Challenger Terragator 2244 Chassis Parts Catalog AG636336
Brand: Challenger Terragator
Type of Machine: Applicators
Type of Manual: Chassis Parts Catalog
Model: Challenger 2244 Terragator Chassis (2008)
Serial Number: ..1021 - ..1030
Part Number: AG636336
Publication Date: 2012
Number of Pages: 752 Pages
Publication Information
Engine Group
Engine Instl-Sisu8.4cta,300hp
Engine Asm-Sisu8.4cta,300hp
Tube Instl-Cac,Tg2244
Tank Instl-Exp And Coolant,2244
Tank Asm-Exp And Coolant,Tg2244
Tube Instl-Cooling Water,2244
Hose Instl-Cooler,Xmsn,Tg2244
Framing Instl-Safety,Fan,2244
Cooler Instl-Tg2244
Cooler Asm-Tg2244
Foam Instl-Anti False Air,Clr
Exhaust Instl-Tg2244
Tube-Flexible,Exhaust
Filter Instl-Air Intake,Tg2244
Cleaner-Gp,Air
Transmission Group
Transmission Instl-Funk,Pwrshft
Filter Asm-Trmsn,Funk
Transmission Asm-Funk,Pwrshft
Dipstick-Funk Transmission,Mod
Driveline Group
Drive System Front-Tg2244
Driveline Asm-7c,Eng Xmsn,2244
Driveline Asm-Axle,Front,2244
Drive System-Rear,Str,Tg2244
Driveline Asm-Rear,Axle,7c
Driveline Asm-7c,Trsmn Art Pnt
Jackshaft Asm-Front,Tg2244
Driveline Instl-Rr,Dgwlk,Tg2244
Driveline Asm-Rear,Tg2244
Bar-Follow,Driveline,Dgwlk
Driveline Asm-Joint Lkge,7c
Jackshaft Asm-Rear,Tg2244
Axle Group
Axle Instl-Front,Jd,Tg2244
Axle Asm-Front,Jd,Tg2244
Axle-Front,22.9344 1,Wet Disk
Dual Brake Hardware
Axle Instl-Rear,Jd,Tg2244dw
Axle Asm-Rear,Jd,Tg2244dw
Axle-Rear,22.933 1,Wet Disc
Pignon Ring Gear
Input Yoke
Axle Housing And Shaft
Input Housing
Brakes
Differential Bearing Quills
Standard Differential
Differential Case
Planetary Drive
Axle Instl-Rear,Jd,Tg2244str
Axle Asm-Rear,Jd,Tg2244str
Hose Instl-Hyd,Brake,Tg2244str
Frame And Steering Group
Chassis Group-Standard,Front
Frame Asm-Front,Tg2244
Chassis Instl-Rr,Dgwlk,Tg2244
Chassis Asm-Rear,Dgwlk,Tg2244
Cylinder Asm-Locking,Dgwlk
Cylinder-Hyd,Dogwalk,Locking
Plate Asm-Pendulum,Artcl,2244
Cylinder Asm-Steering,Artcl
Cylinder-Hyd,D40 80 360 670mm
Hitch Instl-Dgwlk,Tg2244
Block Asm-Div,Lub,Slewing Ring
Cylinder Asm-Steering,Dgwlk,Lh
Cylinder Asm-Steering,Dgwlk,Rh
Hose Instl-Hyd,Brake,Tg2244dw
Chassis Instl-Rear,Tg2244
Chassis Asm-Rear,Str,Tg2244
Fuel System Group
Tank Instl-Fuel,130gl 2244
Tank Asm-Fuel,Rh (65gl)
Cap Instl-Fuel,Lockable
Tank Asm-Fuel,Lh (65gl)
Fuel Line Instl-Tg2244
Hydraulic Group
Tank Instl-Hyd,200l,Tg2244
Tank Asm-Hyd,200l
Filter-Rtn Suct,Argo,300l Min
Cap-Hyd Tank,Breather,Argo
Elbow Asm-Hydr,Tank
Common Hydraulic System-Tg2244
Accumulator Instl-Tg2244
Pump Instl-Gear,Snp3 Funk Trmsn
Valve Instl-Priority,150l Min
Valve Asm-Priority,150l Min
Manifold Instl-Return,Tg2244
Manifold Asm-Return Oil,Tg2244
Hose Intsl-Hyd Sys,Tg2244
Air System Group
Tank Instl-Air,60l,Tg2244
Tank Asm-Air,30l,Wet (Rh)
Tank Asm-Air,30l,Dry (Lh)
Hose Instl-Air System,Tg2244
Dryer Instl-Air,Sgl Canister
Dryer Asm-Air,Sgl Canister
Hose Instl-425l Air System
Dryer Instl-Air,Dbl Canister
Dryer Asm-Air,Dbl Canister
Cooler Instl-Air,700l
Hose Instl-700l Air System
Cab Group
Cylinder Instl-Air Spnsn,Rh
Cylinder Instl-Air Spnsn,Lh
Cylinder Instl-Tipping,Cab
Cylinder Asm-Tipping,Cab,Tg2244
Cylinder-Hyd,35 60 263 463mm
Pump Instl-Tilt,Cab,Tg2244
Pump Asm-Tilt,Cab,Tg2244
Hose Instl-Hyd Sys,Cab,Tg2244
Cab Instl-Tg2244
Windshield Wash-Fluid Fill
Dash Instl-Center Console
Rb 535462d1
Kit-Electrical,Cab
Pedal Instl-Cab,Tg
Pedal Asm-Inching,Funk
Panel Instl-Trim,Tg
Airline Ftg Instl-Cab,Airhorn
Harn Instl-Center Con,Cat Ts
Harness Instl-Cab,Cat Ts,Eur
Asm Cab-X244,W Pallet
Cab Group-X244
Decal Instl-Cab,81xx
Orbitrol Instl-Steering
Orbitrol Asm-Steering
Pedal Instl-Brake,Tg (Service)
Pedal Asm-Brake
Pedal-Brake,Hyd,Safim
Harness Instl-Cab,Eu
Seat Instl-Deluxe
Seat Asm-Deluxe,R B 530160d1
Kit-Seat As. Upper
Kit-Arm Rest As. (Lh)
Kit-Seat Top, Sst
Kit-Suspension
Kit-Suspension,Semr B 524649d1
Seat Asm-Deluxe,Ser B530160d1
Kit-Suspension R B 547609d1
Seat Asm-Deluxe,Semi Active
Kit-Suspension Sa
Kit-Suspension Gp (Seat)
Flasher Instl-Non Domestic (Eu
Radio Instl-Europa
Kit-Extra Key
Air Conditioning Group-Tg2244
A C Filter Instl-Tg2244
Hose Instl-A C,Tg2244
Electrical Group
Battery Instl-Tg2244
Cable Instl-Battery,Tg2244,07
Harness Instl-Chassis,Tg2244
Switch Instl-4wd,Tg2244
Component Instl-Elec,Tg2244
Lighting Group
Light Instl-Work,Nose
Light Instl-Work,Nose,Hid
Appearance Group
Plateau Instl-Fuel,Tg2244
Boxes Instl-Storage,Fr,Tg2244
Box Asm-Storage,Lh,Tg2244
Headlamp Asm-Halogen,Lh
Box Asm-Storage,Rh,Tg2244
Headlamp Asm-Halogen,Rh
Plate Instl-Cover,Front,Tg2244
Ladder Instl-Entrance,Tg2244
Ladder Asm-Entrance,Tg2244
Panel Instl-Side,Hood,Tg2244
Panel Asm-Hood,Rh,Tg2244
Panel Asm-Hood,Lh,Tg2244
Hood Instl-Tg2244
Frame Asm-Hood,Tg2244
Hood Asm-Tg2244
Decal-Inst,Enginehood
Hood-Laminated,Tg2244
Safetythread Instl-Fender
Tire And Wheel Group
Tire Instl-1050 50r32,T2,Mich
Rim And Tire Asm-1050 50r32,T2,Rh,3.10m
Rim And Tire Asm-1050 50r32,T2,Lh,3.10m
Tire Instl-1050 50r32,M28,Mich
Rim And Tire Asm-1050 50r32,M28,Rh,3.10m
Rim And Tire Asm-1050 50r32,M28,Lh,3.10m
Fender Instl-Extention,3.10m
Decal Group
Decal Instl,Tg2244
Guidance Group
No Controller
Controller Instl-Gta
Options Group
Cab Instl-Tg2244,Liq Dry
Armrest Asm-Tg2244,Liq Dry
Armrest Asm-6 81xx,Nl
Joystick Asm-System,Tg
Panel Instl-Keypad,Tg3244
Throttle Instl-Remote,Tg2244
Tank Instl-Water,10l,Tg2244
Specifications By Country Group
Cust Docs-2244,Chassis,Nl,08
Binder-Sheets,Operatorinfo
Decal Instl,Tg2244,Nl
Cust Docs-2244,Chassis,Ger,08
Decal Instl,Tg2244,Ger
Cust Docs-2244,Chassis,Fr,08
Decal Instl,Tg2244,Fr
Instl-Speedlimit,25km H,2244
Cust Docs-2244,Chassis,It,08
Decal Instl,Tg2244,It
