Challenger Terragator Air Spreader System Parts Catalog 558894D1
Brand: Challenger Terragator
Type of Machine: Applicators
Model: Challenger Air Spreader System (2011 - 2018)
Serial Number: ..WXX1001 - ..JXXX9999
Part Number: 558894D1
Number of Pages: 1670 Pages
Product Containment
Air Spreader
Application Rate Sensor Installation, Rotary
Encoder, Dickey-John 360, With 1 Foot Cable
Box And Hardware Installation, Air Spreader
Bracket Kit, 3 Pin Clevis, Quick Release
Tarp Stop Assembly, Short Clevis Pin, Quick Release
Bracket Kit, Quick Release, Offset
Tarp Stop Assembly, Offset, Qr
Cable Spool Kit, Short
Cage Assembly
No Foam Marker
Cap Tube Installation, No Pressure Washer
Cap Installation, Tube, Right Hand, Center
Cartridge Group, 15 Inch
Cover Assembly, Rear Bulkhead
Dummy Bolt Installation, Air Spreader, 4.00
Dummy Bolt Installation, Air Spreader, 8.00
Seal Group
Edge Liner And Tread Installation, Air Spreader
Left Hand
Right Hand
Guard Assembly, Splash, Front, Rear Wheel
Grid Screen Installation, Air Spreader
Holddown Assembly, Main, 3 Wheel
Ladder To Distributor
Ladder Lower, Rear
Lift Eye Installation , Airspreader
Lift Eye Decal Installation , Airspreader
Lube Installation, Air Spreader
Motor Kit, Srt2
Pivot Mount Hardware Kit, Sst
Tarp Motor Group, Srt
Ratchet Assembly, 1.00 Inch, Ss
Riser Installation, 4.00 Inch, Air Spreader
Riser Installation, 8.00 Inch, Air Spreader
Roll Tarp Installation, With Granular, 800
Roll Tarp, Electrical, With Granular
Roll Tarp Installation, Without Granular, 800
Roll Tarp, Electrical, Without Granular
Roll Tarp Installation, With Granular, 400 Air Spreader
Roll Tarp Installation, 144 Inch, No Granular, Air Spreader
Roll Tube Assembly, 144 Inch Box
Sleeper Installation
Splash Guard Installation, Front, Left Hand
Splash Guard Installation, Front, Right Hand
Splash Guard Assembly, Left Hand, Front
Tube Cap Installation, Left Hand
Splash Guard Assembly, Left Hand, Rear
Splash Guard Assembly, Right Hand, Front
Splash Guard Assembly, Right Hand, Rear
Srt Roll Tarp Hardware Kit
Auxiliary
Window Installation
V-Hood Assembly
Primary Product Distribution
Auger Assembly, Air Spreader
Distributor And Auger Assembly, Air Spreader
Auger Hub Assembly
Auger Motor Assembly, Horizontal
Hydraulic Motor, Sealed
Drain Valve Assembly
Ball Valve, 1.50 Inch Poly, Full Flow
Rain Tarp Installation, Rear Of Box
Dispenser Assembly, Dry Implement, Left Hand
Conveyor Assembly, Air Spreader
Motor Assembly, Conveyor, Air Spreader
Drop Chute Assembly
Drop Hose Assembly, Air Spreader
Gate Control Assembly
Dispenser Assembly, Dry Implement, Right Hand
Fan Assembly, Metric, Right Hand
Fan Motor Assembly
Hydraulic Motor, 6.0 Cir Displacement
Fan Assembly, Metric, Left Hand
Manifold And Venturi Assembly
Venturi Tube Locator Lock Assembly
Butterfly Valve Assembly, Left Hand
Air Cylinder Assembly, Left Hand
Butterfly Valve Assembly, Right Hand
Oil Cooler Assembly, Left Hand
Oil Cooler Assembly, Right Hand
Fan And Boom Shut-Off Installation
Butterfly Valve Assembly Lh
Butterfly Valve Assembly Rh
Granular Bin Installation, 8 Inch
Lid Assembly, Granular
Manifold And Venturi Assembly, Boom, 70 Foot
Butterfly Valve Assembly, Left Hand, Center
Air Cylinder Assembly, Left Hand, Center
Butterfly Valve Assembly, Center, Right Hand
Air Cylinder Assembly, Right Hand, Center
Butterfly Valve Assembly Lh Center
Butterfly Valve Assembly Rh Center
Motor Installation, Granular, Left Hand, Falcon Vt
Rework
Motor Electrical 12 Volt Dc
Speed Reducer
Rework Electrical Assembly Pickup
Motor Installation, Granular, Right Hand, Falcon Vt
Motor Installation, Granular, Raven, Right Hand
Motor Installation, Granular, Raven, Left Hand
Sensor Installation, Full Empty, Granular Bins
Vertical Auger Pump Kit, Air Spreader, Twin Bin, 4 Bin
Secondary Product Distribution
Ball Valve, 32 Fp X 32 Mp, Poly
Ball Valve, 0.50 Npt, Union, Poly
Ball Valve, 0.75 Npt, Union, Poly
Ball Valve, 1.00 Inch Full Port Flange X Npt, Electrical
Actuator, 000-60-M-9
Ball Valve, 1.50 Npt, Union, Poly
Ball Valve, 1.50 Npt, T Handle
Boom Assembly, Wet Boom, Air Spreader
Boom Plumbing Assembly, Co Application, Air Spreader
Tee Fitting Assembly, Hose Barb
Wet Boom Fitting Assembly, Dry Spreader
Nozzle Installation, Co Application, Air Spreader
Pressure Plumbing Tee Installation
Butterfly Valve, 1.50, 90d
Chemical Eductor, Clean Load Ii, Poly, 4.5 Gallon
Chemical Eductor Plumbing Assembly, Co Application
Air Spreader, Dry Spreader, Co Application
Flowmeter Installation, Co Application, Air Spreader
Flowmeter, 2.00 Inch, Sp Flange, Rfm60, 12 Volt
Flowmeter, 1.25 Inch, 280 Pulse Per Gallon, 12 Volt
Flowmeter, 2.00 Inch, Sp Flange, Rfm60p, 12 Volt
Gauge Installation, Co Application, Air Spreader
Hydraulic Pump, Fmc, 150, 206
Manifold Assembly, Co Application, Air Spreader
Nozzle Installation, Wet Boom, Center, Co Application
Plumbing Installation, Sparger, Air Spreader
Product Pump Installation, Co Application, Air Spreader
Product Pump Fitting Assembly, Co Application
Plumbing Bypass, 400l, Dry Soilection
Plumbing Installation, Product Pump
Plumbing Installation, Chemical Eductor
Reload Valve Assembly, 400l Dry Spreader
Saddle Installation, Co Application, 81xx
Tank And Saddle Assembly, 400 Gallon, Left Hand
Tank Strap Assembly, 200 Gallon
Tank Fitting Assembly, Left Hand
Tank And Saddle Assembly, 400 Gallon, Right Hand
Tank Fitting Assembly, Right Hand
Saddle Installation, Co Application, 9203
Servo Valve Assembly, Wet Boom, Air Spreader
Strainer Installation, Pressure Plumbing, Twin Bin
Strainer Assembly
Transducer Installation, Co Application, Air Spreader
Pressure Transducer Assembly
Booms
Boom Assembly 70ft
Boom Assembly, 70 Foot, Left Hand
Boom Assembly, 70 Foot, Right Hand
2018
Boom Center Section Installation
Hydraulic Cylinder Assembly, Boom Motion, Air Spreader
Boom Cradle Installation, Air Spreader
Cradle Assembly, Air Spreader
Nozzle Clamp And Band Assembly, Common, Standard
Nozzle Installation
Slider And Stop Assembly, Center Boom
Foam Marker
Ball Valve, 2.00 Inch, Poly
Foam Marker Drop Hose Assembly, 70 Foot
Foam Marker Installation, Air Spreader, Twin Bin, 4 Bin
Foam Marker Regulator Assembly
Solenoid Valve, 25npt, 12 Volt
Foam Marker Tank Assembly, 60 Gallon, Ss
Solenoid Valve Rework
Solenoid Valve
Foam Marker Tank Installation, Rear, Air Spreader
Step Assembly, 60 Gallon, Foam Marker
Step Assembly, 60 Gallon, Foam Marker, 1903
Air Valve Assembly Spreader Co Application, 7gpm
Hydraulic Valve Assembly, Solenoid, Liquid Option
Auger Motor Assembly, Vertical
Hydraulic Motor, 8.0 Cubic Inch
Boom Valve Installation In Out, Air Spreader
Valve And Fitting Assembly, Boom In Out
Hydraulic Valve Assembly, Solenoid, Boom In Out
Bulkhead Assembly, Fan Motor
Check Valve Assembly, 65 Psi
Check Valve Assembly, 25 Psi
Fan Speed Servo Valve Installation
Fan Speed Servo Valve Assembly
Fan Control Valve Installation
Valve Assembly, Flow Air Spreader, Dry Spreader
Filter Bracket Service Kit, Air Spreader
Hydraulic Filter Assembly, Air Spreader
Hydraulic Return Filter Assembly, Air Spreader
Filter Assembly, Air Spreader And Dry Spreader
Hydraulic Filter, 750 Psi
Gauge Installation, Fan Auger
Gear Pump Assembly, Air Spreader
Hose Installation, Cooler, Pump, Valve
Hydraulic Assembly, Basic, Air Spreader
Hydraulic Filter Installation, Air Spreader
Hydraulic Tank Assembly
Hydraulic Tank Cover Assembly
Hydraulic Valve Installation
Hydraulic Valve, Solenoid And Relief Rework
Relief Valve Solenoid, 2500 Psi
Valve Installation, Servo Control
Valve Assembly, Dickey-John
Hydraulic Assembly, Basic, Air Speader, 2013
Hydraulic Tank Installation, Air And Dry Spreader
Hydraulic Boom Valve Assembly Block, Air Spreader
Hydraulic Valve, Air Spreader Boom Block
Hydraulic Cylinder Assembly, O-Ring, Air Spreader
Hydraulic Cylinder, 3.50 X 16.00 X 1.50
Hydraulic Hose Installation, Air Spreader
Hydraulic Hose Installation, Air Spreader, Eaton
Split Flange Kit, 1.00
Hydraulic Hose Installation, Air Spreader, Bosch
Hydraulic Hose Installation, Air Spreader, 9203
Hydraulic Pump Assembly, Air Spreader, 9203
Hydraulic Gear Pump, 1.94 Cir Displacement, Ccw
Variable Displacement Pump, 3.88, Thru Drive, Ccw
Auger
Hydraulic Pump Installation, Air Spreader, 84xx
Hydraulic Pump Assembly, Air Spreader, 84xx
Hydraulic Piston Pump, 98cc, Eaton
Hydraulic Pump Installation, Air Spreader, Eaton
Hydraulic Pump Installation, Air Spreader, Bosch
Hydraulic Pump Assembly, Air Spreader, Bosch
Piston Pump, 90cc, Right Hand
Hydraulic
Hydraulic Pump Installation, Air Spreader, 9203, Cat Ps
Hydraulic Pump Assembly, Air Spreader, Eaton
Hydraulic Pump Assembly, Air Spreader, 8xxx
Piston Pump, 5.19 Cid, Right Hand
Hydraulic Installation, Air Spreader, 83xx
Split Flange Kit, -20 Code 62
Hydraulic Group, Pump Installation, As 6 8xxx
Hydraulic Installation, Air Spreader, Cvt
Hydraulic Servo Valve, 18gpm
Hydraulic Valve Assembly, Selector Bypass
Hydraulic Valve Installation, Selector Bypass
Hydraulic Valve Installation, Boom Block, Air Spreader
Fan
Hydraulic Valve, Solenoid Relief
Hydraulic Cap And Plug Installation
Loose Combo Option, Air Speader, 82xx
Pump Replacement Kit
Pump Assembly, Variable Displacement, Jd Ps Air Spreader
Variable Displacement Pump, 388 Spl Rr Prts
Oil Cooler Installation, Co Application, Air Spreader
Oil Cooler Assembly, Co Application, Air Spreader
Oil Tank Heater Installation, 110 Volt
Plug Assembly, -6 Orfs
Plug Assembly, -8 Orfs
Servo Valve Installation, Air Spreader
Valve Installation, Air Spreader Co Application, 7gpm
Variable Displacement Gear Pump Installation, Air Spreader
Kit, Repair
Electrical Box, Roll Tarp
Electrical Box Installation
Power Distribution Box Assembly, Basic
Co Application System, Falcon Vt, Air Spreader
Harness Installation, Co Application, Input Output Module
Module Assembly, Input Output, Can
Electrical Installation, Roll Tarp
2015
Harness Installation, Fan Cooler, Liquid System
Harness Installation, Granular, Falcon Vt, Air Spreader
2017
Harness Installation, Granular, Air Spreader, Raven
Harness Installation, Co Application, Air Spreader, Raven
Co Application, Granular, Air Spreader, Raven
Lamp Cluster, Rear, Left Hand
Lamp Cluster, Rear, Right Hand
Light Assembly, Tail Amber Flashing Warning Light, Left Hand
Turn Light Assembly, Led, Resistor
Light Assembly, Tail Amber Flashing Warning Light, Right Hand
Module Installation, Input Output, Air Spreader
Power Harness Installation, Granular, Falcon Vt
Power Distribution Cable Installation, Air Spreader
Electrical Box Assembly
Plate Assembly, Power And Ground
Relay And Input Output Installation, Taillights
Relay And Input Output Assembly, Air Spreader
Resistor Assembly, K-680 Ohm, 6 Prong
System Electrical Installation, Air Spreader
Taillight Harness Installation, Amber Flashing Warning Light
2016-2018
System Electrical Installation, Co Application, Falcon Vt, Gr
System Electrical Installation, Air Speader, Cvt
System Harness Installation, Air Speader, Twin Bin, Cvt
System Electrical Installation, Air Speader, Raven
System Harness Installation, Air Spreader
Taillight And Amber Flashing Warning Light Installation
Tail Light Amber Warning Flashing Light Installation
Warning Lamp, Amber
Air System
Air Box Assembly, Air Spreader
Air Box Assembly, Dry, Falcon Ii
Granular
Manifold Assembly
Airline Installation, Air Spreader
Pressure Washer And Rinse System
Harness Installation, Head Rinse, 62 Gallon, System
Pump Rework, Motor, H R
Pump And Motor, Du105 Hypro
Pump 4101n, H, Du105
Harness Installation, Head Rinse, 110 Gallon System
Head Rinse Assembly
Plumbing Assembly, Head Rinse, 62 Gallon
Pump And Base Assembly, Head Rinse
Tank Installation, 62 Gallon, Left Hand, Air Spreader
Tank Assembly, 62 Gallon
Pressure Washer Plumbing Assembly, 62 Gallon, Air Spreader, Jd
Air Spreader, Jd
Pressure Washer And Head Rinse Harness Installation
Pressure Plumbing Assembly Washer With Head Rinse, 62 Gallon
Tank And Saddle Assembly, 110 Gallon, 1903
Tank Strap Assembly, 110 Gallon
Tank Installation, 110 Gallon, Twin Bin
Tank Assembly, 110 Gallon
Decal Installation, 200 Gallon Tank
Decal Installation, 400 Gallon, Co Application
Decal Installation, Air Spreader
Decal Installation, Box, Air Spreader, English
Decal Installation, Reflective, Dot
Paint And Decal Installation, Ag-Chem Logo, Air Spreader
Product Containment
Air Spreader
Cage Assembly
No Foam Marker
Seal Group
Left Hand
Right Hand
Ladder Lower, Rear
Motor Kit, Srt2
Auxiliary
Window Installation
V-Hood Assembly
Auger Hub Assembly
Drop Chute Assembly
Fan Motor Assembly
Rework
Speed Reducer
Strainer Assembly
Booms
Boom Assembly 70ft
2018
Nozzle Installation
Foam Marker
Solenoid Valve
Auger
Hydraulic
Fan
Kit, Repair
2015
2017
2016-2018
Warning Lamp, Amber
Air System
Granular
Manifold Assembly
Head Rinse Assembly
Air Spreader, Jd
