Challenger Tractor MT400 MT500 MT600 Accessories Series Tier 3 Engine Parts Catalog 3906052
702,019
Brand: Challenger
Model: Challenger MT400, MT500, MT600 Accessories Series Tier 3 Engine Tractor
Part Number: 3906052
Number of Pages: 372 Pages
Heater Engine Block - M.T 500 B M.T 600 B M.T 600 C - 110v
Heater Engine Block - M.T 400 B - 110v
Heater Engine Block - M.T 475 B M.T 500 B Powered By Caterpillar - 110v
Heater Engine Block - M.T 500 B M.T 600 B M.T 600 C - 220v
Heater Engine Block - M.T 400 B - 220v
Heater Engine Block - M.T 475 B M.T 500 B Powered By Caterpillar - 220v
Fuel Heater - Powered By Sisu
Transmission Heater - M.T 400 B M.T 500 B Autopower V. I Caterpillar Engine Only 110v
Transmission Heater - M.T 500 B Autopower V. I Sisu Engine 40kph - 50kph
Transmission Heater - M.T 500 B Techstar Cvt Up To S206076 For U.S.A S243059 Other Countries
Transmission Heater - M.T 600 B A Up To S206076 For U.S.A S243059 Other Countries
Fuel Pipes - Water Fuel Separator - M.T 400 B
Fuel Pipes - Water Fuel Separator - M.T 500 B Powered By Caterpillar
Fuel Pipes - Water Fuel Separator - M.T 500 B Powered By Sisu
Fuel Pipes - Water Fuel Separator - M.T 600 B
Fuel Tank & Attachments
Locking Cap
Additional Tank - M.T 400 B
Creeper Gearbox Control - M.T 400 B - 0,11 Mph - Autopower I V
Creeper Gearbox Control - M.T 400 B - 0,37 Mph
Creeper Gearbox Control - M.T 525 B 545 B - 0,11 Mph - Autopower V I
Creeper Gearbox Control - M.T 525 B 545 B - 0,37 Mph - Autopower V I
Creeper Gearbox Control - M.T 555 B 575 B - 0,37 Mph
Creeper Gearbox Control - M.T555 B 575 B Autopower Vi - 0,60 Kph
Pto Shaft - M.T 525 B 575 B
Pto-Coupling Drive Mechanism - M.T 400 B - P.T.O Control 540 1000 Tr Mn
Pto-Coupling Drive Mechanism - M.T 525 B 545 B - P.T.O Control 540 1000 Tr Mn
Pto Drive Mechanism - Four Speed - M.T 400 B
Pto Drive Mechanism - Four Speed - M.T 525 B 545 B
Pto Drive Mechanism - 3 Speed - M.T 555 B 575 B
Pto-Proportional Drive Mechanism - M.T 400 B
Pto-Proportional Drive Mechanism - M.T 525 B 545 B - Autopower V.I - Open Centre Hydraulic
Pto-Proportional Drive Mechanism - M.T 525 B 545 B - Load Sensing & Twin Flow Load Sensing
Pto-Proportional Drive Mechanism - M.T 555 B 575 B
External Controls Fitted On The Rear Fenders - M.T 400 B
Front Pto - M.T 475 B M.T 500 B
Front Pto - M.T 600 C
Front Pto - M.T 585 B M.T 595 B - With Front Linkage 40000n
Front Linkage 28000n - M.T 400 B - Open Centre Hydraulic
Front Linkage 28000n - M.T 400 B - Load Sensing & Twin Flow Load Sensing
Front Linkage 28000n - M.T 425 B 465 B - Accumulator Kit Open Centre Hydraulic
Front Linkage 28000n - M.T 425 B 465 B - Accumulator Kit Load Sensing
Front Linkage 28000n - M.T 475 B M.T 525 B 545 B Autopower V.I - Open Center Hydraulic
Front Linkage 28000n - M.T 475 B M.T525 B 545 B - Accumulator Kit Open Center Hydraulic
Front Linkage 28000n - M.T 475 B M.T 525 B 545 B Autopower V.I - Load Sensing
Front Linkage 28000n - M.T 525 B 545 B - Techstar Cvt - Load Sensing
Front Linkage 28000n - M.T 400 B - Front Dual Kit With Rear Dual Control
Front Linkage 28000n - M.T 400 B Without Front Dual Control - Lift External Control
Front Linkage 40000n - M.T 475 B M.T 525 B 545 B Autopower V.I - Open Center Hydraulic
Front Linkage 40000n - M.T 475 B M.T 525 B 545 B Autopower V.I - Load Sensing
Front Linkage 40000n - M.T 475 B M.T 525 B 595 B - Accumulator Kit - Load Sensing
Front Linkage 40000n - M.T 555 B M.T 595 B Autopower V.I - Load Sensing
Front Linkage 40000n - M.T 525 B 595 B Techstar Cvt
Front Linkage 40000n - M.T 525 B 595 B - Accumulator Kit - Techstar Cvt Load Sensing
Front Linkage - M.T 475 B M.T 525 B 595 B - Without Front Dual Control - Lift External Control
Front Linkage - M.T 475 B M.T 525 B 595 B - Front Dual Kit With Rear Dual Control
Front Linkage 40000n - M.T 600 B
Front Linkage 40000n - M.T 600 B - Without Front Dual Control - Lift External Control
Front Linkage 40000n - M.T 600 B - Front Dual Kit With Rear Dual Control
Front Linkage 40000n - M.T 525 B 575 B
Front Linkage 50000n - M.T 600 B
Front Linkage 50000n - M.T 600 B Without Front Dual Control - Lift External Control
Front Linkage 50000n - M.T 600 B - Front Dual Kit With Rear Dual Control
Front Linkage 50000n - M.T 600 C
Loader - M.T 600 C
Trailer Hitch - M.T 600 C
Swinging Drawbar - M.T 600 C
Front Linkage - Hydraulic - M.T 425 B, 445 B, 455 B, 465 B
Front Linkage - Hydraulic - M.T 555 B 595 B - 2 Quick Couplers Kit For 4 Distributors
Front Linkage - Hydraulic - M.T 525 B 595 B - 4 Quick Couplers Kit For 5 Distributors
Front Linkage - Hydraulic - M.T 600 B - 2 Quick Couplers Kit
Front Linkage - Hydraulic - M.T 600 B - Accumulator Kit
Front Linkage - Hydraulic - M.T 600 C - 2 Quick Couplers Kit
Auxiliary Hydraulics - Distributor - M.T 600 C
Auxiliary Distributors Installation - M.T 600 C - Ls Booster Kit
Sensor Harness Dual Control - M.T 500 B
Auxiliary Distributor - M.T 500 B - 3 Th Spool Valve With Mechanical Control - Load Sensing & Twin Flow Load Sensing
Auxiliary Distributor - M.T 500 B - 4 Th Spool Valve With Mechanical Control - Load Sensing & Twin Flow Load Sensing
Auxiliary Distributor - M.T 525 B M.T 545 B - 3 Th Spool Valve - Open Center Hydraulic
Auxiliary Distributor - M.T 525 B M.T 545 B - 4 Th Spool Valve - Open Center Hydraulic
Auxiliary Distributor - M.T 585 B 595 B Techstar Cvt - 5 Th Spool Valve With Mech . Control-Load & Twin Flow Load Sensing
Auxiliary Distributor - M.T 600 B - 5 Th Electrodynamique Spool Valve - With Electrodynamique Spool Valves
Auxiliary Distributor - M.T 600 B - 6 Th Electrodynamique Spool Valve - With Electrodynamique Spool Valves
Auxiliary Distributor - M.T 600 C - 4 Th Spool Valve Kit - Load Sensing
Right Cover - Load Sensing - M.T 555 B 595 B Autopower Vi - Load Sensing - 50kph
Trailor Brake - M.T400 B - Fixed Axle - Mech. Brake - Open Center Hydr.
Trailor Brake - M.T 400 B - Susp Axle - Mech. Brake - Open Center Hydr.
Trailor Brake - M.T 400 B - Mechanical Brake - Load Sensing
Trailor Brake - M.T 400 B M.T 525 B 545 B - Fixed Front Axle - Power Brake - Open Centre Hydraulic
Trailor Brake - M.T 400 B M.T 525 B 545 B - Suspended Front Axle - Power Brake - Open Centre Hydraulic
Trailor Brake - M.T 400 B M.T 525 B 545 B - Power Brake - Load Sensing
Trailor Brake - M.T 400 B - Mechanical Brake - Twin Flow Open Center
Trailor Brake - M.T 400 B - Mechanical Brake - Twin Flow Open Center - With Suspended Axle
Trailor Brake - M.T 400 B - Power Brake - Twin Flow Open Center
Trailor Brake - M.T 400 B - Power Brake - Twin Flow Open Center - With Suspended Axle
Trailor Brake - M.T 555 B 595 B Techstar Cvt - Power Brake - Load Sensing
Trailor Brake - M.T 600 C - With Brakes High Pressure - Load Sensing
Trailor Brake - M.T 600 C - Load Sensing Pneumatic Braking
Air Compressor - M.T 600 C - Load Sensing Pneumatic Braking
Trailor Brake - Pneumatic Feeding - M.T 600 C - Load Sensing
Cab Mountings - With Suspension - M.T 525 B 545 B - Autopower V.I
Cab Mountings - With Suspension - M.T 525 B 545 B Techstar Cvt
Cab Mountings - With Suspension - M.T 555 B 575 B Autopower V.I
Cab Mountings - With Suspension - M.T 555 B 575 B Techstar Cvt
Cab Mountings - With Suspension - M.T 585 B 595 B Techstar Cvt
Harness Isobus - M.T 500 B - Load Sensing
Harness Isobus - M.T 555 B 575 B - Load Sensing
Harness Isobus - M.T 500 B - Load Sensing - For Italy
Harness Isobus - M.T 525 B 545 B - Autopower V.I - Open Centre Hydraulic
Harness Isobus - M.T 600 B - Load Sensing
Harness Isobus - M.T 600 C
Fieldstar - M.T 500 B M.T 600 B
Autodrive - M.T 525 B 575 B - With Auto Power V I
Datatronic Kit - M.T 500 B - Tractor Equiped With Radar
Datatronic Kit - M.T 500 B - Autopower V I
Datatronic Kit - M.T 500 B Techstar Cvt
Datatronic Kit - M.T 600 B - With Datatronic 3
Datatronic Kit - M.T 600 B - With Datatronic 3 - Tractor Without Radar
Literature
Tripod
Base Station
Radio Antenna - Top Dock
Radio Antenna - Base Station
Top Dock
Literature - With Auto-Guide
Auto-Guide - M.T 555 B 575 B - Auto Guide Sensor
Auto-Guide - M.T 600 B - Auto Guide Sensor - Front Axle Fixed
Auto-Guide - M.T 600 B - Auto Guide Sensor - Front Axle Suspended
Auto-Guide - Mt 525b 545b Autopower Vi Up To 21-Apr-2010 - Mt 525b 545b Techstar Cvt - Hydraulic Lines
Auto-Guide - M.T 525b 545b Autopower Vi From 22-Apr-2010 - Hydraulic Lines
Auto-Guide - M.T 555 B 575 B Auto Power V.I - Hydraulic Lines
Auto-Guide - M.T 585 B 595 B Autopower Vi - Hydraulic Lines - Use Up To U295005
Auto-Guide - M.T 555 B 575 B Techstar Cvt - Hydraulic Lines
Auto-Guide - M.T 585 B 595 B Techstar Cvt - Hydraulic Lines
Auto-Guide - M.T 585 B 595 B Autopower Vi - Hydraulic Lines - Use From U295006
Auto-Guide - M.T 600 B - Hydraulic Lines - Up To T063080
Auto-Guide - M.T 600 B - Hydraulic Lines - From T063081
Auto-Guide - M.T 600 C - Hydraulic Lines
Roof Harnes - Auto Guide - M.T 525 B 595 B M.T 600 B - With Datatronic 3
Roof Harnes - Auto Guide - M.T 555 B 575 B - Without Datatronic 3
Auto-Guide - M.T 500 B M.T 600 B
Auto-Guide - M.T 600 C - Without Fops - With Roof Hatch With Roof Hatch
Auto-Guide - M.T 600 C - Without Roof Hatch
Agcommand - Telemetry Antenna - M.T 525 B 595 B - Agcommand
G.T.A. - M.T 500 B M.T 600 B - With Datatronic 3
Video Camera Kit - With Datatronic 3
Video Camera Kit - M.T 600 C
Tractor Cab - M.T 600 C - Handold
Appliance Bracket Boarded For Cab
Appliance Bracket Boarded For Cab - Auto-Guide 3000 With C3000
Air Conditioner - M.T 600 C - Additional Heater
Rear Window Wiper - M.T 500 B M.T 600 B
Secondary Seat - M.T 400 B
Secondary Seat - M.T 600 C
Tractor Cab - Fenders - M.T 400 B M.T 500 B Powered By Caterpillar
Tractor Cab - Fenders - M.T 500 B M.T 600 B
Tractor Cab - Fenders - M.T 600 C - Fenders Extension
Radio Installation - M.T 525 B 595 B - Agcommand
Radio Installation - M.T 600 C - Agcommand
Electrical Plug - M.T 600 C - Multi Plug Adapter
Working Light - M.T 600 C - Xenon - Standard Roof
Lighting Equipment - Rear - M.T 600 C - Reversing Light Kit
Front Axle 4 Wheel Drive - Mudguards And Supports - M.T 400 B
Front Axle 4 Wheel Drive - Mudguards And Supports - M.T 500 B M.T 600 B M.T 600 C
Front Axle 4 Wheel Drive - Mudguards And Supports - M.T 400 B M.T 500 B M.T 600 B M.T 600 C - Pivoting
Rear Wheels - Fixing By Cone - M.T 400 B M.T 500 B M.T 600 B - Shaft Diameter 95 Mm
Rear Wheels - Fixing By Cone - M.T 400 B M.T 500 B M.T 600 B - Shaft Diameter 110 Mm
