Challenger Terragator Four Bin C System (2019-2024) Part Book
Brand: Challenger
Type of Machine: Terragator
Type of Manual: Parts Book
Model: Challenge Four Bin Terragator C System
Serial Number: ..KXXX1001-..RXXX9999
Year of Manufacture: 2019-2024
Number of Pages: 337 Pages
Filters Guide - Twin Bin_4 Bin
Box Assembly, 4 Bin
Cage
Conveyor
Cover - Rear Bulkhead
Fender - Left Side
Fender - Right Side
Ladder To Distributor
Ladder Lower, Rear
Lift Eye - Soilection
Metering Mechanism Installation, Chain, 4 Bin
Metering Chain
Mud Guard Assembly
Riser Installation, 8.00 Inch, Soil, With Granular
Riser Installation, 8.00 Inch, Soil, Without Granular
Sleeper Installation
Step - Auxiliary
Step - Auxiliary
Primary Product Distribution
Auger - Twin Bin And 4 Bin
Distributor And Auger Assembly, Twin Bin_4 Bin
Auger Motor Assembly, Horizontal
Auger Motor Assembly, Vertical
Drop Hose Assembly, Air Spreader
Granular Bin Installation, 8 Inch
Granular Bin - Drain Valve
Granular Bin - Drop Chute Installation, Twin Bin
Granular Bin - Rain Tarp
Booms
Boom - 70 Feet
Boom Center Section - Manifold And Venturi Assembly
Boom Center Section
Boom Center Section - Fan And Boom Shut-Off
Boom Center Section - Butterfly Valve Assembly Lh
Boom Center Section - Air Cylinder
Boom Center Section - Butterfly Valve Assembly Rh
Boom Center Section - Butterfly Valve Assembly Lh Center
Boom Center Section - Butterfly Valve Assembly Rh Center
Boom Center Section - Fan Motor (Components)
Boom Center Section - Hydraulic Motor, 6.0 Cir Displacement
Boom Center Section - Hydraulic Cylinder Assembly, Boom Motion, Air Spreader
Boom Center Section - Oil Cooler
Boom Center Section - Venturi Tube Locator Lock Assembly
Boom Cradle - Air Spreader
Grease Zerk Mount, 4 Bin
Nozzle Clamp And Band Assembly, Common, Standard
Nozzle
Slider And Stop Assembly, Center Boom
Foam Marker
Foam Marker Tank Installation - Front Mount
Foam Marker - Tank & Pump
Foam Marker - Plumbing Installation
Plumbing Installation - Foam Marker Mixing Chamber, Richway
Without Foam Marker
Common Hydraulic Installation - Hydraulic Hose Installation, Four Bin
Common Hydraulic Installation - Hydraulic Routing Accessories
Hydraulic Component - Fan Motor
Hydraulic Component - Fan Speed Servo Valve
Hydraulic Component - Gauge Installation, Fan_Auger
Hydraulic Component - High Pressure Filter
Hydraulic Filter - Twin Bin And 4 Bin
Hydraulic Component - Hydraulic Plumbing Assembly, Valve
Hydraulic Component - Hydraulic Pump Tee
Hydraulic Tank (Components)
Hydraulic Tank
Hydraulic Component - Hydraulic Valve Assembly, Auger Control
Hydraulic Component - Hydraulic Valve Assembly, Conveyor Speed
Hydraulic Component - Hydraulic Valve Assembly, Flow Control
Hydraulic Component - Hydraulic Valve Installation, Twin Bin Boom Block
Hydraulic Cap And Plug Installation - Tg9300
Hydraulic Hose Installation, Four Bin - Tg9300
Hydraulic Motor Assembly, Metering, Mechanical
Hydraulic Motor, 26 Cid
Hydraulic - Oil Tank Heater Installation, 110 Volt
Hydraulic Pump - Tg9300
Hydraulic - Piston Pump, 60 Cc, Right Hand
Piston Pump (Components) - 90cc
Common Electric Installation - Four Bin
Common Harness Installation - Four Bin
Common - Electrical Control Box
Common Electrical Box Assembly
Common Electrical Box Assembly - Bracket
Lighting - Rotary Beacon
No Beacon Option
Granular Power Box Installation - Tgc
Granular, Power Distribution Box Assembly
Granular Bin - Electrical Box Assembly
Granular, Power Harness Installation, Air Spreader
Granular Bin - Electric Motor
Granular Bin, Motor Installation - Rework Electrical Assembly Pickup
Granular Bin, Motor Installation - Speed Reducer
Granular Bin - Motor Electrical 12 Volt Dc
Wiring Harness - Head Rinse
Reversing Camera - Air Spreader, Terragator
Reversing Camera - Twin Bin_4 Bin
Taillight - Amber Warning Flashing Lights
Work Lights
No Work Light - Air Spreader, Terragator
Controller System
Controller Installation - Raven
Full_Empty Sensor - Granular Bin
Full_Empty Sensor - Four Bin
Air System
Air Box Installation - Air Spreader
Air Valve Box
Air Valve Box - Granular Bin
Air Valve - Manifold (Components)
Airline Installation, Air Spreader
Pressure Washer And Rinse System
Head Rinse - 50 Gallon
Pressure Washer - 50 Gallon
Pressure Washer _ Head Rinse - 50 Gallon
Pressure Washer Plumbing - 50 Gallon
Pressure Washer _ Head Rinse - Tank Assembly
Ball Valve, 0.75 Npt, Union, Poly
Head Rinse - Pipe Lines
Head Rinse - Pump Rework, Motor, H_R
Pump And Motor, Du105 Hypro
Pump 4101n, H, Du105
No Pressure Washer Option - Assembly
Cap Tube Installation, No Pressure Washer
Splash Guard, Front - Left Side
Splash Guard, Front - Right Side
Splash Guard, Rear - Left Side
Splash Guard, Rear - Right Side
Decal Installation, Box
Decal Installation, Four Bin
Decal Installation, Reflective, Dot
Edge Liner And Tread Installation
Decal - Lift Eye
Roll Tarp, Electrical, With Granular
Roll Tarp, Electrical, Without Granular
Roll Tarp - Twin Bin_4 Bin
Roll Tarp, With Granular, 800 - Twin Bin_4 Bin
Roll Tarp, Without Granular, 800 - Twin Bin_4 Bin
Tarp Assembly - Roll - Ratchet, 1.00 Inch, Ss
System Holddowns - 3 Wheels
Density Scale - Dry System
Field Accessories - Foam Marker
Field Accessories - Pressure Washer
Foam Marker - Plumbing Kit
Hardware Kit - Foam Marker
Hardware Kit - Pressure Washer
Brand: Challenger
Box Assembly, 4 Bin
Cage
Conveyor
Fender - Left Side
Fender - Right Side
Ladder Lower, Rear
Metering Chain
Mud Guard Assembly
Step - Auxiliary
Step - Auxiliary
Booms
Boom - 70 Feet
Boom Center Section
Nozzle
Foam Marker
Without Foam Marker
Hydraulic Tank
No Beacon Option
Work Lights
Controller System
Air System
Air Valve Box
Decal - Lift Eye
