Challenger Terragator 1800 GL 2400 GL C Liquid System Parts Catalog 603490D1
Brand: Challenger Terragator
Type of Machine: Applicators
Model: Challenger 1800 GL, 2400 GL Terragator 'C' Liquid System (2019-2021)
Serial Number: ..KXXX1001-..MXXX9999
Part Number: 603490D1
Number of Pages: 351 Pages
Product Containment
1800 2400 Liquid
1800 Gallon
2400 Gallon
Holddown Installation, 3 Wheel, Liquid System
Holddown Installation, 4 Wheel, Liquid System
License Plate Bracket Installation
1800 2400 Gallon
Tank Assembly, 1800 Gallon
Tank Assembly, 2400 Gallon
Butterfly Valve Assembly, 2.00, Electrical, 7 Section
Top Tank Assembly, 135 Gallon
Primary Product Distribution
1800 Liquid
Chemical Eductor, Cleanload, 7 Gallon
Tank Ball Valve
Clean Load Lid Kit, 16 Inch
Flowmeter Assembly, Raven, Magnetic, 3.00 Inch, Flanged
Flowmeter Assembly-Raven, 3.00 Flange
Mounting Ring Assembly, Cleanload
Low Volume, 2400
Suction Plumbing Installation, 5 X 3, 2400 Gallon
Reload Valve Assembly, 5.00, 2400
Scott, 2400 Gallon
Suction Plumbing Installation, 5 Inch, 2400 Gallon
Product Plumbing Installation, 5x3 High Volume, 2400 Gallon
Product Pump Installation, 4 X 3 Plumbing
Product Pump Assembly, 4 X 3
Product Pump Installation, 5 X 3, High Volume, 2400
Product Pump Assembly, 5 X 3
Product Pump, 4.00 X 3.00, Grooved
Centrifugal Pump, 5 X 3
Rear Manifold Assembly, 3x2
Rear Manifold Assembly, 4x3
Plumbing Assembly, Strainer, 2400 Gallon, 3.00
Strainer, 3.00 Line, 316 Ss
Plumbing Assembly, Strainer, 2400 Gallon, 4.00
Y Strainer, 4.00 Inch
Ball Valve, 2.00 Inch, Poly
Ball Valve, 2.00 Inch, Full Port Flange
Ball Valve, 2.00 Sp Flange X 2.00 Male Quick Coupler
Butterfly Valve Assembly, 4.00, With Spring Return
Butterfly Valve, 4.00, Spring Return, Pneumatic
Butterfly Valve Assembly, 5.00, With Spring Return
Butterfly Valve, 5.00, Spring Return Pneumatic
Butterfly Valve Rework, 3.00
Butterfly Valve, 2.00
Butterfly Valve, 3.00, Spring Return, Pneumatic
Butterfly Valve, 5.00, 10 Position Lever
Butterfly Valve And Bracket Assembly, Main Shut-Off, 3.00
Valve, 2 Inch Male Npt X 2 Inch Male Adapter
Secondary Product Distribution
30 And 60 Inch Spacings
Bracket Assembly, Straight L, 2.50 , Right Hand
Bracket Assembly, Straight L, 2.50 , Left Hand
High Volume
Manifold Assembly, High Volume Boom, Left Hand
Pipe Assembly, Left Hand Tip, 2 In., Ss, C, Section
Pipe Assembly, Right Hand Tip, 2 In., Ss, C, Section
3 Inch
Manifold Assembly, High Volume Boom, Right Hand
Low Volume, Medium Volume
Installation
Reload Assembly, 3.00, 2400
Booms
Boom Assembly, 60 80 Foot
Boom Assembly, 80 Foot
Boom Tree Installation
Boom Tree Assembly, Center, 5.00 Slide
Boom Assembly, Center Section, Heavy Duty, Large
Boom Tree Assembly, Sub, 5.00 Slide
Large Boom
Large Tree
Bumper Installation, Tree Limit, 120 Foot
Spring Installation, Boom Level, Large Boom
Boom
Wear Pad Assembly, Passive, 120
Foam Marker
Foam Marker Assembly, Tank And Pumps
Foam Marker Mixing Chamber, Richway
Adapter, 3.00 Flange X 4.00 Hose Barb
Boom Hoist Cylinder Assembly
Boom Tilt Cylinder Assembly, Left Hand
Boom Tilt Cylinder Assembly, Right Hand
Boom Tilt Cylinder, With Autoboom, Left Hand
Norac
Boom Tilt Cylinder, With Autoboom, Right Hand
Product Containment
1800 2400 Liquid
1800 Gallon
2400 Gallon
1800 2400 Gallon
1800 Liquid
Tank Ball Valve
Low Volume, 2400
Scott, 2400 Gallon
High Volume
3 Inch
Installation
Booms
Large Boom
Large Tree
Boom
Foam Marker
Norac
