Challenger Terragator 8333 NMS Liquid System Parts Catalog AG636852
Brand: Challenger Terragator
Type of Machine: Applicators
Model: Challenger 8333 NMS Terragator Liquid System (2011)
Part Number: AG636852
Publication Date: 2012
Number of Pages: 1993 Pages
Publication Information
Hydraulic Group
Valve Instl-Cutter,Std,Tgx244
Valve Asm-Cutter,Std,Tgx244
Valve-Hyd,,Ng06,4 3,A-B On T
Unit Instl-Hyd Pn El,8333,Lnms
Casing Asm-Hyd,Tgx244,Lnms
Manf Instl-Std,Hyd,X244,Lnms
Manf Asm-Std,Hyd,Tgx244,Lnms
Block-Hydr,Hic,Tg9205
Manifold-Nms,Hicb(Rev 07)
Manifold-Nms,Danfoss
Filter Instl-Pres,Tg8333,Lnms
Filter Asm-Pres,Lnms
Filter-Pressure,Argo,Hd172-166
Manf Instl-Leakage,8333,Lnms
Manf Asm-Leak,Tgx244,Lnms
Plumb Instl-Cutter,8333,Lnms
Plumb Instl-Knife Valve,Lnms
Plumb Instl-System,8333,Lnms
Plumbing Instl-Hitch,Lnms
Hose Instl-Hyd,Hp,Std,Chas
Hose Instl-Hyd,Ls,Std,Chas
Electrical Group
Hitch-Reduce,Instl,Switch
Harness Instl-Hyd Unit,X244
Harness Instl-Lght,Tail,8333
Box Asm-Light,Tg Nms,Left
Box Asm-Light,Tg Nms,Right
Light-Pendel,Diagonal
Harness Instl-Main,System,8333
Air System Group
Air Component Opt-Nms
Valve Asm-Air,X244,Lnms
Hitch Group
Hitch Instl,Cat Iv,Tg8333
Hitch Asm-9205nms
Plate Asm-Hitch,9205
Component Instl-Hitch
Arm Asm-Hitch,Tg
Bearing Asm-Blk,Hitch
Bearing Asm-Block,Hitch,Tri-Axer
Bulkhead Asm-Hitch,9205nms
Link Asm-Lift,Long
Cylinder Asm-D50 100 230 510
Link Asm-Lower,Cat Iv,My07
Spring Asm-Pull,Hitch
Link-Top,Cat3,1 1 2 In. Unc,875mm
Coupler Opt-Multi,Hyd,Chassis
Coupler Asm-Multi,Hyd,Chassis
Coupler Opt-Multi,Hyd,Toolbar
Plate Instl-Bulkhead,Hitch,Nms
Plate Asm-Bulkhead,Hitch,Nms
Kit-Coupler,Hyd,Iso,Loose
Link Instl-Lower,Quick,Cat Iii
Link Asm-Lower,Qik,Cat Iii,Lh
Link Asm-Lower,Qik,Cat Iii,Rh
Link Instl-Lower,Quick,Cat Iv
Link Asm-Lower,Qik,Cat Iv,Lh
Link Asm-Lower,Qik,Cat Iv,Rh
Link Instl-Lower,Cat Iii
Link Asm-Lower,Cat Iii-Iv
System Group
Mudguard Instl,Nms
Long Load Sign Instl-9205nms
Tank Instl-Polyester,16m3
Tank Asm-Poly,16m3,Components
Breather Instl-Poly Tank
Lid Asm-Poly Tank,Brthr,Compl
Lid Asm-Poly Tank,Breather
Tank Asm-Poly,16000l,Complete
Pipe Instl-Polytank,16m3
Valve Asm-Rear,Tg3244
Valve Instl-Rear,Gate Valves
Valve Asm-Gate,6in,Air Cyl,Ind
Valve-Gate,6in
Cylinder Asm-Air,D20 80 160mm
Cylinder-Air,D20 80 160mm(6in)
Manhole Instl-Poly Tank
Lid Asm-Poly Tank,Manhole
Decal Inst-Striping,Lnms,8333
Level Indicator Group,Polytank
Float Asm-Adjustable.Nms
Step Instl-Poly Tank
Support Instl-Step,Poly Tank
Support Instl-Hose,Manure,8333
Support Instl-Polytank,8333
Fender Instl-Rear,Tg8333
Fender Asm-Rear,Tg8333
Support Asm-Tank,Rear,8333
Bracket Instl-Breather Support
Guide Instl-Cable,Rear,8333
Guide Instl-Cable,Front,8333
Suction Arm Group
Arm Instl-Suction,Non,8333
Hose Instl-Hyd,Borger,Std,8333
Cutter-Modif,Manure,Std,8333
Plug Instl,Suction,Non,8333
Arm Instl-Suction,Hor,Std,8333
Valve Inst,Ng6,Hor,Suct,Std
Valve-2 2,Nc,3 8
Arm Inst-Suction,Hor,Poly,8333
Arm Asm-Suction,Horizon,2244
Cylinder Asm-D30 50 60 180 500
Cylinder-Hyd,D30 60 180 500
Cylinder Asm-D30 50 580 895mm
Cylinder-Hyd,D30 50 580 895mm
Cylinder Asm-D25 40 150 349
Cylinder-Hyd,D25 40 150 349
Cylinder Asm-D25 40 150 349mm
Rubber Asm-Harmonica,8in
Coupling-Turnable,8in
Bucket Instl-Leakage,8333,Lnms
Component Instl-Elec,Sl Sucarm
Hose Inst,Ng6,Hor,Suct,Std
Hose Instl-Hor Suct,Std,8333
Harn Instl-Suction,H,Std,8333
Block Instl-Ng6,Suction Horiz
Block Asm-Ng6,Suction,Horiz
Valve-Hyd,,Ng06,4 3,Closed Centre
Orifice-1.0mm,Ng6
Orifice-1.5mm,Ng6
Orifice-1.2mm,Ng6
Arm Opt Instl-Horiz,Suct Arm
Valve Asm-Knife,10in,Superload
Valve-Knife,Dn250
Cylinder Asm-D16 25 260 395,Hc
Cylinder-Hyd,D16 25 260 395mm
Coupling Instl-Suct Arm,8.0bau
Funnel-Asm-Suction,8inch
Adaptation-Superload.Lnms,8333
Valve Inst-Cutter,Superload
Component Instl-Cntfgl Pump,Sl
Pump Asm-Centrifugal,Combiload
Motor Asm-Hyd,100cc
Motor-Hyd,100cc,Side Ports
Ring Sprt Instl-Rbr Superld
Ng16 Instl-Hyd,X244lnms
Ng16 Asm-Hyd,X244lnms
Valve-Hyd,Ng16,Ptoa,Ttob
Decal Instl-Superload,Lnms
Cutter-Modif,Manure,Sl,8333
Valve Asm-Knife,8.0in,Superload
Valve-Knife,Dn200
Cylinder-Hyd,D20 40 200
Harness Instl-Sl
Hose Instl-Hyd,Sl,Hor Arm,8333
Coupling Instl-Cntfgl P,10baue
Funnel Opt-Suction,10inch
Arm Instl-Suct,Hor,Standard,Lg
Tube Instl-Rising,Suc,Arm,Lg
Tube Asm-Rising,Suc Arm,Lg
Motor Asm-Hyd,Suc Arm,Hor,Lg
Arm Instl-Hor,Suct Hor,Lg
Arm Asm-Suction,Horizontal,Lg
Valve Asm-8in,Air Cylinder
Cylinder Asm-Air,D22 80 200mm
Cylinder-Air,D22 80 200mm(8in)
Valve-Stem,Gate,Flanged,8
Cylinder Asm-Lift,Suc Arm,Hor
Cylinder-Hyd,D25 50 200 446mm
Cylinder Asm-Lift2,Suc Arm,Hor
Support Instl-Suc Arm,Lg
Bucket Instl-Leakage,8333lnms
Valve Instl-Cyl,Hor Arm.Lg
Valve Asm-Ng6,Cyl,Hor Arm,Lg
Valve-Pres Relief,A+B On T,Ng6
Hose Instl-Hyd,Suc Arm,Hor,Lg
Hose Instl-Air,Suc Arm,Hor,Lg
Harness Instl-Hor Arm,Lg
Arm Instl-Suction,Vert,8333,Sl
Hinge Instl-Hose 10in,Sl,Vert
Cylinder Asm-Swing,Hose,Sl,Ver
Cylinder-Hyd,D25 40 340 600mm
Cylinder Asm-Piv,Hose,10in,Sl
Cylinder-Hyd,D25 50 125 354mmm
Pump Instl-Cntfgl,Manure,Ver
Pump Asm-Centrifugal,Superload
Hose Instl-10in,Sl,Ver
Hose Instl-Cyl,Vert Suction Arm
Harness Instl-Ver Arm
Hose Instl-Air,Suc Arm,Ver
Hose Instl-Hyd,Combiload
Valve Inst-2 2,Combiload
Valve Asm-2 2,Combiload
Sensor Instl-Pressure,Manure
Blockade Instl-Flush,Motor,Cl
Harness Instl-Cl
Arm Instl-Suction,Ver,15m^3
Cylinder Asm-Lift,Vert,Arm
Arm Asm-Suction,Ver,15m^3
Valve Instl-Ng6,Cyl,Vert Arm
Valve Asm-Ng6,Cyl,Vert Arm
Box Opt-Leakage,Vert Suct Arm
Arm Instl-Suct,Vert,Std,8333
Hose Instl-8in,Std,Vert
Tube Instl-Suction,Std,Vert
Manure Pump Group
Tube Asm-Unload,Fl1036,Tg8333
Pump Instl-Fl1036,Tg8333,Lnms
Pump Asm-Fl1036,Lnms
Pump Asm-Fl1036,Mot Hyd,55cc
Transducer Connection Asm
Tube Asm-Pressure Transducer
Motor-Hyd,55cc,Incl Sensor
Pump-Manure,Fl1036,Gearbox
Support Asm-Pump,Tg8333,Lnms
Tube Asm-Outlet,Fl1036,Tg8333
Tube Asm-Inlet,Fl1036,Tg8333
Component Asm,Manual Valve,6in
Valve Asm-Manual,6in
Valve-Stem,Gate,Flanged,Mz,6in
Tube Asm-Inlet,Tank,8in,Fl1036
Pump Instl-Fl1036
Tube Asm-Outlet,Fl1036,Lnms
Pump Instl-Fl1550,Lnms
Pump Asm-El1550,Lnms
Tube Asm-Outlet,Fl1550,Lnms
Tube Asm-Inlet,Fl1550,Tg8333
Pump Asm-Fl1550,Mot Hyd,75cc
Pump-Manure,El1550,Gearbox
Tube Asm-Inlet,Fl1550,Tank,Nms
Manure Filter Group
Cutter Instl-Housing,10000,Lnms
Cutter Asm-Manure,10000,Lnms
Coupler Asm-Quick,Flg,Lh,6in
Tube Instl-Overflow,8333,Lnms
Cutter Instl-Manure,10000,Lnms
Bolt-Eye,M10x35
Rc10000-Incl,Oms200cc
Motor-Hydr,Oms 200,Rc10000
Valve Instl-Reload,Rh
Cutter Instl-Housing ,10000,Lnms
Cutter Asm-Housing,10000,Lnms
Spare Parts
Spare Parts-Tg Nms
Adapter-Gauge,Meas Point
Specifications By Country Group
Specification-Nl,Tg8333,Lnms
Cust Docs-8333,Lnms,Nl
Decal-Install,8333,Lnms
Decal-Joystick,Lnms,Tg8333
Country-Instl,Lnms,Tg8333,Nl
Refl Instl-Tg8333,Lnms
Instal,Sign-Slow,Traffic,
Specification-Bel,Tg8333,Lnms
Country-Instl,Lnms,Tg8333,Be
Guide Instl-Cable,Fender,8333
Ledlight Instl-Tg8333,Lnms
Specification-Ger,Tg8333,Lnms
Cust Docs-8333,Lnms,Ger
Country-Instl,Lnms,Tg8333,Ger
Wedge Gp Instl-Wheel,Tg8333
Specification-Fr,Tg8333,Lnms
Country-Instl,Lnms,Tg8333,Fr
Specification-Uk,Tg8333,Lnms
Cust Docs-8333,Lnms,Uk
Country-Instl,Lnms,Tg8333,Uk
Specification-It,Tg8333,Lnms
Country-Instl,Lnms,Tg8333,It
Long Load Sign Instl-Large
Rotating Lamp System
Lamp Instl-Rotating,Tank,Nms
Options Group
Coupler Asm-Quick,Hitch,Catiii
Link-Top,Cat3,1 1 2 In. Unc,750mm
Coupler Asm-Quick,Vh,Ej35840
Coupler Asm-Quick,Vh,Tj644
Coupler Asm-Quick,Toolbar
Camera Instl-Rear Cam,Colour
Monitor Instl-Rear Cam,Color
Worklight Opt-Hor Suct Arm
Light Asm-Work.Dual.Brckt
Worklight Opt-Vert Suct Arm
Worklight Opt-Lnms,Rear,Hal
Worklight Opt-Lnms,Rear,Hid
Light Asm-Work,Hid,Dual,Brckt
Worklight Opt-Lnms,Rear,Non
Connection Opt-Air V,Injector
Kit-Coupler,Air,Loose
Valve-Reload,Lh,Fr
Component Asm-Manual,Valve,6in
Coupler-Quick,Left Front,6in
Nozzle Instl-Discharge
Spreader-Nutrient,Perfect
Hose Asm-Extension,6.0in,2244
Hose Asm-Supply Tank,6.0in,2244
Hose Asm-Suction,6.0in,2244
Function Opt-Hyd,Extra,Open
Comp Instl-Hyd,Func,Extra,Std
Hose Instl-Function Opt,Extra
Comp Instl-Elec,Hyd,Func,Opt
Valve Instl-Hyd,Extra,Open,Ver
Valve Asm-Hyd,Extra,Open,Nms
Function Opt-Hyd,Extra,Closed
Valve Asm-Hyd,Extra,Closed,Nms
Valve Instl-Hyd,Extra,Open,Hor
Valve Instl-Hyd,Ext,Closed,Hor
Kit-Coupler,Hyd,Iso,Loose,Ex
Canbus Opt-Ext,Sys Nms Liq
Towing Hook Opt-Hitch
Kit-Sensor,M12, Extend,10m
Bulkhead Asm-Drawbar
Drawbar Instl-Hitch
Recommended Dealer Stock
