Challenger Terragator NL L4000G4 Multapplier System Parts Catalog 558898D1
Brand: Challenger Terragator
Type of Machine: Applicators
Model: Challenger NL L4000G4 Multapplier Terragator System Dealer Install (2012-2018)
Serial Number: ..CXXX1001 - ..HXXX9999
Part Number: 558898D1
Number of Pages: 3562 Pages
Product Containment
L4000g4
Nl4000hp, 304ss, 13 Foot, #3 Chain, Dealer Installed
Angle Group, 11-13 Foot 132 Inch, 304ss, Front
Angle Group, 11 Foot 132 Inch, 304ss, Front
Endgate Group Installation, 304ss
Endgate Assembly, 30 Inch Guided, 304ss
Fender Group, 13 Foot 132 Inch, 304ss
Fender Kit, 13 Foot 143 Inch, With Light Mount
Front Conveyor Guard Group
Hillside Divider Assembly, 30 Inch
Hillside Divider Kit, #4, 304ss
Divider Hardware Kit
Idler Drive, 30 Inch Assembly, #2 And 3 Conveyor Ss
Idler, 30 6 Bolt Frame
Lip, Rear Group
Lip Group, 304ss
Wiper Assembly, 30 Inch, Internal 304ss
Inverted Vee Kit, 13 And 14 Foot, High Yield
16 Foot V, Ss
Pattern Test Kit, New Leader
Conveyor, 13 Foot #3, K Pintle Link, 30 Inch, 304ss
304ss
Wiper Belt Conveyor Kit, Spinner
Wiper, Belt Spinner And Conveyor Assembly
Wiper, Front, 304ss
Belt Over Chain, 13 Foot
Frame Assembly, 24 Inch, Twin Spinner, 304
Disc Assembly, Left Hand, 24 Inch
Disc Assembly, Right Hand, 24 Inch
Motor Assembly, Left Hand, Style Ii
5.10 Cir
Motor Assembly, Right Hand, Style Ii
Guard Assembly, Spinner, 30 Inch 126 Inch, 304ss
2016
Fan Frame Hardware Kit
Material Divider Assembly
Shield Bracket Assembly
Dual Pressure Gauge Kit, 5000 Psi
Gauge Kit, 5000 Psi
Gauge Kit, 5000 Psi, Multi Ready
Gearcase Assembly With 6.2 Cid 2000
Gear Case
2017
2018
Hydraulic Tank Installation, High Performance
Cooler Assembly, Hydac Eld4.5
Return Filter
Pwm Control Valve Assembly
Hydraulic Valve, Electrical Pwm
Soft Start Relief Valve
Decal Group, Hydraulic Tank
Oiler Assembly
Nozzle And Hose Assembly
Tank, Chain Oiler
Pump Assembly With Connector
Encoder, Dickey-John 360, With 12 Inch Cable
Encoder, Dickey-John 360, With 1 Foot Cable
Rate Sensor Mount Installation, Dickey John
Decal Group, Safety Installation
Decal Group, Safety Body Installation
Decal Group, Safety Endgate Installation
Decal Group, Decor, G4, Body Only
Decal Group, Decor, L4000, Endgate
Decal Group, L4000, Black Red
2016-2018
Moderately Oil Resistant
Spinner Sensor Kit, Without Cable
Sensor Assembly, With Block
Fan Assembly, 24 Inch Twin, 30 Inch, G4, 304
Double Pinion Gear Case
Gear Case And Tube Assembly
Multapplier Ready
L4000 Hydraulic Assembly, 13 Foot, Pwm
Hydraulic Tank And Cooler Assembly
Hydraulic Tank Assembly
Pressure Gauge Kit, 5000psi, Single
Conveyor, #4 Belt Over Chain, 13 Foot
Conveyor And Shields, 409ss, #4, 30 Inch
Feedgate And Jack Assembly, 409
Fender Group, 13 Foot 132 Inch, 409ss
Inverted Vee Kit, 13 And 14 Foot, High Yield, 409ss
Decal Group, G4
409ss
Endgate Group Installation, 409ss
Endgate Assembly, 409ss, Ship Loose
Fender Kit, 13 Foot 132 Inch, With Light Mount
Angle Group, 14 Foot 132 Inch, 304ss
Angle Group, 14-16 Foot 132 Inch, 304ss
Conveyor And Shield Assembly, 304ss, 14 Foot
Conveyor, #4 Belt Over Chain, 14 Foot
Fender Kit, 14 Foot 132 Inch, 304ss, Without Tape
Fender Kit, 14 Foot 132 Inch, With Light Mount
Drain Hose, 14 Foot Box
Conveyor And Shield Assembly, 409ss, 14 Foot, #4
Fender Kit, 14 Foot 132 Inch, 304ss, With Mud Flap
Nl4000g4 Multapplier, 409ss, 13 5 Foot, Dealer Installed
Gauge Kit, 3000 Psi, Multi Insert
Sfp, Multapplier Ready, Pwm Spinner, Standard
Hydraulics, 13 Foot, Multapplier Ready, Pwm
Valve Assembly, Sfp 40gpm
Hydraulic Servo, 40gpm
Cartridge, 40gpm Servo
Mounting Assembly, Hydraulic Tank
Tank Cooler Assembly
Multapplier, 5 Foot, 102+6 304 Installation
Cover Kit, Rear
Direct Drive Group, 24 Inch
Drive Shaft Assembly
Feedgate Assembly
Foot Mount Group
Hydraulic Motor Assembly
Idler Group, 24 Inch
Idler Assembly
Shield And Chain Assembly
Hydraulic Group, Multapplier, 5 And 7 Foot
Encoder And Bracket Group, Dickey-John 360
Multapplier Wiper
Multapplier Sealer And Front Feedgate
#4 X 24 X 54 Links, Moderately Oil Resistant
Sealer Assembly, Multapplier
Seal Assembly
Hydraulic Kit, Multapplier, 13 Foot
Valve Assembly, Sfp 9gpm
Hydraulic Servo, 9gpm
Cartridge, T, 9gpm Servo
Relief Valve Assembly, Soft Start
Sideboards, 304ss, 13 Foot, 5 Foot Multapplier
Sideboard Kit, Multapplier, 13 Foot
Safety
Bin Level Sensor Assembly
Multapplier
Front Feedgate Group
Multibin
Nl4000g4 Multapplier, 409ss, 14 7 Foot, Dealer Installed
Hydraulic Kit, Multapplier, 14 Foot
Decal Group, Safety, Body Only
Multapplier, 7 Foot, 102+6 304
Chain Shield Assembly, 7 Foot
Conveyor Assembly, #4 Belt Over Chain, 75 Links
Safety Decal Group, Multapplier
Idler Zerk Group, 7 Foot, Multapplier
2013
Chain Oiler Hardware Kit
Drain Hose, 13 Foot Box
Drive Assembly, 30 Inch, Left Hand, Ss
Shaft Assembly, 30 Inch Drive
Sideboard Hardware Kit, Ss
Idler, 30 Inch Conveyor 6 Bolt Frame Ss Assembly
Idler Shaft Assembly, 30 Inch Conveyor
Inverted Vee Kit, 13 And 14 Foot, 304ss, High Yield
Zerk Assembly, Idler, Rear, 7 Foot
Zerks, Idler, Rear
1primary Product Distribution
Belt Over Chain, 54 Link
Conveyor Assembly, #4 Belt Over Chain, 54 Links
Fan, Left Hand Assembly
Fan, Right Hand Assembly
Chain Guides
1hydraulic System
Ball Valve, 1.25 Inch Npt
Ball Valve, 2.00 Inch Npt
Cartridge, 25gpm Servo
Chain Oiler Assembly
Nozzle And Hose Assembly, 30 Inch Bottom, 45 Degree
Valve And Hose Assembly
Valve Assembly, Sfp 25gpm
Hydraulic Servo, 25gpm
Hydraulic Kit, Multapplier, 13 Foot, L4000, Dealer Installed
Hydraulic Kit, Multapplier, 14 Foot, L4000, Dealer Installed
Hydraulic Motor, 1 1 4
Hydraulics, 14 Foot, Multapplier Complete, Pwm
Hydraulics, 13 Foot, Mc Pwm
Hydraulics, 14 Foot, Multapplier Ready,Pwm
Sfp, Multapplier Complete, Pwm Spinner, Standard
Hydraulic Motor
Pressurized Oiler, 12 Volt
Suction Fittings, L4000
Suction Fittings, Mr L4000
Suction Fittings, L4000 Mc
Suction Fittings, Mc L4000
Fitting Kit, Suction, Hydraulic
1controller System
1decals
Lubrication Decal And Chain Conveyor Assembly
1attachments
1 Bow Set Hardware Kit
Hopper, Multapplier, L4000, 5 Foot, Dealer Installed
Hopper, Multapplier, L4000, 7 Foot, Dealer Installed
Sideboard Kit, 13 Foot, 5 Foot Multapplier, Dealer Installed
Sideboard Kit, Multapplier, 14 Foot
Sideboard Kit, 14 Foot, 5 Foot Multapplier, Dealer Installed
Sideboard Kit, 14 Foot, 7 Foot Multapplier, Dealer Installed
1accessories
Endgate Ki , 309ss
Endgate Kit, 409ss
V-Hood
Product Containment
L4000g4
Lip, Rear Group
Lip Group, 304ss
16 Foot V, Ss
304ss
Wiper, Front, 304ss
5.10 Cir
2016
Gauge Kit, 5000 Psi
Gear Case
2017
2018
Return Filter
Oiler Assembly
Tank, Chain Oiler
2016-2018
Multapplier Ready
Decal Group, G4
409ss
Cover Kit, Rear
Feedgate Assembly
Foot Mount Group
Idler Assembly
Multapplier Wiper
Seal Assembly
Safety
Multapplier
Multibin
2013
Zerks, Idler, Rear
Chain Guides
1hydraulic System
Hydraulic Motor
1controller System
1decals
1attachments
1accessories
Endgate Ki , 309ss
Endgate Kit, 409ss
V-Hood
