Challenger Terragator 2244 Chassis Parts Catalog AG636337
Brand: Challenger Terragator
Type of Machine: Applicators
Type of Manual: Chassis Parts Catalog
Model: Challenger 2244 Terragator Chassis (2008)
Serial Number: ..1031 - ..1040
Part Number: AG636337
Publication Date: 2011
Number of Pages: 315 Pages
Publication Information
Engine Group
Engine Instl-Sisu8.4cta,300hp
Engine Asm-Sisu8.4cta,300hp
Tube Instl-Cac,Tg2244
Tank Instl-Exp And Coolant,2244
Tank Asm-Exp And Coolant,Tg2244
Tube Instl-Cooling Water,2244
Hose Instl-Cooler,Xmsn,Tg2244
Framing Instl-Safety,Fan,2244
Cooler Instl-Tg2244
Cooler Asm-Tg2244
Foam Instl-Anti False Air,Clr
Exhaust Instl-Tg2244
Tube-Flexible,Exhaust
Filter Instl-Air Intake,Tg2244
Cleaner-Gp,Air
Transmission Group
Transmission Instl-Funk,Pwrshft
Filter Asm-Trmsn,Funk
Transmission Asm-Funk,Pwrshft
Dipstick-Funk Transmission,Mod
Driveline Group
Drive System Front-Tg2244
Driveline Asm-7c,Eng Xmsn,2244
Driveline Asm-Axle,Front,2244
Drive System-Rear,Str,Tg2244
Driveline Asm-Rear,Axle,7c
Jackshaft Asm-Front,Tg2244
Driveline Asm-7c,Trsmn Art Pnt
Hitch Instl-Dgwlk,Tg2244
Block Asm-Div,Lub,Slewing Ring
Cilinder Asm-Steering,Dgwlk,Lh
Cylinder-Hyd,D40 80 360 670mm
Cilinder Asm-Steering,Dgwlk,Rh
Hose Instl-Hyd,Brake,Tg2244dw
Driveline Instl-Rr,Dgwlk,Tg2244
Driveline Asm-Rear,Tg2244
Bar-Follow,Driveline,Dgwlk
Driveline Asm-Joint Lkge,7c
Jackshaft Asm-Rear,Tg2244
Axle Group
Axle Instl-Front,Jd,Tg2244
Axle Asm-Front,Jd,Tg2244
Axle-Front,22.9344 1,Wet Disk
Axle Instl-Rear,Jd,Tg2244dw
Axle Asm-Rear,Jd,Tg2244dw
Axle-Rear,22.933 1,Wet Disc
Pignon Ring Gear
Input Yoke
Axle Housing And Shaft
Input Housing
Brakes
Differential Bearing Quills
Standard Differential
Differential Case
Planetary Drive
Dual Brake Hardware
Axle Instl-Rear,Jd,Tg2244str
Axle Asm-Rear,Jd,Tg2244str
Hose Instl-Hyd,Brake,Tg2244str
Frame And Steering Group
Chassis Group-Standard,Front
Frame Asm-Front,Tg2244
Chassis Instl-Rr,Dgwlk,Tg2244
Chassis Asm-Rear,Dgwlk,Tg2244
Cylinder Asm-Locking,Dgwlk
Cylinder-Hyd,Dogwalk,Locking
Plate Asm-Pendulum,Artcl,2244
Cylinder Asm-Steering,Artcl
Cylinder Asm-Steering,Dgwlk,Lh
Cylinder Asm-Steering,Dgwlk,Rh
Chassis Instl-Rear,Tg2244
Chassis Asm-Rear,Str,Tg2244
Fuel System Group
Tank Instl-Fuel,130gl 2244
Tank Asm-Fuel,Rh (65gl)
Cap Instl-Fuel,Lockable
Tank Asm-Fuel,Lh (65gl)
Engine Group
Cooler Instl-Tg2244
Cooler Asm-Tg2244
Cleaner-Gp,Air
Transmission Group
Driveline Group
Axle Group
Pignon Ring Gear
Input Yoke
Input Housing
Brakes
Differential Case
Planetary Drive
Dual Brake Hardware
Fuel System Group
