702,019
Challenger Tractor MT525B Parts Catalog 3906148
Brand: Challenger
Model: Challenger MT525B With AutoPower VI Tier 3 Caterpillar Engine Tractor
Part Number: 3906148
Number of Pages: 970 Pages
Dealer Stocking List
Quantity By Tractor
Engine & Equipment
Alternator & Bracket
Starter
Air Compressor
110 V
220 V
Engine Part
Water Fuel Separator
Fuel Tank & Attachments
Up To Serial Or Engine Number U043085
From Serial Or Engine Number U043086
United States Only
North America Only
Batteries And Cables
Without Battery Cut-Off
With Battery Cut-Off
Air Conditioned Installation
Compresser
Pivoting Chassis
Air Cooler
Dual Element
Vertical Exhaust On The Side
Throttle Controls
Clutch
Front Spacer
Flywheel & Flywheel Housing
With Power Shuttle
Up To S344050
From Serial No B130071
Up To U295005
From U295006
From U295005
From U295006 Up To B257037
Excepted B257052 064 075-B258003
Up To S271064
Up To V098037
From V098038
Hydraulique Manifold
Housing
Open Centre Hydraulic Up To U295005
Open Centre Hydraulic From U295006
With Load Sensing
Multiplicateur
Dual Clutch
Reverse Gear
Layshaft
Output Shaft
Synchro
Up To Serial Or Engine Number U295005
From Serial Or Engine Number U295006
With 50kph Tractor Up To U295005
With 50kph Tractor From U295006
Cover
Fork
Creeper Gear
Creeper Gearbox Control
Transmission Control
With Autodrive
Control Armrest
Joystick For Distributor With Electrodynamique Control
Rear Axle
Handbrake
Mechanism
With 50kph Tractor
Centre Housing
Hydromechanical
Hydraulic Lines
5 Differential
5 Differential With 50kph Tractor
Inner Final Drive Gear
Up To Serial Or Engine Number S180004
From Serial Or Engine Number S180005
Distributor Holder
Without Lift
Linkage
Ram 66mm
Ram 75mm
Up To Serial Or Engine Number S116004
From S116005 Up To V098037
With Load Sensing From V098038
Up To Serial Or Engine Number S207081
From Serial Or Engine Number S207082
Top Link With Hook End
Top Link With Ball End
Top Link Lock
Sensing Pin
Telescopic Lower Bar
Lower Bar With Hook
Up To Serial Or Engine Number V014001
From Serial Or Engine Number V014002
Shoe Stabilizers
Swinging Drawbar Support
With Long Hay Ladder
Iso Standard Up To
Iso Standard (50km H) Up To
Iso Standard From
Iso Standard Up To B167040
Iso Standard From B167041
Sae Standard
Up To B166017
Up To Serial Or Engine Number ...
From Serial Or Engine Number ...
From Serial Or Engine Number B069007
2-3-4 Distributors
Up To Serial Or Engine Number C060045
From Serial Or Engine Number C060046
Without Linkage
Load Sensing
Without Front Linkage
Up To Serial Or Engine Number C192032
From Serial Or Engine Number C192033
Load Sensing Up To C192032
Load Sensing From C192033
Pto Drive Mechanism
Pto Shaft
5 Disc
Two Speed
Four Speed
P.T.O Control 1550 2000 Tr Mn
Pto-Dismountable Drive Mechanism
Pto-Coupling Drive Mechanism
P.T.O Control 540 1000 Tr Mn
Control Lever
Pto
Up To Serial Or Engine Number V068035
From V068036 & Up To D099042
From Serial Or Engine Number D099043
Up To Serial Or Engine Number U118058
From U118059 Up To U155020
From Serial Or Engine Number U155021
Ipto Clutch
Front Axle
Weight Carrier & Runner
Belly Weight
Chassis Structure
Bracket
Front Axle Fixed
With Suspended Front Axle
Front Axle 2 Wheel Drive
Up To Serial Or Engine Number T015033
From Serial Or Engine Number T015034
Guard
Differential Lock Mechanism
Final Drive
Up To Serial Or Engine Number V021015
From Serial Or Engine Number V021016
Hydraulic
Steering Wheel And Telescopic Column
With Dot Matrix
Lighting Power Shuttle Drive
Two Wheel Drive
Open Center Hydraulic
Four Wheel Drive
From No U295006
Load Sensing Up To V098037
Up To N° V098037
From N° V098038
Front Suspension Hydraulic Lines
With Fixed Front Axle From U295006 Up To C051027
With Fixed Front Axle From C051028
Up To T036016
From T036017
With 50 Km H Tractor
With Power Brakes
Brake Valve
Without Trailer Braking
With Trailer Braking
Up To C011004
From C011005
Load Sensing Pneumatic Braking
Up To D141016
From D141017
Up To Serial Or Engine Number S123085
From Serial Or Engine Number S123086
With Front Axle Suspended From S123086
Up To Serial Or Engine Number B040053
From Serial Or Engine Number B040054
Without Trailer Braking Up To V098037
Without Trailer Braking From V098038
With Trailer Braking Up To N° S185050
With Trailer Braking From N° S185051 Up To V098037
With Trailer Braking From V098038
Hydraulic Lines Up To U295005
Hydraulic Lines From U295006
Hydraulic Lift Valve
Up To U330004
From U330005
Male Coupler
Auxiliary Distributor
Up Tov098037
Fromv098038
2 Distributors With Mechanical Control
3 Distributors With Mechanical Control
4 Distributors With Mechanical Control
2 Distributors Electrodynamique And 2 Mechanical Control
Hydraulic Lift Distributor
Control Casing
Decal Hydraulic Controls
Electrical Equipment & Instrument Panel
Instrument Panel & Instruments
Electric Equipment & Instrument Panel
Side Console Switches
Industrial Cab
Engine Harness
Front Pto Harness
Up To Serial Or Engine Number V165036
From Serial Or Engine Number V165037
Armrest
External Controls Fitted On The Rear Fenders
Plate Relay & Fuse Holder
Roof Harness
Standard Roof
Hand Rail
Pillar Harness
Not For Usa
For United States Of America
Trailor Electric Socket
Harness Front Electrical Plug
Automatic Air Conditioner Harness & Sensors
Electronic Equipment
Without Electronic Lift
Main Harness
Console
Sensors
Diagnostic Harness
Aboard Computer And Plate Lighting Equipement
Radar
Up To U268039 For Great Britain
From U268040 For Great Britain
Front Axle Suspended Harness Control Box
Transmission Main Harness
Up To U163035
From U163036
Body
Excepted North America
Hood
Left Side
Up To T007071
From T007072
Right Side
Tool Box
Up To V181014
From V181015
Speed Charts
Up To U068065
From U068066
Literature
Tractor Cab
Cab Mountings
From S333080
Suspended Cab Control Unit
Pressue Regulator And Filter
Compressor
Air Tank
Doors
Glass
Window Fixation
Side Window Mechanism
Rear Window Mechanism
Roof
Cladding
Dressing Roof
Instrument Panel Cladding
Cab Insulation
Fenders
Manual Air Conditioner
Hose
Cab Filter
Front Windscreen Wiper
Rear Window Wiper
Side Windscreen Wiper
Windscreen Washer
Canopy
High Visibility Roof
Radio Installation
Agcommand
Iso Standard
Internal Mirrors
Up To T014047
External Mirrors
From T014048
Up To T014046
From T014047
Luxuy
Air Pressure Seat
Adjustable Damper
Seat Belt
Secondary Seat
Lighting
Front
Working Light
Rear
Traffic Warning
Rotating Light
Rims & Wheels Weights
Fitting 8 Screws
Wheel Hub 8 Holes Fixing
Wheel Hub 8 Holes Fixing 6 Bridge Pieces
Rigid
Up To .....
From .....
Compatible For Way Foward 60 Up To ...
Compatible For Way Foward 60 From ...
Pivoting
With 8 Hole Fixing
Wheel Hub 8 Holes Fixing 8 Bridge Pieces
Distance Spacer For Wide Way
Wheel Weights
Repair Kit
Double Clutch
Input Box & Dual Clutch
Gear Box For Power Shuttle
Technology Systems
Top Dock
Base Station
Radio Antenna
Tripod
