Challenger Tractor MT525B MT535B MT545B Parts Catalog 1637450
Brand: Challenger
Model: Challenger MT525B, MT535B, MT545B With Techstar CVT Tractor
Part Number: 1637450
Number of Pages: 840 Pages
Engine & Equipment
With Pneumatic Brake
Alternator & Bracket
80 Amp
Up To R233045
From R233046
Starter
Closed Circuit Breather
110 V
220 V
Engine Part
Fuel Tank & Attachments
United States Only
Fuel System
Fuel Filters And Pipes
Without Battery Cut-Off W O Positive Connection
Without Battery Cut-Off With Positive Connection U P To M322008
With Battery Cut-Off W O Positive Connection
Air Conditioned Installation
Compresser
Dual Element
Vertical Exhaust On The Side
Throttle Controls
Clutch
Front Spacer
Flywheel & Flywheel Housing
Clutch Control
Housing
Gear Box
Inner Housing
Planetary Drive
Pump Shaft
Accumulator Shaft
Hydraulique Motor
Duct Plate
Adjusting Device
H.A 110 Up To 701 3788 & H.A 130 Up To 701 3795
H.A 110 From 701 3789 Up To 701 5040 & H.A 130 From 701 3796 Up To 701 5022
H.A 110 From 701 5041 & H.A 130 From 701 5023
Linings System Comfort
Group Gear Shifting
Drive Line
H.A 110 From 701 3789 & H.A 130 From 701 3796
Up To Serial Or Engine Number ...
From Serial Or Engine Number ...
Joystick For Distributor With Electrodynamique Control
Rear Axle
Up To Serial Or Engine Number N125078
From N125079 & Up To N252052
From Serial Or Engine Number N252053
Not For Usa
For H A 130 Type Transmission United States
Oil Level Indicator
Hydraulic Lines
Bevel Drive
For H A 110 Type Transmission
For H A130 Type Transmission Excepted United State S
Disc Brakes
Cardan Brake
Lift Arms
Angle Sensor
Linkage
Lift Cylinders Feeding
Levelling Box
Top Link With Hook End
Top Link With Ball End
Top Link Lock
Sensing Pin
Lower Bar With Hook
Telescopic Lower Bar
Tube Stabilizers
Iso Standard
Sae Standard
With Dromone Automatic Hook
Without Rings
Hitch
For Germany Only Or Any Text In German Only
With Remote Control
Protection Guard
2-3-4 Distributors
Hydraulic
Front Linkage 25000n
With Accumulator
With Front Dual Control
Lift External Control
Front Linkage 35000n
Accumulator
Pto Drive Mechanism
Independant Power Take Off Clutch
Brake
With 3 Speed Shiftable Ipto
Up To N......
Bridle
For United States Of America
Clockwise Drive Front Pto
Counterclockwise Drive Front Pto
Up To N308095
From Serial Or Engine Number N308096
Front Axle
Weight Carrier & Runner
With Front Lift
Belly Weight
Bracket
Differential Lock Mechanism
Guard And Transmission Shaft
Front Axle Fixed Carraro
Front Axle Suspended Carraro
Type 20.19
Carraro Type 20,19
Carraro Type 20,22
Type 20,29
Arms
Shock Absorber
Up To ...
From ...
Steering Wheel And Telescopic Column
Up To Serial Or Engine Number N307030
From Serial Or Engine Number N307031
Lighting Power Shuttle Drive
Four Wheel Drive
With Load Sensing
Twin Flow Load Sensing And Closed Center Load Sensing
Up To Serial Or Engine Number S009052
From Serial Or Engine Number S009053
Brake Pedals
Pipes And Fitting
Hydraulic Brake Assy
Pump Drive
Filter
H.A 110 Up To 701 1468 & H.A 130 Up To 701 1474
H.A 110 From 701 1469 & H.A 130 From 701 1475
Gear Box Lubrication
Interior
Pressure Filter
Hydraulic Valve Block
H.A 110 Up To 701 5235 & H.A 130 Up To 701 5215
From R179037
Transmission Hydraulic
Auxiliary Hydraulics
With Suspended Front Axle
Front Axle Fixed
Hydraulique Manifold
Auxiliary Distributors Installation
2 Distributors With Mechanical Control
3 Distributors With Mechanical Control
2 Distributors Electrodynamique And 1 Mechanical Control
4 Distributors With Mechanical Control
3 Distributors Electrodynamique And 1 Mechanical Control
2 Distributors Electrodynamique And 2 Mechanical Control
4 Distributors Electrodynamique
Hydraulic Lift Distributor
Load Sensing
3 Distributors
4 Distributors
Control Casing
Decal Hydraulic Controls
Electrical Equipment & Instrument Panel
With Dot Matrix
Electric Equipment & Instrument Panel
Side Console Switches
Industrial Cab
Engine Harness
Instrument Panel Harness
With Autotronic 5
Armrest
Plate Relay & Fuse Holder
Up To Serial Or Engine Number N344027
From Serial Or Engine Number N344028
With High Visibility Roof
Standard Roof
Pillar Harness
Rear Lightning Harness
Trailor Electric Socket
Handold
Automatic Air Conditioner Harness & Sensors
Electronic Equipment
Without Electronic Lift
Main Harness
With Dual Control
With Autotronic 5 Up To R208031
With Autotronic 5 From R208032
Without Dual Control
With Autotronic 5 Up To R093029
With Autotronic 5 From R093030
Console
With Datatronic 3
Aboard Computer And Plate Lighting Equipement
Transfers
Radar
M.T 535 B
Fieldstar
Front Axle Suspended Harness Control Box
Control Box Harness & Cab Controls
Up To Serial Or Engine Number R087007
From Serial Or Engine Number R087008
Sensors
Body
Grille
Hood
Left Side
Right Side
Brackets And Assembling Parts
Tool Box
Emblems
For Uk Only Or Any Text In English Only
See Next Page For Decal Location
For France Only Or Any Text In French Only
For Italy Only Or Any Text In Italian Only
For Spanish
For Sweden
Denmark
For Norway
Literature
Tractor Cab
Cab Mountings
With Suspension
Suspended Cab Control Unit
Pressue Regulator And Filter
Compressor
Air Tank
Up To Serial Or Engine Number N205025
From Serial Or Engine Number N205026
Glass
Window Fixation
Side Window Mechanism
Rear Window Mechanism
Roof
Window
Cladding
Dressing Roof
Instrument Panel Cladding
Cab Insulation
Fenders
Manual Air Conditioner
Windscreen Washer
Front Windscreen Wiper
Up To Serial Or Engine Number N271049
From Serial Or Engine Number N271050
Side Windscreen Wiper
Internal Mirrors
External Mirrors
Electric Control Rear Reflecting Miror
Luxuy
Seat Belt
Secondary Seat
Lighting
Front
Up To Serial M317014 For Tr 40km H Or Up To Serial M338030 For Tr 50km H
From Serial M317015 For Tr 40km H Or From Serial M338031 For Tr 50km H
United States
Standard Roof United States
Traffic Warning
Rear
Rotating Light
Rims & Wheels Weights
Excepted North America
Wheel Hub 10 Holes Assembling
Wheel Hub 10 Holes Fixing 6 Bridge Pieces
Wheel Hub 10 Holes Fixing 8 Bridge Pieces
With 8 Hole Fixing
Mudguards And Supports
Up To P033045
From P033046
With 10 Hole Fixing
Shaft Diameter 95 Mm Cone Wheel Hub Standard
Shaft Diameter 95 Mm Cone Wheel Hub Reversed
Short Shaft Diameter 95 Mm With Spacers For Dual Wheels Cone Wheel Hub Reversed
Distance Spacer For Wide Tread
Wheel Weights
Wheel Wedges
Brand: Challenger
Engine & Equipment
80 Amp
Up To R233045
From R233046
Starter
110 V
220 V
Engine Part
United States Only
Fuel System
Compresser
Dual Element
Throttle Controls
Clutch
Front Spacer
Clutch Control
Housing
Gear Box
Inner Housing
Planetary Drive
Pump Shaft
Accumulator Shaft
Hydraulique Motor
Duct Plate
Adjusting Device
Group Gear Shifting
Drive Line
Rear Axle
Not For Usa
Oil Level Indicator
Hydraulic Lines
Bevel Drive
Disc Brakes
Cardan Brake
Lift Arms
Angle Sensor
Linkage
Levelling Box
Top Link Lock
Sensing Pin
Lower Bar With Hook
Tube Stabilizers
Iso Standard
Sae Standard
Without Rings
Hitch
With Remote Control
Protection Guard
2-3-4 Distributors
Hydraulic
With Accumulator
Accumulator
Pto Drive Mechanism
Brake
Up To N......
Bridle
Up To N308095
Front Axle
With Front Lift
Belly Weight
Bracket
Type 20.19
Carraro Type 20,19
Carraro Type 20,22
Type 20,29
Arms
Shock Absorber
Up To ...
From ...
Four Wheel Drive
With Load Sensing
Brake Pedals
Pipes And Fitting
Pump Drive
Filter
Interior
Pressure Filter
From R179037
Front Axle Fixed
Load Sensing
3 Distributors
4 Distributors
Control Casing
With Dot Matrix
Industrial Cab
Engine Harness
With Autotronic 5
Armrest
Standard Roof
Pillar Harness
Handold
Main Harness
With Dual Control
Console
With Datatronic 3
Transfers
Radar
M.T 535 B
Fieldstar
Sensors
Body
Grille
Hood
Left Side
Right Side
Tool Box
Emblems
For Spanish
For Sweden
Denmark
For Norway
Literature
Tractor Cab
Cab Mountings
With Suspension
Compressor
Air Tank
Glass
Window Fixation
Roof
Window
Cladding
Dressing Roof
Cab Insulation
Fenders
Windscreen Washer
Internal Mirrors
External Mirrors
Luxuy
Seat Belt
Secondary Seat
Lighting
Front
United States
Traffic Warning
Rear
Rotating Light
With 8 Hole Fixing
Up To P033045
From P033046
With 10 Hole Fixing
Wheel Weights
Wheel Wedges
