Challenger Tractor MT535 MT545 Parts Catalog 1637424
Brand: Challenger
Model:
Challenger MT535 Tractor
Challenger MT545 Tractor
Part Number: 1637424
Number of Pages: 727 Pages
Engine And Equipment
M.T 535
M.T 545
Alternator And Bracket
Iskra
Up To Serial Or Engine Number L155012
From Serial Or Engine Number L155013
Heater Engine Block
W O Battery Cut Off W O Positive Connection
W O Battery Cut Off With Positive Connection
With Battery Cut-Off
Air Conditioned Installation
Sanden Compresser
Engine Part
Fuel Tank And Attachments
Additional Tank
Fuel Tank Auxiliary
With Fuel Cooler
Dual Element
With Dusty Aspiration
Vertical
Throttle Controls
Platform
With Autodrive
Clutch
Front Spacer
Flywheel
Wet Clutch With Power Shuttle
Up To L289038
From L289039
With Mechanical Brake Or Power Brake
With Power Brakes
Up To L270016
From L270017
For Hydraulic Pump 110 L Mn
Power Shuttle
Control
Dynashift With Power Shuttle
Mainshaft
Synchro Heavy Duty Transmission
Layshaft
Output Shaft
Cover
Gear Selection
Fork
Creeper Gear
Creeper Gearbox Control
Without Automatic Hook
With Cab
Control Armrest
Joystick For Distributor With Electrodynamique Control
Rear Axle
Handbrake
3 Disc
Mechanism
Centre Housing
Hydromechanical
Heavy Duty
Hydraulic Lift Cover
Linkage
Top Link With Hook End
Up To L154044
From L154045
Levelling Box
Hitch Bar With Telescopic End Cbm
Swinging Drawbar Support
Swinging Drawbar
Cramer
Drawbar
Automatic Hook Dromone
With Remote Control
Pto-Drive Mechanism
Pto Shaft
5 Disc
Independant Power Take Off Clutch
Two Speed
Four Speed
With P.T.O Brakes
Pto-Dismountable Drive Mechanism
Pto
Clock Wise Drive Front Pto
Counterclockwise Drive Front Pto
Drive
Ipto Clutch
Up To L200005
From L200006
Front Axle
Weight Frame And Tow Pin
Belly Weight
Bracket 2 Wheel Drive
Bracket
4 Wheel Drive
Cylinders
Differential Lock Mechanism
M092053 M.T 545
M092054 M.T 545
M091060 M.T 545
M091061 M.T 545
Front Axle Fixed Carraro
Front Axle Suspended Carraro
Housing
Arms
Shock Absorber
Accumulator
Hydraulics
Steering Wheel And Steady Column
Steering Wheel And Telescopic Column
Lighting Power Shuttle Drive
Steering Pump
Steering Hydraulic Lines
Load Sensing Up To M092020 Fixed Axle & M098002 Suspended Axle
Load Sensing Up To M092053 Fixed Axle & M091060 Suspended Axle
Load Sensing From M092021 Fixed Axle & M098003 Suspended Axle
Load Sensing From M092054 Fixed Axle & M091061 Suspended Axle
With Front Axle Suspended Carraro
Load Sensing
With Cab With Mechanical Brake
With Cab And Power Brakes From
With Platform
Without Trailer Braking
Without Trailer Braking And Load Sensing
Hydraulic Lines
Oil Cooler With Load Sensing
2 Distributors Electrodynamique And 1 Mechanical Control
2 Distributors Electrodynamique And 2 Mechanical Control
Auxiliary Distributor
2 Or 3 Load Sensing Distributors
2-3-4 Distributors
Auxiliary Distributors Installati
191_2 Distributors Control
192_3 Distributors Control
Control With 2 Distributor
Cover Rh
Without Trailor Braking
Without Trailor Braking With Front Axle Suspended Carraro
Electrovalves-Hydraulic Pump 110 L Mn Up To L20701 4
Electrovalves-Hydraulic Pump 110 L Mn From L207015
Cover Lh-Pump Filter
Electric Equipment & Instrument Panel
Switches
With Speedometer With Power Shuttle
Engine Harness
Instrument Panel Harness
Armrest
Harness Console
Roof Harness
With High Visibility Roof
Roof
Guideway Footsteps Fenders
Electrical Wiring
Electronic Equipment
Main Harness
Console
Fieldstar
With Power Shuttle
Sheet Metal
Grille
Lateral Exhaust
Central Exhaust
Tool Box
Emblems
Dynashift
Safety
Literature
Tractor Cab
Doors
Glass
Side Window Mechanism
Rear Window Mechanism
Heating Hatchway
Air Hatchway
Window
Cladding
Instrument Panel Cladding
Cab Insulation
Fenders
Hose
Heater Hoses
Air Conditioner
Heater
Front Windscreen Wiper
Rear Window Wiper
Canopy
Radio Installation
Watch
Electrical Plug And Cigar Lighter
Internal Mirrors
External Mirrors
Grammer
Air Pressure Seat With Manual Adjustment
Luxuy
Up To L303040
From L303041
Secondary Seat
Lighting Equipment
Rear
Trailor Electric Socket
Field Lights
Platform With Pillars
Rotating Light
Support
Rims And Wheels Weights
Fitting 8 Screws
Wheel Hub 8 Holes Fixing
Wheel Hub 10 Holes Fixing
Sirmac
With Carraro Front Axle
Pivoting
8 Rails
Shaft Diameter 82mm Cast Iron Disc Wheels
Repair Kits
Gear Box For Power Shuttle
Power Shuttle Input Box
Wet Clutch
Fuel Heater
Front Linkage 22000 N
With Suspended Carraro Front Axle
With Fixed Carraro Front Axle
With Front Dual Control
Front Linkage 35000n
Front Pto
3rd 4th Horizontal Distributor Electrodynamique Ki T For Cab
3 Th Load Sensing Horizontal Spool Valve Kit With Mechanical Control For Cab
3rd Horizontal Distributor Electrodynamique Kit Du Al Control For Cabine
4 Th Load Sensing Horizontal Spool Valve Kit With Mechanical Control For Cab
4 Th Horizontal Distributor Electrodynamique Kit D Ual Control For Cab
Without Fuel Flowmeter
Stock
Appliance Bracket Boarded For Cab
Seat Belt
Fenders Extension
Sensor Harness-Rear Dual Control
Brand: Challenger
Model:
M.T 535
M.T 545
Iskra
Heater Engine Block
Sanden Compresser
Engine Part
Additional Tank
Fuel Tank Auxiliary
With Fuel Cooler
Dual Element
Vertical
Throttle Controls
Platform
With Autodrive
Clutch
Front Spacer
Flywheel
Up To L289038
From L289039
With Power Brakes
Up To L270016
From L270017
Power Shuttle
Control
Mainshaft
Layshaft
Output Shaft
Cover
Gear Selection
Fork
Creeper Gear
With Cab
Control Armrest
Rear Axle
Handbrake
3 Disc
Mechanism
Centre Housing
Hydromechanical
Heavy Duty
Linkage
Up To L154044
From L154045
Levelling Box
Swinging Drawbar
Cramer
Drawbar
With Remote Control
Pto-Drive Mechanism
Pto Shaft
5 Disc
Two Speed
Four Speed
With P.T.O Brakes
Pto
Drive
Ipto Clutch
Up To L200005
From L200006
Front Axle
Belly Weight
Bracket
4 Wheel Drive
Cylinders
M092053 M.T 545
M092054 M.T 545
M091060 M.T 545
M091061 M.T 545
Housing
Arms
Shock Absorber
Accumulator
Hydraulics
Steering Pump
Load Sensing
With Platform
Hydraulic Lines
2-3-4 Distributors
Cover Rh
Switches
Engine Harness
Armrest
Harness Console
Roof Harness
Roof
Electrical Wiring
Main Harness
Console
Fieldstar
With Power Shuttle
Sheet Metal
Grille
Lateral Exhaust
Central Exhaust
Tool Box
Emblems
Dynashift
Safety
Literature
Tractor Cab
Doors
Glass
Heating Hatchway
Air Hatchway
Window
Cladding
Cab Insulation
Fenders
Hose
Heater Hoses
Air Conditioner
Heater
Rear Window Wiper
Canopy
Radio Installation
Watch
Internal Mirrors
External Mirrors
Grammer
Luxuy
Up To L303040
From L303041
Secondary Seat
Lighting Equipment
Rear
Field Lights
Rotating Light
Support
Fitting 8 Screws
Sirmac
Pivoting
8 Rails
Repair Kits
Wet Clutch
Fuel Heater
Front Pto
Stock
Seat Belt
Fenders Extension
