Challenger Terragator 845 NMS Liquid System Parts Catalog AG638274
Brand: Challenger Terragator
Type of Machine: Applicators
Model: Challenger 845 NMS Terragator Liquid System 2012
Part Number: AG638274
Publication Date: 2013
Number of Pages: 1417 Pages
Publication Information
Product Containment
Tank Opt-Polyester,Dw,18000
Fender Instl-Dw,2444
Fender Asm-Dw,Comp,Lh,2444
Fender Asm-Dw,Comp,Rh,2444
Support Instl-Hose,Manure,Tg24
Tank Inst-Polyester,18000
Support Asm-Tank,2244,My11
Tank Asm-Poly,18000,Components
Tank Asm-Poly,18000,Complete
Tank Asm-Poly,18000,Laminated
Manhole Instl-Poly Tank,18000l
Lid Asm-Poly Tank,Manhole
Lid Asm-Poly Tank,Brthr,Compl
Valve Instl-Rear,18000
Valve Asm-Knife,6in,Snrs,Pneum
Level Indicator Group,18000
Float Asm-Adjustable.Nms
Rack Inst-Rear Atch,Tank 18000
Decal Inst-Striping Lnms,18000
Guide Instl-Cable Front,18000
Primary Product Distribution
Arm Instl-Suction,Non,2444
Adapter Instl-Suct Arm,Non
Comp Instl-Hyd,Suct Arm,Non
Arm Group-Suct,Hor,Cl,2444
Valve Inst,Ng6,Hor,Suct,Std
Valve-2 2,Nc,3 8
Component Instl-Elec,Sl Sucarm
Hose Instl-Hor Suct,Std,8333
Arm Asm-Suction,Hor,Std,2444
Bearing Asm-Blk,Hitch
Arm Asm-Suction,Horizon,2244
Cylinder Asm-D30 50 60 180 500
Cylinder-Hyd,D30 60 180 500
Cylinder Asm-D30 50 580 895mm
Cylinder-Hyd,D30 50 580 895mm
Cylinder Asm-D25 40 150 349
Cylinder-Hyd,D25 40 150 349
Cylinder Asm-D25 40 150 349mm
Rubber Asm-Harmonica,8in
Coupling-Turnable,8in
Harn Instl-Suction,H,Std,Tg244
Bucket Instl-Leakage,Tg2444
Hose Instl-Ng6,Hor,Std,Tg2444
Block Instl-Ng6,Suction Horiz
Block Asm-Ng6,Suction,Horiz
Valve-Hyd,,Ng06,4 3,Closed Cen
Orifice-1.0mm,Ng6
Orifice-1.5mm,Ng6
Orifice-1.2mm,Ng6
Valve-Hyd,,Ng06,4 3,A-B On T
Hose Instl-Air,Hor,Suct,Arm
Component Instl-Cntfgl Pump,Sl
Valve Asm-Knife,10in,Superload
Valve-Knife,Dn250
Cilinder Asm-D16 25 260 395,Hc
Cylinder-Hyd,D16 25 260 395mm
Pump Asm-Centrifugal,Combiload
Motor Asm-Hyd,100cc
Motor-Hyd,100cc,Side Ports
Ring Sprt Instl-Rbr Superld
Blockade Instl-Flush,Motor,Cl
Hose Instl-Hyd,Cl,Hor Arm
Manifold Instl-Combiload
Manifold Asm-Combiload
Harness Instl,Cl,Tg2444
Hose Instl-Hyd,Cl,Vert Arm
Coupling Instl-Cntfgl P,10baue
Funnel Opt-Suction,10inch
Arm Group-Suct,Hor,Std,2444
Arm Opt Instl-Horiz,Suct Arm
Coupling Instl-Suct Arm,8.0bau
Funnel-Asm-Suction,8inch
Arm Group-Suct,Vert,Std,2444
Hinge Instl-Hose 10in,Sl,Vert
Cylinder Asm-Swing,Hose,Sl,Ver
Cylinder-Hyd,D25 40 340 600mm
Cylinder Asm-Piv,Hose,10in,Sl
Cylinder-Hyd,D25 50 125 354mmm
Hose Instl-10in,Sl,Ver
Valve Instl-Cyl,Vert Arm.2244
Valve Asm-Ng6,Cyl,Vert Arm
Valve-Pres Relief,A+B On T,Ng6
Arm Instl-Vert,Suct,2444
Arm Asm-Vert,Suction,2444
Valve Asm-Knive,8in,Snsrs,Pneu
Cylinder Asm-Lift,Vert,Arm
Cylinder-Hyd Lift,Vert Arm
End-Rod,M30x2.0,Gir30do 2rs
Hose Instl-Cyl,Vert Arm,2444
Hose Instl-Air,Vert Arm,2444
Instl-Harness,Suct,Vert,2444
Tube Instl-Suction,Std,Vert
Box Opt-Leakage,Suct Arm,Vert
Arm Group-Suct, Vert,Cl,2444
Pump Instl-Cntfgl,Manure,Ver
Pump Asm-Centrifugal,Superload
Pump Group-Fl1036,Lnms,2444
Hose Asm-Unload,Tank,Lnms
Pump Instl-Fl1036,Lnms
Pump Asm-Fl1036,Lnms,2444
Support Asm-Pump,Lnms
Tube Asm-Inlet,Fl1036,Tg8333
Component Asm,Manual Valve,6in
Valve Asm-Manual,6in
Valve-Stem,Gate,Flanged,Mz,6in
Pump Asm-Fl1036,Mot Hyd,55cc
Motor-Hyd,55cc,Incl Sensor
Pump-Manure,Fl1036,Gearbox
Tube Asm-Outlet,Fl1036,2444
Pump Group-El1550,Lnms,2444
Pump Instl-El1550,Lnms,2444
Pump Asm-El1550,Lnms,2444
Tube Asm-Inlet,Fl1550,Tg8333
Pump Asm-El1550,Mot Hyd,75cc
Pump Asm-Outlet,El1550,Lnms
Hose Asm-Inlet,Tank,Lnms
Cutter Group-Manure,12000,2444
Air Instl-Rc12000,X244,Lnms
Tube Instl-Overflow,2444,Lnms
Valve Asm-Inlet,Tank,Cutter
Valve Asm-Knive,8in,Snsrs,Hydr
Cutter Instl-Manure,12000,2444
Cutter-Rc12000,Oms250m
Motor-Hydr,Oms 250 M,Rc12000
Cutter Asm-Rotacut,2444,Lnms
Valve Instl-Cutter,Bottom
Toolkit Instl-Dism,Rc,2244
Toolkit Asm-Dismantle,Rotacut
Support Asm-Tool,Dism,Rc,2244
Cutter Group-Manure,10000,2444
Cutter Instl-Manure,10000,2444
Rc10000-Incl,Oms200cc
Motor-Hydr,Oms 200,Rc10000
Swivel Instl-Tool,Dism,Rc10000
Swivel Asm-Tool,Dism,Rc10000
Hydraulic Group-Tg2444,Lnms
Cooler Instl-Oil,Tg2444
Cooler Asm-Oil,Tg2444
Instl-Relay,30a
Manifold Asm-Return Oil,Clr
Valve Instl-Cutter,Std,Tg2444
Valve Asm-Cutter,Std,Tg2444
Unit Instl-Hyd Pn El,Tg2444,Ln
Casing Asm-Hyd,Tgx244,Lnms
Manf Instl-Std,Hyd,Tg2444,Lnms
Manf Asm-Std,Hyd,Tg2444,Lnms
Block-Hydr,Hic,Tg9205
Manifold-Nms,Hicb(Rev 07)
Manifold-Nms,Danfoss
Valve Instl-Dw,Tg2444,Lnms
Valve Asm-Dw,Tg2444,Lnms
A Valve-Hyd,,Ng06,4 2,A-B On T
A Valve-Reducer,160bar,Ng6
Tube Instl-Art,Hyd Unit,Tg2444
Tube Instl-Hyd Unit,Hitch,Lnms
Tube Instl-Extra Function,Lnms
Plumbing Instl-Hitch,Lnms
Hose Instl-Brake,System,Tg2444
Hose Instl-Cutter,2444,Lnms
Hose Instl-Pump,Borger,Tg2444
Hose Instl-Dw,2444,Lnms
Hose Instl-Valves,Knife,Tg2444
Hose Instl-Sys,Front,Lnms,2444
Hose Instl-Hyd,Borger,Lkg,2444
Instl-Elec,Hyd Unit,2444
Harness Instl-Main,System,Lnms
Instl-Switch,Hitch,Reduce
Harness Instl-Dogwalk,X244
Switch Instl-Dw,Lock-Unlk,X244
Harness Instl-Lght,Tail,Lnms
Box Asm-Light,Tg Nms,Left
Light-Pendel,Diagonal
Box Asm-Light,Tg Nms,Right
Air System
Air Group-Tg2444,Lnms
Valve Asm-Air,Tg2444,Lnms
Decal Instl-Superload,Lnms
Decal Instl-Tg845,Lnms
Decal-Joystick,Lnms
Decal Instl-Chassis,Tg845
Hitch Instl-Cat Iv,Dw,2444
Arm Asm-Hitch,Tg
Bulkhead Asm-Hitch,9205nms
Cylinder Asm-D50 100 230 510
Spring Asm-Pull,Hitch
Link Asm-Lift,2444
Link Asm-Lower,Cat Iv,2444
Link Instl-Lower,Quick, Cat Ii
Link Asm-Lower,Qik,Catiii,Rh
Link Asm-Lower,Qik,Catiii,Lh
Link Instl-Lower,Quick,Cat Iv
Link Asm-Lower,Qik,Cativ,Rh
Link Asm-Lower,Qik,Cativ,Lh
Link Instl-Lower,Cat Iii
Link Asm-Lower,Catiii
Plate Instl-Bulkhead,Hitch,Nms
Hose Instl-System,Rr,Lnms,2444
Plate Instl-Bulkhead,Hitch,Lnms
Plate Asm-Bulkhead,Hitch,Nms
Kit-Coupler,Hyd,Iso,Loose
Coupler Opt-Multi,Hyd,Chassis
Hose Instl-Multi Coupler,Opt
Coupler Instl-Multi,Hyd,Chas
Coupler Asm-Multi,Hyd,Chassis
Coupler Opt-Multi,Hyd,Toolbar
Spare Parts-Tg Nms
Adapter-Gauge,Meas Point
Lamp Instl-Rotating,Tank,Nms
Connection Asm-Lamp,Rotating
Accessoiries
Chock Wheel-Instl,Rg600
Country-Instl,Lnms,Tg845,Ger
Placard Instl-Reflective,Tg8333,3.35
Refl Placards Asm-Lh,Workw,3350mm
Refl Placards Asm-Rh,Workw,3350m
Reflector Instl-Tg845
Long Load Sign Instl-2444,Lnms
Coupler Asm-Quick,Hitch,Catiii
Link-Top,Cat3,1 1 2 In. Unc,750mm
Coupler Asm-Quick,Vh,Ej35840
Coupler Asm-Quick,Vh,Tj644
Coupler Asm-Quick,Toolbar
Camera Monitor Option,Color
Camera Instl-Rear,Lnms
Monitor Instl-Rear Camera
Cable-Instl,Monitor,Motec,Tg
Cable-Instl,Camera,Motec,Lnms
Worklight Opt-Front,Rev,Hal
Worklight Opt-Front,Rev,Hid
Worklight Opt-Lnms,Rear,Hal
Light Asm-Work.Dual.Brckt
Worklight Opt-Lnms,Re,Top,Hal
Worklight Opt-Hor Suct Arm
Worklight Opt-Vert Suct Arm
Connection Opt-Air V,Injector
Kit-Coupler,Air,Loose
Valve Opt-Reload,Rh
Component Asm-Manual,Valve,6in
Nozzle Instl-Discharge
Spreader-Nutrient,Perfect
Hose Asm-Extension,6.0in,2244
Hose Asm-Supply Tank,6.0in,224
Hose Asm-Suction,6.0in,2244
Funct Opt-Hyd,Extra,Open
Comp Instl-Hyd,Func,Extra,Std
Comp Instl-Elec,Hyd,Func,Opt
Valve Instl-Hyd,Extra,Open,Ver
Valve Asm-Hyd,Extra,Open,Nms
Button Instl-Rear,Light Bar
Hose Instl-Funct,Opt,Ext,Vert
Harness Instl,Funct,Hyd,Extra
Funct Opt-Hyd,Extra,Closed,Ver
Valve Asm-Hyd,Extra,Closed,Nms
Function Opt-Hyd,Extra,Open
Valve Instl-Hyd,Extra,Open,Hor
Support Instl-Mount,Ng6,Funct
Hose Instl-Function,Opt,Extra
Function Opt-Hyd,Xtr,Closd
Valve Instl-Hyd,Ext,Closed,Hor
Kit-Coupler,Hyd,Iso,Loose,Ex
Function Opt-Hyd,Xtr,2nd,Closd
Coupling Instl-Hyd,Extra,2nd
Harness Instl,Funct,Hyd,2nd
Comp Instl,Hyd,Funct,Extra,2nd
Hose Instl-Funct,Opt,Extra,2nd
Canbus Opt-Ext,Sys Nms Liq
Towing Hook Opt-Hitch
Kit-Sensor,M12, Extend,10m
Bulkhead Asm-Drawbar
Drawbar Instl-Hitch
Product Containment
Valve-2 2,Nc,3 8
Orifice-1.0mm,Ng6
Orifice-1.5mm,Ng6
Orifice-1.2mm,Ng6
Valve-Knife,Dn250
Motor Asm-Hyd,100cc
Instl-Relay,30a
Air System
Decal-Joystick,Lnms
Arm Asm-Hitch,Tg
Link Asm-Lift,2444
Spare Parts-Tg Nms
Accessoiries
Valve Opt-Reload,Rh
Drawbar Instl-Hitch
