Challenger Tractor MT445B Parts Catalog 3906182
Brand: Challenger
Model: Challenger MT445B Tractor
Serial Number: T177054 - C241017
Part Number: 3906182
Number of Pages: 171 Pages
Engine & Equipment
Alternator And Bracket
Heater Engine Block
Engine Part
Dual Element
Low Pressure Fuel System
Fuel Pipes
Fuel Tank & Attachments
Additional Tank
Fuel System
Air Conditioned Installation
(Components)
Vertical Exhaust On The Side
Throttle Controls
Weight Frame And Tow Pin
Belly Weight
Bracket
Front Axle 2 Wheel Drive
Cylinders
Guard And Transmission Shaft
Clutch
Differential Lock Mechanism
Front Axle 4 Wheel Drive
Steering Cylinders
Housing
Final Drive
Steering Wheel & Telescopic Column
Steering Hydraulic Lines
Front Spacer
Flywheel & Flywheel Housing
With Power Shuttle
Wet Clutch With Power Shuttle
Chassis Structure
Module Powershift
Dual Clutch
Reverse Gear
Layshaft
Output Shaft
Brand: Challenger
Engine & Equipment
Heater Engine Block
Engine Part
Dual Element
Fuel Pipes
Additional Tank
Fuel System
(Components)
Throttle Controls
Belly Weight
Bracket
Cylinders
Clutch
Steering Cylinders
Housing
Final Drive
Front Spacer
With Power Shuttle
Chassis Structure
Module Powershift
Dual Clutch
Reverse Gear
Layshaft
Output Shaft
