Challenger Tractor MT485D Parts Catalog 6246067
Brand: Challenger
Model: Challenger MT485D With Techstar CVT Tractor
Serial Number: D288058 - E309059
Part Number: 6246067
Number of Pages: 675 Pages
Engine & Equipment
Cylinder-Block
Timing Gear Housing
Flywheel And Housing
Crankshaft, Pistons & Piston Rod
Balancer Weight
Camshaft & Valve Mechanism
Oil Sump
Oil Cooler & Filter
Engine Breather
Injection System
Low Pressure Fuel System
Intake & Exhaust Manifold
Pipes
Electronic Engine Management
Engine Parts
Piston- Cylinder Head With Valves
2 Alternators
110 V
Engine Part
Fuel Tank & Attachments
Fuel Tank (Components)
(Components)
Breather Line
Fuel System
Air Conditioned Installation
Oil Recovery
Dual Element
Vertical Exhaust On The Side
Pollution Control
Throttle Controls
Weight Frame And Tow Pin
265 Kg
Bracket
Guard And Transmission Shaft
Clutch
Differential Lock Mechanism
Front Axle 4 Wheel Drive
Housing
Final Drive
Hydraulic Valve Block
Direction Sensor
Steering Wheel & Telescopic Column
Steering Hydraulic Lines
Auto Guide
Damper
Gear Box
Inner Housing
Planetary Drive
Pump Shaft
Accumulator Shaft
Hydraulique Motor
Duct Plate
Adjusting Device
Linings System Comfort
Group Gear Shifting
Drive Line
Range
Control Armrest
Handbrake
Wheel Shaft Housing
Oil Level Indicator
Bevel Drive
Hydraulic Lines
Inner Final Drive Gear
Disc Brakes
Cardan Brake
Brake Pedals
Pipes And Fitting
Front Suspension Hydraulic Lines
Cab Suspension Hydraulic Lines
Auxiliary Hydraulics
Hydraulic Brake Assy
Pump Drive
Filter
Gear Box Lubrication
Interior
Pressure Filter
Pump Installation
Cover Right
Hydraulique Manifold
Hydraulic Coupling
Auxiliary Distributors Installation
2 Electrohydraulic Spool Valves And 2 Mechanical Spool Valves
4 Distributors Electrodynamique
Load Sensing Hydraulic
146_2 Distributors Electrodynamique Control
With Electro-Hydraulic Control
Auxiliary Hydraulic Control
Decal Hydraulic Controls
Batteries & Cables
Instrument Panel & Instruments
Side Console Switches
Lighting & Power Shuttle Drive
Engine Harness
Plate Relay & Fuse Holder
Decal
External Controls Fitted On The Rear Fenders
Manual Air Conditioner
Roof Harness
Autoguide 3000 & C3000
Field Lights Harness
Front Lightning Harness
North America
Main Harness
Sensors
Transmission Control
Ignition Switch
Aboard Computer
Radar
Topdock
Auto-Guide
Autoguide 3000
Telemetry Antenna
Harness Isobus
Front Axle Suspended Harness Control Box
Control Box Harness & Cab Controls
Transmission Main Harness
Grille
Front
Working Light
Speed Sign
Traffic Warning
Sae
Rear
Rotating Light
With Suspension
Tractor Cab
Glass
Left Side
Right Side
Rear Window Mechanism
Roof
Cladding
Instrument Panel Cladding
Cab Insulation
Fenders
Standard Roof
Automatic Air Conditioner
Heater Control
Radio Installation
Sae Standard
Internal Mirrors
External Mirrors
Electric Rear View Mirror
Seat Belt
Secondary Seat
Hood
Hood Frame
Footstep
Tool Box
Toolbox
Literature
Basic
Emblems
Safety
Speed Charts
4 Wheels Drive
Mudguards And Supports
Wheel Hub 10 Holes Assembling
Fixing By Cone
Rear Wheel Weight 1 X 250 Kgf
Rear Wheel Weights
With Steel Rim
Implement Drive System
Independant Power Take Off Clutch
Bridle
Hydraulic Shifting
Pto
Lift Cylinders Feeding
Lift Arms
Angle Sensor
Linkage
Levelling Box
Hydraulic
Top Link With Ball End
Top Link Lock
Sensing Pin
Category 3
Telescopic Lower Bar
Tube Stabilizers
Swinging Drawbar Support
Swinging Drawbar
Front Rear Loaders
Frame
Kit
Water Fuel Separator
Alternator And Bracket
Female Coupler
Datatronic Kit
Complemantary Products
Video Camera Kit
Rear Fender Extension
Front Mudguards Kit
Front Pto
Front Dual Kit
Quick Coupling
Dealer Stocking List
Brand: Challenger
Engine & Equipment
Cylinder-Block
Timing Gear Housing
Balancer Weight
Oil Sump
Oil Cooler & Filter
Engine Breather
Injection System
Pipes
Engine Parts
2 Alternators
110 V
Engine Part
(Components)
Breather Line
Fuel System
Oil Recovery
Dual Element
Pollution Control
Throttle Controls
265 Kg
Bracket
Clutch
Housing
Final Drive
Direction Sensor
Auto Guide
Damper
Gear Box
Inner Housing
Planetary Drive
Pump Shaft
Accumulator Shaft
Hydraulique Motor
Duct Plate
Adjusting Device
Group Gear Shifting
Drive Line
Range
Control Armrest
Handbrake
Wheel Shaft Housing
Oil Level Indicator
Bevel Drive
Hydraulic Lines
Disc Brakes
Cardan Brake
Brake Pedals
Pipes And Fitting
Pump Drive
Filter
Interior
Pressure Filter
Pump Installation
Cover Right
Hydraulic Coupling
Batteries & Cables
Engine Harness
Decal
Roof Harness
North America
Main Harness
Sensors
Ignition Switch
Aboard Computer
Radar
Topdock
Auto-Guide
Autoguide 3000
Telemetry Antenna
Harness Isobus
Grille
Front
Working Light
Speed Sign
Traffic Warning
Sae
Rear
Rotating Light
With Suspension
Tractor Cab
Glass
Left Side
Right Side
Roof
Cladding
Cab Insulation
Fenders
Standard Roof
Heater Control
Radio Installation
Sae Standard
Internal Mirrors
External Mirrors
Seat Belt
Secondary Seat
Hood
Hood Frame
Footstep
Tool Box
Toolbox
Literature
Basic
Emblems
Safety
Speed Charts
4 Wheels Drive
Fixing By Cone
Rear Wheel Weights
With Steel Rim
Bridle
Hydraulic Shifting
Pto
Lift Arms
Angle Sensor
Linkage
Levelling Box
Hydraulic
Top Link Lock
Sensing Pin
Category 3
Tube Stabilizers
Swinging Drawbar
Front Rear Loaders
Frame
Kit
Female Coupler
Datatronic Kit
Video Camera Kit
Front Mudguards Kit
Front Pto
Front Dual Kit
Quick Coupling
