Challenger Rotary Header Conditioner DKHC Parts Catalog 00727233
Brand: Challenger
Type of Machine: Hay Equipment, Rotary Header Conditioner
Model: Challenger DKHC Rotary Header Conditioner
Part Number: 00727233
Number of Pages: 205 Pages
Publication Information
Drives - Header Drive (12 Foot)
Drives - Header Drive-Left (15 Foot), (S.N. Hp05101 Thru Ht05246)
Drives - Header Drive-Right (15 Foot), (S.N. Hp05101 Thru Ht05246)
Drives - Header Drive-Left (15 Foot), (S.N. Ht05247 And Later)
Drives - Header Drive-Right (15 Foot), (S.N. Ht05247 And Later)
Drives - Gearbox Assembly (12 Foot), (700730831 Gearbox Assembly)
Drives - Gearbox Assembly (15 Foot), (700717706 Gearbox Assembly), (S.N. Hp05101 Thru Ht05246)
Drives - Housing Assembly, (700722693 Housing Assembly), (S.N. Hs05101 Thru Ht05246)
Drives - Gearbox Assembly (15 Foot), (700730832 Gearbox Assembly), (S.N. Ht05247 And Later)
Drives - Housing Assembly, (700730833 Housing Assembly), (S.N. Ht05247 And Later)
Drives - Header Drive Cage-Left
Drives - Header Drive Cage-Right
Drives - Hay Conditioner Drive (Left), (12 Foot)
Drives - Hay Conditioner Drive (Right), (12 Foot)
Drives - Hay Conditioner Drive (15 Foot), (Mechanical Tensioning)
Drives - Hay Conditioner Drive (15 Foot), (Hydraulic Tensioning), (S.N. Hp05101 Thru Hs05125)
Drives - Hay Conditioner Drive (15 Foot), (Hydraulic Tensioning), (S.N. Hs05126 And Later)
Drives - Gearcase Assembly (12 Foot)
Drives - Gearbox Assembly (15 Foot), (700149848 Gearbox Assembly)
Drives - Conditioner Drive U-Joint (Upper), (700719226 U-Joint Assembly), (12 Foot)
Drives - Conditioner Drive U-Joint (Lower), (700719402 U-Joint Assembly), (12 Foot)
Drives - U-Joint Assembly, (700713437 U-Joint Assembly), (15 Foot)
Drives - U-Joint Assembly, (700715721 U-Joint Assembly), (15 Foot)
Drives - U-Joint Assembly-Upper H C Drive (15 Ft), (700705407 U-Joint Assembly), (Mechanical Tensioning)
Drives - U-Joint Assembly-Upper H C Drive (15 Ft), (700722360 U-Joint Assembly), (Hydraulic Tensioning)
Drives - U-Joint Assembly-Timing (15 Foot), (700717388 U-Joint Assembly), (S.N. Hp05101 Thru Hs05125)
Drives - U-Joint Assembly-Timing (15 Foot), (700721265 U-Joint Assembly), (S.N. Hs05126 And Later)
Cutter Bar - Cutter Bar, Rock Guards And Skid Shoes, (12 Foot)
Cutter Bar - Cutter Bar, Rock Guards And Skid Shoes, (15 Foot)
Cutter Bar - Cutter Bar Assembly (12 Foot), (700713464 Cutterbar Assembly)
Cutter Bar - Cutter Bar Assembly (15 Foot), (700717697 Cutter Bar Assembly)
Cutter Bar - Cutter Disc-Left (12 Foot)
Cutter Bar - Cutter Disc-Right (12 Foot)
Cutter Bar - Cutter Disc-Left (15 Foot)
Cutter Bar - Cutter Disc-Right (15 Foot)
Cutter Bar - Spindle Assembly (Inner), (700719597 Spindle Assembly-Inner)
Cutter Bar - Spindle Assembly (Outer), (700719598 Spindle Assembly-Outer)
Cutter Bar - Cutter Disc And Knives (12 Foot)
Cutter Bar - Cutter Disc And Knives (15 Foot), (S.N. Hp05101 Thru Hr05100)
Cutter Bar - Cutter Disc And Knives (15 Foot), (S.N. Hr05101 And Later)
Cutter Bar - U-Joint Assembly (Cutter Disc), (700721264 U-Joint Assembly)
Cutter Bar - Cutter Oil Bottle, (700149964 Oil Bottle Assembly)
Electrical - Electrical Harness-Sensor, (12 Foot)
Electrical - Electrical Harness And Flashers, (15 Foot)
Electrical - Electrical Harness Service Parts
Hay Conditioner - Hay Conditioner Mounting (Left), (12 Foot)
Hay Conditioner - Hay Conditioner Mounting (Right), (12 Foot)
Hay Conditioner - Conditioner Roll Pivot Assembly (Left), (12 Foot)
Hay Conditioner - Conditioner Roll Pivot Assembly (Right), (12 Foot)
Hay Conditioner - Conditioner Tensioner
Hay Conditioner - Hay Conditioner-Left (15 Foot), (Mechanical Tensioning)
Hay Conditioner - Hay Conditioner-Right (15 Foot), (Mechanical Tensioning)
Hay Conditioner - Hay Conditioner Pivot-Left (15 Foot), (Mechanical Tensioning)
Hay Conditioner - Hay Conditioner Pivot-Right (15 Foot), (Mechanical Tensioning)
Hay Conditioner - Hay Conditioner-Left, (S.N. Hp05101 Thru Hs05523), (15 Foot)
Hay Conditioner - Hay Conditioner-Right, (S.N. Hp05101 Thru Hs05523), (15 Foot)
Hay Conditioner - Hay Conditioner-Left, (S.N. Hs05524 And Later), (15 Foot)
Hay Conditioner - Hay Conditioner-Right, (S.N. Hs05524 And Later), (15 Foot)
Frame And Shields - Header Frame (12 Foot)
Frame And Shields - Header Frame, Cradle And Lift Arms, (15 Foot)
Frame And Shields - Header Frame-Left And Right (12 Foot)
Frame And Shields - Header Frame-Left And Right (15 Foot), (Mechanical Tensioning)
Frame And Shields - Header Frame-Left And Right (15 Foot), (Hydraulic Tensioning)
Frame And Shields - Swathboard Mounting (12 Foot)
Frame And Shields - Swathboard And Mounting (15 Foot), (Mechanical Tensioning)
Frame And Shields - Swathboard Mounting (15 Foot), (Hydraulic Tensioning)
Frame And Shields - Shields-Cutterbar, Left, (12 Foot)
Frame And Shields - Shields-Cutterbar, Right, (12 Foot)
Frame And Shields - Shields-Cutterbar, Left, (15 Foot)
Frame And Shields - Shields-Cutterbar, Right, (15 Foot)
Frame And Shields - Curtains (12 Foot)
Frame And Shields - Curtains (15 Foot)
Frame And Shields - Forming Shields, (S.N. Hp05101 Thru Hs05523)
Frame And Shields - Forming Shields, (S.N. Hs05524 And Later)
Frame And Shields - Shields-Center Safety, (12 Foot)
Frame And Shields - Shields-Left Safety, (12 Foot)
Frame And Shields - Shields-Right Safety, (12 Foot)
Frame And Shields - Shields-Center Safety, (15 Foot)
Frame And Shields - Shields-Left, Safety (15 Foot), (Mechanical Tensioning)
Frame And Shields - Shields-Right, Safety (15 Foot), (Mechanical Tensioning)
Frame And Shields - Shields-Left, Safety (15 Foot), (Hydraulic Tensioning)
Frame And Shields - Shields-Right, Safety (15 Foot), (Hydraulic Tensioning)
Frame And Shields - Skid Shoe-Left And Right, (15 Foot)
Hydraulics - Hydraulic Drive (12 Foot)
Hydraulics - Hydraulic Drive (15 Foot)
Hydraulics - Hydraulic Motor Assembly, (700727806 Hydraulic Motor Assembly)
Hydraulics - Hydraulic Tensioning, (15 Foot)
Hydraulics - Hydraulic Tensioning Valve, (15 Foot)
Decal And Kits - Decals (12 Foot)
Decal And Kits - Decals (15 Foot)
Decal And Kits - High Skid Shoe Kit, (Bk11197 High Skid Shoe Kit)
Decal And Kits - Gauge Roller Kit, (Bk11136 Gauge Roller Kit)
Decal And Kits - Swathboard Actuator Kit, (Bk11097 Swathboard Actuator Kit)
Decal And Kits - Swathboard Actuator Kit, (Continued)
Decal And Kits - Door Protector Kit (12 Foot), (Bk11030 Door Protector Kit)
Decal And Kits - Door Protector Kit (15 Foot), (Bk11077 Door Protector Kit)
Decal And Kits - Decal Kit (No Text), (700731624 Decal Kit-No Text)
Decal And Kits - Decal Kit (Spanish), (700730413 Decal Kit-Spanish)
Decal And Kits - Decal Kit (French), (700730414 Decal Kit-French)
Recommended Dealer Stock - Recommended Dealer Stock
Brand: Challenger
