Challenger Terragator Air Max Precision 1_2 Parts Catalog 604050D1
Brand: Challenger Terragator
Type of Machine: Applicators
Model: Challenger Air Max Precision 1, Air Max Precision 2 Terragator 'C' (2019-2021)
Serial Number: ..KXXX1001-..MXXX9999
Part Number: 604050D1
Number of Pages: 624 Pages
Product Containment
Air Max Precision, Tgc
Installation Arrangement, Air Max Precision 1
V-Hood Installation, Air Max 1000
Conveyor Cover
Amp1
Airmax Precision
Bypass Valve
Hydraulic Motor, 9.9 Cid
Air Max 1000
Hydraulic Component Installation, Pwm Valve Amp 1
Hydraulic Valve Assembly, Conveyor, Amp 1
Hydraulic Valve, Pwm 15gpm, Air Max Precision 1
Air Max Precision 1
Air Max Precision
Decal Installation, Air Max Precision
Installation Arrangement, Air Max Precision 2
Flip Panel Installation
V-Hood Installation, Air Max 2000
Air Max 2000
Amp2
Hydraulic Component Installation, Pwm Valve Amp 2
Hydraulic Valve Assembly, Conveyor, Amp 2
Hydraulic Valve, Pwm 15gpm, Air Max Precision 2
Hydraulic Hose Installation, Air Max Precision 2
Sensor Installation, Rate, Air Max 2
Decal Installation, Air Max Precision 2
Bumper Installation, Rear
Dual Bin Divider Installation
Riser
No Granular Bin
Fender Installation, Air Max
Airmax 1000 2000
Ladder Installation, Rear
Granular Metering Housing Installation
Assembly
Motor, Electrical, Twin Output
Hardware Group, Granular
Lift Eye Installtion, Airmax Precision
Lift Eye Decal Installation , Airmax Precision
Hardware Group, No Lift Eye
Housing Installation-Metering, Granular
Spacer Installation, 2.25 Wheel
Air Max
No Spraymax Option
Bulkhead Cover Installation, Front
Screen Installation, Front, Without Tank
Auxiliary
Option
Unloading Chute Installation
Window Installation, Hopper
Primary Product Distribution
Blower Installation
Oil Cooler Assembly, Left Hand
Oil Cooler Assembly, Right Hand
Blower Assembly
Hydraulic Motor Assembly, Fan
Hydraulic Motor, 1.83 Cir
Fan Guard Installation
Pre Cleaner Installation
Catch Pan Installation, Air Max 1000 2000
Rear
Conveyor Belt Installation, Lower
Conveyor Flap Kit
Kit
Manifold And Funnel Installation
Manifold Assembly
Metering Wheel Installation, Standard
Metering Wheel Installation, Low Rate
Metering Wheel Installation, Maxirate High
Plate Installation, Product Deflector
Screen Installation
Screen Installation, Air Max 1000
Sleeper Installation
Booms
Outlet Deflector Installation
Outlet Tube Installation, Boom Center
Left Hand
Boom Assembly, 70 Foot, Air Max 1000 2000, Left Hand
Tip Fold Cylinder Assembly
Right Hand
Boom Assembly, 70 Foot, Air Max 1000 2000, Right Hand
Boom Pivot Installation
Boom Fold Cylinder Assembly
Boom Rack Installation
Boom Rack Assembly
Boom Suspension Installation
Boom Suspension Cylinder Assembly
Foam Marker
Foam Marker Mixing Chamber, Richway
Foam Marker Assembly, Tank And Pumps
Hydraulic Hose Installation, Airmax Precision
Low Pressure Hydraulic Filter Assembly
Sequence Valve Assembly, Air Max
Hydraulic Filter Assembly, High Pressure, 4000 Psi, Amp
Hydraulic Reservoir Assembly
Hydraulic Valve Assembly, Fan
Tg7300c Tg8300c Tg8400c
Hose Installation
Hydraulic Valve
Hydraulic Pump Installation, Amp, Bosch
Hydraulic Pump Assembly, Air Max Precision, Bosch
Piston Pump, 90cc, Right Hand
Tg9300c
Hydraulic Pump Installation, Air Max Precision, 9300
9300
Hydraulic Tank Heater Installation, 120 Volt
Hydraulic Cap And Plug Installation
Clamping Installation
Raven Controller
Electrical Installation, Roll Tarp
Electrical Group
Electrical Box Assembly
Granular, Power Distribution Box Assembly
Fuse Installation
Rotating Beacon Lamp Assembly
Bumper
No Worklight
Controller System
Valve Installation
Valve Assembly
Sensor Installation, Autoboom
Ultrasonic Sensor, Digital, Left Hand
Ultrasonic Sensor, Digital, Right Hand
Sensor Installation, Rate, Air Max 1
Pressure Washer And Rinse System
3 Wheel
4 Wheel
Eame
Tarp Installation, Air Max
Ratchet Assembly, 1.00 Inch, Ss
Hardware Group, No Tarp
Cab Kit, 98 Air Max, New Cab
Dry System
Air Max Precision, Cc
Foam Marker Tank
Without Wheels
Field Accessories, Granular Bin, Maxirate
Granular Bin Assembly, Maxirate
Metering Wheel Assembly, Maxirate
Metering Wheel Assembly, Low Rate
Metering Wheel Assembly, Standard
Field Accessories, Pressure Washer Tank Installation
Hardware Kit, Pressure Washer
Hardware Kit, Granular Bin
