Challenger Terragator 3244 Chassis Parts Catalog AG622838
Brand: Challenger Terragator
Type of Machine: Applicators
Type of Manual: Chassis Parts Catalog
Model: Challenger 3244 Terragator Chassis
Serial Number: ..SXX1001 - ..SXX1010
Part Number: AG622838
Publication Date: 2008
Number of Pages: 943 Pages
Publication Information
Engine Group
Engine Instl-Cat Tiii,Tg3244
Engine Asm-Cat C11,Tiii,364hp
Cooler Instl-Tg3244
Cooler Asm
Tube Instl-Cooling Water
Tank Gp-Exp And Coolant
Tank Asm-Exp And Coolant
Tube Instl-Cac,Tg3244
Foam Inst-Anti False Air,Clr
Hose Instl-Cooler,Xmsn
Framing Instl-Safety,Fan
Exhaust Instl-Tg3244
Filter Instl-Air Intake,Tg3244
Transmission Group
Transmission Instl-Cat,Tg3244
Transmission Asm-Cat Delt,3244
Trans-Cat Delta,Pwrshft,16f 4r
Transmission Ar
Clutch Gp
Case Parts Gp-Planetary
Drive Gp-Pump
Shaft Gp-Transmission
Cover Gp Shipping
Clutch Gp Front Wheel Assist
4whl Drive
Valve Gp-Mdl-C
Mounting Gp-Transmission
Flange Kit-Split,Code 61-32
Filter Asm-Trmsn
Sensor-Hyd.Press.
Valve Gp-Rlf-C
Driveline Group
Drive System-Tg3244
Axle Group
Axle Instl-Axletech,Front
Axle-Front,24.66 1,Wet Disk
Carrier Assembly
Brake Assy
Housing Group
Wheel End
Wet Disc Brake
Axle Instl-Axletech,Rear,Str
Axle-Rear,24.66 1,Wet Disk
Axle Instl-Axletech,Dgwlk
Frame And Steering Group
Frame Asm-Front,Tg3244
Chassis Instl-Long,Rear
Chassis Asm-Rear,Straight
Plate Asm-Pendeling
Cylinder Asm-Steering,Artcl,Rh
Cylinder-Hyd,3.50x14.00x1.75 Rod
Cylinder Asm-Steering,Artcl,Lh
Driveline Instl,Chas,Rr,Str,L
Jackshaft Asm-Front,Tg3244
Chassis Instl-Dgwlk,Long
Chassis Asm-Dgwlk,Long
Cylinder Asm-Locking,Dgwlk
Cylinder-Hyd,Dogwalk,Locking
Drln Instl-Chas,Rr,L,Dgwlk
Driveline Asm-Rear
Jackshaft Asm-Rear,Tg3244
Bar-Follow,Driveline,Dgwlk
Hitch Instl-Tg3244
Block Asm-Div,Lub,Slewing Ring
Cylinder Asm-Steering,Dgwlk
Cylinder-Hyd,D40 80 360 670mm
Chassis Instl-Dgwlk,Shrt
Chassis Asm-Dgwlk,Shrt
Drln Instl-Chas,Rr,Shrt,Dgwlk
Jackshaft Asm-Ft,Shrt,Tg3244
Fuel System Group
Tank Instl-Fuel,200gl
Tank Asm-Fuel,Rh
Tank Asm-Fuel,100gl,Poly,Rh
Tank Asm-Fuel,Lh
Fuel Line Instl-Tg3244
Hydraulic Group
Orbitrol Instl-Steering
Orbitrol Asm-Steering
Tank Instl-Hyd,200l
Tank Asm-Hyd,200l
Filter-Rtn Suct,Argo,300l Min
Cap-Hyd Tank,Breather,Argo
Pump Instl-Gear,Snp3 Delta Trm
Valve Instl-Priority,150l Min
Valve Asm-Priority,150l Min
Valve-Priority,150l Min,Safim
Manifold Instl-Return,Tg3244
Manifold Asm-Return Oil
Accumulator Instl-Tg3244
Hose Instl-Hyd Sys,Tg3244chas
Air System Group
Tank Instl-Air,42l,Tg3244
Tank Asm-Air,42l
Tank Asm-Air,21l,Front (Wet)
Tank Asm-Air,21l,Rear (Dry)
Dryer Instl-Air,Sgl Canister
Governor Air Dryer Asm
Dryer-Air,Single Canister
Hose Instl-Air System,Tg3244
Cab Group
Cab Instl-Tg3244
Pedal Instl-Brake,Tg (Service)
Pedal Asm-Brake
Windshield Wash-Fluid Fill
Dash Instl-Center Console
Asm-Dash Cluster
Kit-Electrical,Cab
Bracket Instl-Mag Sw
Sw Asm-Magnetic
Panel Instl-Trim,Tg
Lighter Asm-Cigar
Airline Ftg Instl-Cab,Airhorn
Harness Instl-Cab,Cat,3244
Module-Power Dist, Ii Fuse
Module-Power Dist,Hi Current
Pedal Instl-Cab,Tg3244
Pedal Asm-Inching,Cat
Pedal-Inching,Cat Trans
Pedal Asm-Throttle
Harn Instl-Center Con,3244
Floormat Instl-Cab,Upgrade,Tg
Cab Asm-Terragator,Non Dom
Valve Instl-Horn,Air
Door Asm-Lh
Door Inst
Cab Glass
Air Horn
Outer Roof
Window Glass Rh
Roof Inner
Controls Front
Steering Column Covers
Hvac
Hvac W And W O Atc
Motor Blower Asm Pressure
Wiper
Interior Trim
Floormat Covers
Cab Electrical
Audio
Electrical Roof
Barrier Instl-Heat
Harness Instl-Cab,Eu
Cylinder Instl-Tipping,Cab
Cylinder-Hyd,D40 60 560 749mm
Pump Instl-Tilt,Cab,Tg3244
Cylinder Instl-Air Spnsn,Rh
Cylinder Instl-Air Spnsn,Lh
Hose Instl-Hyd Sys,Tg3244cab
Seat Instl-Basic
Seat Asm-Basic,Air
Kit-Seat As. Upper
Kit-Seat Top, Sst
Kit-Back,Upper
Kit-Cushion,Seat,Sst
Kit-Suspension Gp (Seat)
Kit-Arm Rest As. (Lh)
Seat Instl-Deluxe
Seat Asm-Deluxe,Semi Active
Kit-Suspension,Semi Active
Radio Instl-Europa
Cab Instl-Tg3244liq Dry
Armrest-Asm,3244,Nms
Armrest Asm,3244,Bare Chassis
Armrest Asm-9203,Nl
Panel Instl-Keypad,Tg3244
Hose Instl-A C,Tg3244
A C Instl Group
A C Asm,Cii
Filter Asm-A C
Electrical Group
Harness Instl-Chassis,Tg3244
Battery Instl-Tg3244
Cable Instl-Battery,Tg3244
Switch Instl-4wd,Tg
Flasher Instl-Non Domestic (Eu)
Lighting Group
Light Instl-Work,Nose
Light Instl-Work,Nose,Hid
Worklight Instl-Fender
Lamp-Working,Rectang,Rwk
Harness Instl-Wl,Fender
Appearance Group
Platform Instl-Entrance,Tg3244
Ladder Asm-Entrance,Tg3244
Mudguard Instl-Front,3.15m
Tank Instl-Rinse,8.0gl
Tank Asm-Water
Hood Instl-Tg3244
Frame Asm-Hinge,Hood,Tg3244
Hood-Asm,Tg2244 Tg3244
Grill Asm-Tg
Lock-Hood
Boxes Instl-Storage,Fr
Box Asm-Storage,Rh
Headlamp Asm-Halogen,Rh
Box Asm-Storage,Lh
Headlamp Asm-Halogen,Lh
Insulation Instl-Tg3244
Fender Instl-Extensions,3.15m
Fender Instl-Extensions,3.35m
Mudguard Instl-Front,3.35m
Tire And Wheel Group
Tire Instl-1050 50r32,T2,Mich,3.15m
Rim And Tire Asm-1050 50 R32,T2,Lh,3.15m
Rim And Tire Asm-1050 50 R32,T2,Rh,3.15m
Tire Instl-1050 50 R32,M28,Mic,3.15m
Rim And Tire Asm-1050 50r32,M28,Rh,3.15m
Rim And Tire Asm-1050 50r32,M28,Lh,3.15m
Tire Instl-1050 50r32,T2,Mich,3.35m
Rim And Tire Asm-1050 50r32,T2,Rh,3.35m
Rim And Tire Asm-1050 50 R32,T2,Lh,3.35m
Tire Instl-1050 50r32,M28,Mich,3.35m
Rim And Tire Asm-1050 50r32,M28,Rh,3.35m
Rim And Tire Asm-1050 50r32,M28,Lh,3.35m
Decal Group
Decal Instl-Cab,92xx
Guidance Group
Radar Group-Common
No Controller
Controller Instl-Gta
Options Group
Kit-Extra Key
Wegde Gp-Wheel,Tg3244
Engine Group
Cooler Instl-Tg3244
Cooler Asm
Transmission Group
Transmission Ar
Clutch Gp
Drive Gp-Pump
Cover Gp Shipping
4whl Drive
Valve Gp-Mdl-C
Filter Asm-Trmsn
Sensor-Hyd.Press.
Valve Gp-Rlf-C
Driveline Group
Drive System-Tg3244
Axle Group
Carrier Assembly
Brake Assy
Housing Group
Wheel End
Wet Disc Brake
Plate Asm-Pendeling
Driveline Asm-Rear
Hitch Instl-Tg3244
Fuel System Group
Tank Asm-Fuel,Rh
Tank Asm-Fuel,Lh
Hydraulic Group
Tank Instl-Hyd,200l
Tank Asm-Hyd,200l
Air System Group
Tank Asm-Air,42l
Cab Group
Cab Instl-Tg3244
Pedal Asm-Brake
Asm-Dash Cluster
Kit-Electrical,Cab
Sw Asm-Magnetic
Panel Instl-Trim,Tg
Lighter Asm-Cigar
Pedal Asm-Throttle
Door Asm-Lh
Door Inst
Cab Glass
Air Horn
Outer Roof
Window Glass Rh
Roof Inner
Controls Front
Hvac
Hvac W And W O Atc
Wiper
Interior Trim
Floormat Covers
Cab Electrical
Audio
Electrical Roof
Barrier Instl-Heat
Seat Instl-Basic
Seat Asm-Basic,Air
Kit-Seat As. Upper
Kit-Seat Top, Sst
Kit-Back,Upper
Seat Instl-Deluxe
Radio Instl-Europa
Armrest Asm-9203,Nl
A C Instl Group
A C Asm,Cii
Filter Asm-A C
Electrical Group
Switch Instl-4wd,Tg
Lighting Group
Appearance Group
Tank Asm-Water
Hood Instl-Tg3244
Grill Asm-Tg
Lock-Hood
Box Asm-Storage,Rh
Box Asm-Storage,Lh
Decal Group
Guidance Group
Radar Group-Common
No Controller
Options Group
Kit-Extra Key
