Challenger Terragator 8303 Chassis Parts Catalog AG632819
Brand: Challenger Terragator
Type of Machine: Applicators
Type of Manual: Chassis Parts Catalog
Model: Challenger 8303 Terragator Chassis
Serial Number: ..WXX1001
Part Number: AG632819
Publication Date: 2010
Number of Pages: 2520 Pages
Publication Information
Engine Group
Engine Install-Sisu, 8.4 300 Hp,6303
Cover, Driveline
Engine-Sisu, 8.4. 300 Hp,6303
Housing Gear
Flywheel And Housing
Valve Mechanism
Inlet Exhaust Manifold
Piping Turbo
Sump Oil
Cooler Oil
Filter Centrifugal Oil
Pump Coolant
Pump Fuel
Filter Fuel
Eem3 Parts
Starter Motor
Drive Device
Compressor
Engine Overhaul Parts
Compressor-A C,R134a,2 Groove
Engine Install-Sisu, 8.4 330 Hp,8303
Engine-Sisu 8.4l,330 Hp,8303
Cooling Package
Barrier Recirc
Expansion Tank
Guard Fan
Install-Clamping,Sisu Cvt
Install-Air Intake
Air Cleaner-15.00 Diameter
Muffler
Baffle Install-Air, Non-Domestic
Baffle Install-Air, Domestic
Transmission Group
Transmission Install-Fendt Cvt
Transmission Cvt, Ml260
Adjusting Device
Pipelines
Lube Oil Pump
Pump Shaft
Accumulator Shaft
Hydr. Motor
Group Gear Shifting
Gear Pump
Electric Box
Range Shaft
Duct Plate
Gear Box Lubrication
Valve Unit
Oil Level Indicator
Gearbox- Housing
Inner Housing
Planetary Drive
Front W. Drive Const
Engine P.T.O
Shifting
Control- Electric
Transmitter
Pump Drive
Kit Vario Insert,New
Additional Parts Kit
Adapter -Steer-16morfsxm33
Adapter -Steer-6morfsxm14
Tee -Run -16 Orfs Swivel
Adapt -16mor X -16fsorfs
Grip-Centerl,Transmission,Funk
Kit-Pushbutton Switches
Switch Assembly -Pushbutton
Switch Group-Pushbutton
Angle Transmission
Driveline Group
Drive System
Driveline Install
Driveline-8.5c Engine To Transmission
Driveline, Front 8.5c
Driveline, Middle 8.5c
Driveline, Rear 8.5c
Axle Install-Rear, 17.55 1
Axle Assembly-Rear, 17.55 1
Housing Group
Carrier Assembly
Bearing Kit
Bolt Kit
Shaft And Wheelend
Bearing Kit Inner
Bearing Kit Outer
Brake Group
Axle And Steering Group
Spring Assembly-Brake
Frame And Suspension Group
Fork Assembly-Domestic
Fork Assembly-Eame
Fuel System Group
Tank Install-Fuel
Tank Assembly-Fuel, 65 Gl, Lh
Tank,Assembly-Fuel,100gl,Rh
Cap Install-Fuel.Lockable
Tank Assembly-Fuel,65 Gl,Lh
Hydraulic Group
Hydraulic Install
Tee -Swivel 12 Orfs
Connector -Steer 10stor-12orfs
Elbow -90d-12orfs Bulkhead
Hydraulic Hose Kit
Hose-Install
Hydraulic Tank Install
Hydraulic Tank Assembly
Hydac Hydraulic Filter, 90
Valve-Ball Assembly,-12stor F M
Elbow -45 -12stor-12orfs
Elbow -45 -8stor-8orfs
Adapter -20 Stor X -20 Bead
Tank-Hydraulic Support Install
Cylinder Install- Steering
Cylinder Assembly-Steering,Lh
Cylinder, 2.5x1.25x14
Connector -8orfs-8stor
Tee -8orfs X 8orfs X 8stor
Cylinder Assembly-Steering,Rh
Standard Steering Pump
Valve Assembly-Priority, 2011
Pump,Pressure Comp,60cc,C-Pad, 2011
Connector
Tee -6orfs X 6orfsx 6stor
Pump Install, Circulator
Pump,Gear, 25cc, Tang
Elbow -90deg 12stor X 12orfs
Control -Steering
Cover-Column,Steering
Column-Steering
Standard Steering, Domestic
Steering Orbitrol Install, Domestic
Steering Orbitrol Assembly, Domestic
Steering Unit-Ospq,125 250,2011
Adapter M12x1.5mor X -40rfs
Elbow -90d M18x1.5 X 8stor
Elbow -Lg90 M18x1.5 X Stor
Standard Steering,Non-Domestic
Steering Orbitrol Install Non-Domestic
Steering Orbitrol Assembly Non-Domestic
Elbow -8stor X -8orfs
Pump,Pressure Comp,60cc,C-Pad, 2010
Valve Assembly-Priority, 2010
Eh-Valve,Pved-Cl
Field-Kit,Assist,Steering
Assembly-Assisted Steering Unit
Assisted Steering
Install-Assisted Steering Unit
Elbow -90deg-6stor-8orfs
Connector -Steer-6stor-8orfs
Elbow -8 Orfs 45deg
Tee -Run, -12mor X -12orfs
Elbow -90l,-06stor X-06orfs
Tee -Br,-06stor X -08orfs
Elbow -90d M12x1.5 X4orfs
Check Valve -12orfsx-12orfs
Adaptor-M18-1.5-Morx-08fnpt
Connector -12 Orfsx 12stor
Elbow -90-6stor X 6orfs
Elbow -90deg 6 Orfs X 10 Stor
Air System Group
Valve Fitting Assembly-Brake,E-6
Valve Assembly-Brake,Park
Airline Ftg Install-Park Brake
Box Assembly-Air Dryer
Governor Air Dryer Install
Governor Air Dryer Assembly
Air Dryer,Single Canister
Governor,Air
Air System-Domestic
Valve Install-Brake
Valve Assembly-Brake,Relay,R14
Valve Assembly-Brake,Relay,R12
Reservoir Install-Air,Domestic
Tank Assembly-Reservoir,Lh
Tank Assembly-Reservoir,Rh
Hose Kit-Air System,Domestic
Hose Clamp Install-Air System,Domestic
Air System-Non-Domestic
Valve Install-Brake,Tuv
Valve Assembly-Brake,Relay,R12,Tuv
Valve Assembly-Brake,Relay,R14,Tuv
Hose Kit-Air System,Non-Domestic
Reservoir Install-Air,Tuv
Tank Assembly-Reservoir,Lh,Tuv
Tank Assembly-Reservoir,Rh,Tuv
Horn (Air)
Horn Air
Cab Group
Seat Assembly-Basic, Air
Kit-Suspension (Seat)
Kit-Air Spring
Kit-Service,Compressor
Kit-Spring And Shock
Assembly Spring Isolater
Seat Install-Deluxe
Seat Assembly-Deluxe,Semi Active
Kit-Seat Suspension
Kit-Pan Back W Lumbar
Kit-Lumbar,Sst
Electrical Install Satellite Radio
Install-Radio,Non-Domestic
Install-Radio,Domestic
Install-Radio,Kit Xm
Install-Radio,Kit Sirius
Audio
Radio Accessory Kit
Base -Antenna
Wiper Group
Wiper Blade Assembly
Kit-Wiper Motor
Wiper Motor Hardware
Door Installation
Door Assembly
Door Glass
Cab Glass
Rh Window Glass
Inner Roof
Interior Trim
Floormats Covers
Outer Roof
Dash Install-Center Console
Pedal Install
Pedal-Throttle
Pedal Assembly-Clutch
Floormat Install-Cab
Cab Assembly
Install-Harness,Cab,Sisu Cvt
Control Group-Limp Home
Mirror Install
Mirror Assembly-Rh
Mirror Assembly-Lh
Controls
Hvac Group
Hvac Unit-Autocontro
Electical Inner Roof
Dome Light
Cab Electric
Support Assembly-Cab,Air Ride
Support Assembly-Cab,No Air Ride
Install-Cab,A S,2b
Install-Panel,Trim,Dry
Assembly-Armrest,Cvt,A S
Console-Assembly,Control
Pad Assembly-Arm
Cvt Controller
Install-Cab,A M
Install-Panel,Trim,Amp
Assembly-Armrest,Cvt,A M
Install-Cab,Nl,Bare Chassis
Install-Panel,Trim,Nl
Assembly-Armrest,Cvt,Nl
Install-Cab,Nl,Bare Chassis,A5
Assembly-Armrest,Cvt,Nl,A5 Vt
Electric -Wachendorff Opus A5
Install-Cab,A S
Assembly-Armrest,A S
Console-Assembly,Bottom,Cvt
Liquid Combo (A M)
Install-Panel,Trim,Amp,Combo
Panel Assembly-Gauge,Liquid
Assembly-Armrest,Cvt,Liquid
Liquid Combo (A M) W A5 Vt
Assembly-Armrest,Cvt,Liquid,A5 Vt
Liquid Combo (A S)
Install-Panel,Trim,As,Combo
Liquid Combo (N L)
Install-Panel,Trim,Liquid
Liquid Combo (N L) W A5 Vt
Install-Panel,Trim,Combo
Harness Install-Armrest,Cat Ts
Install-Remote Throttle,Cvt
Switch Assembly-A C,High Pressure
Receiver Dehydrator
Receiver Install-Dehydrator
Electric Group
Alarm Install-Reverse
Install-Battery
Install-Harness,Cable,Chassis,Domestic
Install-Harness,Ad,Cvt
Install-Master Module,Domestic,Cvt
Install-Tcu.Cvt
Install-Harness,Cable,Chassis,Non
Install-Master Module,Non,Cvt
Install-Harness,Mitron,Cvt
Install-Harness,No Autoguide
Install-Electric,Tag Axle,Cvt
Install-Elec.Tllt,Bare Chassis
Module Install-I O,Relay,Tilt
Module Assembly-I O,Can
Rear Lh Lamp Cluster Assembly
Lamp Cluster Rear Lh
Rear Rh Lamp Cluster Assembly
Lamp Cluster Rear Rh
Lighting Group
Lamp-Warning,Amber
Light-Work,Hid,Pendent Mount
Work Light Install-Afwork Light Support
Work Light-Dual Beam
Work Light Install-Awfl Support, Hid
Install-Support,Headlight,Non Domestic
Install-Assembly,Headlight,Rh
Install-Assembly,Headlight,Lh
Headlight Install-Hood,Cowork Lighting
Headlight-Halogen,Wrapping,Lh
Headlight-Halogen,Wrapping,Rh
Cowork Lighting Assembly-Hood
F A-Beacon,Amber-Mirror Mount
Lamp-Rotating,Amber
F A-Beacon,Amber-Roof Mount
Install-Hal,Above Cab,Rear
Work Light
Install-Hal,Cab,Rear
Install-Hid,Above Cab,Rear
Install-Hid,Cab,Rear
Beacon Amber
Light Install-Beacon, Amber,Tuv
Appearance Group
Mirror Install-Auxillary,Front
Mirror Assembly-Auxillary
F A-Auxillary,Front,Mirror Install
F A-Mirror Install-Extension
Support Install-Afwork Light,Front
Support-Assembly,Turn Signal,Rh
Support-Assembly,Turn Signal,Lh
Toolbox Step Install
Step Assembly-Lh
Box Assembly-Utility,Lh
Reflector Install-Cabinet
Bracket Install-Light Supt
Install-Support,Afwork Light Work Light,R L Box
Cabinet And Step Install
Step Assembly-Rh
Install-Box,Accessory
Mud Guard Cover Install
Rinse Tank Install
Tank-Rinse,Plastic
Box Assembly-Battery
Step Install-Cab, Entrance
Step Assembly
Cabinet Install-Pw Reel,Rh
Cabinet Assembly-Rh
Mud Guard Install
Door Install-Engine
Panel Assembly, Front, Lh
Panel Assembly, Front, Rh
Door Assembly, Rh
Panel Assembly, Rear, Rh
Panel Assembly, Rear, Lh
Hood Install
1tire And Wheel Group
Tire Rim-1000 50r25 Gy
Tire Rim Assembly-Front
Tire Rim-66x34-25,10p,Dt,Fs
Tire Rim Assembly Front
Tire Rim-1000 50r25 Michelin
Tire Rim-Rr,1000 50r25 Michelin
Tire Rim Assembly-Rr,Rh
Tire Rim Assembly-Rr,Lh
Tire Rim-Rr,1000 50r25 Gy
Tire Rim-Rr,66x43-25, 16p, Fs
1decal Group
Decal Install-Na
Decal Install-Int
Decal Install
Decal Install-8303
Decal Install-6303
Decal-Striping,Hood,Front,8303 Challenger
Decal-Inst,Cabroof,8303 Challenger
Sign Install-Slow Moving Vehicle,Front
1guidance Group
Option-No Controller
Radar Install
Kit-Gps,Phoenix 300
Receiver Install-Gps,Phoenix 300
Antenna Install-Gps,Phoenix 300
Option-Gps, Phoenix 200
Kit-Gps,Phoenix 200
Option-Lightbar,Rgl 600
Kit-Lightbar,Rgl600
Switchbox Cable Install-Rgl 600
Lightbar Install-Rgl 600
Sensor Install-Tilt
Plate Install-Smartrax,Phx 200
Control Install-Smartrax,Cab
Kit-Cab,Smartrax
Switch Install-Enable,Smartrax
Valve Install-Smartrax
Kit-Chassis,Smartrax
Valve Assembly-Hydraulic,Smartrax
Smartrax Hydraulic Valve
Console Install-Gta
Controller Install-Raven 5000
Node Install-Boom Speed,Raven
Controller Install-Viper Pro
Install-Accuboom,Raven
Kit-Accuboom,Raven
Install-W O Accuboom,Raven
Install-Terminal,Autoguide
Terminal Kit
Telemetry Group
Telemetry Ready Assembly
Telemetry Hardware Group
1options Group
Bolt Install-Frame,W O Boom
Boom Rest Install
220v Europe Blk Htr Install
Tag Axle Install
Axle Wheel Assembly-Tag,Michelin
Tire Rim Assembly-Michelin
Shaft Assembly-Tag Axle
Kit-Tag Axle
Cylinder-Hydraulic,2.50x12.00x1.125
Arm, Assembly, Tag Axle
Hose Clamp Install
Hydraulic-Block Install
Hydraulic-Block Assembly
Hydraulic-Block,Tag Axle
Install-Decal, Tag Axle, Cvt
Kit-Tag Axle,3 Wheel
Common Parts-Tag Axle
Mech Install-Tag Axle
Hydraulic Install,Tag Axle, Field
Kit Assembly-Lug Wrench
Kit Assembly-Lug,Wrench
Kit-Extra Key,Terragator
Plumbing Assembly,W O Hyd,W O Pressure Washer
Hose Install, Pw
Plumbing Assembly-System,W Hyd,W Pressure Washer
Pump And Motor Assembly-Washer,Pressure
Pump And Motor-Washer,Pressure
Reel Assembly
Reel Assembly-Pressure Washer
1recommended Dealer Stock
Engine Group
Cover, Driveline
Housing Gear
Valve Mechanism
Piping Turbo
Sump Oil
Cooler Oil
Pump Coolant
Pump Fuel
Filter Fuel
Eem3 Parts
Starter Motor
Drive Device
Compressor
Cooling Package
Barrier Recirc
Expansion Tank
Guard Fan
Install-Air Intake
Muffler
Transmission Group
Adjusting Device
Pipelines
Lube Oil Pump
Pump Shaft
Accumulator Shaft
Hydr. Motor
Group Gear Shifting
Gear Pump
Electric Box
Range Shaft
Duct Plate
Valve Unit
Oil Level Indicator
Gearbox- Housing
Inner Housing
Planetary Drive
Engine P.T.O
Shifting
Control- Electric
Transmitter
Pump Drive
Angle Transmission
Driveline Group
Drive System
Driveline Install
Housing Group
Carrier Assembly
Bearing Kit
Bolt Kit
Shaft And Wheelend
Bearing Kit Inner
Bearing Kit Outer
Brake Group
Fork Assembly-Eame
Fuel System Group
Tank Install-Fuel
Hydraulic Group
Hydraulic Install
Tee -Swivel 12 Orfs
Hydraulic Hose Kit
Hose-Install
Connector
Control -Steering
Column-Steering
Eh-Valve,Pved-Cl
Assisted Steering
Elbow -8 Orfs 45deg
Air System Group
Governor,Air
Air System-Domestic
Valve Install-Brake
Horn (Air)
Horn Air
Cab Group
Kit-Air Spring
Seat Install-Deluxe
Kit-Seat Suspension
Kit-Lumbar,Sst
Audio
Radio Accessory Kit
Base -Antenna
Wiper Group
Kit-Wiper Motor
Door Installation
Door Assembly
Door Glass
Cab Glass
Rh Window Glass
Inner Roof
Interior Trim
Floormats Covers
Outer Roof
Pedal Install
Pedal-Throttle
Cab Assembly
Mirror Install
Mirror Assembly-Rh
Mirror Assembly-Lh
Controls
Hvac Group
Dome Light
Cab Electric
Install-Cab,A S,2b
Pad Assembly-Arm
Cvt Controller
Install-Cab,A M
Install-Cab,A S
Liquid Combo (A M)
Liquid Combo (A S)
Liquid Combo (N L)
Receiver Dehydrator
Electric Group
Install-Battery
Install-Tcu.Cvt
Lighting Group
Lamp-Warning,Amber
Lamp-Rotating,Amber
Work Light
Beacon Amber
Appearance Group
Step Assembly-Lh
Step Assembly-Rh
Rinse Tank Install
Tank-Rinse,Plastic
Step Assembly
Cabinet Assembly-Rh
Mud Guard Install
Door Install-Engine
Door Assembly, Rh
Hood Install
1decal Group
Decal Install-Na
Decal Install-Int
Decal Install
Decal Install-8303
Decal Install-6303
1guidance Group
Radar Install
Kit-Gps,Phoenix 300
Kit-Gps,Phoenix 200
Kit-Lightbar,Rgl600
Sensor Install-Tilt
Kit-Cab,Smartrax
Console Install-Gta
Kit-Accuboom,Raven
Terminal Kit
Telemetry Group
1options Group
Boom Rest Install
Tag Axle Install
Kit-Tag Axle
Hose Clamp Install
Hose Install, Pw
Reel Assembly
