Challenger Tractor MT475B Parts Catalog 3906197
Brand: Challenger
Model: Challenger MT475B Tractor
Part Number: 3906197
Number of Pages: 747 Pages
Dealer Stocking List
Quantity By Tractor
Engine & Equipment
Alternator & Bracket
Starter
110 V
Engine Part
Without Battery Cut-Off
With Battery Cut-Off
Pivoting Chassis
Without Air Conditioning
Engine Without Air Compressor
Engine With Air Compressor
Dual Element
Fuel Tank & Attachments
Additional Tank
Fuel Pipes
Water Fuel Separator
Without Additional Tank
With Additional Tank
Air Cooler
Air Conditioned Installation
Compresser
Vertical Exhaust On The Side
Cab With Flat Bottom
Throttle Controls
Clutch
Front Spacer
Flywheel & Flywheel Housing
With Power Shuttle
With Electric Control
Load Sensing Up To U295005
Load Sensing From U295006 Up To B257037
Excepted B257052 064 075-B258003
Up To Serial Or Engine Number U295005
From Serial Or Engine Number U295006
Housing
Open Centre Hydraulic Up To U295005
Open Centre Hydraulic From U295006
With Load Sensing
Module Powershift
Dual Clutch
Reverse Gear
Layshaft
Output Shaft
Synchro
Cover
Fork
Creeper Gear
With Super Creeper Gear
Creeper Gearbox Control
Transmission Control
Rear Axle
Handbrake
Mechanism
Centre Housing
Hydromechanical
Open Center Hydraulic
Hydraulic Lines
5 Differential
Up To Serial Or Engine Number D141016
From Serial Or Engine Number D141017
Hydraulic Lift Cover
Linkage
Ram 66mm
Ram 75mm Up To U295005
Ram 75mm From U295006
With Load Sensing Up To V098037
With Load Sensing From V098038
Ram 75mm
Levelling Box
Cat. 2
Cat. 3
Top Link With Ball End
Load Sensing
Sensing Pin
Lower Bar With Hook
Telescopic Lower Bar
Up To Serial Or Engine Number V014001
From Serial Or Engine Number V014002
Up To Serial Or Engine Number B166017
From Serial Or Engine Number B166018
Up To B166017
From B166018
Iso Standard Up To
Iso Standard From
Up To Serial Or Engine Number C060045
From Serial Or Engine Number C060046
Without Linkage
Hydraulic
Accumulator
Without Front Linkage
Up To Serial Or Engine Number C192032
From Serial Or Engine Number C192033
Open Centre Hydraulic Up To C192032
Open Center Hydraulic From C192033
Load Sensing Up To C192032
Load Sensing From C192033
Pto Drive Mechanism
Pto Shaft
5 Disc Up To C205000
5 Disc From C205001
Two Speed
Four Speed
Cable Control
Pto-Dismountable Drive Mechanism
Pto-Coupling Drive Mechanism
Control Lever
Without Control Lever
Up To D295069
From D295070
Front Axle
Weight Frame And Tow Pin
Chassis Structure
Bracket
Front Axle 2 Wheel Drive
Up To Serial Or Engine Number T015033
From Serial Or Engine Number T015034
Guard
Guard And Transmission Shaft
Differential Lock Mechanism
Front Axle Fixed
Final Drive
Steering Wheel And Telescopic Column
Lighting Power Shuttle Drive
Steering Pump
Open Centre Hydraulic -W O Assited Steering
Up To U295005
From No U295006
Up To N° V098037
From N° V098038
With Fixed Front Axle From U295006 Up To C051027
With Fixed Front Axle From C051028
Up To D141016
From D141017
Up To U138012
From U138013
With Mechanical Brake
From U295006
Up To T259015
With Trailer Braking From U295006
Right Cover
Without Trailer Braking
Trailer Brake Valve
Up To Serial Or Engine Number B040053
From Serial Or Engine Number B040054
Without Trailer Braking Up To V098037
Without Trailer Braking From V098038
With Trailer Braking Up To V098037
With Trailer Braking From V098038
Open Centre Hydraulic Twin Flow Open Centre
Hydraulic Lines Up To U295005
Hydraulic Lines From U295006
Pump
Twin Flow Open Center Up To U295005
Twin Flow Open Center From U295006
Hydraulic Lift Valve
Up To U330004
From U330005
Open Centre Hydraulic Up To N° T263072
Open Centre Hydraulic From N° T263073
Auxiliary Distributor
Up Tov098037
Fromv098038
2 Distributors With Mechanical Control
3 Distributors With Mechanical Control
4 Distributors With Mechanical Control
Hydraulic Lift Distributor
Decal Hydraulic Controls
Electrical Equipment & Instrument Panel
With Speedometer With Power Shuttle
Electric Equipment & Instrument Panel
Side Console Switches
For United States Of America
Not For Usa
Up To Serial Or Engine Number U183044
From Serial Or Engine Number U183045
Trailor Electric Socket
Roof Harness
Hand Rail
Electronic Equipment
Main Harness
Console
Control Box Harness & Cab Controls
Sensors
Body
United States Only
Excepted North America
Up To V162008
From V162009
Left Side
Right Side
Tool Box
2 Stair
With 3 Stair
Speed Charts
Up To V181014
From V181015
Safety
From U068066
Literature
Tractor Cab
Up To V046025
From V046026
With Fuel Tank 130l
Sheet Metal Seal
Doors
Glass
Side Window Mechanism
Rear Window Mechanism
Roof
Cladding
Dressing Roof
Instrument Panel Cladding
Cab Insulation
Fenders
Hoses
Heater
Hose
Manual Air Conditioner
Standard Roof
Heater Control
Windscreen Washer
Front Windscreen Wiper
Rear Window Wiper
Canopy
Radio Installation
Eec Standard
Electrical Plug
Internal Mirrors
External Mirrors
Air Ride Suspension
Suspension
Seat Belt
Secondary Seat
Lighting
Front
North America Only
Working Light
Traffic Warning
Rear
Rotating Light
Rims & Wheels Weights
Fitting 8 Screws
Wheel Hub 8 Holes Fixing
Wheel Hub 8 Holes Fixing 6 Bridge Pieces
Rigid
Pivoting
Compatible For Way Foward 60 Up To ...
Compatible For Way Foward 60 From ...
Up To ..... Axle Dia. 25mm
From ..... Axle Dia. 28mm
Wheel Hub 8 Holes Fixing 8 Bridge Pieces
With 8 Hole Fixing
Distance Spacer For Wide Way
Repair Kit
Double Clutch
Input Box & Dual Clutch
Gear Box For Power Shuttle
Brand: Challenger
Quantity By Tractor
Engine & Equipment
Starter
110 V
Engine Part
Pivoting Chassis
Dual Element
Additional Tank
Fuel Pipes
Air Cooler
Compresser
Throttle Controls
Clutch
Front Spacer
With Power Shuttle
Housing
With Load Sensing
Module Powershift
Dual Clutch
Reverse Gear
Layshaft
Output Shaft
Synchro
Cover
Fork
Creeper Gear
Rear Axle
Handbrake
Mechanism
Centre Housing
Hydromechanical
Hydraulic Lines
5 Differential
Linkage
Ram 66mm
Ram 75mm
Levelling Box
Cat. 2
Cat. 3
Load Sensing
Sensing Pin
Lower Bar With Hook
Up To B166017
From B166018
Iso Standard Up To
Iso Standard From
Without Linkage
Hydraulic
Accumulator
Pto Drive Mechanism
Pto Shaft
5 Disc From C205001
Two Speed
Four Speed
Cable Control
Control Lever
Up To D295069
From D295070
Front Axle
Chassis Structure
Bracket
Guard
Front Axle Fixed
Final Drive
Steering Pump
Up To U295005
From No U295006
Up To N° V098037
From N° V098038
Up To D141016
From D141017
Up To U138012
From U138013
From U295006
Up To T259015
Right Cover
Trailer Brake Valve
Pump
Up To U330004
From U330005
Up Tov098037
Fromv098038
Not For Usa
Roof Harness
Hand Rail
Main Harness
Console
Sensors
Body
United States Only
Up To V162008
From V162009
Left Side
Right Side
Tool Box
2 Stair
With 3 Stair
Speed Charts
Up To V181014
From V181015
Safety
From U068066
Literature
Tractor Cab
Up To V046025
From V046026
With Fuel Tank 130l
Sheet Metal Seal
Doors
Glass
Roof
Cladding
Dressing Roof
Cab Insulation
Fenders
Hoses
Heater
Hose
Standard Roof
Heater Control
Windscreen Washer
Rear Window Wiper
Canopy
Radio Installation
Eec Standard
Electrical Plug
Internal Mirrors
External Mirrors
Air Ride Suspension
Suspension
Seat Belt
Secondary Seat
Lighting
Front
North America Only
Working Light
Traffic Warning
Rear
Rotating Light
Fitting 8 Screws
Rigid
Pivoting
With 8 Hole Fixing
Repair Kit
Double Clutch
