Challenger Terragator 835 Chassis Parts Catalog AG641813
Brand: Challenger Terragator
Type of Machine: Applicators
Model: Challenger 835 Terragator Chassis 2014
Serial Number: ..EW001001-..EW001004
Part Number: AG641813
Number of Pages: 1651 Pages
Publication Information
Engine Fuel And Exhaust System
Engine Instl-Sisu,84cta,330hp
Engine Asm-Ap,8.4,330hp,T4f
Gearbox Instl-Pumpdiverter
Box-Pump Diverter,Gear,Tg8333
Engine Pre Asm-Sisu,Stage 4
Bracket Instl-Engine,8.4,T4f
Dipstick Instl-Engine,3whl
Pump Instl-Hyd,Ls,63cc
Pump Asm-Hyd,Ls,Nms
Pump Instl-Fwd,3whl
Pump Asm-Fwd,3whl
Pump-Hydr,78cc,H1,Ccw Fwd
Engine Instl-Sisu,84awf,330hp
Hose Instl-Heating,Cab,Tg835
Gear Housing
Flywheel House
Valve Mechanism
Inlet Manifold
Exhaust Manifold
Hp Turbo
Lp Turbo+Icac
Egr Parts
Oil Sump
Crankcase Ventilation
Piping Of Coolant
Coolant Pump
Fuel Pump
Eem Parts
Starter Motor
Drive Device
Compressor
Scr Parts
Engine Overhaul Parts
Cooler Gp-Stage4, Tg835
Tube Instl-Cac,X33
Cooler Instl-Stage 4
Cooler Asm- Stage4
Faster Asm-Trun,Quarter
Air Instl-False,Anti
Tube Instl-Water,Cooler
Tank Instl-Clg,Water,
Exhaust Instl-Tg835
Tube Instl-Exhaust,Tg835
Sensor Instl-Nox,Doc
Def Instl- Tg835, Adblue Comp
Dosing Module Instl-Def,Stage4
Hose Instl-Def,Tg
Pump Instl-Dosage,Def,Stage4
Tank Instl-Def,85l
Def-Tank,Stage3b,85ll
Air Intake Group, X33
Filter Instl-Air,Tg835
Tube Instl- Airintake,X33
Tank Instl-Fuel,600l
Tank Asm-Fuel,Rh (65gl)
Cap Instl-Fuel,Lockable
Tank Asm-Fuel,Tank,379l,Rh
Fuel Line Instl-Tg835
Axle Instl-Tg835
Axle Asm-Tg835
Axle-Rear,24.66 1,Wet Disk
Caliper-Brake,Knott,4x79.3
Brake-Park,Knott,Fsg110
Axle-Rear,24.66 1, Wet Disk
Carrier Assembly
Housing Group
Wheel End
Wet Disc Brake
Cooler Instl-Axle,Rr
Cooler Asm-Axle
Cooler-Hydr,Tt07,Axle
Valve Instl-Flw Reg,Clr,Axle
Valve-2 2,Nc,Esteer,Rg6x5
Frame And Suspension
Chassis Group-Std,Tg835,T4f
Fork Instl-Front,8333
Fork Asm-Front,Tg8333
Block-Divider,Grease,4sect
Gearbox Asm-Fwd,Tg8333
Motor Asm-Hyd,Fwd,Tg8333
Cylinder Asm-Steering
Cylinder-Hyd,35 70 480 756mm
Lubrication Instl-Blck,Str Cyl
Alarm Instl-Reverse
Control Gp-Steering
Orbitrol Instl-Steering
Orbitrol Asm-Steering
Hose Instl-Steering Sys
Transmission Instl-Cvt,Ml260
Transmission Instl-Cvt,Isolato
Xmsn Asm-Cvt,Ml260
Transmission-Cvt,Ml260
Gearbox-Housing
Oil Level Indicator
Inner Housing
Planetary Drive
Pump Shaft
Accumulator Shaft
Range Shaft
Hydr. Motor
Duct Plate
Adjusting Device
Pipelines
Group Gear Shifting
Shifting
Pump Drive
Lube Oil Pump
Pump Installation
Gear Box Lubrication Filters
Valve Unit
Front Wheel Drive Constant
Electrical System Transmitter
Electrical System Control
Drive System
Driveline Instl-Rear,Cvt,Axle
Driveline Asm-Cvt,Axle,8.5c
Driveline Instl-Cvt,Engine
Driveline-8.5c Engine To Trans
Pedal Instl-Brake,Tg (Service)
Pedal Asm-Brake,Hanging
Pedal-Brake,Hyd,Hanging
Bracket Instl-Stop,Pedal,Brak
Air System
Air Group-Chassis,Tg835
Chain Instl-Debreath,Tank,Air
Tank Instl-Air,42l,Tg
Tank Asm-Air,40l
Tank Asm-Air,20l,Front (Wet)
Tank Asm-Air,20l,Rear (Dry)
Hose Instl-Air,Standaard,3whl
Dryer Instl-Air,Single Caniste
Tank Instl-Air,Regeneration
Tank Asm-Air, Regeneration
Dryer Instl-Air,Sgl Canister
Dryer Asm-Air,Sgl Canister
Dryer-Air,Sgl Canister,12v
Cable Instl-Adapt,Airdryer,Sgl
Hose Instl-Air,Sys,Dryer,Sngl
Dryer Inst-Air,Double,Canister
Dryer Instl-Air,Dbl Canister
Dryer Asm-Air,Dbl Canister
Cooler Instl-Air,700l
Hose Instl-Air,Sys,Dryer,Dbl
Hose Instl-Clr,Axle,Chassis
Tank Instl-Hydr,Tg835
Tank Asm-Hydr
Cap-Hyd Tank,Breather,Argo
Hydraulic Gp-Tg835
Instl-Swivel, Hydraulic-Fwd
Cooler Instl-Oil
Cooler Asm-Tg8133
Manifold Asm-Return Oil,Clr
Manifold-Return,Tg
Accumulator Instl-2.0l,Metric
Hose Instl-Hyd,Chassis,Tg835
Hose Instl-Hyd,Nose,Tg8333
Hose Instl-Hyd,Cvt,Cooler
Hose Instl-Brake Sys
Hose Instl-Fwd,835
Hose Instl-Priority Valve,835
Hose Instl-Suction,Pumps,Hyd
Valve Instl-Divertion,Oil,Brak
Valve Asm-Divertion,Oil,Brake
Tube Instl-Hyd,Fwd
Valve Instl-Priority,150l Min
Valve Asm-Priority,150l Min
Valve-Priority,150l Min,Safim
Manifold Instl-Fwd,3whl
Manifold-Fwd,Tg835 Wandfluh
Manifold Instl-Suction
Manifold Asm-Suction
Instl-Harness,Cab,2444
Electric Group
Switch Instl-Magnetic
Battery Instl-Tg8333
Breaker Instl-Junction Block
Light Instl-Traffic,Tg8333
Headlamp Asm-Halogen,Lh
Headlamp Asm-Halogen,Rh
Module Instl-High,Current
Node Instl-Micro,Esx
Instl-Ext,Light,Tg
Sensor Instl-Temp,Ambient
Plate Instl-Comp,Elec,Stage4
Harness Instl-Chassis,Tg835
Instl-Elec,Axle,Cooling,Tg835
Worklight Opt-Front,Std
Lamp Instl-Rotating,Lh,Front
Lamp Instl-Rotating,Rh,Front
Worklight Instl-Nose,Hal
Light Asm-Left
Light-Halogeen,Short Range
Bezel-Light,Left
Light-Halogeen,Long Range
Light Asm-Right
Bezel-Light,Right
Worklight Instl-Nose,Hid
Light-Asm-Left,Hid
Light Asm-Right,Hid
Cab Group-Tg835
Suspension Instl-Cab,Rear
Suspension Instl-Cab,Fr
Asm-Cab,Tg835
Panel Instl-Trim,Tg
Airline Ftg Instl-Cab,Airhorn
Pedal Instl-Throttle
Console Instl-Cab
Isolation Instl-Sound,Cab
Cab Group,Cvt,Ace
Pedal Instl-Clutch
Floormat Instl-Cab,8333
Wiper Group
Arr-Inner Roof
Arr-Interior Trim
Arr-Horn(Air)
Hvac Group
Arr-Audio
Arr-Outer Roof
Arr-Floormats Covers
Arr-Elec Inner Roof
Arr-Controls (Front)
Seat Instl-Deluxe
Dash Instl-Center Console
Decal-Inst,Cabroof,835
Cab Asm-Terragator
Arr-Door Installation
Arr-Door Asm
Arr-Door Glass
Radio Instl-Europa
Kit-Extra Key,Terragator
Mirror Instl-Standard
Bracket Asm,Mirror,Lh
Bracket Asm,Mirror,Rh
Mirror Instl-Elec Positioning
Mirror Instl-Mirrors,Elec,Lh
Mirror-Adjustable,Heat,12v
Mirror Instl-Mirrors,Elec,Rh
Instl Elec-Mir,Adjandheat
Bracket Instl-Stnd,Mir,Lh
Bracket Asm-Mirror,Lh
Bracket Instl-Stnd,Mir,Rh
Bracket Asm-Mirror,Rh
Instl-Plate,Mirror,Elec
Armrest Instl-Tg2444,Liq Dry
Asm-Armrest,Cvt,2444,Liq Dry
Joystick Asm-Cvt,Liq Dry
Instl-Switch,4wd,2444
Panel Instl-Keypad,2444
Bush Instl-Retainer,Mir,Rh
Airco And Heating System
Airco Group-Tg835
A C Filter Instl-Tg2244
Compressor Instl-Airco,Tg
Hose Instl-A C,835
Appereance-Group,Tg835
Tank Instl-Water,10l,Tg2244
Entrance Instl-Tg835
Entrance Asm-Tg835
Ladder Asm-Entrance
Platform Instl-Fueltank,Rh
Step Instl-Fuel,Tank,Lh
Step Asm-Fuel,Tank
Box Instl-Storage Battery,Tg83
Cover Asm-Batterybox,Lh,Tg8333
Cover Asm-Toolbox,Rh,Tg8333
Frame Instl-Exhaust,Airfilter
Platform Instl-Def Tank,Tg835
Bracket Instl-Guide,Hose,Cable
Bracket Instl-Shield,Heat,Aio
Platform Instl-Fueltank,Lh
Step Instl-Fuel,Tank,Rh
Frontplate Instl-Tg835
Frontplate Asm-Tg835
Hatch Instl,Cac,Access
Hood Instl-Tg835
Hood Asm-Tg835
Tire Instl-1050,184,Mich,Front
Rimandtire Asm-1050,184,Front
Tire Instl-1050 50r32,M28,Mich
Wheel Asm-Front,M28
Tire Instl-1050,3.35m,184,Tg83
Rimandtire Asm-1050,3.35m,184,Rh
Rimandtire Asm-1050,3.35m,184,Lh
Tire Instl-1050 50 R32,M28,Mic
Rimandtire Asm-Ch,1050,3.35m,M28
Tire Instl-1050,3.15m,184,Tg83
Rimandtire Asm-1050,3.15m,184,Rh
Rimandtire Asm-1050,3.15m,184,Lh
Tire Instl-1050 50 R32,M28, Mi
Rimandtire Asm-Ch,1050 50r32,M28
Controller System
Instl-Vt,2444
Guidance System
Op-Man,Grp,Ag150,Sys,F I,Nl
Op-Man,Grp,Ag150,Sys,F I,Ger
Op-Man,Grp,Ag150,Sys,F I,Fr
Op-Man,Grp,Ag150,Sys,F I,Dk
Telemetry Opt-Ready
Telemetry Asm
Op-Man,Grp,Telementry,Sys,Nl
Op-Man,Grp,Telementry,Sys,Ger
Op-Man,Grp,Telementry,Sys,Fr
Op-Man,Grp,Telementry,Sys,En
Op-Man,Grp,Telementry,Sys,Dk
Instl-Topdock,Agi4,Tg
Agcommant Hardware Grp F A
Op-Man,Grp,Ag150,Sys,F I,En
Instl-Sgr-1,Tg
Instl-Antenna,Sgr-1,Tg
Instl Harn-Ag,Roof,Tg
Bracket Gp-Housing Dome
Terminal Instl-Gx45
Instl-Ag,Ready,Tg835
Bracket Instl-Top Dock
Sensor Instl-Art,Autog,8333
Orbitrol Instl-Autoguide,Tg835
Elec Instl-Autoguide,Tg835
Valve Instl-Autoguide
Valve Asm-Steer,Autoguide
Pved-Valve,40l,8333
Hose Instl-Autoguide,835
Terminal Instl-C3000,Tg
Op-Man,Grp,Ag350,Sys,F I,Nl
Op-Man,Grp,Ag350,Sys,F I,De
Op-Man,Grp,Ag350,Sys,F I,Fr
Op-Man,Grp,Ag350,Sys,F I,En
Op-Man,Grp,Ag350,Sys,F I,Dk
Placard Instl-Reflective,Tg833
Refl Placards Asm-Lh,Workw,335
Refl Placards Asm-Rh,Workw,335
Refl Placards Asm-Lh,Workw,315
Refl Placards Asm-Rh,Workw,315
Radar Group-Common
Radar Group-Common,Uk
Worklight Opt-Front,Rev,Hal
Worklight Opt-Front,Rev,Hid
Worklight-Opt,Cab(Floodlight)
Worklight Opt-Cab,Hid,Fr
Worklight Opt-Rear, W O Rops
Worklight Instl-Cab,W O Rops
Harness Instl-Wl,Cab,Rr
Worklight Opt-Rear,Hid
Worklight Instl-Cab,Hid
Instl-Box,Tools
Wrench-Wheel,Mtg,Set
Mat-Floor, Challenger
Lightbar Instl-Ld40,Tg
Filter Instl-Bio,Diesel,Tg8333
Recommended Dealer List
Maintenance-Service,100hour
Pump Asm-Hyd,Ls,Nms
Pump Instl-Fwd,3whl
Pump Asm-Fwd,3whl
Gear Housing
Flywheel House
Valve Mechanism
Inlet Manifold
Exhaust Manifold
Hp Turbo
Lp Turbo+Icac
Egr Parts
Oil Sump
Piping Of Coolant
Coolant Pump
Fuel Pump
Eem Parts
Starter Motor
Drive Device
Compressor
Scr Parts
Tube Instl-Cac,X33
Cooler Asm- Stage4
Exhaust Instl-Tg835
Hose Instl-Def,Tg
Tank Instl-Def,85l
Axle Instl-Tg835
Axle Asm-Tg835
Carrier Assembly
Housing Group
Wheel End
Wet Disc Brake
Cooler Asm-Axle
Alarm Instl-Reverse
Control Gp-Steering
Xmsn Asm-Cvt,Ml260
Gearbox-Housing
Oil Level Indicator
Inner Housing
Planetary Drive
Pump Shaft
Accumulator Shaft
Range Shaft
Hydr. Motor
Duct Plate
Adjusting Device
Pipelines
Group Gear Shifting
Shifting
Pump Drive
Lube Oil Pump
Pump Installation
Valve Unit
Drive System
Air System
Tank Asm-Air,40l
Tank Asm-Hydr
Hydraulic Gp-Tg835
Cooler Instl-Oil
Cooler Asm-Tg8133
Manifold-Return,Tg
Hose Instl-Fwd,835
Tube Instl-Hyd,Fwd
Electric Group
Instl-Ext,Light,Tg
Light Asm-Left
Bezel-Light,Left
Light Asm-Right
Bezel-Light,Right
Light-Asm-Left,Hid
Light Asm-Right,Hid
Cab Group-Tg835
Asm-Cab,Tg835
Panel Instl-Trim,Tg
Console Instl-Cab
Cab Group,Cvt,Ace
Pedal Instl-Clutch
Wiper Group
Arr-Inner Roof
Arr-Interior Trim
Arr-Horn(Air)
Hvac Group
Arr-Audio
Arr-Outer Roof
Arr-Elec Inner Roof
Seat Instl-Deluxe
Cab Asm-Terragator
Arr-Door Asm
Arr-Door Glass
Radio Instl-Europa
Airco Group-Tg835
Hose Instl-A C,835
Entrance Asm-Tg835
Ladder Asm-Entrance
Step Asm-Fuel,Tank
Hood Instl-Tg835
Hood Asm-Tg835
Wheel Asm-Front,M28
Controller System
Instl-Vt,2444
Guidance System
Telemetry Opt-Ready
Telemetry Asm
Instl-Sgr-1,Tg
Terminal Instl-Gx45
Pved-Valve,40l,8333
Radar Group-Common
Instl-Box,Tools
