Challenger Terragator 845 Parts Catalog AG641814
Brand: Challenger Terragator
Type of Machine: Applicators
Model: Challenger 845 Terragator Chassis 2014
Serial Number: ..EW001001-..EW001010
Part Number: AG641814
Publication Date: 2017
Number of Pages: 2413 Pages
Publication Information
Engine Fuel And Exhaust System
Engine Instl-Sisu 84cta,360hp
Engine Instl-Sisu,84cta,330hp
Engine Asm-Sisu,Tg2444
Bracket Instl-Engine
Engine Pre Asm-Sisu,Stage 3b
Engine-Sisu84,368hp,Stage 3b
Gearbox Instl-Pumpdiverter
Box-Pump Diverter,Gear,Tgx244
Pump Instl-Hd,100cc,System
Pump Asm-100cc,Ccw
Pump-Hydr,100cc,H1,Ccw
Pump Instl-Hyd,Ls,63cc
Pump Asm-Hyd,Ls,Nms
Hose Instl-Heating,Cab,Tg2444
Gear Housing
Flywheel Housing
Valve Mechanism
Cilinder Head
Inlet- And Exhaust Manifold
Piping Of Turbo
Oil Sump
Crankcase Ventilation
Coolant Pump
Fuel Pump
Starter Motor
Drive Device
Compressor
Engine Overhaul Parts
Cooling Package Group
Tube Instl-Cac,Tg8333
Tube Instl-Water,Cooler
Cooler Instl-Tg2444
Cooler Asm
Spring-Gas,350n,200mm,485mm
Foam Instl-Anti False Air,Clr
Cooler Instl-Dropbox,Tg2444
Bracket Instl-Clr,Engine
Tank Instl-Clg,Water,
Exhaust Instl-Tg2444
Doc Instl-Unit,Tg2444
Sensor Instl-Nox,Doc
Tube Instl-Exhaust
Def Instl (Eat Components)
Tank Instl-Def.85l
Def-Tank,Stage3b,85ll
Dosing Module Instl-Def,Tg
Pump Instl-Dosage,Def,Tg
Hose Instl-Def,Tg
Filter Instl-Air Intake
Filter Instl-Airinlet,Tg2444
Venturi Instl-Agitator
Tube Instl-Airfilter,Tg2444
Fuel Line Instl
Tank Instl-Fuel,600l
Tank Asm-Fuel,Rh (65gl)
Cap Instl-Fuel,Lockable
Tank Asm-Fuel,Tank,379l,Rh
Axle Instl-Tg2444,Fr
Axle Asm-Tg2444,Fr
Axle-Front,24.66 1,Wet Disk
Carrier Assembly
Brake Assy
Housing Group
Wheel End
Wet Disc Brake
Axle Instl-Axletech,Str
Axle-Rear,24.66 1,Wet Disk
Cap Instl,Holes,Fueltnk,Dnms
Axle Instl-Axletech,Dgwlk
Frame And Suspension
Chassis Group-Standard
Chassis Gp-Straight
Pen Instl-Strcil,Strcil,2444
Pen Instl-Artcl Pnt,Tg2444
Chassis Asm-Straight
Bearing Instl-Arcl Pnt
Plate Instl-Pendel,Tg2444
Plate Asm-Pendeling
Plate Instl-Blck,Pendl Plate
Driveline Instl-Dbl Joint,Long
Driveline-1520mm,10knm
Driveline Instl-Modification
Driveshaft-Artiiculation,Tg845
Jackshaft Asm-Long,1580mm
Bearing-Plmr,Rlr Brg,Snl213l
Bearing-Plmr,Rlr Brg,Snl213f
Cylinder Asm-Str,Tg2444
Cylinder-Hyd,D45 90 406 734
Alarm Instl-Reverse
Chassis Gp-Dogwalk,Short
Chassis Instl,Dogwalk
Hitch Instl-Tg2444
Block Asm-Div,Lub,Slewing Ring
Bracket Asm-Harn Cable,Lt Un
Driveline Instl-Dbl Joint,Tunn
Bar-Follow,Driveline,Dgwlk
Jackshaft Asm-Tunnel,2444
Cylinder Instl-Locking,Dgwlk
Cylinder Asm-Locking,Dgwlk
Cylinder-Hyd,Dogwalk,Locking
Hitch Asm-Tg2444
Control Gp-Steering
Column As.-Steering
Orbitrol Instl-Steering
Orbitrol Asm-Steering
Drive System
Driveline Instl-Cvt,Engine
Driveline-8.5c Engine To Trans
Transmission Gp-Cvt,Tg2444
Xmsn Asm-Cvt,Ml260
Transmission-Cvt,Ml260,2444
Transmission-Cvt,Agconld
Gearbox-Housing
Oil Level Indicator
Inner Housing
Planetary Drive
Pump Shaft
Accumulator Shaft
Range Shaft
Hydr. Motor
Duct Plate
Adjusting Device
Pipelines
Group Gear Shifting
Shifting
Pump Drive
Lube Oil Pump
Pump Installation
Gear Box Lubrication Filters
Valve Unit
Front Wheel Drive Constant
Electrical System Transmitter
Electrical System Control
Dropbox Asm-Cvt
Tube-Breather,Clutch,Cvt
Hose Instl-Cvt
Transmission Instl-Cvt,Isolato
Testpoint Instl,Cvt
For Brakes See Axles And Cab
Air System
Dryer Instl-Air,Sgl Canister
Tank Instl-Air,Regeneration
Tank Asm-Air, Regeneration
Hose Instl-Air,System
Dryer Asm-Air,Sgl Canister
Dryer-Air,Sgl Canister,12v
Cable Instl-Adapt,Airdryer,Sgl
Dryer Instl-Air,Double,Caniste
Hose Instl-Air,Sys,Dryer,Dbl
Dryer Instl-Air,Dbl Canister
Dryer Asm-Air,Dbl Canister
Cooler Instl-Air,700l
Air Component Opt Chassis
Chain Instl-Debreath,Tank,Air
Hose Instl-Air,Standard,Tg2444
Tank Instl-Air,42l,Tg
Tank Asm-Air,40l
Tank Asm-Air,20l,Front (Wet)
Tank Asm-Air,20l,Rear (Dry)
Valve Instl-Reduce,Cabsusp,845
Tank Instl-Hyd,200l,Tg2444
Bulkhead Asm-Hydr,Tgx444
Tank Asm-Hydr
Cap-Hyd Tank,Breather,Argo
Common Hydraulic-Group
Tube Instl-Suction
Accumulator Instl-2.0l,Metric
Manifold Instl-Return
Manifold Instl-Suction
Manifold Asm-Suction
Support Instl-Manifold
Hose Instl-Chassis,Tg2444
Hose Instl-Ls,Pump,Steering
Hose Instl-Pump,Hp,System
Hose Instl-Return,Chassis
Hose Instl-Pump,Ls,System
Hose Instl-Leak,Ls,System
Hose Instl-Orbitrol
Hose Instl-Priority,Valve
Hose Instl-Pump,Emergency,Stee
Hose Instl-Brake,Pedal
Hose Instl-Art,Point,Tg2444
Hose Instl-Clr,Axle,Fr Side
Valve Instl-Priority,150l Min,
Valve Asm-Priority,150l Min
Manifold-Instl,Steering,Ls,Pum
Manifold-Steering,Ls,Pump
Pump Instl-Emergency,Steering
Pump-Asm,Emergency,Steering
Manifold-Pump,Emergency,Steeri
Control Kit Pump Emergencystee
Valve Asm-Flw Reg,Clr,Axle
Valve-2 2,Nc,Esteer,Rg6x5
Cooler Instl-Axle,Fr
Cooler Asm-Axle
Cooler-Hydr,Tt07,Axle
Cooler Instl-Axle,Rr
Light Instl-Work,Nose
Light Asm-Left
Light-Halogeen,Short Range
Bezel-Light,Left
Light-Halogeen,Long Range
Light Asm-Right
Bezel-Light,Right
Light Instl-Work,Nose,Hid,Dbl
Electric Group-2444
Switch Instl-Magnetic
Battery Instl-Tg8333
Breaker Instl-Junction Block
Light Instl-Traffic,Tg8333
Headlamp Asm-Halogen,Lh
Headlamp Asm-Halogen,Rh
Module Instl-High,Current
Instl-Ext,Light,Tg
Instl-Harness,Chassis,Tg845
Instl-Relaymodule,2v
Instl-Relay,30a
Sensor Instl-Temp,Ambient
Light Instl-Width, Machine
Instl-Elec,Axle,Cooling,Tg845
Lamp Instl-Rotating,Lh Rh,Fron
Lamp Instl-Rotating,Lh.Front
Connection Asm-Lamp,Rotating
Lamp Instl-Rotating,Rh,Front
Instl Harn,Beacon,Landr,Tg
Radio Instl-Europa
Cab-Group,2444
Suspension Instl-Cab,Rear
Asm-Cab,2444
Windshield Wash-Fluid Fill
Panel Instl-Trim,Tg
Airline Ftg Instl-Cab,Airhorn
Pedal Instl-Throttle
Console Instl-Cab
Pedal Instl-Brake,Tg (Service)
Pedal Asm-Brake,Hanging
Pedal-Brake,Hyd,Hanging
Instl-Harness,Cab,2444
Cab Group,Cvt,Ace
Pedal Instl-Clutch
Cab Asm-Tg,Cvt,Front,W Pallet
Cab Asm-Cvt,Front
Door Asm
Arr-Cab Glass
Arr-Rh Window Glass
Arr Decals
Floormat Instl-Cab,8333
Wiper Group
Wiper Motor,1 In. Shft,Lh,85
Arr-Inner Roof
Arr-Interior Trim
Arr-Horn(Air)
Arr-Audio
Antenna
Radio Accessory Kit
Arr-Outer Roof
Arr-Floormats Covers
Arr-Elec Inner Roof
Arr-Controls (Front)
Hvac Group
Grip Instl Hand,Door
Seat Instl-Deluxe
Dash Instl-Center Console
Decal-Inst,Cabroof,845
Suspension Instl-Cab,Fr
Handle-Exterior
Seat Asm-Deluxe,Semi Active
Kit-Seat Top, Sst
Kit-Suspension Sa
Kit-Suspension Gp (Seat)
Kit-Seat As. Upper
Kit-Arm Rest As. (Lh)
Kit-Suspension
Mirror Instl-Standard
Bracket Instl-Mirror,Lh
Bracket Instl-Mirror,Rh
Mirror Instl-Mirrors,Std,Lh
Mirror Instl-Mirrors,Std,Rh
Mirror Instl-Electrical
Mirror Instl-Mirrors,Elec,Lh
Mirror-Adjustable,Heat,12v
Mirror Instl-Mirrors,Elec,Rh
Instl Elec-Mir,Adjandheat
Instl-Plate,Mirror,Elec
Airco And Heating System
Air Conditioning Group
A C Filter Instl-Tg2244
Hose Instl-A C
Hvac Unit-Autocontrol
Apperance-Group
Tank Instl-Water,10l,Tg2244
Platform Instl-Fueltank,Lh
Platform Instl-Fueltank,Rh
Box Instl-Storage Battery,Tg83
Cover Asm-Batterybox,Lh,Tg8333
Cover Asm-Toolbox,Rh,Tg8333
Support Instl-Light,Traffic,Fr
Step Instl-Fuel,Tank,Rh
Support Instl-Mirror,Rh
Decal Instl-Antislip,Platform
Entrance Instl-Tg2444
Platform Instl
Stepladder Asm-Tg
Support Instl-Platform
Tunnel Instl-Hose,Tg2444
Support Instl-Filter,Air,Tg244
Faster Asm-Trun,Quarter
Bumper Instl-Tg2444
Bumper Laminated-Tg2444
Panel Instl-Cover,Engine,2444
Panel Asm-Cover,Engine,Rh
Fender Instl-Front,2444
Fender Asm-Front,Comp,Lh,2444
Fender Asm-Front,Complete,2444
Fender Asm-Front,Laminate,2444
Fender Asm-Front,Comp,Rh,2444
Ladder Instl-Art,Point
Bracket Instl-Watertank,Tpcs
Panel Asm-Cover,Engine,Lh
Hood Instl-Tg2444
Hood Asm-Tg2444
Hood Asm-Pre,Tg2444
Hood-Laminated,Tg2444
Grill Instl-Hood,Tg,Ch
Seal Instl-Hood,Tg2444
Grip Instl-Hood,Tg2444
Latch Instl-Hood,Tgx444
Decal Instl-Hood,Tg2444
1decals
1wheels
Wrench-Wheel,Mtg,Set
Tire Instl-1050,3.15m,M28,Mich
Rimandtire Asm-Ch,1050 50r32,M28
Tire Instl-1050,3.15m,184,Tg84
Rimandtire Asm-1050,3.15m,184,Rh
Rimandtire Asm-1050,3.15m,184,Lh
Tire Instl-900 60 R32,Michelin
Rimandtire Asm-900 60 R32,Rh
Rimandtire Asm-900 60 R32,Lh
1controller System
Instl-Vt,2444
1guidance System
Telemetry Opt-Ready
Agcommant Hardware Grp F A
Op-Man,Grp,Ag150,Sys,F I,En
Op-Man,Grp,Telementry,Sys,En
Op-Man,Grp,Telementry,Sys,Ger
Op-Man,Grp,Ag150,Sys,F I,Ger
Op-Man,Grp,Ag150,Sys,F I,Dk
Op-Man,Grp,Ag150,Sys,F I,Fr
Op-Man,Grp,Ag150,Sys,F I,Nl
Op-Man,Grp,Telementry,Sys,Fr
Op-Man,Grp,Telementry,Sys,Nl
Op-Man,Grp,Telementry,Sys,Dk
Op-Man,Grp,Ag350,Sys,F I,En
Op-Man,Grp,Ag350,Sys,F I,De
Op-Man,Grp,Ag350,Sys,F I,Fr
Op-Man,Grp,Ag350,Sys,F I,Nl
Op-Man,Grp,Ag350,Sys,F I,Dk
Lightbar Instl-Ld40,Tg
Autoguide Opt-Ready Kit
Sensor Instl-Ag2,Tg3244
Bracket Instl-Top Dock
Elec Instl-Autoguide
Orbitrol Instl-Autoguide
Valve Instl-Autoguide,2444
Valve Asm-Steer,Autoguide
Pved-Valve,40l,8333
Hose Instl-Autoguide
Bracket Gp-Housing Dome
Terminal Instl-Gx45
Telemetry Asm
Instl-Sgr-1,Tg
Instl-Antenna,Sgr-1,Tg
Instl Harn-Ag,Roof,Tg
Instl-Topdock,Agi4,Tg
Terminal Instl-C3000,Tg
1attachments
Radar Group-Common,Eu
Radar Group-Common,Uk
1accessories
Towing Hook-Sk5a (Front)
Worklight-Opt,Cab(Floodlight)
Worklight Opt-Rear, W O Rops
Worklight Instl-Cab,W O Rops
Harness Instl-Wl,Cab,Rr
Instl-Box,Tools
Worklight Opt-Rear,Hid
Worklight Instl-Cab,Hid
Worklight Opt-Cab,Hid,Fr
Mat-Floor, Challenger
Worklight Opt-Front,Forward,Hi
Worklight Opt-Front,Forw,Hal
Panel Instl-Keypad,2444
Filter Instl-Bio,Diesel,Tg2444
Armrest Instl-Tg2444,Liq Dry
Asm-Armrest,Cvt,2444,Liq Dry
Joystick Asm-Cvt,Liq Dry
Instl-Switch,4wd,2444
Kit-Filter,500h,Tg845
