Challenger Tractor MT476 Parts Catalog CPE476
Brand: Challenger
Model: Challenger MT476 Tractor
Part Number: CPE476
Number of Pages: 507 Pages
Cylinder Engine
Engine 1006-6
Sedimenter
Pistons And Connecting Rods
Cylinder Head Cover And Filler
Engine Breather
Valves And Rockershafts
Cylinder Head Cover Rear
Timing Case
Axle Drive
Idler Gears
Lubrificating Oil Filter And Oil Cooler
Lubrificating Oil Pump
Crankshaft Oil Seal Rear
Crankshaft Pulley
Fan And Extension
Thermostato And Housing
Fuel Injection Pump
Fuel Injection Equipment
Controls
Cold Wheather Starting Aid
Low Pressure Fuel Pump
Induction Manifold
Admission System Turbo
Exhaust Manifold
Flywheel
Alternator Bosch
Starter Motor
Power Take Off Cover
Flwheel Housing
Exhaust System
Fitting Items
Joints Set Cylinder Head
Joints Set Block
Air Cleaner
Air Cleaner With Nozzle Dust
Fuel System Protector
Fuel Tank Left Hand
Fuel System 12 Speed
Fuel System 18 Speed
Fuel System Fasteners
Exhaust
Exhaust Vertical
Plug
Cam
2 Wheels Drive
4 Wheels Drive
Syncromesh
Gear
Shaft
Yoke
Spacer 12 Speed
Propeller Axle
Rear Axle 18 Speed
Support
Propeller Axle 2 Wheels Drive
Coupling
Drive Shaft
Selector
Central Frame
12 Speed 540 Rpm
Pinion And Diferential
Flange And Pinion
12 Speed 540 1000 Rpm
Diferential
Flange
12 Speed With Spacer 540 1000 Rpm
12v Without Spacer 540 Rpm
18v Without Spacer 540 Rpm
Rear Axle Differential
18v Without Spacer 540 1000 Rpm
Kit Gear
Rear Final Drive
Shaft-Half
Cover Left Hand
Cover Right Hand
Final Drive Cover
Brand: Challenger
Part Number: CPE476
Cylinder Engine
Engine 1006-6
Sedimenter
Engine Breather
Timing Case
Axle Drive
Idler Gears
Crankshaft Pulley
Fan And Extension
Fuel Injection Pump
Controls
Induction Manifold
Exhaust Manifold
Flywheel
Alternator Bosch
Starter Motor
Flwheel Housing
Exhaust System
Fitting Items
Joints Set Block
Air Cleaner
Fuel Tank Left Hand
Exhaust
Exhaust Vertical
Plug
Cam
2 Wheels Drive
4 Wheels Drive
Syncromesh
Gear
Shaft
Yoke
Spacer 12 Speed
Propeller Axle
Rear Axle 18 Speed
Support
Coupling
Drive Shaft
Selector
Central Frame
12 Speed 540 Rpm
Flange And Pinion
Diferential
Flange
Kit Gear
Rear Final Drive
Shaft-Half
Cover Left Hand
Cover Right Hand
Final Drive Cover
