Challenger Tractor MT525B MT535B MT545B Parts Catalog 1637435
Brand: Challenger
Model: Challenger MT525B, MT535B, MT545B With AutoPower VI Tractor
Part Number: 1637435
Number of Pages: 1289 Pages
Engine & Equipment
With Pneumatic Brake
Starter
Alternator & Bracket
80 Amp
Up To R233045
From R233046
Closed Circuit Breather
220 V
110 V
Engine Part
Fuel Tank & Attachments
United States Only
Fuel System
Fuel Filters And Pipes
Air Conditioned Installation
(Components)
Dual Element
Vertical Exhaust On The Side
Throttle Controls
Weight Carrier & Runner
Weight Frame And Tow Pin
Belly Weight
Bracket
Front Axle 2 Wheel Drive
Standard Front Axle
Wide Front Axle
Clutch
Guard
Front Axle Fixed Carraro
Housing
Differential Lock Mechanism
Guard And Transmission Shaft
M.T 525 B
545 B
M.T 535 B
M.T 545 B
Pin Kit
Shaft
Front Axle Suspended Carraro
Arms
Shock Absorber
Accumulator
Wheel & Steady Column
Steering Wheel And Telescopic Column
Two Wheel Drive
Four Wheel Drive
Steering Hydraulic Lines
Front Spacer
With Power Shuttle
With Auto Power V I
Flywheel & Flywheel Housing
Power Shuttle
Dynashift With Power Shuttle
Wet Clutch With Power Shuttle
Hydraulic Lines
Layshaft
Mainshaft
Output Shaft
Fork
Cover
Autodrive
Creeper Gear
Creeper Gearbox Control
Shift Lever
Control Armrest
Fingertip
Control
Hydromechanical
Inner Final Drive Gear
Hydraulic Lift Cover
Distributor Holder
Gear Box For Power Shuttle
Centre Housing
With Power Brakes
With Mechanical Brake
Brake Pedals
Pipes And Fitting
Handbrake
Mechanism
Oil Filter
Front Suspension Hydraulic Lines
Twin Flow Load Sensing
Oiling
Load Sensing
Without Trailor Brake
Trailer Brake Valve
With Front Axle Suspended Carraro
Up To No P278015
From N¦ P278016
Centrifugal Filter
Without Trailer Braking
With Trailer Braking
Cover Right
Open Center Hydraulic
Hydraulic Lift Valve
Without Lift Valve
With Load Sensing
Hydraulic Coupler
Auxiliary Hydraulic Valve Lines
Auxiliary Distributor
Hydraulic Lift Distributor
Open Centre Hydraulic
Oil Recovery
& 1 Mechanical Control
And 1 Dual Control
& 2 Mechanical Control
And 2 Dual Control
+ 1 Mechanical Control+ 1 Dual
Control Casing
Joystick For Distributor With Electrodynamique Control
Decal Hydraulic Controls
Batteries And Cables
With Battery Cut-Off
With Dot Matrix
Instrument Panel & Instruments
Lighting Power Shuttle Drive
Electric Equipment & Instrument Panel
Side Console Switches
Industrial Cab
External Controls Fitted On The Rear Fenders
Engine Harness
Trailor Electric Socket
For United States Of America
Automatic Air Conditioner Harness & Sensors
Without Electronic Lift
Electrical Wiring
Sensor Harness Dual Control
Instrument Panel Harness
Armrest
Plate Relay & Fuse Holder
Roof
Roof Harness
With High Visibility Roof
Standard Roof
Pillar Harness
Handold
Rear Lightning Harness
Main Harness
With Dual Control
Without Dual Control
Console
Aboard Computer And Plate Lighting Equipement
Transfers
Control Box Harness & Cab Controls
Front Axle Suspended Harness Control Box
Transmission Main Harness
Radar
Front
Up To Serial M311051
From Serial M311052
United States
Field Lights
Traffic Warning
Rear
Rotating Light
Fieldstar
Cab Mountings
With Suspension
Suspended Cab Control Unit
Compressor
Air Tank
Tractor Cab
Up To Serial Or Engine Number N195046
From Serial Or Engine Number N195047
Glass
Window Fixation
Side Window Mechanism
Rear Window Mechanism
Window
Cladding
Dressing Roof
Instrument Panel Cladding
Cab Insulation
Fenders
Hose
Windscreen Washer
Front Windscreen Wiper
Rear Window Wiper
Side Windscreen Wiper
Sae Standard
Iso Standard
Internal Mirrors
External Mirrors
Electric Control Rear Reflecting Miror
Seat Belt
Secondary Seat
Grille
Hood
Brackets And Assembling Parts
Left Side
Right Side
Tool Box
Literature
Emblems
With Dyna-6
Dynashift
40km H 24.8 Mph
Safety
For Spanish
For Sweden
Denmark
For Norway
2 Wheel Drive
4 Wheel Drive
Mudguards And Supports
Wheel Hub 8 Holes Fixing 8 Bridge Pieces
Wheel Hub 10 Holes Assembling
With 10 Hole Fixing
Fixing By Cone
Distance Spacer For Wide Tread
Wheel Weights
Wheel Wedges
Implement Drive System
5 Disc
Two Speed
Four Speed
With P.T.O Brakes
Pto-Dismountable Drive Mechanism
Pto-Coupling Drive Mechanism
Control Lever
Pto-Proportional Drive Mechanism
Pto
Up To N308095
Drive
Ipto Clutch
Lift Cylinders
Ram 66 Mm
Ram 75 Mm
Lift Cylinders Feeding
Linkage
Levelling Box
Top Link With Hook End
Lower Bar With Toogle
Lower Bar With Hook
Telescopic Lower Bar
Tube Stabilizers
Automatic Stabilisers
Drawbar And Hitch
Swinging Drawbar Support
With Rollers
Swinging Drawbar
With Dromone Automatic Hook
With Automatic Hook Lemoine
Swinging Drawbar Tidying
Cramer
Hitch
Lemoine
With Remote Control
Hydraulic Control
Hydraulic
2-3-4 Distributors
Front Linkage 25000n
With Accumulator
With Front Dual Control
Front Linkage 35000n
Brand: Challenger
Engine & Equipment
Starter
80 Amp
Up To R233045
From R233046
220 V
110 V
Engine Part
United States Only
Fuel System
(Components)
Dual Element
Throttle Controls
Belly Weight
Bracket
Standard Front Axle
Wide Front Axle
Clutch
Guard
Housing
M.T 525 B
545 B
M.T 535 B
M.T 545 B
Pin Kit
Shaft
Arms
Shock Absorber
Accumulator
Two Wheel Drive
Four Wheel Drive
Front Spacer
With Power Shuttle
With Auto Power V I
Power Shuttle
Hydraulic Lines
Layshaft
Mainshaft
Output Shaft
Fork
Cover
Autodrive
Creeper Gear
Shift Lever
Control Armrest
Fingertip
Control
Hydromechanical
Distributor Holder
Centre Housing
With Power Brakes
Brake Pedals
Pipes And Fitting
Handbrake
Mechanism
Oil Filter
Oiling
Load Sensing
Trailer Brake Valve
Up To No P278015
From N¦ P278016
Centrifugal Filter
Cover Right
Without Lift Valve
With Load Sensing
Hydraulic Coupler
Oil Recovery
And 1 Dual Control
And 2 Dual Control
Control Casing
With Dot Matrix
Industrial Cab
Engine Harness
Electrical Wiring
Armrest
Roof
Roof Harness
Standard Roof
Pillar Harness
Handold
Main Harness
With Dual Control
Console
Transfers
Radar
Front
From Serial M311052
United States
Field Lights
Traffic Warning
Rear
Rotating Light
Fieldstar
Cab Mountings
With Suspension
Compressor
Air Tank
Tractor Cab
Glass
Window Fixation
Window
Cladding
Dressing Roof
Cab Insulation
Fenders
Hose
Windscreen Washer
Rear Window Wiper
Sae Standard
Iso Standard
Internal Mirrors
External Mirrors
Seat Belt
Secondary Seat
Grille
Hood
Left Side
Right Side
Tool Box
Literature
Emblems
With Dyna-6
Dynashift
40km H 24.8 Mph
Safety
For Spanish
For Sweden
Denmark
For Norway
2 Wheel Drive
4 Wheel Drive
With 10 Hole Fixing
Fixing By Cone
Wheel Weights
Wheel Wedges
5 Disc
Two Speed
Four Speed
With P.T.O Brakes
Control Lever
Pto
Up To N308095
Drive
Ipto Clutch
Lift Cylinders
Ram 66 Mm
Ram 75 Mm
Linkage
Levelling Box
Lower Bar With Hook
Tube Stabilizers
Drawbar And Hitch
With Rollers
Swinging Drawbar
Cramer
Hitch
Lemoine
With Remote Control
Hydraulic Control
Hydraulic
2-3-4 Distributors
With Accumulator
