BigBoss1
106
307,104
Challenger Terragator C Air Max Precision 1 2 2019-2024 Part Book
Brand: Challenge
Type of Machine: Terragator
Type of Manual: Part Book
Model:
Challenger Air Max Precision 1 Terragator C
Challenger Air Max Precision 2 Terragator C
Serial Number: ..KXXX1001-..RXXX9999
Year of Manufacture: 2019-2024
Number of Pages: 388 Pages
Filters Guide & Belts Guide - Air Max Precision, Tgc
Installation Arrangement, Air Max Precision 1
Installation Arrangement, Air Max Precision 2
Bumper - Rear
Bumper - Rear
Dual Bin Divider
Dual Bin Divider - Riser
Fan Spacer - Without Granular Bin
Fenders - Air Max
Flip Panel
Granular Bin - Air Max 1000_2000
Granular Bin - Ladder
Granular Metering Housing
Granular Metering Housing - Assembly
Hardware - Granular
Ladder - Without Granular Bin
Lift Eye - Air Max Precision
Hardware - No Lift Eye
Maxi-Rate - Housing Installation Metering, Granular
Maxi-Rate - Granular Metering Housing
Maxi-Rate - 2.25 Wheel
Mudguard - Air Max
Without Spraymax
Without Spraymax - Bulkhead Cover
Without Spraymax - Screen
Step - Auxiliary
System Holddowns - Option
Unloading Chute
V-Hood - Air Max 1000
V-Hood - Air Max 2000
V-Hood (Lengthwise) - Air Max 1000
Hopper Window
Primary Product Distribution
Blower
Blower - Oil Cooler
Blower (Components)
Blower (Components) - Hydraulic Motor
Blower (Components) - Hydraulic Motor, 1.83 Cir
Blower - Fan Shroud
Blower - Pre-Cleaner
Catch Pan - Air Max 1000_2000
Catch Pan - Rear
Conveyor Belt - Bottom
Conveyor Belt - Top
Conveyor Cover
Conveyor Drive Sprocket - Front
Conveyor Drive Sprocket - Air Max Precision 1
Conveyor Drive Sprocket - Air Max Precision 2
Conveyor Flap Kit
Hydraulic Assembly, Conveyor Motor - Air Max Precision
Conveyor Motor - Bypass Valve
Conveyor - Hydraulic Motor, 9.9 Cid
Deflector Kit - Adjusting
Gearbox - Components
Manifold & Funnel
Manifold
Metering Gate - Air Max 1000
Metering Gate - Air Max 2000
Metering Wheel - Standard
Metering Wheel - Low Rate
Metering Wheel - Maxi Rate High
Product Deflector Plate
Screen
Screen - Air Max 1000
Sleeper Installation
Booms
Boom - Outlet Deflector
Boom - Outlet Tube Installation, Boom Center
Boom - 70 Feet
Boom - Tip Fold Cylinder
Boom Pivot Assembly
Boom Pivot Assembly - Boom Folding Cylinder
Boom Rest
Boom Suspension
Boom Suspension Cylinder
Foam Marker
Foam Marker Installation - Air Max
Foam Marker - Tank & Pump
Plumbing Installation - Foam Marker Mixing Chamber, Richway
Hydraulic Lines - Air Max Precision
Common - Hydraulic Component Installation
Common Hydraulic Installation - Hydraulic Filter
Common Hydraulic Installation - Hydraulic Tank
Common Hydraulic Installation - Hydraulic Valve Assembly, Fan
Common Hydraulic Installation - Low Pressure Hydraulic Filter Assembly
Common Hydraulic - Low Pressure Hydraulic Filter Assembly
Common Hydraulic - Sequence Valve Assembly, Air Max
Hydraulic Component Installation, Pwm Valve Amp 1
Hydraulic Component Installation, Pwm Valve Amp 2
Hydraulic Component Installation - Hydraulic Valve Assembly, Conveyor, Amp 1
Hydraulic Component Installation - Hydraulic Valve Assembly, Conveyor, Amp 2
Hydraulic Component - Hydraulic Valve, Pwm 15gpm, Air Max Precision 1
Hydraulic Component - Hydraulic Valve, Pwm 15gpm, Air Max Precision 2
Chassis Hydraulic Installation - Tg7300c _ Tg8300c _ Tg8400c
Chassis Hydraulic Installation - Tg9300c
Chassis Hydraulic - Hose Installation
Chassis Hydraulic Installation - Hydraulic Valve
Hydraulic Boom Valve Assembly - Air Max Precision
Hydraulic Boom Block Assembly - Air Max Precision
Hydraulic Pump - Amp, Bosch
Hydraulic Pump - Air Max Precision, 9300
Hydraulic Pump - Air Max Precision, Bosch
Hydraulic Pump - 9300
Piston Pump (Components) - 90cc
Hydraulic Hose Installation, Air Max Precision 2
Hydraulic Tank Heater (120v)
Loose Combo Option-Air Max Precision_Air Spreader, Cvt - Hydraulic Cap And Plug Installation
Lighting - Rotary Beacon
Wiring Harness - Air Max 1000
Wiring Harness - Air Max 2000
Electric Installation - Air Max Precision 1
Electrical Installation - Raven Controller
Electrical Installation, Roll Tarp
Granular Bin - Electrical Group
Granular Bin - Electrical Box Assembly
Granular, Power Distribution Box Assembly
Granular, Power Distribution Box - Fuse
Granular Metering Housing - Motor, Electrical, Twin Output
Reversing Camera - Air Max Precision
Taillight Installation, Euro - Air Max Precision
Taillight Installation, North America - Air Max Precision
Taillight Installation - Bumper
Work Lights - Air Max Precision
No Work Light
Controller System
Autoboom - Electrical Group
Autoboom - Hydraulic Hose Installation
Autoboom - Valve Installation
Autoboom - Valve Assembly
Autoboom - Hydraulic Valve (Components)
Sensor, Autoboom
Full_Empty Sensor - Air Max Precision
Sensor Installation, Rate, Air Max 1
Sensor Installation, Rate, Air Max 2
Ultrasonic Sensor, Digital - Left Side
Ultrasonic Sensor, Digital - Right Side
Pressure Washer And Rinse System
Pressure Washer Tank - 3 Wheels
Pressure Washer Tank - 4 Wheels
Emblems - Air Max Precision
Emblems - Air Max Precision 2
Safety & Warning - Air Max
Decal - Lift Eye
Reflector - Eame
Tarp Installation, Air Max
Tarp Assembly - Roll - Air Max
Tarp Assembly - Roll - Ratchet, 1.00 Inch, Ss
Hardware - No Tarp
Common Parts - Cab Kit, 98 Air Max, New Cab
Density Scale - Dry System
Field Accessories - Autoboom
Field Accessories - Granular Bin
Field Accessories - Foam Marker
Field Accessories - Metering Wheel
Field Accessories - Pressure Washer Tank
Field Upgrade Kit, Fan - Air Max Precision
Hardware Kit - Foam Marker Tank
Hardware Kit - Granular Bin
Hardware Kit - Pressure Washer
Plumbing Kit, Foam Marker - Air Max Precision
