Challenger Terragator 8333 Chassis Parts Catalog AG630200
Brand: Challenger Terragator
Type of Machine: Applicators
Type of Manual: Chassis Parts Catalog
Model: Challenger 8333 Terragator Chassis (2010)
Serial Number: ..VXX1001
Part Number: AG630200
Number of Pages: 1148 Pages
Publication Information
Gearbox Instl-Pumpdiverter
Box-Pump Diverter,Gear,Tg8333
Engine Pre Asm-Sisu,Tg8333
Bracket Instl-Engine
Dipstick Instl-Engine,Sisu,Tg8333
Engine Instl-Sisu,84cta,330hp
Hose Instl-Heating,Cab
Cooler Instl-Tg8333
Cooler Asm
Tube Instl-Cac,Tg8333
Tube Instl-Water,Cooler
Tank Instl-Clg,Water,Tg8333
Air Instl-False,Anti
Exhaust Instl-Damper
Exhaust Instl-Tube,Turbo Side
Filter Instl-Air Intake,Filter
Filter Instl-Airintake,Tubes
Transmission Group
Transmission Instl-Cvt,Isolator
Xmsn Asm-Cvt,Ml260
Transmission-Cvt,Ml260
Adjusting Device
Pipelines
Lube Oil Pump
Pump Shaft
Accumulator Shaft
Hydr. Motor
Group Gear Shifting
Gear Pump
Electronic Box
Range Shaft
Duct Plate
Gear Box Lubrication
Valve Unit
Oil Level Indicator
Gearbox-Housing
Inner Housing
Planetary Drive
Front W. Drive Const
Engine P.T.O
Shifting
Control-Electronic
Transmitter
Pump Drive
Driveline Group
Driveline Instl-Rear,Cvt,Axle
Driveline Instl-Cvt,Engine
Driveline-8.5c Engine To Trans
Axle Group
Axle Instl-Tg8333
Axle Asm-Tg8333
Brake Asm-Parking,Disc
Kit,Lining
Kit,Seal
Kit,Hyd
Kit,Hardware
Kit,Repair
Brake Asm-Dry Disc,Sec
Axle-Rear,24.66 1,Wet Disk
Carrier Assembly
Housing Group
Wheel End
Wet Disc Brake
Frame And Steering Group
Fork Instl-Front,Tg8333
Fork Asm-Front,Tg8333
Gearbox Asm-Fwd,Tg8333
Motor Asm-Hyd,Fwd,Tg8333
Cylinder Asm-Steering,Tg8333
Cylinder-Hyd,35 70 480 456mm
Lubrication Instl-Blck,Str Cyl
Fuel System Group
Tank Instl-Fuel,600l
Tank Asm-Fuel,Rh (65gl)
Cap Instl-Fuel,Lockable
Tank Asm-Fuel,Tank,379l,Rh
Fuel Line Instl
Hydraulic Group
Pump Instl-Hyd.Hp,Nms
Pump Asm-Hyd,Hp,Nms
Pump Instl-Hyd,Hd,Fwd
Pump Asm-Hyd,Hd,Fwd
Pump Instl-Hyd,Ls,Nms
Pump Asm-Hyd,Ls,Nms
Pump Instl-Gear,Snp
Orbitrol Instl-Steering
Orbitrol Asm-Steering
Tank Instl-Hyd,200l,Tg8333
Tank Asm-Hyd,200l
Filter-Rtn Suct,Argo,300l Min
Cap-Hyd Tank,Breather,Argo
Flange Asm-Sae,Adapter 2 In
Valve Instl-Priority,150l Min
Valve Asm-Priority,150l Min
Valve-Priority,150l Min,Safim
Valve Instl-Pressure-Relief
Instl-Swivel,Hydraulic-Fwd
Tube Instl-Hyd,Fwd
Valve Asm-2 2no,Fwd
Hose Instl-Hyd,Cvt,Cooler
Hose Instl-Brake Sys
Hose Instl-Hyd,Nose,Tg8333
Hose Instl-Fwd,8333
Hose Instl-Steering Sys
Hose Instl-Priority Valve,8333
Hose Intl-Hyd,Tank
Cooler Instl-Oil
Cooler Asm-Tg8133
Manifold Asm-Return Oil,Clr
Cooler-Oil,Asa0256 12vdc
Accumulator Instl-2.0l,35bar
Manifold Instl-Return,8333
Manifold Asm-Return,8333
Valve Instl-Divertion,Oil,Brake
Valve Asm-Divertion,Oil,Brake
Air System Group
Tank Instl-Air,42l,Tg3244,Tg8333
Tank Asm-Air,40l
Tank Asm-Air,20l,Front (Wet)
Tank Asm-Air,20l,Rear (Dry)
Hose Instl-Air,Standard,Tg8333
Chain Instl-Debreath,Tank,Air
Dryer Instl-Air,Sgl Canister
Dryer Asm-Air,Sgl Canister
Hose Instl-Air,System
Tank Instl-Air,Regeneration
Tank Asm-Air,Regeneration
Dryer Instl-Air,Dbl Canister
Dryer Asm-Air,Dbl Canister
Cooler Instl-Air,700l,8333
Hose Instl-Air,System,Dryer,Double
Cab Group
Windshield Wash-Fluid Fill
Panel Instl-Trim,Tg
Lighter Asm-Cigar
Airline Ftg Instl-Cab,Airhorn
Pedal Instl-Brake,Tg (Service)
Pedal Asm-Brake
Pedal-Brake,Hyd
Pedal Instl-Throttle
Pedal-Inching
Pedal Instl-Clutch
Pedal Asm-Clutch
Console Instl-Cab
Isolation Instl-Sound,Cab
Seat Instl-Deluxe
Seat Asm-Deluxe,Semi Active
Kit-Seat As. Upper
Kit-Arm Rest As. (Lh)
Kit-Seat Top,Sst
Kit-Suspension
Kit-Spring And Shock As.
Kit-Air Spring
Dash Instl-Center Console
Control Gp-Steering
Column As.-Steering
Cover-Column,Steering
Floormat Instl-Cab,Tg8333
Cab Asm-Terragator,Tg8333
Wiper Group
Arr Decals
Arr-Door Installation
Arr-Door Asm
Arr-Door Glass
Handle Door Ext
Arr-Cab Glass
Arr-Rh Window Glass
Arr-Inner Roof
Arr-Outer Roof
Arr-Interior Trim
Arr-Floormats Covers
Arr-Horn (Air)
Arr-Elec Inner Roof
Arr-Controls (Front)
Arr-Cab Electrical
Hvac Group
Arr-Audio
Kit-Wiper Motor
Suspension Instl-Cab,Fr
Suspension Instl-Cab,Rear
Radio Instl-Europa
Armrest Instl-Tg8333,Liq Dry
Armrest Asm-Cvt,Liq Dry
Joystick Asm-Cvt,Liq Dry
Asm-Armrest,Cvt,Nl
Panel Instl-Keypad,Tg8333
Hose Instl-A C,8333
Filter Instl-Airco
Filter Asm-A C
Electrical Group
Alarm Instl-Reverse
Harness Instl-Cab,Eu
Harness Instl-Cab,Sisu Cvt
Flasher Instl-Non Domestic (Eu)
Switch Instl-Magnetic
Battery Instl-Tg8333
Breaker Instl-Junction Block
Module Instl-High,Current
Node Instl-Micro,Esx
Harness Instl-Chassis,Tg8333
Harness Instl-Clutch,Fan
Instl-Tcu,Cvt,Tg
Lighting Group
Worklight Instl-Nose,Std
Light Asm-Left
Bezel-Light,Left
Light Asm-Right
Bezel-Light,Right
Worklight Instl-Nose,Hid
Light Asm-Left,Hid
Light Asm-Right,Hid
Light Instl-Traffic,Tg8333
Headlamp Asm-Halogen,Lh
Headlamp Asm-Halogen,Rh
Worklight Opt-Front,Std
Worklight
Lamp Instl-Rotating,Lh,Front
Connection Asm-Lamp,Rotating
Lamp Instl-Rotating,Rh,Front
Worklight Opt-Front,Rev,Hal
Worklight-Oval,Double Beam
Worklight Opt-Front,Rev,Hid
Worklight-Oval,Hid
Worklight-Opt,Cab (Floodlight)
Worklight Opt-Cab,Hid,Fr
Worklight Instl-Cab,W O Rops
Harness Instl-Wl,Cab,Rr
Worklight Instl-Cab,Hid
Appearance Group
Tank Instl-Water,10l,Tg2244,Tg8333
Platform Instl-Fueltank,Lh
Platform Instl-Fueltank,Rh
Entrance Instl-Tg8333
Ladder Asm-Entrance
Entrance Asm-Tg8333
Panel Instl-Cover,Engine
Cover Side-Asm,Rh,Tg8333
Cover Side-Asm,Lh,Tg8333
Tunnel Instl-Hose Routing
Step Instl-Fuel,Tank,Lh
Step Asm-Fuel,Tank
Step Instl-Fuel,Tank,Rh
Frame Instl-Exhaust,Airfilter
Box Instl-Storage,Battery,Tg8333
Cover Asm-Batterybox,Lh,Tg8333
Cover Asm-Toolbox,Rh,Tg8333
Frontplate Instl-Tg8333
Frontplate Asm-Tg8333
Hood Instl,Tg8333
Hood Asm-Tg8333
Mirror Instl-Standard
Bracket Asm,Mirror,Lh
Bracket Asm,Mirror,Rh
Mirror Instl-Adj And Heat
Bracket Asm-Mir,Adj And Heat,Rh
Bracket Asm-Mir,Adj And Heat,Lh
Bush Instl-Retainer,Mir,Rh
Tire And Wheel Group
Tire Instl-1050 50r32,T2,Mich,Front
Wheel Asm-Front,T2
Tire Instl-1050 50r32,M28,Mich,Front
Wheel Asm-Front,M28
Tire Instl-1050 50r32,T2,Mich,3.35m
Rim And Tire Asm-1050 50r32,T2,Rh,3.35m
Rim And Tire Asm-1050 50 R32,T2,Lh,3.35m
Tire Instl-1050 50r32,M28,Mich,3.35m
Rim And Tire Asm-1050 50r32,M28,Rh,3.35m
Rim And Tire Asm-1050 50r32,M28,Lh,3.35m
Tire-Instl-1050 50r32,T2,Mich,3.15m
Rim And Tire Asm-1050 50 R32,T2,Lh,3.15m
Rim And Tire Asm-1050 50 R32,T2,Rh,3.15m
Tire Instl-1050 50r32,M28,Mich,3.15m
Rim And Tire Asm-1050 50r32,M28,Rh,3.15m
Rim And Tire Asm-1050 50r32,M28,Lh,3.15m
Placard Instl-Reflective,Tg8333,3.35m
Refl Placards Asm-Lh,Workw,3.35m
Refl Placards Asm-Rh,Workw,3.35m
Placard Instl-Reflective,Tg8333,3.15m
Refl Placards Asm-Lh,Workw,3.15m
Refl Placards Asm-Rh,Workw,3.15m
Decal Group
Decal-Inst,Cabroof,8333
Decal Instl,Tg8333,Chassis
Guidance Group
Radar Group-Common
Radar Group-Common,Uk
Controller Instl-Gta
Opt-Gps,Phoenix 200,Rg Tg
Kit-Gps,Phoenix 200
Kit-Gps,Phoenix 300
Receiver Instl-Gps,Phoenix 300
Antenna Instl-Gps,Phoenix 300
Kit-Lightbar,Rgl600
Swbox Cable Instl-Rgl 600
Lightbar Instl-Rgl 600,Tg
Sensor Instl-Tilt,Rg Tg
Kit-Sensor,Tilt
Telemetry Group
Telemetry Opt-Ready
Telemetry Ready Asm
Telemetry Asm
Options Group
Kit-Extra Key
Throttle Instl-Remote,Tg8333
Filter Instl-Bio,Diesel,Tg8333
Specifications By Country Group
Cust Docs-8333,Chassis,Nl,10
Cust Docs-8333,Chassis,Ger,10
Cust Docs-8333,Chassis,Fr,10
Recommended Dealer Stock
Cooler Instl-Tg8333
Cooler Asm
Transmission Group
Xmsn Asm-Cvt,Ml260
Adjusting Device
Pipelines
Lube Oil Pump
Pump Shaft
Accumulator Shaft
Hydr. Motor
Group Gear Shifting
Gear Pump
Electronic Box
Range Shaft
Duct Plate
Valve Unit
Oil Level Indicator
Gearbox-Housing
Inner Housing
Planetary Drive
Engine P.T.O
Shifting
Control-Electronic
Transmitter
Pump Drive
Driveline Group
Axle Group
Axle Instl-Tg8333
Axle Asm-Tg8333
Kit,Lining
Kit,Seal
Kit,Hyd
Kit,Hardware
Kit,Repair
Carrier Assembly
Housing Group
Wheel End
Wet Disc Brake
Fuel System Group
Fuel Line Instl
Hydraulic Group
Pump Asm-Hyd,Hp,Nms
Pump Asm-Hyd,Hd,Fwd
Pump Asm-Hyd,Ls,Nms
Pump Instl-Gear,Snp
Tank Asm-Hyd,200l
Tube Instl-Hyd,Fwd
Valve Asm-2 2no,Fwd
Hose Instl-Fwd,8333
Hose Intl-Hyd,Tank
Cooler Instl-Oil
Cooler Asm-Tg8133
Air System Group
Tank Asm-Air,40l
Cab Group
Panel Instl-Trim,Tg
Lighter Asm-Cigar
Pedal Asm-Brake
Pedal-Brake,Hyd
Pedal-Inching
Pedal Instl-Clutch
Pedal Asm-Clutch
Console Instl-Cab
Seat Instl-Deluxe
Kit-Seat As. Upper
Kit-Seat Top,Sst
Kit-Suspension
Kit-Air Spring
Control Gp-Steering
Column As.-Steering
Wiper Group
Arr Decals
Arr-Door Asm
Arr-Door Glass
Handle Door Ext
Arr-Cab Glass
Arr-Rh Window Glass
Arr-Inner Roof
Arr-Outer Roof
Arr-Interior Trim
Arr-Horn (Air)
Arr-Elec Inner Roof
Arr-Cab Electrical
Hvac Group
Arr-Audio
Kit-Wiper Motor
Radio Instl-Europa
Asm-Armrest,Cvt,Nl
Hose Instl-A C,8333
Filter Instl-Airco
Filter Asm-A C
Electrical Group
Alarm Instl-Reverse
Instl-Tcu,Cvt,Tg
Lighting Group
Light Asm-Left
Bezel-Light,Left
Light Asm-Right
Bezel-Light,Right
Light Asm-Left,Hid
Light Asm-Right,Hid
Worklight
Worklight-Oval,Hid
Appearance Group
Ladder Asm-Entrance
Entrance Asm-Tg8333
Step Asm-Fuel,Tank
Hood Instl,Tg8333
Hood Asm-Tg8333
Wheel Asm-Front,T2
Wheel Asm-Front,M28
Decal Group
Guidance Group
Radar Group-Common
Kit-Gps,Phoenix 200
Kit-Gps,Phoenix 300
Kit-Lightbar,Rgl600
Kit-Sensor,Tilt
Telemetry Group
Telemetry Opt-Ready
Telemetry Ready Asm
Telemetry Asm
Options Group
Kit-Extra Key
