Challenger Terragator 3244 NMS Liquid System Parts Catalog AG626982
Brand: Challenger Terragator
Type of Machine: Applicators
Model: Challenger 3244 NMS Terragator Liquid System 2008
Part Number: AG626982
Publication Date: 2009
Number of Pages: 973 Pages
Publication Information
Hydraulic Group
Bulkheadplate Instal-Artclpnt
Plate Asm-Bulkhead,Tg3244
Cooler Instl-Oil,Tg3244,Lnms
Cooler Asm-Oil,Tgx244,Nms
Cooler-Oil,Ec01-12voc
Comp Asm-Hyd,Oil Cooler,Tg3244
Filter Instl-Pres,Tg3244,Lnms
Filter-Pressure,Argo,Hd172-166
Plate Instl-Bulkhead,Hitch,Nms
Plate Asm-Bulkhead,Hitch,Nms
Manf Instl-Leakage,Tg3244,Lnms
Manifold Asm-Leakage,3244,Lnms
Manf Asm-Leak,Tgx244,Lnms
Unit Instl-Hyd Pn El,X244,Lnms
Unit Asm-Hyd Pn El,X244,Lnms
Casing Asm-Hyd,Tgx244,Lnms
Manf Instl-Std,Hyd,X244,Lnms
Manf Asm-Std,Hyd,Tgx244,Lnms
Block-Hydr,Hic,Tg9205
Manifold-Nms,Hicb(Rev 07)
Manifold-Nms,Danfoss
Pump Instl-Hyd,Hd,Tg3244
Pump Asm-Hyd,Hd,Tgx244
Pump-Hyd,75cc,Rh,Pto,Sae C
Pump Instl-Hyd,Ls,Tg3244
Pump Asm-Hyd,Ls,Tgx244
Pump Hyd-Ls,Jrr060b
Valve Instl-Cutter,Std,Tgx244
Valve Asm-Cutter,Std,Tgx244
Valve-Hyd,,Ng06,4 3,A-B On T
Plumbing Instl-Cab,Articltn Pnt
Plumbing Instl-System,3244nms
Plumbing Instl-Cutter,X244,Nms
Plumb Instl-Knife Valve,10in
Plumbing Instl-Dw,3244nms
Valve Instl-Dw,3244,Lnms
Valve Asm-Dw,3244,Lnms
Valve-Hyd,,Ng06,4 2,A-B On T
Valve-Reducer,160bar,Ng6
Orifice-2.0mm,Ng6
Electrical Group
Hitch-Reduce,Instl,Switch
Harness Instl-Main,System,X244
Harness Instl-Lght,Tail,X244
Box Asm-Light,Tg Nms,Left
Light-Pendel,Diagonal
Box Asm-Light,Tg Nms,Right
Harness Instl-Hyd Unit,X244
Harness Instl-Dogwalk,X244
Switch Instl-Dw,Lock-Unlk,X244
Air System Group
Air Group,X244,Lnms
Valve Asm-Air,X244,Lnms
Hitch Group
Component Instl-Hitch
Arm Asm-Hitch,Tg
Bulkhead Asm-Hitch,9205nms
Link Asm-Lift,Long
Cylinder Asm-D50 100 230 510
Cylinder-Hyd,50 100 230 510mm
Link Asm-Lower,Cat Iv ,My07
Stabilization Asm-Hitch
Link-Top,Cat3,1 1 2 In. Unc,875mm
Kit-Coupler,Hyd,Iso,Loose
System Group
Mudguard Instl,Nms
Tank Instl-Polyester,Dw,18m3
Tank-Manure,Poly,18m3,Rwk
Pipe Instl-Poly,18m3,3244
Valve Asm-Rear,Tg3244
Valve Instl-Rear,Gate Valves
Valve Asm-Gate,6in,Air Cyl,Ind
Valve-Gate,6in
Cylinder Asm-Air,D20 80 160mm
Cylinder-Air,D20 80 160mm(6in)
Decal-Inst,Striping Nms 18m3
Fender Instl-Tank,Poly,3244
Fender Instl-Tg3244,Chassis,Dw
Fender Asm-Tg3244,Chassis,Dw,Lh
Fender Asm-Tg3244,Chassis,Dw,Rh
Level Indicator Group,3244
Level Indicator Asm-Ma Tk,Poly
Manhole Instl-Poly Tank
Breather Instl-Poly Tank
Lid Asm-Poly Tank,Breather
Lid-Poly Tank,High,Breather
Suction Arm Group
Block Instl-Ng6,Suction Horiz
Block Asm-Ng6,Suction Horiz
Valve-Hyd,,Ng06,4 3,Closed Center
Orifice-1.0mm,Ng6
Orifice-1.5mm,Ng6
Orifice-1.2mm,Ng6
Tube Instl-Overflow,3244,Lnms
Hose Instl-Horiz,Suction,Standard
Frame Instl-Leakage,X244,Lnms
Valve Inst,Ng6,Hor,Suct,Std
Valve-2 2,Nc,3 8
Cartridge-2x2valve Nc,S202
Hose Inst,Ng6,Hor,Suct,Std
Arm Inst-Suction,Hor,18m3,Poly
Arm Asm-Suction,Horiz,9205,08
Cylinder Asm-D30 50 60 180 500
Cylinder-Hyd,D30 60 180 500
Cylinder Asm-D30 50 580 895mm
Cylinder-Hyd,D30 50 580 895mm
Cylinder Asm-D25 40 150 349
Cylinder-Hyd,D25 40 150 349
Cylinder Asm-D25 40 150 349mm
Valve Inst-Cutter,Superload
Ring Sprt Instl-Rbr Harmonica
Component Instl-Cntfgl Pump,Sl
Valve Asm-Knife,10in,Superload
Valve-Knife,Dn250
Cylinder Asm-D16 25 260 395,Hc
Cylinder-Hyd,D16 25 260 395mm
Pump Asm-Centrifugal,Superload
Impeller Asm,Cntfgl Pump,Sl
Motor Asm-Hyd,100cc
Motor-Hyd,100cc,Side Ports
Component Instl-Hydr,Sl,X244
Component Asm-Hydr,Sl,X244
Plumbing Instl,Superl,3244,Lnms
Ng16 Instl-Hyd,X244lnms
Ng16 Asm-Hyd,X244lnms
Valve-Hyd,Ng16,Ptoa,Ttob
Cutter-Modif,Manure,Superl,Po
Support-Hose,Asm
Valve Asm-Knife,8.0in,Superload
Valve-Knife,Dn200
Cylinder-Hyd,D20 40 200
Coupling Instl-Cntfgl P,8.0per
Coupling Instl-Suct Arm,8.0bau
Coupling Instl-Cntfgl P,10bau
Funnel-Asm-Suction,8inch
Funnel Opt-Suction,10inch
Arm Opt Instl-Horiz,Suct Arm
Plumbing Instl-Std,3244,Lnms
Cutter-Modif,Manure,Std,Poly
Manure Pump Group
Pump Group-Fl1036,Tg3244,Lnms
Pump Asm-Fl 1036,Tgx244,Lnms
Transducer Connection Asm
Motor-Hyd,55cc,Incl Sensor
Component Asm,Manual Valve,6in
Valve Asm-Manual,6in
Valve-Stem,Gate,Flanged,Mz,6in
Pump-Manure,Fl1036
Gearbox-Pd1045 Mr1 3.5 00
Pump Group-Fla1540,Tg3244,Lnms
Pump Asm-Fla1540,Tgx244,Lnms
Motor-Hyd,75cc,Inkl. Sensor
Pump-Manure,Fla1540
Manure Filter Group
Cutter Instl-Manure,12000,X244
Cutter Asm-Rotacut,X244,Lnms
Valve Asm-8in,Air Cylinder
Cylinder Asm-Air,D22 80 200mm
Cylinder-Air,D22 80 200mm(8in)
Valve-Stem,Gate,Flanged,8
Cutter-Rc12000,Oms250m
Motor-Hydr,Oms 250 M,Rc12000
Air Instl-Rc12000,X244,Lnms
Toolkit Asm-Dismantle,Rotacut
Cutter Instl-Manure,10000,X244
Rc10000-Incl,Oms200cc
Motor-Hydr,Oms 200,Rc10000
Appearance Group
Mirror Instl-Standard
Bracket Asm,Mirror,Lh
Bracket Asm,Mirror,Rh
Decal Group
Options Group
Camera Instl-Rear Cam
Monitor Instl-Rear Cam,Tgx244
Harness Instl-Wl,Cab,Rr,Bare
Worklight Instl-Cab,W O Rops
Lamp-Working,Rectang,Rwk
Mirror Instl-Adj And Heat
Bracket Asm-Mir,Adj And Heat,Rh
Bracket Asm-Mir,Adj And Heat,Lh
Elec Instl-Heating,4mirrors
Nozzle Instl-Discharge
Spreader-Nutrient,Perfect
Towing Hook Opt-Hitch
Kit-Sensor,M12, Extend,10m
Bulkhead Asm-Drawbar
Drawbar Instl-Hitch
Link-Top,Cat3,1 1 2 In. Unc,750mm
Hose Asm-Extension,6.0in2244
Hose Asm-Supply Tank,6.0in,2244
Lamp Instl-Rotating,Lh,Front
Connection Asm-Lamp,Rotating
Lamp Instl-Rotating,Rh,Front
Specifications By Country Group
Decal-Install,3244,Lnms
Cust Docs-3244lnms,Ger,Challen
Cust Docs-3244lnms,Us,Challen
Decal-Install,3244,Lnms,Us
Cust Docs-3244lnms,Nl,Challen
Cust Docs-3244lnms,Fr,Challen
Cust Docs-3244lnms,Uk,Challen
Cust Docs-3244lnms,Dk,Challen
Cust Docs-3244lnms,08,Hun
Miscellaneous Group
Spare Parts-Tg Nms
Recommended Dealer Stock
Hydraulic Group
Pump Hyd-Ls,Jrr060b
Orifice-2.0mm,Ng6
Electrical Group
Air System Group
Air Group,X244,Lnms
Hitch Group
Arm Asm-Hitch,Tg
Link Asm-Lift,Long
System Group
Mudguard Instl,Nms
Valve-Gate,6in
Suction Arm Group
Orifice-1.0mm,Ng6
Orifice-1.5mm,Ng6
Orifice-1.2mm,Ng6
Valve-2 2,Nc,3 8
Valve-Knife,Dn250
Motor Asm-Hyd,100cc
Support-Hose,Asm
Valve-Knife,Dn200
Manure Pump Group
Pump-Manure,Fl1036
Pump-Manure,Fla1540
Manure Filter Group
Appearance Group
Decal Group
Options Group
Drawbar Instl-Hitch
Miscellaneous Group
Spare Parts-Tg Nms
