Hub 8 Holes Fixing
Wheel Hub 8 Holes Fixing 6 Bridge Pieces
Rigid
Up To .....
From .....
Compatible For Way Foward 60 Up To ...
Compatible For Way Foward 60 From ...
Pivoting
Wheel Hub 10 Holes Assembling
With 8 Hole Fixing
Wheel Hub 8 Holes Fixing 8 Bridge Pieces
Distance Spacer For Wide Way
Shaft Diameter 82 Mm Steel Disc Wheels
Shaft Diameter 82mm Cone Wheel Hub For Dual Whee Ls Cast Iron Steel
Wheel Weights
Repair Kit
Double Clutch
Input Box & Dual Clutch
Gear Box For Power Shuttle
Technology Systems
Top Dock
Base Station
Radio Antenna
Tripod
