Challenger Tractor MT434 Parts Catalog CPE434
Brand: Challenger
Model: Challenger MT434 Tractor
Part Number: CPE434
Number of Pages: 1284 Pages
Engine And Equipment
Tractors With Operator Plataform
Tractors With Cab
Pistons And Connecting Rods
Valves And Rockershafts
Cylinder Head Cover
Engine Breather
Timing Case
Camshaft
Idler Gears
Tachometer Drive
Lubrificating Oil Filter And Oil Cooler
Oil Sump
Balancer Unit And Oil Pump
Crankshaft Oil Seal
Induction Manifold
Cold Wheather Starting Aid
Exhaust Manifold
Fuel Injection System
Fuel Injection Pump
Fuel Oil Lift Pump
Fuel System
Crankshaft Pulley
Fan And Extension
Thermostato And Housing
Without Air Conditioner
Power Take-Off
Fitting Items
Flywheel
Cylinder Head Gasket Set
Cylinder Block Gasket Set
Starter Motor
Prestolite
Bosch
Without Nozzle Dust
Air Cleaner
With Nozzle Dust
Tractors With 2 Wheels Drive And Operator Platafor M
18 Speeds
Simple Tank
Double Tank
Tractors With 18 Speeds And Simple Tank
Clutch
Split Torque
13
Ceramic Disk
Tractors With Cab And 8x8 Speed
2 Wheels Drive
077_8x8 Transmission
4 Wheels Drive
084_8x8 Transmission
Cover
With Clutch Split
Pto (540 Rpm)
Syncromesh
Set Transmission
Inlet Shaft
Pto (540 1000 Rpm)
Retainer Main Drive Shaft
Bearing
121_12 Speed Transmission
130_12 Speed Transmission
Selector
540 Rpm
2 Wheels Driv
4 Wheels Driv
540 1000 Rpm
18 Speed
Shaft
Gear
Rear Axle
Plug
Cam
Middle Body
With Paddy
Kit Gear
Diferential
Pto 540 1000 Rpm
Flange
Pto 540 Rpm
Flange And Pinion
Pinion And Diferential
Rear Final Drive
Shaft-Half
Support
Left Hand
Right Hand
Final Drive Cover
12 Speed And Without Tdp
12x12 Speed And Without Tdp
Independent Power Take-Off Clutch
Linkage
Drawbar
Hd
Arm Rest
Levelling Arm
Links
3000-4000kgf
With Quick Coupler
Without Quick Coupler
Telescopic Drawbar And Autohitch
Tractors With Cab And Electronic System
Without Paddy
Telescopic Stabiliser
Pto-Drive Mechanism
Without Selecte Valve
Electronic System
Tdp Kit
Front Axle
Hydraulics
Tractors With 4 Wheels Drive And Operator Platafor M
With Cab
Without Cab
Tractors With 4 Wheels Drive And Cab
With Independent Power Take Off
With Independent Power Take Off And Cab
With Independent Power Take Off And Operato R Plataform
Ferguson System
Cylinder
Control
Hydraulic Lift Cover
12 Speed
With Ferguson System
2600 Kgf
Ipto 540 1000 Rpm
Ipto 540 Rpm
Brake
Centrifugal Filter
Valve
Simple With Detain
Dual
Single
1 Body
Master Cylinder
Hydraulic Lines
With Selecte Valve
Hinge Support
Draft Braket
Electric Equipment & Instrument Panel
Battery
18 Speeds Ferguson System
Sheet Metal
Tractors With Operator Plataform Without Nozzle Dust
Tractors With Operator Plataform With Nozzle Dust
12x12 Speed
With Transmission 8x8 Speed
Grille
Spanish
With Cab And Without Pto
Portuguese
Head Lamp
Operator Plataform
With Base & With Seat Belt
Tractors With Cab And Ferguson System
Over Protective
Roll- Over Protective
Rops Inclinable
Warning Light
Canopy
Rear Control
Side Console
Console
Tractor Cab
Air Conditioner
Roof
Rear Windscreen Wiper
With Hydrotronic
Tractor With Cab
Cladding
Cab Heating System
Roor Cab
Tractors With Cab Without Nozzle Dust
Tractors With Cab With Nozzle Dust
Without Hydraulic
Sealing
Rims And Wheels Weights
Large Hub) Pirelli
Large Hub) Goodyear
4 Wheel Drive
18.4-R34 (Radial) Goodyear
16.9-R30 (Radial) Goodyear
16.9-R34 (Radial) Goodyear
18.4-38 (Radial) Goodyear
18.4-30 (10l) Pirelli
16.9-30 (8l) Pirelli
18.4-34 (10l) Pirelli (Pavt)
16.9-30 (8l) Goodyear
18.4-30 (10l) Goodyear
18.4-R30 (Radial) Goodyear
2 + 2 X 72 Kg
Wheel
Rim W16lx34
Rim W15lx34
Rim W14lx30
Rim W16lx30
Rim W16x34 (Pavt)
8x42 Kgf + 1x84 Kgf
Accessories Miscellaneous
Starting Heater
Spanner
Tools
Brand: Challenger
Part Number: CPE434
Tractors With Cab
Cylinder Head Cover
Engine Breather
Timing Case
Camshaft
Idler Gears
Tachometer Drive
Oil Sump
Crankshaft Oil Seal
Induction Manifold
Exhaust Manifold
Fuel Injection Pump
Fuel Oil Lift Pump
Fuel System
Crankshaft Pulley
Fan And Extension
Power Take-Off
Fitting Items
Flywheel
Starter Motor
Prestolite
Bosch
Without Nozzle Dust
Air Cleaner
With Nozzle Dust
18 Speeds
Simple Tank
Double Tank
Clutch
Split Torque
13
Ceramic Disk
2 Wheels Drive
4 Wheels Drive
Cover
With Clutch Split
Pto (540 Rpm)
Syncromesh
Set Transmission
Inlet Shaft
Pto (540 1000 Rpm)
Bearing
Selector
540 Rpm
2 Wheels Driv
4 Wheels Driv
540 1000 Rpm
18 Speed
Shaft
Gear
Rear Axle
Plug
Cam
Middle Body
With Paddy
Kit Gear
Diferential
Pto 540 1000 Rpm
Flange
Pto 540 Rpm
Flange And Pinion
Rear Final Drive
Shaft-Half
Support
Left Hand
Right Hand
Final Drive Cover
Linkage
Drawbar
Hd
Arm Rest
Levelling Arm
Links
3000-4000kgf
With Quick Coupler
Without Paddy
Pto-Drive Mechanism
Electronic System
Tdp Kit
Front Axle
Hydraulics
With Cab
Without Cab
Ferguson System
Cylinder
Control
12 Speed
2600 Kgf
Ipto 540 1000 Rpm
Ipto 540 Rpm
Brake
Centrifugal Filter
Valve
Simple With Detain
Dual
Single
1 Body
Master Cylinder
Hydraulic Lines
With Selecte Valve
Hinge Support
Draft Braket
Battery
Sheet Metal
12x12 Speed
Grille
Spanish
Portuguese
Head Lamp
Operator Plataform
Over Protective
Rops Inclinable
Warning Light
Canopy
Rear Control
Side Console
Console
Tractor Cab
Air Conditioner
Roof
With Hydrotronic
Tractor With Cab
Cladding
Cab Heating System
Roor Cab
Without Hydraulic
Sealing
Large Hub) Pirelli
Large Hub) Goodyear
4 Wheel Drive
2 + 2 X 72 Kg
Wheel
Rim W16lx34
Rim W15lx34
Rim W14lx30
Rim W16lx30
Rim W16x34 (Pavt)
8x42 Kgf + 1x84 Kgf
Starting Heater
Spanner
Tools
