Challenger Terragator Twin Bin System Parts Catalog 558895D1
Brand: Challenger Terragator
Type of Machine: Applicators
Model: Challenger Twin Bin Terragator System (2011 - 2018)
Serial Number: ..WXX1001 - ..JXXX9999
Part Number: 558895D1
Number of Pages: 1976 Pages
Product Containment
Twin Bin
Box Assembly, Twin Bin
Bracket Kit, 3 Pin Clevis, Quick Release
Tarp Stop Assembly, Short Clevis Pin, Quick Release
Bracket Kit, Quick Release, Offset
Tarp Stop Assembly, Offset, Qr
Cable Spool Kit, Short
Cage Assembly
No Foam Marker
Cap Tube Installation, No Pressure Washer
Cap Installation, Tube, Right Hand, Center
Cartridge Group, 15 Inch
Conveyor Assembly
Cover Assembly, Rear Bulkhead
Drop Chute Installation, Twin Bin
Dummy Bolt Installation, Twin Bin, 4.00
Bolt Installation-Dummy, Twin Bin, 8.00
Seal Group
Left Hand
Right Hand
Fender Tread Installation
Guard Assembly, Splash, Front, Rear Wheel
Holddown Assembly, Main, 3 Wheel
Ladder Lower, Rear
Ladder To Distributor
Lift Eye Installation , Soilection
Lube System Installation, Twin Bin
Metering Mechanism Installation, Chain, Twin Bin
Metering Chain Installation
Hydraulic Motor Assembly, Metering, Mechanical
Hydraulic Motor, 26 Cid
Motor Kit, Srt2
Pivot Mount Hardware Kit, Sst
Tarp Motor Group, Srt
Mud Guard Assembly
Ratchet Assembly, 1.00 Inch, Ss
Riser Installation, 4.00 Inch, With Granular, Twin Bin
Riser Installation, 4.00 Inch, Without Granular, Twin Bin
Riser Installation, 8.00 Inch, With Granular, Twin Bin
Riser Installation, 8.00 Inch, Without Granular, Twin Bin
Roll Tarp, Electrical, With Granular
Roll Tarp, Electrical, Without Granular
Twin Bin 4 Bin
Roll Tube Assembly, 144 Inch Box
Sleeper Installation
Splash Guard Installation, Front, Left Hand
Splash Guard Installation, Front, Right Hand
Splash Guard Assembly, Left Hand, Rear
Splash Guard Assembly, Right Hand, Rear
Splash Guard Assembly, Right Hand, Front
Srt Roll Tarp Hardware Kit
Auxiliary
Tube Cap Installation, Left Hand
V-Hood Assembly
Primary Product Distribution
Auger Assembly, Twin Bin And 4 Bin
Distributor And Auger Assembly, Twin Bin 4 Bin
Auger Hub Assembly
Auger Motor Assembly, Horizontal
Hydraulic Motor, Sealed
Auger Motor Assembly, Vertical
Air Spreader
Drain Valve Assembly
Ball Valve, 1.50 Inch Poly, Full Flow
Rain Tarp Installation, Rear Of Box
Dispenser Assembly, Dry Implement, Left Hand
Dispenser Assembly, Dry Implement, Right Hand
Vertical Auger Pump Kit, Air Spreader, Twin Bin, 4 Bin
Drop Hose Assembly, Air Spreader
Fan Assembly, Metric, Left Hand
Fan Motor Assembly
Hydraulic Motor, 6.0 Cir Displacement
Fan Assembly, Metric, Right Hand
Manifold And Venturi Assembly
Venturi Tube Locator Lock Assembly
Butterfly Valve Assembly, Left Hand
Air Cylinder Assembly, Left Hand
Butterfly Valve Assembly, Right Hand
Oil Cooler Assembly, Left Hand
Oil Cooler Assembly, Right Hand
Fan And Boom Shut-Off Installation
Butterfly Valve Assembly Rh
Butterfly Valve Assembly Lh
Granular Bin Installation, 8 Inch
Lid Assembly, Granular
Manifold And Venturi Assembly, Boom, 70 Foot
Butterfly Valve Assembly, Left Hand, Center
Air Cylinder Assembly, Left Hand, Center
Butterfly Valve Assembly, Center, Right Hand
Air Cylinder Assembly, Right Hand, Center
Butterfly Valve Assembly Lh Center
Butterfly Valve Assembly Rh Center
Rework
Motor Electrical 12 Volt Dc
Motor Installation, Granular, Left Hand, Falcon Vt
Speed Reducer
Motor Installation, Granular, Right Hand, Falcon Vt
Motor Installation, Granular, Raven, Left Hand
Motor Installation, Granular, Raven, Right Hand
Sensor Installation, Full Empty, Granular Bins
Secondary Product Distribution
Ball Valve, 32 Fp X 32 Mp, Poly
Ball Valve, 0.50 Npt, Union, Poly
Ball Valve, 0.75 Npt, Union, Poly
Ball Valve, 1.00 Inch Full Port Flange X Npt, Electrical
Actuator, 000-60-M-9
Ball Valve, 1.50 Npt, T Handle
Ball Valve, 1.50 Npt, Union, Poly
Boom Plumbing Assembly, Co Application, Air Spreader
Tee Fitting Assembly, Hose Barb
Wet Boom Fitting Assembly, Dry Spreader
Butterfly Valve, 1.50, 90d
Chemical Eductor Plumbing Assembly, Co Application
Chemical Eductor, Clean Load Ii, Poly, 4.5 Gallon
Air Spreader, Dry Spreader, Co Application
Flowmeter Installation, Co Application, 2 And 4 Bin
Flowmeter, 2.00 Inch, Sp Flange, Rfm60, 12 Volt
Flowmeter, 1.25 Inch, 280 Pulse Per Gallon, 12 Volt
Flowmeter, 2.00 Inch, Sp Flange, Rfm60p, 12 Volt
Gauge Installation, Co Application, Air Spreader
Hydraulic Pump, Fmc, 150, 206
Manifold Assembly, Co Application, Air Spreader
Plumbing Bypass, 400l, Dry Soilection
Plumbing Installation, Chemical Eductor
Plumbing Installation, Product Pump
Plumbing Installation, Sparger, Air Spreader
Pressure Plumbing Tee Installation
Product Pump Installation, Co Application, Air Spreader
Product Pump Fitting Assembly, Co Application
Reload Valve Assembly, 400l Dry Spreader
Saddle Installation, Co Application, 81xx
Tank And Saddle Assembly, 400 Gallon, Left Hand
Tank Fitting Assembly, Left Hand
Tank Strap Assembly, 200 Gallon
Tank And Saddle Assembly, 400 Gallon, Right Hand
Tank Fitting Assembly, Right Hand
Saddle Installation, Co Application, 9203
Servo Valve Assembly, Wet Boom
Strainer Installation, Pressure Plumbing, Twin Bin
Strainer Assembly
Transducer Installation, Co Application, Air Spreader
Pressure Transducer Assembly
Booms
Boom Assembly 70ft
Boom Assembly, 70 Foot, Left Hand
Boom Assembly, 70 Foot, Right Hand
2018
Boom Assembly, Wet Boom, Air Spreader
Nozzle Installation, Co Application, Air Spreader
Boom Center Section Installation
Hydraulic Cylinder Assembly, Boom Motion, Air Spreader
Boom Cradle Installation, Air Spreader
Cradle Assembly, Air Spreader
Nozzle Installation
Nozzle Installation, Wet Boom, Center, Co Application
Nozzle Clamp And Band Assembly, Common, Standard
Slider And Stop Assembly, Center Boom
Foam Marker
Ball Valve, 2.00 Inch, Poly
Foam Marker Installation, Air Spreader, Twin Bin, 4 Bin
Foam Marker Regulator Assembly
Solenoid Valve, 25npt, 12 Volt
Foam Marker Tank Assembly, 60 Gallon, Ss
Solenoid Valve Rework
Solenoid Valve
Foam Marker Drop Hose Assembly, 70 Foot
Foam Marker Tank Installation, Rear, Air Spreader
Step Assembly, 60 Gallon, Foam Marker
Step Assembly, 60 Gallon, Foam Marker, 1903
Air Valve Assembly Spreader Co Application, 7gpm
Hydraulic Valve Assembly, Solenoid, Liquid Option
Boom Valve Installation In Out, Twin Bin
Valve And Fitting Assembly, Boom In Out, Twin Bin
Hydraulic Valve Assembly, Solenoid, Boom In Out
Bulkhead Assembly, Fan Motor
Check Valve Assembly, 65 Psi
8203 8204, 2012
Fan Control Valve Installation
Valve Assembly, Flow Air Spreader, Dry Spreader
Fan Speed Servo Valve Installation
Fan Speed Servo Valve Assembly
Filter Assembly, Air Spreader And Dry Spreader
Hydraulic Filter, 750 Psi
Filter Bracket Service Kit, Twin Bin And 4 Bin, Air Spreader
Hydraulic Filter Assembly, Twin Bin And 4 Bin
Flow Control Valve, 2500 Relief
Gauge Installation, Fan Auger
High Pressure Filter Assembly
2015
Hose Installation, Cooler, Pump, Valve
2014
Hydraulic Assembly, Conveyor Motor
Hydraulic Motor, Chrome Shaft
Hydraulic Cylinder Assembly, O-Ring, Air Spreader
Hydraulic Cylinder, 3.50 X 16.00 X 1.50
Hydraulic Plumbing Assembly, Solenoid Valve
Relief Valve, Inline, 2500 Psi
Valve Solenoid Assembly, Auger, Vertical
Hydraulic Plumbing Assembly, Proportional Valve
Valve Block Harness Assembly
Hydraulic Block, Dual Bank Manifold
Hydraulic Plumbing Assembly, Valve
Hydraulic Block, Twin Bin Manifold, A
Hydraulic Pump Tee Installation
Hydraulic Valve Assembly, Flow Control
Hydraulic Valve Installation, Twin Bin Boom Block
Hydraulic Tank Assembly
Hydraulic Return Filter
Hydraulic Tank Cover Assembly
Hydraulic Tank Mount
Hydraulic Assembly, Basic, Twin Bin With Chain Motor
Hydraulic Tank Installation, Air And Dry Spreader
Hydraulic Valve Assembly, Conveyor Speed
Hydraulic Valve Assembly, Auger Control
Hydraulic Group, Pump Installation, Twin Bin 6 8
Hydraulic Pump Assembly, Air Spreader, Twin Bin, 8xx
Piston Pump, 60 Cc, Right Hand
Piston Pump, 5.19 Cid, Right Hand
2017
9300
Hydraulic Hose Installation, Twin Bin
Hydraulic Installation, Bulkhead, 120 Inch
Chassis And System, Twin Bin, 8203 8204
Hydraulic Installation, Chassis, Twin Bin, Bosch, 2012
Tg8300 Tg8400
Piston Pump, 90cc, Right Hand
Hydraulic Installation, Twin Bin, Cvt
Auger
Hydraulic Motor, 8.0 Cubic Inch
Hydraulic Piston Pump, 98cc, Eaton
Hydraulic Pump Installation, Twin Bin, 8400
Hydraulic Pump Assembly, Front, Twin Bin, 84xx
Hydraulic Pump Assembly, Rear, Twin Bin, Eaton
Hydraulic Pump, Piston, 62cc, Eaton
Hydraulic Pump Installation, Twin Bin, 8300
Hydraulic Pump Installation, Twin Bin, 84xx
Hydraulic Pump Installation, Twin Bin, 9203
Hydraulic Pump Assembly, Twin Bin, 9203
Variable Displacement Pump, 3.88, Thru Drive, Ccw
Variable Displacement Pump, 2.93, Ccw
Hydraulic Pump Installation, Twin Bin, Eaton
Hydraulic Pump Assembly, Front, Twin Bin, Eaton
Hydraulic Pump, 3000 Psi
Hydraulic Return Filter Assembly, Air Spreader
Fan
Hydraulic Valve, Air Spreader Boom Block
Hydraulic Valve, Dual Po Check With Thermal Relief
Hydraulic Valve Assembly, Twin Bin, Boom Block
Tg9300
Hydraulic Cap And Plug Installation
Oil Cooler Assembly, Co Application, Air Spreader
Oil Cooler Installation, Co Application, Air Spreader
Oil Tank Heater Installation, 110 Volt
Pump Installation, Var Var, Twin Bin, 2012
Pump Assembly, Variable Displacement, Jd Ps, Twin Bin, 2012
Pump Assembly, Variable Displacement, Jd Ps Air Spreader
Variable Displacement Pump, 388 Spl Rr Prts
Pump Installation, Variable Displacement, Twin Bin
Pump Replacement Kit
Routing Accessories
Servo Valve Installation, Twin Bin
Tee Assembly, Hydraulic Pump
Valve Installation, Twin Bin, 4 Bin, Co Application, 7gpm
Kit, Repair
Co Application Harness Installation, Twin Bin And 4 Bin,Raven
Electrical Box, Roll Tarp
Electrical Box Installation
Power Distribution Box Assembly, Basic
Co Application System, Falcon Vt, Twin Bin
Electrical Installation, Roll Tarp
Harness Installation, Granular, 2 And 4 Bin, Raven
Harness Installation, Granular, Falcon Vt, Twin Bin
Co Application, Granular, Air Spreader, Raven
Harness Installation, I O, Co Application, Twin And Four Bin
Module Assembly, Input Output, Can
Co Application, Granular, 2 And 4 Bin, Raven
Harness Installation, Co Application, Input Output Module
Harness Installation, Fan Cooler, Liquid System
Lamp Cluster, Rear, Left Hand
Lamp Cluster, Rear, Right Hand
Light Assembly, Tail Amber Flashing Warning Light, Left Hand
Turn Light Assembly, Led, Resistor
Light Assembly, Tail Amber Flashing Warning Light, Right Hand
Plate Assembly, Power And Ground
Power Harness Installation, Granular, Falcon Vt
Power Distribution Cable Installation, Air Spreader
Electrical Box Assembly
Resistor Assembly, K-680 Ohm, 6 Prong
System Electrical Installation, Co Application, Falcon Vt, Gr
System Electrical Installation, Twin Bin, Falcon Vt
System Electrical Installation, Twin Bin, Raven
Taillight And Amber Flashing Warning Light Installation
Tail Light Amber Warning Flashing Light Installation
Warning Lamp, Amber
Air System
4 Way Air Valve Solenoid
Air Box Assembly, Air Spreader
Air Box Assembly, Dry, Falcon Ii
Granular
Manifold Assembly
Airline Installation, Air Spreader
Pressure Washer And Rinse System
Harness Installation, Head Rinse, 62 Gallon, System
Pump Rework, Motor, H R
Pump And Motor, Du105 Hypro
Pump 4101n, H, Du105
Harness Installation, Head Rinse, 110 Gallon System
Head Rinse Assembly
Plumbing Assembly, Head Rinse, 62 Gallon, Twin Bin 4 Bin
Pump And Base Assembly, Head Rinse
Pressure Washer Plumbing Assembly, 62 Gallon, Air Spreader, Jd
Tank Installation, 62 Gallon, Left Hand, Air Spreader
Tank Assembly, 62 Gallon
Pressure Washer And Head Rinse, 62 Gallon
Pressure Washer Option, 62 Gallon, Twin Bin And 4 Bin
Air Spreader, Jd
Pressure Washer And Head Rinse Harness Installation
Pressure Plumbing Assembly Washer With Head Rinse, 62 Gallon
Tank Installation, 62 Gallon, Left Hand, Dry Spreader
Tank Installation, 110 Gallon, Twin Bin
Tank Assembly, 110 Gallon
Tank Strap Assembly, 110 Gallon
Tank And Saddle Assembly, 110 Gallon, 1903
Decal Installation, 200 Gallon Tank
Decal Installation, 400 Gallon, Co Application
Decal Installation, Box
Decal Installation, Twin Bin
Decal Installation, Reflective, Dot
Edge Liner And Tread Installation
Lift Eye Decal Installation , 2 Bin 4 Bin
Product Containment
Twin Bin
Cage Assembly
No Foam Marker
Conveyor Assembly
Seal Group
Left Hand
Right Hand
Ladder Lower, Rear
Motor Kit, Srt2
Mud Guard Assembly
Twin Bin 4 Bin
Auxiliary
V-Hood Assembly
Auger Hub Assembly
Air Spreader
Fan Motor Assembly
Rework
Speed Reducer
Strainer Assembly
Booms
Boom Assembly 70ft
2018
Nozzle Installation
Foam Marker
Solenoid Valve
8203 8204, 2012
2015
2014
2017
9300
Tg8300 Tg8400
Auger
Fan
Tg9300
Routing Accessories
Kit, Repair
Warning Lamp, Amber
Air System
Granular
Manifold Assembly
Head Rinse Assembly
Air Spreader, Jd
