Challenger Terragator 845 Chassis Parts Catalog AG638226
Brand: Challenger Terragator
Type of Machine: Applicators
Type of Manual: Chassis Parts Catalog
Model: Challenger 845 Terragator Chassis 2012
Part Number: AG638226
Publication Date: 2013
Number of Pages: 1825 Pages
Publication Information
Engine Fuel And Exhaust System
Engine Instl-Sisu 84cta,360hp
Engine Instl-Sisu,84cta,330hp
Engine Asm-Sisu,Tg2444
Bracket Instl-Engine
Engine Pre Asm-Sisu,Stage 3b
Gearbox Instl-Pumpdiverter
Box-Pump Diverter,Gear,Tgx244
Pump Instl-Hp,100cc,System
Pump Asm-100cc,Ccw
Pump-Hydr,100cc,H1,Ccw
Pump Instl-Hyd,Ls,63cc
Pump Asm-Hyd,Ls,Nms
Hose Instl-Heating,Cab,Tg2444
Cooling Package Group
Tube Instl-Cac,Tg8333
Tube Instl-Water,Cooler
Cooler Instl-Tg2444
Cooler Asm
Cooler Instl-Dropbox,Tg2444
Tank Instl-Clg,Water,Tg8333
Foam Instl-Anti False Air,Clr
Exhaust Instl-Tg2444
Doc Instl-Unit,Tg2444
Sensor Instl-Nox,Doc
Tube Instl-Exhaust
Clamp Asm-Sliding V
Def Instl (Eat Components)
Tank Instl-Def.85l
Def-Tank,Satge3b,85l
Dosing Module Instl-Def,Tg
Pump Instl-Doasge,Def,Tg
Hose Instl-Def,Tg
Tank Instl-Fuel,600l
Tank Asm-Fuel,Tank,379l,Rh
Cap Instl-Fuel,Lockable
Tank Asm-Fuel,Rh (65gl)
Fuel Line Inst
Axle Instl-Tg2444,Fr
Axle Asm-Tg2444,Fr
Axle-Front,24.66 1,Wet Disk
Carrier Assembly
Housing Group
Wheel End
Wet Disc Brake
Axle Instl-Axletech,Str
Axle-Rear,24.66 1,Wet Disk
Axle Instl-Axletech,Dgwlk
Frame And Suspension
Chassis Group-Standard
Chassis Gp-Straight
Pen Instl-Strcil,Strcil,2444
Pen Instl-Artcl Pnt,Tg2444
Chassis Asm-Straight
Plate Instl-Pendel,Tg2444
Plate Asm-Pendeling
Bearing Instl-Arcl Pnt
Cylinder Asm-Str,Tg2444
Cylinder-Hyd,D45 90 406 734
Plate Instl-Blck,Pendl Plate
Alarm Instl-Reverse
Driveline Instl-Dbl Joint,Long
Driveline-1520mm,10knm
Jackshaft Asm-Short,2444
Chassis Gp-Dogwalk,Short
Chassis Instl,Dogwalk
Hitch Instl-Tg2444
Block Asm-Div,Lub,Slewing Ring
Bracket Asm-Harn Cable,Lt Un
Cylinder Instl-Locking,Dgwlk
Cylinder Asm-Locking,Dgwlk
Cylinder-Hyd,Dogwalk,Locking
Hitch Asm-Tg2444
Control Gp-Steering
Column As.-Steering
Orbitrol Asm-Steering
Orbitrol Instl-Steering
Driveline Instl-Dbl Joint,Shor
Transmission Gp-Cvt,Tg2444
Xmsn Asm-Cvt,Ml260
Transmission-Cvt,Ml260,2444
Dropbox Asm-Cvt
Hose Instl-Cvt
Transmission Instl-Cvt,Isolato
Testpoint Instl,Cvt
Drive System
Driveline Instl-Cvt,Engine
Driveline-8.5c Engine To Trans
For Brakes See Axles And Cab
Air System
Dryer Instl-Air,Sgl Canister
Tank Instl-Air,Regeneration
Tank Asm-Air, Regeneration
Hose Instl-Air,System
Dryer Asm-Air,Sgl Canister
Dryer-Air,Sgl Canister,12v
Cable Instl-Adapt,Airdryer,Sgl
Dryer Instl-Air,Double,Caniste
Dryer Instl-Air,Dbl Canister
Dryer Asm-Air,Dbl Canister
Cooler Instl-Air,700l
Air Component Opt Chassis
Chain Instl-Debreath,Tank,Air
Hose Instl-Air,Standard,Tg2444
Tank Instl-Air,42l,Tg
Tank Asm-Air,40l
Tank Asm-Air,20l,Front (Wet)
Tank Asm-Air,20l,Rear (Dry)
Tank Instl-Hyd,200l,Tg2444
Tank Asm-Hydr
Cap-Hyd Tank,Breather,Argo
Bulkhead Asm-Hydr,Tgx444
Common Hydraulic-Group
Tube Instl-Suction
Accumulator Instl-2.0l,Metric
Manifold Instl-Return
Manifold Instl-Suction
Manifold Asm-Suction
Support Instl-Manifold
Hose Instl-Chassis,Tg2444
Hose Instl-Ls,Pump,Steering
Hose Instl-Pump,Hp,System
Hose Instl-Return,Chassis
Hose Instl-Pump,Ls,System
Hose Instl-Leak,Ls,System
Hose Instl-Orbitrol
Hose Instl-Priority,Valve
Hose Instl-Pump,Emergency,Stee
Hose Instl-Brake,Pedal
Valve Instl-Priority,150l Min,
Valve Asm-Priority,150l Min
Manifold-Instl,Steering,Ls,Pum
Manifold-Steering,Ls,Pump
Pump Instl-Emergency,Steering
Pump-Asm,Emergency,Steering
Manifold-Pump,Emergency,Steering
Control Kit Pump Emergencystee
Hose Instl-Art,Point,Tg2444
Light Instl-Work,Nose
Light Asm-Left
Light-Halogeen,Short Range
Bezel-Light,Left
Light-Halogeen,Long Range
Light Asm-Right
Bezel-Light,Right
Light Instl-Work,Nose,Hid,Dbl
Light Asm-Left,Double Hid
Light Asm-Right,Double Hid
Electrical Group-2444
Switch Instl-Magnetic
Battery Instl-Tg8333
Breaker Instl-Junction Block
Light Instl-Traffic,Tg8333
Headlamp Asm-Halogen,Rh
Headlamp Asm-Halogen,Lh
Module Instl-High,Current
Instl-Ext,Light,Tg
Instl-Relaymodule,2v
Instl-Relay,30a
Sensor Instl-Temp,Ambient
Light Instl-Width, Machine
Instl-Harness,Chassis,Tg845
Lamp Instl-Rotating,Lh Rh,Fron
Lamp Instl-Rotating,Lh.Front
Connection Asm-Lamp,Rotating
Lamp Instl-Rotating,Rh,Front
Instl Harn,Beacon,Landr,Tg
Worklight Opt-Front,Rev,Hal
Worklight Opt-Front,Rev,Hid
Worklight-Opt,Cab(Floodlight)
Worklight Opt-Cab,Hid,Fr
Worklight Opt-Rear, W O Rops
Worklight Instl-Cab,W O Rops
Harness Instl-Wl,Cab,Rr
Worklight Opt-Rear,Hid
Worklight Instl-Cab,Hid
Cab-Group,2444
Suspension Instl-Cab,Rear
Asm-Cab,2444
Windshield Wash-Fluid Fill
Panel Instl-Trim,Tg
Airline Ftg Instl-Cab,Airhorn
Pedal Instl-Throttle
Console Instl-Cab
Pedal Instl-Brake,Tg (Service)
Pedal Asm-Brake,Hanging
Pedal-Brake,Hyd,Hanging
Instl-Harness,Cab,2444
Decal-Inst,Cabroof,2444
Cab Group,Cvt,Ace
Pedal Instl-Clutch
Floormat Instl-Cab,8333
Wiper Group
Wiper Motor,1 In. Shft,Lh,85
Arr-Inner Roof
Arr-Interior Trim
Arr-Horn (Air)
Arr-Audio
Antenna
Radio Accessory Kit
Arr-Outer Roof
Arr-Floormat Covers
Arr-Elec Inner Roof
Arr-Controls (Front)
Hvac Group
Hvac Unit-Autocontrol
Grip Instl Hand,Door
Seat Instl-Deluxe
Dash Instl-Center Console
Suspension Instl-Cab,Fr
Cab Asm-Cvt,Front
Door Asm
Arr-Cab Glass
Arr-Rh Window Glass
Arr Decals
Seat Asm-Deluxe,Semi Active
Kit-Seat Top, Sst
Kit-Suspension Sa
Kit-Suspension Gp (Seat)
Kit-Seat As. Upper
Kit-Arm Rest As. (Lh)
Kit-Suspension
Radio Instl-My12
Kit-Extra Key
Mirror Instl-Standard
Bracket Instl-Mirror,Lh
Bracket Instl-Mirror,Rh
Mirror Instl-Mirrors,Std,Lh
Mirror Instl-Mirrors,Std,Rh
Mirror Instl-Electrical
Mirror Instl-Mirrors,Elec,Lh
Mirror Instl-Mirrors,Elec,Rh
Instl Elec-Mir,Adjandheat
Mat-Floor, Challenger
Armrest Instl-Tg2444,Liq Dry
Asm-Armrest,Cvt,2444,Liq Dry
Joystick Asm-Cvt,Liq Dry
Instl-Switch,4wd,2444
Panel Instl-Keypad,2444
Airco And Heating System
Filter Instl-Air Intake
Filter Instl-Airinlet,Tg2444
Venturi Instl-Agitator
Tube Instl-Airfilter,Tg2444
Air Conditioning Group
A C Filter Instl-Tg2244
Hose Instl-A C
Apperance-Group
Tank Instl-Water,10l,Tg2244
Platform Instl-Fueltank,Lh
Platform Instl-Fueltank,Rh
Box Instl-Storage Battery,Tg83
Cover Asm-Batterybox,Lh,Tg8333
Cover Asm-Toolbox,Rh,Tg8333
Support Instl-Light,Traffic,Fr
Step Instl-Fuel,Tank,Rh
Support Instl-Mirror,Rh
Decal Instl-Antislip,Platform
Entrance Instl-Tg2444
Platform Instl
Stepladder Asm-Tg
Support Instl-Platform
Tunnel Instl-Hose,Tg2444
Support Instl-Filter,Air,Tg244
Bumper Instl-Tg2444
Panel Instl-Cover,Engine,2444
Panel Asm-Cover,Engine,Rh
Fender Instl-Front,2444
Fender Asm-Front,Comp,Lh,2444
Fender Asm-Front,Comp,Rh,2444
Ladder Instl-Art,Point
Panel Asm-Cover,Engine,Lh
Hood Instl-Tg2444
Hood Asm-Tg2444
Hood Asm-Pre,Tg2444
Grill Instl-Hood,Tg,Ch
Seal Instl-Hood,Tg2444
Grip Instl-Hood,Tg2444
Latch Instl-Hood,Tgx444
Decal Instl-Hood,Tg2444
Insulation Instl-Tg2444
Tire Instl-1050,3.15m,T2,Mich
Rimandtire Asm-Ch,1050 50 R32,T2
Tire Instl-1050,3.15m,M28,Mich
Rimandtire Asm-Ch,1050 50r32,M28
Tire Instl-900 60 R32,Michelin
Rimandtire Asm-900 60 R32,Rh
Rimandtire Asm-900 60 R32,Lh
Controller System
Instl-Vt,2444
Guidance System
Antenna Instl- Gps,Sgr1,Tg
Instl Harn-Ag,Roof,Tg
Instl-Antenna,Sgr-1,Tg
Bracket Gp-Housing Dome
Valve Instl-Autoguide,2444
Valve Asm-Steer,Autoguide
Pved-Valve,40l,8333
Lightbar Instl-Ld40,Tg
Autoguide Opt-Ready Kit
Sensor Instl-Art,Autog,2444
Bracket Instl-Top Dock
Instl Harness-Ag,Pved,2444
Orbitrol Instl-Autoguide
Hose Instl-Autoguide
Mli Topdock Optie-Autoguide 15
Instl-Terminal,Gx45,8333
Telemetry Opt-Ready
Telemetry Ready Asm
Telemetry Asm
Placard Instl-Reflective,Tg833
Refl Placards Asm-Lh,Workw,335
Refl Placards Asm-Rh,Workw,335
Radar Group-Common,Uk
Radar Group-Common,Eu
Towing Hook-Sk5a (Front)
Instl-Box,Tools
Recommended Dealer Stock
Pump Asm-100cc,Ccw
Pump Asm-Hyd,Ls,Nms
Cooler Instl-Tg2444
Cooler Asm
Tube Instl-Exhaust
Clamp Asm-Sliding V
Tank Instl-Def.85l
Hose Instl-Def,Tg
Fuel Line Inst
Axle Asm-Tg2444,Fr
Carrier Assembly
Housing Group
Wheel End
Wet Disc Brake
Chassis Gp-Straight
Plate Asm-Pendeling
Alarm Instl-Reverse
Hitch Instl-Tg2444
Hitch Asm-Tg2444
Control Gp-Steering
Column As.-Steering
Xmsn Asm-Cvt,Ml260
Dropbox Asm-Cvt
Hose Instl-Cvt
Testpoint Instl,Cvt
Drive System
Air System
Tank Asm-Air,40l
Tank Asm-Hydr
Tube Instl-Suction
Hose Instl-Orbitrol
Light Asm-Left
Bezel-Light,Left
Light Asm-Right
Bezel-Light,Right
Instl-Ext,Light,Tg
Instl-Relay,30a
Cab-Group,2444
Asm-Cab,2444
Panel Instl-Trim,Tg
Console Instl-Cab
Cab Group,Cvt,Ace
Pedal Instl-Clutch
Wiper Group
Arr-Inner Roof
Arr-Interior Trim
Arr-Horn (Air)
Arr-Audio
Antenna
Radio Accessory Kit
Arr-Outer Roof
Arr-Floormat Covers
Arr-Elec Inner Roof
Hvac Group
Seat Instl-Deluxe
Cab Asm-Cvt,Front
Door Asm
Arr-Cab Glass
Arr-Rh Window Glass
Arr Decals
Kit-Seat Top, Sst
Kit-Suspension Sa
Kit-Seat As. Upper
Kit-Suspension
Radio Instl-My12
Kit-Extra Key
Hose Instl-A C
Apperance-Group
Platform Instl
Stepladder Asm-Tg
Bumper Instl-Tg2444
Hood Instl-Tg2444
Hood Asm-Tg2444
Hood Asm-Pre,Tg2444
Controller System
Instl-Vt,2444
Guidance System
Pved-Valve,40l,8333
Telemetry Opt-Ready
Telemetry Ready Asm
Telemetry Asm
Instl-Box,Tools
