702,019
Challenger Terragator 835 NMS Liquid System Parts Catalog AG641679
Brand: Challenger Terragator
Type of Machine: Applicators
Model: Challenger 835 NMS Terragator Liquid System 2014
Part Number: AG641679
Publication Date: 2015
Number of Pages: 3109 Pages
Publication Information
Product Containment
Tank Opt-Polyester,16m^3,8333
Mudguard Instl,Nms
Tank Instl-Polyester,16m3
Tank Asm-Poly,16m3,Components
Breather Instl-Poly Tank
Lid Asm-Poly Tank,Brthr,Compl
Lid Asm-Poly Tank,Breather
Tank Asm-Poly,16000l,Complete
Manhole Instl-Poly Tank
Lid Asm-Poly Tank,Manhole
Level Indicator Group,Polytank
Float Asm-Adjustable.Nms
Pipe Instl-Polytank,16m3
Valve Asm-Rear,Tg3244
Valve Instl-Rear,Gate Valves
Valve Asm-Gate,6in,Air Cyl,Ind
Valve-Gate,6in
Cylinder Asm-Air,D20 80 160mm
Cylinder-Air,D20 80 160mm(6in)
Decal Inst-Striping,Lnms,8333
Support Instl-Polytank,8333
Support Asm-Tank,Front,8333
Fender Instl-Rear,Tg8333
Fender Asm-Rear,Tg8333
Bracket Instl-Breather Support
Guide Instl-Cable,Rear,8333
Guide Instl-Cable,Front,8333
Support Instl-Hose,Manure,8333
Long Load Sign Instl-9205nms
Support Asm-Tank,Rear,8333
Primary Product Distribution
Coupling Instl-Cntfgl P,10baue
Coupling Instl-Suct Arm,8.0bau
Pump Group-El1550,Lnms,Tg8333
Tube Asm-Unload,Fl1036,Tg8333
Tube Asm-Inlet,Fl1550,Tank,Nms
Pump Instl-Fl1550,Lnms
Pump Asm-El1550,Lnms
Tube Asm-Inlet,Fl1550,Tg8333
Component Asm,Manual Valve,6in
Valve Asm-Manual,6in
Valve-Stem,Gate,Flanged,Mz,6in
Bushing-Slide,Valve,6in,Mach
Pump Asm-Fl1550,Mot Hyd,75cc
Pump-Manure,El1550,Gearbox
Transducer Connection Asm
Tube Asm-Outlet,Fl1550,Lnms
Support Asm-Pump,Lnms
Pump Group-Fl1036,Tg8333
Tube Asm-Inlet,Tank,8in,Fl1036
Pump Instl-Fl1036
Pump Asm-Fl1036,Lnms
Pump Asm-Fl1036,Mot Hyd,55cc
Pump-Manure,Fl1036,Gearbox
Motor-Hyd,55cc,Incl Sensor
Tube Asm-Inlet,Fl1036,Tg8333
Tube Asm-Outlet,Fl1036,Lnms
Cutter Group-Manure,10000,835
Cutter Instl-Manure,10000,Lnms
Rc10000-Incl,Oms200cc
Motor-Hydr,Oms 200,Rc10000
Cutter Instl-Housing ,10000,Ln
Cutter Asm-Housing,10000,Lnms
Coupler Asm-Quick,Flg,Lh,6in
Valve Asm-Knife,8.0in,Superloa
Valve-Knife,Dn200
Cylinder-Hyd,D20 40 200
Valve Asm-8in,Air Cylinder
Valve-Stem,Gate,Flanged,8
Cylinder Asm-Air,D22 80 200mm
Cylinder-Air,D22 80 200mm(8in)
Tube Instl-Overflow,835,Lnms
Valve Instl-Reload,Rh,Fr,835
Arm Instl-Suction,Non,835
Arm Opt Instl-Suction,Non,835
Plug Instl,Suction,Non,8333
Plate Instl-Blind,Dn200
Adapter Instl-Ng6,Non,Suct
Hose Instl-Hyd,Borger,Std,835
Harness Instl-Loadvalve
Component Instl-Elec,Sl Sucarm
Arm Group-Suct,Hor,Std,835
Arm Opt Instl-Suct,Hor,Std,835
Arm Opt Instl-Horiz,Suct Arm
Valve Asm-Knife,10in,Superload
Valve-Knife,Dn250
Cilinder Asm-D16 25 260 395,Hc
Cylinder-Hyd,D16 25 260 395mm
Arm Instl-Suct,Hor,Std,835
Bucket Instl-Leakage,8333,Lnms
Arm Inst-Suction,Hor,Poly,835
Bearing Asm-Blk,Hitch
Bearing Asm-Block,Hitch,Tri-Ax
Arm Asm-Suction,Horizon,2244
Coupling-Turnable,8in,Painted
Rubber Asm-Harmonica,8in
Cylinder Asm-D30 50 60 180 500
Cylinder-Hyd,D30 60 180 500
Cylinder Asm-D30 50 580 895mm
Cylinder-Hyd,D30 50 580 895mm
Cylinder Asm-D25 40 150 349
Cylinder-Hyd,D25 40 150 349
Cylinder Asm-D25 40 150 349mm
Valve Inst,Ng6,Hor,Suct,Std
Valve-2 2,Nc,3 8
Hose Inst,Ng6,Hor,Suct,Std
Hose Instl-Hor Suct,Std,8333
Block Instl-Ng6,Suction Horiz
Block Asm-Ng6,Suction,Horiz
Valve-Hyd,Ng06,4 3,A-B On T
Orifice-1.5mm,Ng6
Valve-Hyd,,Ng06,4 3,Closed Cen
Orifice-1.0mm,Ng6
Orifice-1.2mm,Ng6
Harn Instl-Suction,H,Std,8333
Hose Instl-Air,Hor,Suct,Arm
Arm Group-Suct,Hor,Sl,835
Arm Opt Instl-Suct,Hor,Sl,835
Component Instl-Cntfgl Pump,Sl
Pump Asm-Centrifugal,Combiload
Flange-Impeller,Cntfgl-Pump,Sl
Motor Asm-Hyd,100cc
Motor-Hyd,100cc,Side Ports
Ring Sprt Instl-Rbr Superld
Cutter-Modif,Manure,Sl,8333
Valve Inst-Cutter,Superload
Ng16 Instl-Hyd,X244lnms
Ng16 Asm-Hyd,X244lnms
Valve-Hyd,Ng16,Ptoa,Ttob
Component Instl-Hydr,Sl,Tg8333
Component Asm-Hydr,Sl,Tg8333
Hose Instl-Hyd,Sl,Hor Arm,8333
Blockade Instl-Flush,Motor,Cl
Hose Instl-Hyd,Sl,Std,835
Harness Instl-Sl
Decal Instl-Superload,Lnms
Arm Group-Suct,Vert,Cl,835
Arm Instl-Suct,Vert,Std,835
Hinge Instl-Hose 10in,Sl,Vert
Cylinder Asm-Swing,Hose,Sl,Ver
Cylinder-Hyd,D25 40 340 600mm
Cylinder Asm-Piv,Hose,10in,Sl
Cylinder-Hyd,D25 50 125 354mmm
Hose Instl-10in,Sl,Ver
Arm Instl-Suction,Vert,Tg835
Arm Asm-Suction,Vert,Tg835
Valve Asm-Knive,8in,Snsrs,Pneu
Cylinder Asm-Lift,Vert,Arm
Cylinder-Hyd Lift,Vert Arm
End-Rod,M30x2.0,Gir30do 2rs
Valve Instl-Cyl,Vert Arm.Tg8x5
Valve Asm-Ng6,Cyl,Vert Arm
Valve-Pres Relief,A+B On T,Ng6
Hose Instl-Cyl,Vert Arm,835
Harness Instl-Ver Arm,Tg835
Hose Instl-Air,Suc Arm,Ver
Arm Opt Instl-Suct,Vert,Cl,835
Pump Instl-Cntfgl,Manure,Ver
Pump Asm-Centrifugal,Superload
Sensor Instl-Pressure,Manure
Manifold Instl-Combiload
Manifold Asm-Combiload
Hose Instl-Hyd,Combiload,835
Sensor Instl-Pressure,Cl,Tg835
Harness Instl-Cl
Arm Group-Suct,Vert,Std,835
Arm Opt Instl-Suct,Ver,Std,835
Arm Opt Instl-Suction,Std,Vert
Tube Instl-Suction,Std,Vert
Component Asm-Manual,Valve,6in
Coupler-Quick,Left Front,6in
1hydraulic System
Bracket Instl-Clr,Axle,1550
Valve Instl-Hyd,Extra,Open,Hor
Valve Asm-Hyd,Extra,Open,Nms
Hose Instl-Function Opt,Extra
Function Opt-Hyd,Extra,Closed
Valve Instl-Hyd,Ext,Closed,Hor
Valve Asm-Hyd,Extra,Closed,Nms
Comp Instl-Hyd,Func,Extra,Std
Hydraulic Group,835,Lnms,My14
Comp Group-Syst,Std,835,Lnms
Valve Instl-Cutter,Std,Tgx244
Valve Asm-Cutter,Std,Tgx244
Unit Instl-Hyd Pn El,8333,Lnms
Unit Asm-Hyd Pn El,X244,Lnms
Casing Asm-Hyd,Tgx244,Lnms
Manf Instl-Std,Hyd,X244,Lnms
Manf Asm-Std,Hyd,Tgx244,Lnms
Block-Hydr,Hic,Tg9205
Manifold-Nms,Hicb(Rev 07)
Manifold-Nms,Danfoss
Manf Instl-Leakage,8333,Lnms
Manf Asm-Leak,Tgx244,Lnms
Plumb Group-Syst,Std,835,Lnms
Plumb Instl-Cutter,8333,Lnms
Plumb Instl-Knife Valve,Lnms
Plumbing Instl-Hitch,Lnms
Plumb Instl-Hyd,Tank
Plumb Instl-System,835,Lnms
Pump Asm-100cc,Ccw
Pump-Hydr,100cc,H1,Ccw
Cylinder Asm-D50 100 230 510
Cylinder-Hyd,50 100 230 510mm
1electrical System
Lamp Instl-Rotating,Tank,Nms
Electric Group,835,Lnms
Instl-Switch,Hitch,Reduce
Harness Instl-System,Tg835
Harness Instl-Light,Tail,Tg835
Unit Asm-Light,Lh
Light-Pendel,Diagonal
Unit Asm-Light,Rh
Tread Instl-Safety,Lnms
Harness Instl-Hyd Unit,Tg835
1air System
Air Component Opt-Nms
Valve Asm-Air,Tg835,Lnms
1decals
Decal Instl-Chassis,Tg835
Refl Instl-Tg835,Lnms
Sign Instl-Slow,Traffic
Decal Instl-Tg835,Lnms
Decal-Joystick,Lnms,Tg8333
1attachments
Plate Instl-Bulkhead,Hitch,Nms
Plate Asm-Bulkhead,Hitch,Nms
Coupler Opt-Multi,Hyd,Chassis
Coupler Asm-Multi,Hyd,Chassis
Spare Parts-Tg Nms,Cvt
Adapter-Gauge,Meas Point
Hitch Instl-Cat Iv,Tg835
Hitch Asm-Cat Iv,Tg835
Hitch Instl-Cat Iv,Tg8x5
Spring Asm-Pull,Hitch
Link Asm-Lift,2444
Plate-Locking Pin,Liftlink
Link Asm-Lower,Cat Iv,2444
Arm Asm-Hitch,Tg8x5
Bulkhead Asm-Hitch,Tg8x5
Link-Top,Catiii,1 3 4unc,672mm
Plate Asm-Hitch,Cat Iv.Tg835
1accessories
Nozzle Instl-Discharge
Spreader-Nutrient,Perfect
Worklight Opt-Hor Suct Arm
Light Asm-Work.Dual.Brckt
Kit-Coupler,Hyd,Iso,Loose
Funnel-Asm-Suction,8inch
Towing Hook Opt-Hitch
Kit-Sensor,M12, Extend,10m
Bulkhead Asm-Drawbar
Drawbar Instl-Hitch
Link-Top,Cat3,1 1 2 In. Unc,750mm
Connection Opt-Power,Impl
Funnel Opt-Suction,10inch
Worklight Opt-Vert Suct Arm
Kit-Coupler,Hyd,Iso,Loose,Ex
Function Opt-Hyd,Extra,Open
Comp Instl-Elec,Hyd,Func,Opt
Valve Instl-Hyd,Extra,Open,Ver
Box Opt-Leakage,Vert Suct Arm
Worklight Opt-Lnms,Rear,Hal
Worklight Opt-Lnms,Rear,Hid
Light Asm-Work,Hid,Dual,Brckt
Coupler Opt-Multi,Hyd,Toolbar
Connection Opt-Air V,Injector
Kit-Coupler,Air,Loose
Camera Monitor Option,Color
Camera Instl-Rear,Lnms
Monitor Instl-Rear Camera
Cable-Instl,Monitor,Motec,Tg
Cable-Instl,Camera,Motec,Lnms
Link Instl-Lower,Quick, Cat Ii
Link Asm-Lower,Qik,Catiii,Rh
Link Asm-Lower,Qik,Catiii,Lh
Link Instl-Lower,Quick,Cat Iv
Link Asm-Lower,Qik,Cativ,Lh
Link Instl-Lower,Cat Iii
Link Asm-Lower,Catiii
Glass Instl-Sight,Tank,Tg8333
Specs-Nl,Tg835,Lnms,My14
Country Instl-Lnms,Tg835,Nl
Cust-Doc,Tg835,Chassis,Nl,My14
Cust-Doc,Tg835,Lnms,Nl,My14
Specs-Ger,Tg835,Lnms,My14
Country Instl-Lnms,Tg835,Ger
Wedge Gp Instl-Wheel,Tg8333
Cust-Doc,Tg835,Chassis,Ger,My1
Cust-Doc,Tg835,Lnms,Ger,My14
Specs-Bel,Tg835,Lnms,My14
Country Instl-Lnms,Tg835,Be
Guide Instl-Cable,Fender,8333
Ledlight Instl-Tg835,Lnms
Specs Opt-Bel,Nl,835,Lnms,My14
Specs Opt-Bel,Fr,835,Lnms,My14
Cust-Doc,Tg835,Chassis,Fr,My14
Cust-Doc,Tg835,Lnms,Fr,My14
Specs-Fr,Tg835,Lnms,My14
Country Instl-Lnms,Tg835,Fr
Specs-It,Tg835,Lnms,My14
Country Instl-Lnms,Tg835,It
Cust-Doc,Tg835,Chassis,It,My14
Cust-Doc,Tg835,Lnms,It,My14
Specs-Uk,Tg835,Lnms,My14
Cust-Doc,Tg835,Chassis,Uk,My14
Cust-Doc,Tg835,Lnms,Uk,My14
Valve-Reload,Lh,Fr,835
Coupler Asm-Quick,Hitch,Catiii
Coupler Asm-Quick,Vh,Ej35840
Coupler Asm-Quick,Vh,Tj644
Coupler Asm-Quick,Toolbar
Hose Asm-Suction,6.0in,2244
Hose Asm-Extension,6.0in,2244
Hose Asm-Supply Tank,6.0in,224
