Challenger Terragator 1800 2400 GL C Liquid System (2019-2024) Part Book
Brand: Challenger
Type of Machine: Terragator
Type of Manual: Parts Book
Model: Challenger 1800 GL, 2400 GL C Liquid System Terragator
Serial Number: ..KXXX1001-..RXXX9999
Year of Manufacture: 2019-2024
Number of Pages: 485 Pages
Filters Guide - 1800_2400 Liquid
135 Gallon Tank Mounting Kit - 1800 Gallon
135 Gallon Tank Mounting Kit - 2400 Gallon
Holddown Installation, 3 Wheel, Liquid System
Holddown Installation, 4 Wheel, Liquid System
License Plate Holder
Product Tank - Mudguard
Product Tank - Step & Handle
Product Tank - 1800 Gallon
Product Tank - 2400 Gallon
Product Tank (Components) - 1800 Gallon
Tank Assembly, 2400 Gallon
Top Tank Assembly, 135 Gallon
Primary Product Distribution
Chemical Eductor - 1800 Liquid
Chemical Eductor - 2400 Gallon
Chemical Eductor - Poly, Cleanload
Clean Load Lid Kit, 16 Inch
Without Chemical Eductor - 1800 Gallon
Without Chemical Eductor - 2400 Gallon
Pump Off, Option - 1800 Gallon
Pump Off, Option - 2400 Gallon
Flowmeter Assembly, Raven, Magnetic, 3.00 Inch, Flanged
Flowmeter Assembly-Raven, 3.00 Flange
Mounting Ring Assembly, Cleanload
Product Plumbing Installation, 4x3, Low Volume - 1800 Gallon
Product Plumbing Installation, 5x3 Low Volume - 2400 Gallon
Product Plumbing Installation, 5x3, Mid Volume - 2400 Gallon
Product Plumbing Installation, 5x3 High Volume, 2400 Gallon
Pressure Plumbing - Scott, 2400 Gallon
Pressure Plumbing Installation - Low Volume, 2400
Pressure Plumbing Installation, 4.00 - Scott, 2400 Gallon
Suction Line - 5 Inch, 2400 Gallon
Suction Line - 5 X 3, 2400 Gallon
Product Pump Installation, 4 X 3 Plumbing
Product Pump Installation, 5 X 3, High Volume,
Product Pump Assembly, 4 X 3
Product Pump Assembly, 5 X 3
Product Pump, 4.00 X 3.00, Grooved
Centrifugal Pump, 5 X 3
Rear Manifold Assembly, 3x2
Rear Manifold Assembly, 4x3
Reload Valve Assembly, 5.00, 2400
Plumbing Assembly, Strainer, 2400 Gallon, 3.00
Plumbing Assembly, Strainer, 2400 Gallon, 4.00
Y Strainer, 4.00 Inch
Strainer, 3.00 Line, 316 Ss
Ball Valve, 2.00 Inch, Poly
Ball Valve, 2.00 Inch, Full Port Flange
Ball Valve, 2.00 Sp Flange X 2.00 Male Quick Coupler
Butterfly Valve Assembly, 2.00, Electrical, 7 Section
Butterfly Valve Assembly, 4.00, With Spring Return
Butterfly Valve Assembly, 5.00, With Spring Return
Butterfly Valve Rework, 3.00
Valve, 3.00 Inch, Butterfly With 10 Position Lever
Butterfly Valve, 2.00
Butterfly Valve, 5.00
Butterfly Valve, 3.00, Spring Return, Pneumatic
Butterfly Valve, 4.00, Spring Return, Pneumatic
Butterfly Valve, 5.00, Spring Return Pneumatic
Butterfly Valve, 5.00, 10 Position Lever
Butterfly Valve And Bracket Assembly, Main Shut-Off, 3.00
Valve, 2 Inch Male Npt X 2 Inch Male Adapter
Secondary Product Distribution
Plumbing Assembly, Wet, Hv - 30 And 60 Inch Spacings
Plumbing Assembly, Wet, Lv_Mv - 30 And 60 Inch Spacings
Bracket Assembly, Straight L, 2.50 , Right Hand
Bracket Assembly, Straight L, 2.50 , Left Hand
Endrow Plug - Installation
Hose Hanger - 3 Inch
Hose Hanger Assembly, Boom Tip - Low Volume, Medium Volume
Hose Hanger Assembly, Boom Tip - High Volume
Manifold Assembly, High Volume Boom, Left Hand
Manifold Assembly, High Volume Boom, Right Hand
Pipe Assembly, Left Hand Tip, 2 In., Ss, C, Section
Pipe Assembly, Right Hand Tip, 2 In., Ss, C, Section
Reload Assembly - 1800 Liquid
Reload Assembly, 3.00, 2400
Reload Assembly, 4.00 - 1800 Liquid
Reload Assembly, 4.00 - 2400 Gallon
Booms
Boom - 60_80 Foot
Boom - 80 Foot
Boom Tree Installation
Boom Tree Installation - New
Boom Tree Assembly, Center, 5.00 Slide
Boom Tree Assembly, Center, 5.00 Slide - New
Boom, Center Section, Heavy Duty, Large
Boom, Center Section, Heavy Duty, Large - Kit
Boom, Center Section, Heavy Duty, Large - New
Boom Tree Assembly, Sub, 5.00 Slide
Boom Tree Assembly, Sub, 5.00 Slide - Kit
Boom Tree Assembly, Sub, 5.00 Slide - New
Hose Installation, Grease - Large Boom
Grease Bank Hose Kit - Large Tree
Bumper Installation, Tree Limit, 120 Foot
Bush - Installation
Spring - Boom Level, Large Boom
Tie Strap Installation - Boom
Wear Pad Assembly, Passive, 120
Foam Marker
Foam Marker - Tank & Pump
Foam Marker Drop Hose Assembly - 1800 _ 2400 Gallon
Foam Marker Installation, Tank And Pumps - 1800 _ 2400 Gallon
Foam Marker Installation, Terragator Boom - 1800 _ 2400 Gallon
Plumbing Installation - Foam Marker Mixing Chamber, Richway
Adapter, 3.00 Flange X 4.00 Hose Barb
Boom Hoist Cylinder Assembly
Boom Swing Cylinder Assembly - Large Tree
Boom Tilt Cylinder
Boom Tip Fold Cylinder
Boom Tip Fold Cylinder - Auto
Hydraulic Block - Autoboom
Hydraulic Block - Standard
Hydraulic Block - Norac
Hydraulic Block - Norac, Passive
Hydraulic Boom Block Assembly - Autoboom
Hydraulic Boom Block Assembly - Standard
Hydraulic Boom Block Assembly - Norac, Passive
Hydraulic Cap Plug Installation - Low Volume
Hydraulic Cap Plug Installation - Mid_High Volume, 2400 Gallon
Product Tank - Hydraulic Charge Filter
Product Tank - Hydraulic Cooler
Hydraulic Cylinder Installation - 60_80
Hydraulic Cylinder Installation - 60_80 Auto
Hydraulic Cylinder Installation - Norac
Hydraulic Cylinder Installation - 60_80 Norac
Hydraulic Cylinder Installation - 60_80 Norac, Auto
Hydraulic Cylinder Installation, Norac - 80 Auto
Hydraulic Cylinder Installation - 80 Foot
Hydraulic Cylinder Installation - 80 Auto
Hydraulic Damper Cylinder Installation, Norac, Large Boom
Hydraulic Hose Installation - 60_80
Hydraulic Hose Installation - 80 Foot
Hydraulic Hose Installation, Rogator Boom Norac - Passive
Hydraulic Hose Installation, Terragator Boom Norac
Hydraulic Hose Installation, Terragator Boom Norac - 60_80
Hydraulic Pump - 1800 Gallon
Hydraulic Pump - 2400 Gallon
Hydraulic Pump Hose Installation, Mid And High Volume - 2400 Gallon
Product Tank - Hydraulic Lines
Product Tank - Hydraulic Pump
Hydraulic Pump - 45cc Ep Control
Piston Pump (Components) - 90cc
Product Tank - Hydraulic Tank
Valve Block (Components) - Autoboom, Raven
Amber Warning Flashing Lights
Wiring Harness - Autoboom
Electrical Box - Liquid System
Product Tank - Electrical Box
Electric Installation, Norac, Passive
Electric Installation, Norac, Passive - Uc7
Electrical Box - Cover
Wiring Harness - 1800 Gallon
Wiring Harness - 2400 Gallon
Wiring Harness - Boom
Product Tank - Wiring Harness
Electrical Installation, Liquid System, Raven - Node Installation
Wiring Harness - Norac
Wiring Harness - Raven
Work Lights - Reload
Lighting - Rotary Beacon
Taillight Installation - Fender
Taillight Installation, Liquid System
Work Lights - Clamp
Work Lights - #3
Work Lights - #3, Dual Beam
Work Lights - Center Frame
Work Lights - Dual Beam
Controller System
Bumper - Norac
Flowmeter Installation, Raven, 3 Inch, Add On
Flowmeter Installation, Magnetic - 3 Inch, 3x3
Flowmeter Installation, Magnetic - 3 Inch, 4x4
Flowmeter Plumbing Installation, Raven, 3.00 Inch
Sensor Installation, Norac, Boom
Sensor Installation - Raven
Roll Sensor Installation, Norac, Large Boom
Sensor Assembly, Center, Norac
Sensor Assembly, Center, Norac, Large Boom
Sensor Assembly, Center, Norac - Ultrasonic Sensor
Ultrasonic Sensor
Ultrasonic Sensor - Raven
Ultrasonic Sensor - Boom Sensor Arm Assembly
Air System
Boom Cleanout, Terragator, 60_80 Foot - Air System
Control Box - Air_Electrical
Air Valve Box, 7 Section, With End Row
Air System Installation, Quick Exhaust, Endrow
Air System Installation, Quick Exhaust - 7 Section
Air Plumbing Installation, Quick Stop, End Row, 60_80 Foot
Air Plumbing, Quick Stop, 30 Inch, 60_80 Feet
Air Plumbing, Quick Stop, 60 Inch, 60_80 Feet
Quick Exhaust Valve
Quick Stop Valve, 1.00npt X 0.75npt
Pressure Washer And Rinse System
Pressure Washer
Rinse Tank - 2400 Gallon
Safety & Warning - Product Tank
Camera Installation - Reverse - 120 Feet
Reversing Camera - Liquid System
Discharge Installation, Rear
End Row Nozzles - Field Accessories
Field Accessories, Pressure Washer - Water Lines
Chemical Eductor Kit - Poly, Cleanload
Chemical Eductor - Performance Improvement Kit
Dealer Resource Service Kit - Norac
Foam Marker - Field Accessories
Brand: Challenger
Booms
Boom - 60_80 Foot
Boom - 80 Foot
Bush - Installation
Foam Marker
Boom Tilt Cylinder
Work Lights - Clamp
Work Lights - #3
Controller System
Bumper - Norac
Ultrasonic Sensor
Air System
Quick Exhaust Valve
Pressure Washer
