Challenger Tractor MT465B Parts Catalog 1637474
Brand: Challenger
Model: Challenger MT465B Tractor
Part Number: 1637474
Number of Pages: 958 Pages
Engine & Equipment
Alternator & Bracket
80 Amp
120 Amp
Starter
Up To R006022
From R006023
Up To P341051
From P341052
Engine Part
Up To P097084
From P097085
With Auto Power I V
Up To Serial Or Engine Number P110007
From Serial Or Engine Number P110008
Up P097084
Up To P110007
From P110008
With Fuel Tank 150l Up To P097084
With Fuel Tank 145l From P097085
W O Battery Cut-Of
Without Battery Cut-Off
With Battery Cut-Off
Air Conditioned Installation
Compresser
Dual Element
Vertical Exhaust On The Side
Throttle Controls
Clutch
With Power Shuttle
With Dry Clutch
Front Spacer
With Mechanical Reversing Gear
Dry Clutch
Up To Serial Or Engine Number P186029
From Serial Or Engine Number P186030
Power Shuttle
5 Disc
Wet Clutch With Power Shuttle
With Speedshift
Valve With Speedshift
With Mechanical Reverse Shuttle
Up To R032030
From R032031 Up To S151025
From S151026
Load Sensing From S151026
Housing
Speedshift With Power Shuttle
Speedshift With Mechanical Shuttle
With Double Cone Synchro
Control
Layshaft
Countershaft
Mainshaft
Output Shaft
Mechanical Forward Reverse
Cover
Reversing Gear Selection
Fork
Load Sensing
Creeper Gear
With Super Creeper Gear
Auto Power I V
Creeper Gearbox Control
Shift Lever
Left Hand Controls
Rear Axle
Handbrake
Mechanism
Hydromechanical
Hydraulic Lines
Rear Axle Differential
Inner Final Drive Gear
Up To Serial Or Engine Number S180004
From Serial Or Engine Number S180005
Distributor Holder
Linkage
Lift Cylinders
Ram 66 Mm
Ram 75 Mm
With Load Sensing Up To N¦ S337077
With Load Sensing From N¦ S337078
Up To Serial Or Engine Number S207081
From Serial Or Engine Number S207082
Levelling Box
Top Link With Ball End
Cat. 2
Up To N099061
From N099062 Up To N292021
From N292022 Up To P061062
From P061063
With Load Sensing
Sensing Pin
Telescopic Lower Bar
Tube Stabilizers
Automatic Stabilizers
Swinging Drawbar Support
Sae Standard
Iso Standard
Swinging Drawbar Tidying
Hydraulic Control
Hitch
Control Lever
Mono Handle
Open Centre Hydraulic
Auxiliary Distributor
Pto Drive Mechanism
Up To P053026
Up To Serial Or Engine Number S005006
From Serial Or Engine Number S005007
Cable Control
4 Speed Pto
Pto-Dismountable Drive Mechanism
Pto-Coupling Drive Mechanism
P.T.O Control 540 1000 Tr Mn
Four Wheel Drive
Platform
Pto
With Dromone Automatic Hook
Front Axle
Weight Frame And Tow Pin
Bracket
Front Axle 2 Wheel Drive
Standard Front Axle
Wide Front Axle
Cylinders
Guard
Differential Lock Mechanism
With AutoPower I V
Guard And Transmission Shaft
Front Axle 4 Wheel Drive
Steering Cylinders
Up To N176016
From N176017
Hydraulic
Steering Wheel And Telescopic Column
Lighting Power Shuttle Drive
Two Wheel Drive
Up To N126023
From N126024
Twin Flow Open Center
Up To S151025
Up To R328065
From R328066
With Mechanical Brake
Up To S066037 W O Auto 4 Power I V & Up To S151025 With Auto Po
Without Trailer Braking-From S066038 W O Auto Power I V & From S151026 With Auto Power I
Up To R236038
From R236039
With Auto Power I V Up To S123085
With Auto Power I V From S123086
With Auto Power I V Up To S110051
With Auto Power I V From S110052
Without Trailor Brake
Selector Valve
With Trailer Braking
Trailer Brake Valve
Centrifugal Filter
Cover Right
With Auto Power I V Up To N¦ R117068
With Auto Power I V From N¦ R117069
Without Lift Valve
Pump
Hydraulic Lift Valve
Open Centre Hydraulic Twin Flow Load Sensing Up To N281029
Twin Flow Load Sensing From N281030
Open Centre Hydraulic Twin Flow Open Centre
Hydraulic Coupling
2 Or 3 Load Sensing Distributors
Open Centre Hydraulic Auto Power I V
Open Center Hydraulic
3 Distributors With Mechanical Control
Hydraulic Lift Distributor
With Joystick
Joystick For Distributor With Electrodynamique Control
Decal Hydraulic Controls
Electrical Equipment & Instrument Panel
With Speedometer With Power Shuttle
With Speedometer With Mechanical Reversing Gear
Electric Equipment & Instrument Panel
Side Console Switches
Engine Harness
57l Min Open Center Up To N257085
100l Min Twin Flowopen Center
AutoPower I V Excepted North America
57l Min Open Center From N257086- 100l Min Twin Flowopen Center
100l Min Twin Flow Open Center
AutoPower I V North America
Harness Console
Up To Serial Or Engine Number N288075
From Serial Or Engine Number N288076
With High Visibility Roof
Handold
Rear Lightning Harness
For United States Of America
Trailor Electric Socket
Rotating Light
With Platform
Electronic Equipment
Open Centre Hydraulic Up To N257085
Open Centre Hydraulic From N257086
Up To Serial Or Engine Number N257085
From Serial Or Engine Number N257086
Console
Up To R117039
From R117040
With Power Shuttle- 57l Min Open Center
With Power Shuttle- 100l Min Twin Flow Open Center
57l Min Open Center
With Auto Power I V Up To N¦ S123065
With Auto Power I V From N¦ S123066
Body
Grille
Hood
Brackets And Assembling Parts
Tool Box
Emblems
3 Stairs Up To P150082
2 Stairs From P150083
3 Stairs From P150083
40km H 24.8 Mph
For Uk Only Or Any Text In English Only
See Next Page For Decal Location
Safety
Literature
Tractor Cab
Cab Mountings
Front Opening Screen
Doors
Glass
Front Opening Screen Mechanism
Side Window Mechanism
Rear Window Mechanism
Roof
Window
Cladding
Dressing Roof
Up To Serial Or Engine Number N357052
From Serial Or Engine Number N357053
Cab Insulation
Fenders
Hoses
Heater
Hose
Manual Air Conditioner
Air Conditioner
Cab Filter
Heater Control
Windscreen Washer
Up To Serial Or Engine Number N273048
From N273049 Up To P194058
From Serial Or Engine Number P194059
Up To Serial Or Engine Number N271049
From Serial Or Engine Number N271050
Canopy
Eec Standard
Internal Mirrors
External Mirrors
Suspension
Air Ride Suspension
Seat Belt
Secondary Seat
Standard Roof
Platform With Pillars
Safety Frame
Instrument Panel Cladding
Up To R011025
From R011026
Lighting
Front
Field Lights
Rear
Traffic Warning
Rims & Wheels Weights
2 Wheel Drive
Wheel Hub 8 Holes Fixing
Wheel Hub 8 Holes Fixing 6 Bridge Pieces
4 Wheel Drive
Mudguards And Supports
Pivoting
Wheel Hub 8 Holes Fixing 8 Bridge Pieces
Distance Spacer For Wide Tread
Repair Kit
For Mechanical Forward Reverse
Power Shuttle Input Box
Gear Box For Mechanical Shuttle
Gear Box For Power Shuttle
Centre Housing
Brand: Challenger
Engine & Equipment
80 Amp
120 Amp
Starter
Up To R006022
From R006023
Up To P341051
From P341052
Engine Part
Up To P097084
From P097085
With Auto Power I V
Up P097084
Up To P110007
From P110008
W O Battery Cut-Of
Compresser
Dual Element
Throttle Controls
Clutch
With Power Shuttle
With Dry Clutch
Front Spacer
Dry Clutch
Power Shuttle
5 Disc
With Speedshift
Up To R032030
From S151026
Housing
Control
Layshaft
Countershaft
Mainshaft
Output Shaft
Cover
Fork
Load Sensing
Creeper Gear
Auto Power I V
Shift Lever
Left Hand Controls
Rear Axle
Handbrake
Mechanism
Hydromechanical
Hydraulic Lines
Distributor Holder
Linkage
Lift Cylinders
Ram 66 Mm
Ram 75 Mm
Levelling Box
Cat. 2
Up To N099061
From P061063
With Load Sensing
Sensing Pin
Tube Stabilizers
Sae Standard
Iso Standard
Hydraulic Control
Hitch
Control Lever
Mono Handle
Pto Drive Mechanism
Up To P053026
Cable Control
4 Speed Pto
Four Wheel Drive
Platform
Pto
Front Axle
Bracket
Standard Front Axle
Wide Front Axle
Cylinders
Guard
With AutoPower I V
Steering Cylinders
Up To N176016
From N176017
Hydraulic
Two Wheel Drive
Up To N126023
From N126024
Up To S151025
Up To R328065
From R328066
Up To R236038
From R236039
Selector Valve
Trailer Brake Valve
Centrifugal Filter
Cover Right
Without Lift Valve
Pump
Hydraulic Coupling
With Joystick
Engine Harness
Harness Console
Handold
Rotating Light
With Platform
Console
Up To R117039
From R117040
57l Min Open Center
Body
Grille
Hood
Tool Box
Emblems
40km H 24.8 Mph
Safety
Literature
Tractor Cab
Cab Mountings
Doors
Glass
Roof
Window
Cladding
Dressing Roof
Cab Insulation
Fenders
Hoses
Heater
Hose
Air Conditioner
Cab Filter
Heater Control
Windscreen Washer
Canopy
Eec Standard
Internal Mirrors
External Mirrors
Suspension
Air Ride Suspension
Seat Belt
Secondary Seat
Standard Roof
Safety Frame
Up To R011025
From R011026
Lighting
Front
Field Lights
Rear
Traffic Warning
2 Wheel Drive
4 Wheel Drive
Pivoting
Repair Kit
Centre Housing
