Challenger Terragator 3244 NMS Liquid System Parts Catalog AG626313
Brand: Challenger Terragator
Type of Machine: Applicators
Model: Challenger 3244 NMS Terragator Liquid System 2007
Part Number: AG626313
Publication Date: 2008
Number of Pages: 468 Pages
Publication Information
Hydraulic Group
Bulkheadplate Instal-Artclpnt
Plate Asm-Bulkhead,Tg3244
Cooler Instl-Oil,Tg3244,Lnms
Cooler Asm-Oil,Tgx244,Nms
Cooler-Oil,Ec01-12voc
Comp Asm-Hyd,Oil Cooler,Tg3244
Filter Instl-Pres,Tg3244,Lnms
Filter-Pressure,Argo,Hd172-166
Plate Instl-Bulkhead,Hitch,Nms
Plate Asm-Bulkhead,Hitch,Nms
Manf Instl-Leakage,Tg3244,Lnms
Manifold Asm-Leakage,3244,Lnms
Manf Asm-Leak,Tgx244,Lnms
Unit Instl-Hyd Pn El,X244,Lnms
Unit Asm-Hyd Pn El,X244,Lnms
Casing Asm-Hyd,Tgx244,Lnms
Manf Instl-Std,Hyd,X244,Lnms
Manf Asm-Std,Hyd,Tgx244,Lnms
Block-Hydr,Hic,Tg9205
Manifold-Nms,Hicb(Rev 07)
Manifold-Nms,Danfoss
Pump Instl-Hyd,Hd,Tg3244
Pump Asm-Hyd,Hd,Tgx244
Pump-Hyd,75cc,Rh,Pto,Sae C
Pump Instl-Hyd,Ls,Tg3244
Pump Asm-Hyd,Ls,Tgx244
Pump Hyd-Ls,Jrr060b
Valve Instl-Cutter,Std,Tgx244
Valve Asm-Cutter,Std,Tgx244
Valve-Hyd,,Ng06,4 3,A-B On T
Plumbing Instl-Cab,Articltn Pnt
Plumbing Instl-System,3244nms
Plumbing Instl-Cutter,X244,Nms
Plumb Instl-Knife Valve,10in
Plumbing Instl-Dw,3244nms
Valve Instl-Dw,3244,Lnms
Valve Asm-Dw,3244,Lnms
Valve-Pres Relief,A+B On T,Ng6
Valve-Hyd,,Ng06,4 2,A-B On T
Orifice-2.0mm,Ng6
Electrical Group
Hitch-Reduce,Instl,Switch
Harness Instl-Main,System,X244
Harness Instl-Lght,Tail,X244
Box Asm-Light,Tg Nms,Left
Light-Pendel,Diagonal
Box Asm-Light,Tg Nms,Right
Harness Instl-Hyd Unit,X244
Air System Group
Air Group,X244,Lnms
Valve Asm-Air,X244,Lnms
Hitch Group
Component Instl-Hitch
Arm Asm-Hitch,Tg
Bulkhead Asm-Hitch,9205nms
Link Asm-Lift,Long
Cylinder Asm-D50 100 230 510
Cylinder-Hyd,50 100 230 510mm
Link Asm-Lower,Cat Iv ,My07
Stabilization Asm-Hitch
Link-Top,Cat3,1 1 2 In. Unc,875mm
Kit-Coupler,Hyd,Iso,Loose
System Group
Mudguard Instl,Nms
Tank Instl-Polyester,Dw,18m3
Tank-Manure,Poly,18m3,Rwk
Pipe Instl-Poly,18m3,3244
Valve Asm-Rear,Tg3244
Valve Instl-Rear,Gate Valves
Valve Asm-Gate,6in,Air Cyl,Ind
Valve-Gate,6in
Cylinder Asm-Air,D20 80 160mm
Cylinder-Air,D20 80 160mm(6in)
Decal-Inst,Striping Nms 18m3
Fender Instl-Tank,Poly,3244
Fender Instl-Tg3244,Chassis,Dw
Fender Asm-Tg3244,Chassis,Dw,Lh
Fender Asm-Tg3244,Chassis,Dw,Rh
Level Indicator Group,3244
Level Indicator Asm-Ma Tk,Poly
Manhole Instl-Poly Tank
Breather Instl-Poly Tank
Lid Asm-Poly Tank,Breather
Lid-Poly Tank,High,Breather
Suction Arm Group
Block Instl-Ng6,Suction Horiz
Block Asm-Ng6,Suction Horiz
Valve-Hyd,,Ng06,4 3,Closed Center
Orifice-1.0mm,Ng6
Orifice-1.5mm,Ng6
Orifice-1.2mm,Ng6
Tube Instl-Overflow,3244,Lnms
Hose Instl-Horiz,Suction,Standard
Frame Instl-Leakage,X244,Lnms
Arm Instl-Suction,Hor,18m3,Poly
Hydraulic Group
Pump Hyd-Ls,Jrr060b
Orifice-2.0mm,Ng6
Electrical Group
Air System Group
Air Group,X244,Lnms
Hitch Group
Arm Asm-Hitch,Tg
Link Asm-Lift,Long
System Group
Mudguard Instl,Nms
Valve-Gate,6in
Suction Arm Group
Orifice-1.0mm,Ng6
Orifice-1.5mm,Ng6
Orifice-1.2mm,Ng6
