Challenger Terragator 2244 NMS Liquid System Parts Catalog AG637297
Brand: Challenger Terragator
Type of Machine: Applicators
Model: Challenger 2244 NMS Terragator Liquid System (2010)
Part Number: AG637297
Publication Date: 2011
Number of Pages: 1697 Pages
Publication Information
Product Containment
Tank Opt-Poly,Tg2244,Dw,15m3
Mudguard Instl,Nms
Fender Instl-Chassis,Tg2244,Dw
Fender Asm-Tg2244,Chassis,Dw,Lh
Fender Asm-Tg2244,Chassis,Dw,Rh
Fender Instl-Tank,Poly,Tg2244
Tank Asm-Poly,Tg2244,Dw,15m3
Level Indicator Group,3244
Level Indicator Asm-Ma Tk,Poly
Manhole Instl-Poly Tank
Breather Instl-Poly Tank
Lid Asm-Poly Tank,Breather
Lid-Poly Tank,High,Breather
Pipe Instl-Poly,Tg2244,15m3
Valve Instl-Rear,Gate Valves
Valve Asm-Gate,6in,Air Cyl,Ind
Valve-Gate,6in
Cylinder Asm-Air,D20 80 160mm
Cylinder-Air,D20 80 160mm(6in)
Decal Inst-Striping,Lnms,8333
Primary Product Distribution
Arm Instl-Suction,Non,2244
Cutter-Modif,Manure,Std,Poly
Support-Hose,Asm
Tube Instl-Overflow,2244,Lnms
Hose Instl-Hyd,Borger,Std,2244
Cover Instl-Blind,8in
Harness Instl-Loadvalve
Arm Instl-Suction,Hor,Sl,2244
Arm Opt Instl-Suct,Sl,2244
Component Instl-Elec,Sl Sucarm
Valve Inst-Cutter,Superload
Valve-Hyd,,Ng06,4 3,A-B On T
Component Instl-Cntfgl Pump,Sl
Valve Asm-Knife,10in,Superload
Valve-Knife,Dn250
Cilinder Asm-D16 25 260 395,Hc
Cylinder-Hyd,D16 25 260 395mm
Ring Sprt Instl-Rbr Superld
Ng16 Instl-Hyd,X244lnms
Ng16 Asm-Hyd,X244lnms
Valve-Hyd,Ng16,Ptoa,Ttob
Cutter-Modif,Manure,Sl,Tg2244
Valve Asm-Knife,8.0in,Superload
Valve-Knife,Dn200
Cylinder-Hyd,D20 40 200
Decal Instl-Superload,Lnms
Component Instl-Hydr,Sl,2244
Component Asm-Hydr,Sl,2244
Bracket Instl-Manf,Ng16,2244
Hose Instl-Hyd,Sl,Hor Arm
Harness Instl-Sl
Block Instl-Ng6,Suction Horiz
Block Asm-Ng6,Suction,Horiz
Valve-Hyd,,Ng06,4 3,Closed Centre
Orifice-1.0mm,Ng6
Orifice-1.5mm,Ng6
Orifice-1.2mm,Ng6
Frame Instl-Leakage,X244,Lnms
Valve Inst,Ng6,Hor,Suct,Std
Valve-2 2,Nc,3 8
Hose Instl-Hor Suct,Std,8333
Harn Instl-Suction,H,Std,8333
Arm Inst-Suction,Hor,Poly,2244
Bearing Asm-Blk,Hitch
Bearing Asm-Block,Hitch,Tri-Axer
Arm Asm-Suction,Horizon,2244
Cylinder Asm-D30 50 60 180 500mm
Cylinder-Hyd,D30 60 180 500
Cylinder Asm-D30 50 580 895mm
Cylinder-Hyd,D30 50 580 895mm
Cylinder Asm-D25 40 150 349
Cylinder-Hyd,D25 40 150 349
Cylinder Asm-D25 40 150 349mm
Rubber Asm-Harmonica,8in
Coupling-Turnable,8in
Pump Asm-Centrifugal,Combiload
Motor Asm-Hyd,100cc
Motor-Hyd,100cc,Side Ports
Coupling Instl-Cntfgl P,10baue
Funnel Opt-Suction,10inch
Hose Inst,Ng6,Hor,Suct,Std
Arm Opt Instl-Horiz,Suct Arm
Coupling Instl-Suct Arm,8.0bau
Funnel-Asm-Suction,8inch
Arm Group-Suct,Vert,Std,2244
Harness Instl-Ver Arm
Valve Instl-Cyl,Vert Arm.2244
Valve Asm-Ng6,Cyl,Vert Arm
Valve-Pres Relief,A+B On T,Ng6
Hose Instl-Cyl,Vert Arm,2244
Hose Instl-Air,Vert Arm,2244
Hose Instl-8in,Std,Vert
Arm Instl-Vert,Suct,Std,2244
Cylinder Asm-Lift,Vert,Arm
Cylinder-Hyd Lift,Vert Arm
Arm Asm-Vert,Suction,Std,2244
Valve Asm-8in,Air Cylinder
Cylinder Asm-Air,D22 80 200mm
Cylinder-Air,D22 80 200mm(8in)
Valve-Stem,Gate,Flanged,8
Hinge Instl-Hose 8in,Std,Vert
Cylinder Asm-Swing,Hose,Sl,Ver
Cylinder-Hyd,D25 40 340 600mm
Cylinder Asm-Piv,Hose,10in,Sl
Cylinder-Hyd,D25 50 125 354mmm
Box Opt-Leakage,Vert Arm,2244
Arm Group-Suct,Vert,Sl,2244
Arm Instl-Vert,Suct,Sl,2244
Arm Asm-Vert,Suction,Sl,2244
Pump Instl-Cntfgl,Manure,Ver
Pump Asm-Centrifugal,Superload
Hose Instl-10in,Sl,Ver
Hose Instl-Hyd,Sl,Ver Arm
Arm Instl-Hor,Suct Hor,Lg
Arm Asm-Suction,Horizontal,Lg
Cylinder Asm-Lift,Suc Arm,Hor
Cylinder-Hyd,D25 50 200 446mm
Cylinder Asm-Lift2,Suc Arm,Hor
Cylinder-Hyd,D25 40 200 446mm
Support Instl-Suc Arm,Lg
Hose Instl-Air,Suc Arm,Hor,Lg
Harness Instl-Hor Arm,Lg
Bucket Instl-Leakage,2244,Lnms
Tube Instl-Rising,Suc,Arm,Lg
Tube Asm-Rising,Suc Arm,Lg
Motor Asm-Hyd,Suc Arm,Hor,Lg
Hose Instl-Hyd,Suc Arm,Hor,Lg
Valve Instl-Cyl,Hor Arm.Lg
Valve Asm-Ng6,Cyl,Hor Arm,Lg
Cutter Instl-Manure,12000,X244
Cutter Asm-Rotacut,X244,Lnms
Cutter-Rc12000,Oms250m
Motor-Hydr,Oms 250 M,Rc12000
Component Asm,Manual Valve,6in
Valve Asm-Manual,6in
Valve-Stem,Gate,Flanged,Mz,6in
Air Instl-Rc12000,X244,Lnms
Toolkit Asm-Dismantle,Rotacut
Support Asm-Tool,Dism,Rc,2244
Cutter Instl-Manure,10000,X244
Rc10000-Incl,Oms200cc
Motor-Hydr,Oms 200,Rc10000
Swivel Instl-Tool,Dism,Rc10000
Swivel Asm-Tool,Dism,Rc10000
Pump Group-Fl1036,Tg3244,Lnms
Pump Asm-Fl1036,Tgx244,Lnms
Transducer Connection Asm
Motor-Hyd,55cc,Incl Sensor
Pump-Manure,Fl1036
Gearbox-Pd1045 Mr1 3.5 00
Pump Group-Fla1540,Tg3244,Lnms
Pump Asm-Fla1540,Tgx244,Lnms
Pump-Manure,Fla1540
Hydraulic Group,Tg2244,Lnms
Plumb Group-Syst,Std,2244,Lnms
Plumbing Instl-Hitch,Lnms
Plumbing Instl-2244,Cab Artclpnt
Plumbing Instl-Pump,Ls,Cab,Blkhd
Plumbing Instl-System,2244,Nms
Plumb Instl-Knife Valve,10in
Plumbing Instl-Cutter,2244,Nms
Bulkheadplate Instl-Artclpnt
Plate Asm-Bulkhead,Tg3244
Cooler Instl-Oil,Tgx244,Lnms
Cooler Asm-Oil,Tgx244,Nms
Cooler-Oil, Ec01-12voc
Comp Asm-Hyd,Oil Cooler,Tgx244
Unit Instl-Hyd Pn El,X244,Lnms
Unit Asm-Hyd Pn El,X244,Lnms
Casing Asm-Hyd,Tgx244,Lnms
Manf Instl-Std,Hyd,X244,Lnms
Manf Asm-Std,Hyd,Tgx244,Lnms
Block-Hydr,Hic,Tg9205
Manifold-Nms,Hicb(Rev 07)
Manifold-Nms,Danfoss
Pump Instl-Hyd,Hd,Tg3244
Pump Asm-Hyd,Hd,Tgx244
Pump-Hyd,75cc,Rh,Pto,Sae C
Pump Instl-Hyd,Ls,Tg3244
Pump Asm-Hyd,Ls,Tgx244
Pump Hyd-Ls,Jrr060b
Valve Instl-Cutter,Std,Tgx244
Valve Asm-Cutter,Std,Tgx244
Filter Instl-Pres,Tg8333,Lnms
Filter Asm-Pres,Lnms
Filter-Pressure,Argo,Hd172-166
Manf Instl-Leakage,2244,Lnms
Manf Asm-Leak,Tgx244,Lnms
Bracket Instl-Manf,Lkg,2244
Valve Instl-Dw,2244,Lnms
Valve Instl-Dw,3244,Lnms
Valve Asm-Dw,3244,Lnms
Valve-Hyd,,Ng06,4 2,A-B On T
Valve-Reducer,160bar,Ng6
Orifice-2.0mm,Ng6
Plumbing Instl-Dw,2244,Lnms
Kit-Coupler,Hyd,Iso,Loose
Coupler Asm-Multi,Hyd,Chassis
Coupler Opt-Multi,Hyd,Toolbar
Harness Instl-Dogwalk,X244
Switch Instl-Dw,Lock-Unlk,X244
Air System
Air Group,X244,Lnms
Valve Asm-Air,X244,Lnms
Link Instl-Lower,Quick,Cat Iii
Link Asm-Lower,Qik,Cat Iii,Lh
Link Asm-Lower,Qik,Cat Iii,Rh
Link Instl-Lower,Quick,Cat Iv
Link Asm-Lower,Qik,Cat Iv,Lh
Link Asm-Lower,Qik,Cat Iv,Rh
Link Instl-Lower,Cat Iii
Link Asm-Lower,Cat Iii-Iv
Plate Instl-Bulkhead,Hitch,Nms
Plate Asm-Bulkhead,Hitch,Nms
Coupler Opt-Multi,Hyd,Chassis
Instl-Box,Tools
Accessoiries
Spare Parts-Tg Nms
Adapter-Gauge,Meas Point
Specification-Nl,Tg2244,Lnms
Decal-Inst,2244,Lnms,General
Cust Docs-2244,Lnms.Nl
Binder-Sheets,Operatorinfo
Country-Spec,Instl,Tg2244,Nl
Long Load Sign Instl-9205nms
Sign-Long Load,423x423
Specification-Uk,Tg2244,Lnms
Cust Docs-2244,Lnms,Uk
Country-Spec,Instl,Tg2244,Uk
Specification-Ger,Tg2244,Lnms
Cust Docs-2244,Lnms,Ger
Country-Spec,Instl,Tg2244,Ger
Wedge Gp-Wheel,Tg2244
Specification-Fr,Tg2244,Lnms
Cust Docs-2244,Lnms,Fr
Country-Spec,Instl,Tg2244,Fr
Country-Spec,Instl,Tg2244,It
Specification-It,Tg2244,Lnms
Cust Docs-2244,Lnms,It
Mirror Instl-Standard
Bracket Asm,Mirror,Lh
Bracket Asm,Mirror,Rh
Mirror Instl-Adj And Heat
Bracket Asm-Mir, Adj And Heat,Rh
Bracket Asm-Mir, Adj And Heat,Lh
Coupler Asm-Quick,Hitch,Catiii
Link-Top,Cat3,1 1 2 In. Unc,750mm
Coupler Asm-Quick,Vh,Ej35840
Coupler Asm-Quick,Vh,Tj644
Coupler Asm-Quick,Toolbar
Camera Instl-Rear Cam,Colour
Monitor Instl-Rear Cam,Color
Harness Instl-Wl,Cab,Rr,Bare
Worklight Instl-Cab,W O Rops
Lamp-Working,Rectang,Rwk
Worklight Opt-Hor Suct Arm
Light Asm-Work.Dual.Brckt
Worklight Opt-Vert Suct Arm
Worklight Opt-Fender,Fr,Rv,Hal
Worklight Opt-Fender,Fr,Rv,Hid
Light Asm-Work,Hid,Dual,Brckt
Worklight Opt-Fender,Fr,Rv,Non
Worklight Opt-Lnms,Rear,Hal
Worklight Opt-Lnms,Rear,Non
Towing Hook-Sk5a (Front)
Connection Opt-Air V,Injector
Kit-Coupler,Air,Loose
Valve Opt-Reload,Rh
Component Asm-Manual,Valve,6in
Coupler-Quick,Left Front,6in
Nozzle Instl-Discharge
Hose Asm-Extension,6.0in,2244
Hose Asm-Supply Tank,6.0in,2244
Hose Asm-Suction,6.0in,2244
Lamp Instl-Rotating,Lh,Front
Connection Asm-Lamp,Rotating
Lamp Instl-Rotating,Rh,Front
Comp Instl-Hyd,Func,Extra,Std
Comp Instl-Elec,Hyd,Func,Opt
Valve Instl-Hyd,Extra,Open,Ver
Valve Asm-Hyd,Extra,Open,Nms
Hose Instl-Function Opt,Extra
Kit-Coupler,Hyd,Iso,Loose,Ex
Valve Asm-Hyd,Extra,Closed,Nms
Valve Instl-Hyd,Extra,Open,Hor
Function Opt-Hyd,Extra,Closed
Valve Instl-Hyd,Ext,Closed,Hor
Function Opt-Hyd,Xtr,2nd,Closd
Coupling Instl-Hyd,Extra,2nd
Harness Instl,Funct,Hyd,2nd
Comp Instl,Hyd,Funct,Extra,2nd
Hose Instl-Funct,Opt,Extra,2nd
Canbus Opt-Ext,Sys Nms Liq
Towing Hook Opt-Hitch
Bulkhead Asm-Drawbar
Drawbar Instl-Hitch
Product Containment
Mudguard Instl,Nms
Valve-Gate,6in
Support-Hose,Asm
Valve-Knife,Dn250
Valve-Knife,Dn200
Harness Instl-Sl
Orifice-1.0mm,Ng6
Orifice-1.5mm,Ng6
Orifice-1.2mm,Ng6
Valve-2 2,Nc,3 8
Motor Asm-Hyd,100cc
Pump-Manure,Fl1036
Pump-Manure,Fla1540
Pump Hyd-Ls,Jrr060b
Orifice-2.0mm,Ng6
Air System
Air Group,X244,Lnms
Instl-Box,Tools
Accessoiries
Spare Parts-Tg Nms
Valve Opt-Reload,Rh
Drawbar Instl-Hitch
